View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Motor mount help
- how much should a bare gsr head go for??
- Removin that damn O2 sensor
- JDM sirII nto a 92-95 hatch
- water spots, help!
- Do I have clutch problems?
- Differential housing
- Coupe front end
- Engine Swap Advice:
- lowering car question.
- Give me suggestions on where to look.....clank heard when going over speed bumps.
- Help...stripped wheel stud....how do I change it?
- Question for anyone who's ever owned a DynoMax kit.
- swapped from cx to dx
- I don't know how up to date this is but look....
- Lower control arm/steering knuckle balljoint
- V-afc
- Benen Suspension Products
- Trade Parts ??
- Running too rich
- help me please!!! how do i take this off???
- Will an Icebox fit in a 92 civic CX with a B16a and ITR throttle body?
- Can I ground my Knock Sensor with this method?
- lowering springs question
- Apexi world sport on DX?
- Where can I buy rebuilt stock calipers?
- i need del sol rails
- What is wrong with my sol???
- Tornactive.com reliable?
- 99-00 Exhaust Fitment Compatability HELP!!! EXPERT ADVICE NEEDED!!!
- problems with car
- GReddy Evo??
- SOHC = 450 lbs??
- 99 EX check engine light
- New pics of a work in progress...
- Hatchback muffler, EK same as EG?
- EK Amber Sidemarkers...
- air dam
- Camber kits??
- Hub cap retaining washers
- Si Brake swap
- Saturday project pics
- 91 rex Si seats in EG?
- Mista Bone
- B18C5 in Del Sol?
- blue box
- Cwest coilovers?
- has anyone bought from delcamino
- Thought I'd share the Civics for sale in my area.
- please give me a site that sells high performance wheels.....Evo's are cool
- d16y8 distributor in a 5g civic
- Honda Automatics, do they come with Tranny coolers?
- HELP: Mugen or Spoon??
- exhaust piping diameter?pls help
- should i change springs?
- isurance
- Possible Dyno Day at Le-Toy Motorsport in Bakersfied, CA
- ok screw sohc what will it take to hit 13's street tires n/a...
- is it ok not to have a MUFFLER on my 92 civic hatch
- Anbody know where to find this lip for under 200$?
- Question about a 99 Civic SI
- GSR Raditor in a Civic?
- Anyone know where I can find a cheap battery hold down for a CRX?
- Anyone seen this done?
- Help Installing a ProForm Tachometer
- did all ex civics come with power steering?
- new tranny!!!!!!
- hp?
- Twin-cam head on D16 block?
- Brake conversion question
- OEM or Aftermarket?
- H22a civic having problem starting it........
- D16 timing ?
- motor makes clicking noise but wont start....
- brakes lights not working on my 93 civic coupe (did search no luck)
- Does CEL code 65 affect performance
- Problem...
- Right hand drive conversion?
- Anybody know much about the new K series engines?
- MistaBone or SiFreak..you here right now?
- Help me estimate my drop
- Roll Cage Help,
- Someone clear this up for me on IM swap...
- WANTED - weight of gutted SI hatchback (EH)
- Best Turbo money can buy? Drag, Gready, HKS? What?
- GaugeCluster>>??
- What radiator do I use in a hybrid swap?
- 2 questions
- EG Hatch Interior Suppliers
- Offset
- Which ac bracket for b16 in ek?
- How much do stock front fenders weigh? I want fiber images c/f front fenders...
- Just put in my neuspeed shortshifter
- What tool for spark plug removal?
- have a problem....
- SKUNK2 or Ground Control
- advice on intakes
- skunk2 camber kit
- A/C problems - won't recharge
- Frage zu MSD Ignition 6AL.
- OT: Testing the waters, possibly for sale 98 Civic Coupe
- b20 from late model crv/800.00, good price?
- haed replacement
- ECU question
- b20/vtec or h22 for EK, need more pwr&tqr?
- 18 inch motegi mr7's on a 98 hatchback?
- SPOON drain Plugsssssss ** which is which **
- Anybody on here have a H22a daily driver?
- can u put an exhaust made for a 99 HB to fit a 99 coupe? what modifications need to be done?
- Had my engine swapped but.....
- LSD???
- Hey..what ever happen to..
- what is the best AFC VTEC setting on JDM B16A II with with I/H/E
- Hx wheels on 92-95 si?
- What is needed to fit a EX swaybar on my DX Hatch?
- shave moldings or not to shave
- What's the stock timing on a '92 VX supposed to be?
- d16y8 and tranny in a 92 hatch
- 5th gen Coupe/Hatch doors
- B16a2 Compression Ratio?
- Speaker box
- oK. EG amber cluster..????
- how much to pay for 99-00 si
- how big are the tips on a thermal research exhaust?
- Tranny Help>>>
- what size socket do i need to buy for axle? help!
- A few JRSC Questions
- Looking for BLACK lug Nuts for my 98 Civic Coupe!
- Quick smog/cat question dealing with a stock cx hb
- Timing belt loose?!?
- Best HID kits?
- why B over H series?
- rota pics
- crashed a vdub meet today
- D16Y vs. D16Z questions...
- Need help engine/electrical problem
- Confused about something. . . .
- 1999 Civic SI - Jackson Racing Supercharger vs. Greddy Turbo Kit
- drag II got a question for ya!
- Wher can i get a hb 92 cx???
- Can anyone confirm this?
- Buddyclub SpecI exhaust....
- just dont makes any sense...
- Do Eibach spring for 1992 hatchback fits on 1998 hatchback???
- 5zigen fireball rear section exhaust
- I think im in LOVE (B18C1)
- carbon fiber tailgate
- 96+ HELP PLEASE (hatch)
- Stupid question: does the 95 Civic EX Coupe have ABS or not?
- Question about flywheels.....anybody have experience with
- !HELP! cigarette lighter stop my engine & now won't start
- camshaft or aluminum flywheel?
- *** Place to Put * CUSCO oil CATch CAN ** on EG BODY
- is this JDM???ANSWER PLS!!
- Dropping vtec via V-AFC on p72 mugen chipped ecu ?
- GS-R Gauge Cluster?
- ? For those with B20's in there EG
- 'Best' aftermarket headers, turbo and intake manifold?
- Hi I'm new Here (pics of my ride inside)
- Test pipe on 2000 Si
- 99-00 front end on a 96?
- Whats the best Over-All SHort Shifter for 98 Honda Civic Coupe?
- Rich/Lean & Fuel PSI Meters
- B16 information needed
- painting my valve cover...have a question
- HX wheels!? Good Solution or bootleg?
- Flushing coolant
- pre built crvtec
- speedo fix?
- Need help with my meters!!!
- Anyone know how much i can sell a Black widow mid wing for a 96-00 Civic HB??
- differences between '95 and '96 civic
- need answers for cx valve reliefs!
- Engine Swap
- Rear hatch noise
- Heat shield problem
- What magazine do you like best? Super Street, Honda Tuning...
- cel code 36
- Goin to canada soon!
- Tien S.tech springs
- I have an extremely n00b question...
- wiring harness?
- What's the difference between CX DX and VX?
- is srr stuff good or bad...very important...
- whats the difference between skunk2 manifold and the itr manifold?(did search no luck)
- Nagging Problem
- disc brake conversion
- Skunk2 camber kit
- weight of sunroof assembly on a 93 SI hatchback
- Brake upgrades
- help needed please
- Question about some mods
- wiring harness for jdm motor swap, which one?!?
- 5th gen prelude headlight swap on Del Sol
- ECU questions
- how much its a 96 ek shell worth??
- Armrest in an EK hatch?
- question for 96-98 EK's with 99-00 tail lights.
- Distributor help
- Integra Cluster in 98 Civic
- CTR motor or ITR
- What wiring
- S2000 start switch in a 93 civic
- Any diff between the USDM and JDM D16Y8?
- integra front sway on ek?
- anyone know the phone number for mb fiberglass products?
- Need HELP, anyone with a 96-98 EX Manual Civic in the Bay Area, PLEASE READ!!
- Valve Cover doesn't say VTEC??
- trip to HK part 2
- integra seats in civic
- ?how do you post pictures?
- pics from my trip to HK
- Pyramid of Speed
- CTR/ITR Mirrors?
- Congrats to Halo on the article in HondaTuning
- What spring rates would be appropriate?
- aftermarket steering wheel????
- srr rear lca for ek
- what is long block??what is short block?
- *HELP* Will a Greddy Evolution Cat-back for 92-95 coupes fit the hatchback?
- Removing the valve cover bolts
- i just need a YES or a NO answer
- Fun for ALL
- A/C on 93 Hatch--noisy compressor help!
- Shocks And Springs
- Clutch problem!!!!
- Part # for CTR carpet?
- Rear Disk Conversion
- Engine Swap
- C-West Kit
- Where to get CTR front lip and OEM 96-98 rear lip?
- who here runs ls swaps in their car?
- I need some infos on suspension
- del sol guys...trick for stock fog lights??
- Please post pics of any eg with HX wheels!! I need to see how much fender space there is!!!
- I'm already bored...
- 4000 mile round trip driving with my VX....
- ek sway bar help
- seat rails?
- CEL code #41
- Selling my cx to get a Harley Davidson
- JDM B16A2 in 93 Civic DX. ECU Wire problem PLEASE READ
- Civic DX HX LX and EX? Vtec?
- shes almost back together*pic*
- Tires Tires Tires....Battle>>>Azenis VS. T1 Proxes Sz.....14 INCH
- How much do i sell for?
- Broken Wheel Stud
- what should i paint?
- Fixing Rims
- Which One Is Which?
