View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EJ8 Sedan rear bumper compatiblity
- mini me question
- need help on replacing glass in passenger window
- My buddy took out all harnesses form his SI and gave me to sell But I don't know which is floor harn
- shaved 1/4 windows on a eg
- Is this engine vtec?
- EG rack in Ek
- 2000 Civic engine problem
- mini me HELP! d15b8 / Z6 ? would it work?
- electrical prob.
- help ID this tranny(seArch no luck)
- Front End Conversion...
- Jdm b16 95 del sol distributor
- Can a Eg civic hatch pull a small Trailer if i get a h22 swap?
- My car is possessed, never know if its going to start or not.
- Clicking from engine....?
- battery problems
- Install new clutch, car wont move! HELP Please!
- turbo charge a jdm b16a2 motor
- B16 wont idle less then 1,500
- Sensors???
- what should i do first
- Car keeps dying cause fuse blows.
- A/C, and P/S Removal
- Eg wiper blades faded...
- speed problem
- new to the eg world, need all the info i can get
- AC !!
- Rear Control Arm Problem
- Replacement Bumper for 2000 Civic Si
- Tanabe USA looking for new contacts
- boost b16 or ls vtec
- Timing Belt
- What are these coolant passages for?
- 0bd2 ls in a 95 ex eg questions
- 0420 code, what cat?
- rear sway bar with omnipower lca
- Adjustable front endlinks?
- what tophats to buy?
- need help folding mirrors
- sol stock muffler = crappola
- what would be good asking price?
- help with ac belt
- LS Motor Swap..I searched
- Civic HatchBack Engine swap Help
- MUGEN or SPOON????? which do you like and WHY??
- "ATTENTION" DOES ANYONE KNOW A TRACK??? CIRCUIT STYLE FREE RIDE in SO CAL???
- clutch
- obd1 ecu swap and CEL
- Question for people using VX rims
- Some questions about my Eg yO!
- looking for hydro y21 b16 tranny with LSD
- Is this EX too expensive?
- Radiator question
- Rear Tranny mount - quick help
- need help please ,1st timer on H-T !!
- can some one please help!!!!!!!!!!
- cleaning up the engine bay - what to remove what to leave alone
- mounting liscense plate to the side
- Anyone know anything about these radiator cooling plates?
- Turbotime gets his TURBOtime
- what are you words on replacing the harmonic damper unorthodoxed racing pully
- Improving gas mileage by the computer route?
- Hood cable compatibility
- turbo on stocj gsr engine
- HELP!!!! bolt snapped
- help me find cheap sohc vtec engine please
- halogens for 99 em1
- what exhaust
- water pump and timing belt
- A/F gauge and o2 sensor
- Quick question
- 99-00 Civic Si B16a2 Header question!
- 99 EK with GSR swap - car DIES / BOGS and then comes back ?
- I heard something that seems to not make sense
- Performance for my D16Z6
- 99-00 SI's W/O front lips from the factory?
- ***im stumped on this swap im doing need help no spark***
- question on VAFCs
- rust repair for quarter panels.
- del sol exhaust
- A few head questions.
- My D15B swap - Thank you Hmotorsonline
- Type R or GSR
- Doing Auto- Stick swap... Question... (Searched)
- How many miles until a tune-up is to be done?
- dual canister exhaust
- need some advice on a b series tranny
- Civic EK shocks on a Dc Teg? quick answer needed!
- Del Sol Spoiler
- ECU CODE 90 P1456
- toda stroke kit
- Ek hatch, 3000gt, or volks GTI vr-6 ?
- Apexi World Sport
- Question about O2 sensor when going from obd2->obd1
- Does Vtec work if your MAP sensor is bad?
- which intake?
- 99 front conversion on a EG
- D15B7 rod bearings
- Will it fit? Lower tie bars
- p28 won't idle.
- 3-stage vtec jdm d15b.....who's heard of them?
- 92-95 civic head lights (how do u open them up?)
- Question about zeal super functions
- integra springs/exhaust on 99-00 si?
- fully built SOHC civics thoughts of this setup?
- Big "KONI's" for big engine
- hatch wiper plug?
- New, need some help!
- fuel pump relay pulsating sound after swap
- VTEC-E with a p06 ecu, help
- y7/y8 mini-me question (knock sensor and iacv)
- 96 Y8 Manifold Swap onto 99 Y7, Idles Rough with IACV Code 14
- are iacv dif for obd1 and obd2? cant figure out problem after auto to tranny manifold swap
- help taking out oem tape deck!!
- Civic EX door stuck please help
- Bad experience w/pacesetter...
- what years are obd2a & obd2b?
- timing belt skipped some teeth
- SHIFT LINKAGE PROBLEM ... MAJOR HELP NEEDED.
- n e 1 know how to wire obd2 engine harness to obd1?
- What Plug is this? (pics)
- question for you Hybrid Ls-JDM B16 tranny in your HB.
- blown headgasket I REALLY NEED SOME HELP
- del sol
- Hey yo does anyone think the Mini Me swap is a good idea? Why so/not?
- Bad lighting
- Test pipe Question (previously searched)
- ex/si block
- vtec killers
- Good website to buy used JDM wheels?
- 97 del sol, OBD I or II
- 92-95 EX Doors
- C's shift plate outline for all you DIY thanks to yellow blur
- Frank motor
- rough idle
- motor swap
- Headlights
- need help
- vtech killers
- URGENT: TYC Spoon-Style mirrors.
- front end
- obd converter.
- jdm D16A sohc vtec
- Type R suspension
- need a little help with finish wiring my o2 sensor up
- how many psi will stock sleeves do?
- Does this car sound like a good deal?
- COOLING FAN PROBLEMS.
- will the sparco harnest bar work on a del sol
- b16 with gsr tranny
- Difference's in P28's.
- Vacuum Line Connections????
- Engine VIN numbers?
- Who has the Home Depot front lip?
- ECM
- Diff between Apexi N1 and N1 "style"
- Code 21 !? obd1 jdm vtec in my EF VTEC spool valve (I Tried in the EF forum...)
- Need Help. Newb Axle question
- Engine smell...
- Speed limiter on '97 Civic HX????
- H20 part number help
- Grinding Sound
- Omni Power full coilover system and camber kit?????
- what internals would you use?
- Bride seat material?
- JDM SiR bumper
- My compression test results, Comments
- Reverse Whine
- im getting a p30 ecu chipped out..need help..
- Are The JDM/USDM 99-00 Civic Fog Light Harness(s) different?
- have you ordered from??
- Map Sensor interchangeable?
- AC braket mount, Can it be cut? Mani problems
- rear disc conversion 91 integra to a 96 coupe.. will it work..
- bolts on front bumper civic 97
- DX Ecu with HX motor...ANYTHING different (customer car)
- si top end
- 95 integra LOWER starter bolt!!....needed
- Having prob with H22A swap in EK civic
- d16y8 headbolts part number?
- 2000 civic ex swap
- Off-set Question on RIms
- OEM Timing belt...
- theaves are the worst..
- Looking for something like a ls turbo in a hatch
- CO2 sensor
- EK City Light Question??????
- Please read this thread.
- Sparco Racing Fighter Seat
- Fuel Filter Q's from EG DX & EX
- Impossible?
- Emergency!!! how to get tire off??
- Stiff Rear doors on '99 EX sedan?
- Tempreture gauge not working?
- Recaro vs. Tenzo Seats
- Would these fogs be hard to install on my Civic?
- f series into a hatch
- Review: Denfi knock-off gauges from ebay
- buddy club exhaust
- URGENT cam installation help
- Zex Flywheel...
- RHD Conversion
- 92 hatch overheating
- Need help finding exhaust gasket!!!
- stock 99-00 si airbox for a b18c1?
- ***Please post your ride***
- Speedometer inaccuracy
- Clicking noise from tranny... throw out bearing?
- help with cusco 6 point roll cage in 99 si
- can any body help
- CARB LEGAL HEADERS?? CAULIFONIA=)
- EJ1 Weight Reduction Info
- Where to route vac and coolant lines?
- Im a newn need help
- Da integra seats into an eg civic?
- can i use stock headgasket for header?
- Cost to replace both front shocks?
- How much is this car worth?
- Do I have a possible throttle problem?
- oem interior parts????????
- 2000 Auto Civic EX - putting in a manual 1997 b18c motor, what ecu jdm or usdm.
- D16y8...Interference or not
- Weird electrical hum comming from IACV
- Rebuilding the D16Z6
- Help Installed Gauge covers Now car overheats..?
- EM1 SCREEN SAVER shots "lets see em"
- bc3+ cam settings
- tail light
- gas door
- Looking for a Honda Parts store, site, person, something....
- I'm planning a swap...
- conversion dramas
- My A/M B16A2 Sol Build...
- *****Problem with B18C1*****
- for the same price, Exedy flywheel or ACT Prolite?
- B16A Vs B16B CrankShaft ??
- Help: Where's a good shop to get a windshield replaced in S.F.?
- fuel pump isn't turning on
- IACV interchangable?
- problem with brakes
- CF HOOD ADJUSTING...
- b16a Oil Temp sensor
- Slave Cylinder braided line
- Helpe me start my car.
- radio bezel, bouncing idle, 94 civic coupe
- riced out powerwheel? wtf
- Car stalls after filling up with gas
- how to peel up the carpet from my DX coupe? T_T
- master cylinder? air in lines?
