View Full Version : Honda Civic / Del Sol (1992 - 2000)
- lower control arms
- Tein springs, subs or SRI
- just a header question for k20a2 in ek
- Guage Cluster ???
- Remove the rear seats in my '92 DX hatch
- Optional Console Question...
- Clutch opinons
- aftermarket springs
- 94-97 teg master cyclinder and booster is it
- how-to fix ripped mounting holes
- question about the o2 sensor
- CX head swap
- Question about a swap!
- pic request: lets see some of the baddest 4 door civic around
- exhaust too loud
- B16A2 Del Sol
- Brake Upgrade Question
- Proud new member!!
- Is it possible my battery is to dead to crank my car.....
- I think t/b got stuck open last night, wanna see what you guys think??
- Side Mirror Question.
- d16z6 motor revs up to about 4000 rpm and motor gets extremely loud
- 97 ex coupe w/ 99 si rear discs....which lines?
- Aftermarket Steering Wheel Install ?
- Will 94 eclipes coilovers work for a 94 civic?
- Can you bore a 1.6 to a 1.8?
- Seat Question
- Changing Upper Radiator Hose..
- Tranny swap
- Anybody have expierience with H&R coilovers? cant raise my car....
- EBay replica visions?
- What msd ignition is right for me?
- What Or where can i find The Hatch part ? of the hatch back?
- Honda OIL or Castrol ???
- b16 sleeved 85mm bore + type r crank and rods = high reving 2L engine?
- Dumb question maybe....please help
- Speakers dont fit in hatch doors....PLEASE HELP......
- lowering springs install?
- Clutch Change searched already and no avail
- P&P Head and portmatch #s???
- Install a D16A9 - ZC Head on D16Y8 Block
- HELP .....tranny...gear getting stuck ..will not go into any gear's while running
- diy ctr headlights?
- Problem after cold starts
- result of bad/cheap gas?
- Si Spoiler
- Will the Rear R Seat from a JDM Type R fit In an EG?
- customize s2000 headlight into civic hatch..wat do i need?
- Lowering issue
- Noob Uberdata question
- integra stolen in new york
- READ INSIDE
- my RPM start at 3000 eventime i start my car..can some1 help??
- very dim clock... whats the problem?
- thermostat maybe? overheating, heat not working.
- air flow per minute
- Magnaflow Universial Oval Muffler? for 00 Civic Coupe?
- cluster question
- Tein or Tokico
- ANYONE KNOW THE SPECS ON JDM B20?!?!
- Body work?
- Do you got the Spirit?
- vtec head question
- since im a newb.. engine help
- Where do I find.....?
- F'in crank pulley will not come off!
- GSC's ls/vtec machine @ Savannah
- Best Motoring - Civic Type R videos
- Newbie here! Is it worth modifying an engine with 156K miles?
- push start button
- D15b sputters right before vtec hits... HELP????
- EK stock airbox rocks!!!
- Ground Control Question, Help!
- Need Exhaust help!
- Sensors on the B16A2 (SI) intake manifold
- CTR transmission specs?
- check engine light question?
- car wont start....Very cold start
- Some simple questions
- Going rate for a 98 civic si...
- Code 54
- Whats the difference between the EG and the EH?
- jdm lighing question
- Swapping Front Knuckles
- I THINK I BROKE MY TRANNY NEED ADVISE
- looking to buy a real spoon front lip any got 4 sale
- TURBO 1.5L or LS SWAP?????????
- Ex/Si Door Conversion
- Blue and Gold must see??
- Questions about my setup??
- Need help with visors...not a noob question.
- Nitrous shot
- shaking
- What to do to make JDM EG guage cluster shine brighter?
- Tranny ?uestion
- Compression test results. whats the verdict
- Clutch Pedal Problem
- Questions regarding civic regular maintenance
- Merry Christmas From The Staff
- b18b engine with auto tranny, how easy is it to make manual
- Engine support
- Sensor on b-18c1 just under the vtec solenoid
- new car or fix what i have right now???
- Oversize oil filters
- want a couple of u guys opinion...
- 95 check engine light ???.
- think i spun a bearing.... can someone please help
- SEARCHED everywhere, how do i REMOVE the stock HEADUNIT on the 92-95 Civic's????PLEASE HELP!
- Offsets for 99-00 Si Rims?
- DIY: Free* License Plate Relocation
- stock intake resonator
- rear camber
- VAFC HELP
- Suspension questions... searched
- jdm/mugen parts
- pic request -- del sol at night
- Honda-techs project car
- Spark Plug Gap?
- WINGS WEST BODY KITS!!!!!!!!!
- 93 Civic AT Speed sensor wire colors
- GSR Block W/ LS head *UPDATE*
- Removing EG hatch spoiler
- Friend's 92 hatch with b18c in it is throwing code 31....
- Need Advice, total newb here :)
- quick question dealing with leaking oil!
- Del Sol Rear Window not Working???????????
- d16 max hp
- need some advice on motor swap
- Speed sensor?????Help
- VAFC causing a code 3 (Map Sensor)?
- 99 civic SI Info:?
- Honda Civic LX 97 automatic. How to add keyless entry option ? and engine autostart by key
- Power Window Problem :o
- HELP QUICK! Bumper welding question...
- 4x144.3 help!?
- ek rear strut trunk cutting help ?
- how can i change the driver side axle boot myself?
- *EM1 Crashed NEED an HT Estimate!!
- Isolated squealing noise, any solutions?
- K20 swap in 94vtec del sol ? wondering
- Need Help fast Bought Car today with loose axle.
- RED hatchback formerly for sale
- Taillights
- bad stock tach??
- Tire Rub issue
- Removing scratches and chips in fog lights?
- where are omni power coil overs from
- FUeL SAVER?
- auto to manual mount??????
- h22 swap
- LED's need a resistor
- DOES ANYONE MAKE A COVER PANEL FOR A CRX
- To all you guys running aftermarket steering wheel in EK
- all civics rigged for a tach?
- 2.5 exhaust question
- Spoon N1????
- lights flickering while driving?
- Curious about PDL Control Unit Interchangeability
- fuel cell on a daily driver?
- zc motor
- AutoGage Tach wires
- i gotta couple questions anyone feel free to coment
- Seafoam helped tranny?
- rear strut bar
- anyone frimilar with everything behind the dash in an EG (eh) Glovebox question.
- A/F Ratio Question...
- I was going to buy the jdm half red half clear eg tail lights, but was told theres a getto way to ma
- Weird rattle from engine under load
- vtec wiring problem... d6 pin already in use???
- Exhaust questions??
- Question about sunroofs? Weight?
- Broken D16 Engine Mount
- I need a side view pic of an EG steering column and ignition switch.
- b16 sleeved 84mm... is it possible to stroke it to 2L???
- cvt transmission in my hx mkaes a wierd noise as i start off...
- 94 CX Fuel Guage Problem.
- car lags at 3k rpm? VW
- poorly installed timing belt question
- Strut Bar
- tranny rebuild
- LS swap questions
- Does a resistor box have anything to do with getting spark?
- **HELP** tail light prob!! EG tech pro's plz help!
- NEED SOME HELP W/ MY SWAP??? Clucth Prob....
- Rear Lip?
- '92 civic $200
- What cables to put on a 00 Civic ?
- Christmas Tree
- CAI Install on HX (HELP PLEASE!!)
- Power Door Lock Control Unit???
- RADIATOR?
- Compression Test: Cold or Warm
- Removing Rear Bumper (EK)
- Squeekin like a mofo
- big problem!
- legend brakes on a b16 delsol
- Piston ring ?.
- removing center console on del sol
- question. not related to cars.
- Sparco harness bar $199
- Kyb AGX shocks adjusting question
- What's a CX flywheel weigh?
- 94-01 Integra Mirrors on 96+ Civics?
- Brakes lose pressure when climates hot!!
- Walbro Fuel Pump Wire Gage???
- looking for a traction bar
- '02 civic tranny on a d16y8
- Reinstalled dash now car won't crank....wtf
- EG OR DC-5?
- More O2 Sensor info ?
- HX Swap into EX
- wiring my vtec
- Tein SS coilover question
- GC spring rates???
- What jdm parts fit 2dr coupes.
- Oil Light stays on for about 2 seconds
- no vtec at all?!
- hit a curb
- Tech pic
- BOMZ Silencer - where to find?
- i need help BADLY! some1 help me! its about DEL_SOL! AUTO TOO STICK
- How to Install JDM Side Markers onto a 92-95 Hatch
- HELP FAST!!!!!! Mini me swpa gone bad
- how rare is a 5spd 4 door?
- Bit of the Newb question
- Will ITR 96 brake direct bolt on to 95 Civic Coupe DX?
- quick dumb question re: d15b
- question about oil cap
- which ecu gets better mpg p06 or p28?
- New drag setup for my civic coupe
- clutch replacement experiences...
- Let's add a "Car Won't Start" guide to archives (I'll start)
- I have an oxygen sensor question...
- valves from different heads
- 00si ITR front 5 lug conv.
- Coolant flush, drain bolt on a sohc?
- zc need help
- injectors
- 99-00 Si gauge cluster 3 or 4 plugs
- Question about axles and a d15b
- d16z6 head on d16y8 block
- Trunsignle
- zc swap need help
- k20a delsol
- gsr dual bend shifter on eg
- rebuilding manual tranny... is it worth it?
- 92-95 EG, GATHERS REAR SPEAKERS $150, $180 SHIPPED
- where did you buy your wilwood brake kits for under 710
- ELD electric load detector HELP
- Where does the Evap hose go?
