View Full Version : Honda Civic / Del Sol (1992 - 2000)
- no power
- Wheel Rub part two
- b18c1 into 1992 civic VX exhaust question
- Gas filler in the door jam
- Supercharged B16A del sol bogging at 1/2 throttle
- anyone had check engine code p0420......
- Are these rear wheel bearings/hubs the same?
- REQUEST: 95 Civic headlight and corner light wiring diagrams
- civic for sale
- how to plug the hole on the firewall after cruise control cable removed
- Apexi N1 catback Question
- 99 si lip on EG
- vtec stutters
- looking 4 link to online service manual for 97 honda civic
- Weird noise coming from the passenger side of the car
- QUICK!!! REAR BREAK PAD INSTALL calipers wont compress
- difference between EG and EK rear subframe?
- best d series tranny?
- looking for exhast manifold for 97 civic......1.6 no vtech
- D15B 14b
- D15b Turbo 10psi
- EG HATCHBACK
- ls swap into a ek
- Integra MC / BB swap into 92 Civic Hatch problems
- another question.
- First Post
- tranny help!!!!!!!!
- 2 cars... lots of questions
- OBD2
- stuck gas pedal 94 del sol.
- rear lip or no rear lip....tht is the ?
- Post up pics of midori hatches
- d16z6 distributor problems
- Where to find...
- What is the stock pounds of pressure on the radiator cap? (95 EG)
- Complete Engine Swap Guide???
- just a quick muff question
- What OEM steering wheels will fit my Civic?
- 91 dx 5spd tranny into 94 auto dx
- clutch pedal problems
- cant start engine after auto - manual coversion
- new muffler? yay or nay
- Quarter Window Glue?????????????????
- Rear Lip for a EK Coupe...
- Clutch making funny noise
- quick question
- BUSTED!...Motor Mount and P.S.
- I've been researching my next car purchase...
- emergency brake indicator(on dash)
- DOES ANYBODY KNOW THE HONDA-TECH SONG?
- that stuff that you wrap around intake?
- Exterior Window Mouldings..Where Can I Buy
- Need help my girlfriends friend put dirty oil in her gastank!!!!
- swapped 98engine in to 99
- noob to ebay
- headlight disassembly
- ebay carbon fiber air box
- Weird electrical problem on 93 Civic...
- Brakes peddle goes down to much
- 99-00 big brake kit on EG
- Transmission bearings, I need some where can I find them?
- changing 96 civic coupe rear brake drums to disc??
- low profile-Jack
- perhaps some help?
- Outer tie rod will it cause a clicking when braking?
- are 99-00 Si & Ex wings the same?
- Which Autozone blanks should I buy?
- Do I need to change my oil pump for my eg GSR swap?
- b4 and after pic of my civic got stolen
- bad alternator = no start
- removing the immobilizer?
- p28 spoon chip/ebay ....anygood?
- msd ignition
- Laggy 2nd and 3rd gear after startup
- Looking to add A/C to B16A Need opinions.
- 3rd to 2nd gear mis shift..
- online manual..?
- Does anyone know where i can get a cat back exhaust for 95 ex 4dr???????
- hello everyone what should i do
- broke a screw on my valve cover...
- Cost of installing sidemarkers?
- Darn rear discs.
- Motor mount question
- tranaxle rebuilt
- transmission differances...
- Intake Manifold question
- What to do while interior is out?
- B18C5.... slammed... sick of going through axles..
- B16 OIL BURN QUESTION
- clutch worse in heat
- INTAKE D16Y7
- New fuel cuz of low octane?
- jdm sidemarker link dont work
- Not enough oil?
- Is a Pilot Bearing and a Release bearing the same thing?
- h22a into eg hatch
- need advice
- Oil light comes on even though enough oil is in the sump.
- comptech sway / tie bar fit with dc sports single muffler exhaust
- differences in b16a11 and b16a111
- Gauge lights go on while downshifting, then dies.
- EG Manual pedals won't work in a AT EG?
- noise comming from the intake manifold.
- Car Shows
- Which hood pins work the best?
- rims / tuner lugs question
- Interior Paint
- Who to contact if you have experience problems with "service bulletin" at your local Honda dealershi
- apexi ws damper kit for ek question
- Ek Swap Q..
- rod knock questions
- what lights are these???
- ls/vtec guys out there...help!!!
- Oil found on plug wires?????
- Can't turn distributor any further.....
- 95 EG Swap Question
- Swappinq a H22 into a 95 Civic Coupe
- GSR rotors-rear disc swap
- 1.5 Lsi - Vtec
- taillight keeps dying
- 99 civic dx, CEL codes please help
- obd2 harness in a obd1 eg
- 92-95 Civic Hatchback Lips Questions.
- electrical help on EG
- sohc vtec into delsol shift linkage??
- Seat?
- JDM climate control question
- my shifter shakes!
- D15b Turbo
- what injector clips for 880cc injectors.
- NEED INFO/HELP: FITTING CTR GAUGE CLUSTERS
- fuel and spark no start
- Brake question on a 2000 Civic Si
- 1995 Civic EX idle problem**Tech Help
- White smoke?!?!?!? wtf?
- d15b7 valve springs, retainers, cam? anyone sell them??
- Replacement quarter panals or not... ?
- buddy club spec II exhaust on em1
- Any experiences with AJUSA.com?
- built d16 or stock b16
- integra dash
- full tank of gas on 120K??? WTF!
- need help...what type spray to use on Raybrig EK fog lights lenses
- *****BRAND NEW TURBO PARTS FOR CHEAP!!*******
- wiring b18c1 swap with 00 ex harness
- DEL SOL Repair Manual?
- haze on head lights?
- intro to my world
- 95 civic wont start
- NEED A ECU
- Del Sol roof leak
- For those of you who bought new molded but uncut carpet.
- ima new comer.......
- MINNESOTA help me
- fuseable link? where would i find it?
- Seized rear bumper screws... best way to remove??
- Throttle Position Sensor
- D series blocks
- I need a Si proportioning valve
- NEED HELP JDM D15B!!!! please help not a stuiped question at all
- 99-00 civic h4 or 9006?
- Help Please
- Does 99-00 SI interior fit in EGs?
- QUESTION ABOUT EG Civic Window installation
- What is that skidplate that covers the whole underside of your car? 92-95 Civic
- Front disc brake upgrade question.
- is this way too cheap?
- ╙Interior Neon light problems╜
- Is there a way to have an accurate unricey tach read out
- radiator for b18a1 swap in eg
- what motor oil you guy put in a gsr 95 motor and wat kine of oil filter thanks
- quick valve question, duh.
- I need some help on a coolant line
- civic si cluster
- wen to replace the timing belt?
- Ann odd one for yall...
- Swaping 97 ITR OBD2A into 99 EK OBD2b
- Size of CX steelies?
- european spec rear fog light reflector
- H22 distributor and ignition problem!
- Motor Mount Replacment
- 95 Civic - Blower motor forced shutoff?
- thin moldings for eg civic without holes?
- Expected Performance?
- b16 oil capacity ?
- What size are the screws yo need for licence plate?
- ACURA MTF in civic ??
- engine cleanning advise
- Urgent help!!, Car pulls to the left hard.
- Auto to Manual conversion, Reverse light
- d16z6 HELP
- What button is supposed to be here?
- EK Hatch vs. EK Coupe Weight
- vtec solenoid
- ultimate H22 swap?
- Cat Converter took a shit.
- clucth master cylinder went bad...
- integra master cylinder in ek?
- Civic Helms manual???
- motor swap without engine lift?
- need some info on 00 SI
- car starts for no longer than a second!
- car dies looses all electric power PLEASE HELP
- what is the best mod youve done to the Z6?
- Will EJ exhuast fit an EG?
- Question about valve cover gasket?
- Top speed of a SI 99-00. pic please
- Can I run motor with no O2 senor?
- ««For the Love of God! Code 14 & 41! Eyes bleeding from search»»
- Cwest Front bumper look decent?
- 1996 Hatchback CX
- Car not starting when its hot out.
- Amber...err DEEEP RED gauges
- broken fpr
- Clutch feels weird
- h22 motor swap
- Which radiator hoses to use for a EH GSR?
- 3 to 2 iacv wire help??
- Vtec Controller Settings on a H22A
- 99 hatch-Tein EDFC and spoon strut bar , will it work?
- head change
- header question
- heater hoses...where do they run to??
- Really hard to put into gear
- Some EG6 pics to chew on...
- tranny swap-cam trouble
- I HATE THEIVES!
- j-mcmil6's 1996 Honda Civic DX
- GSR SWAP IAB QUESTION EK9 96
- Have a Del_sol with Type-R swap.
- Anyone ever put the maroon sedan interior into a coupe/hatch?
- Power window adjustment -- searched
- Sparks shooting off brakes when you hit them???
- Inline fuel filter install on EG?
- integra suspension question,problem!
- 99 civic rear lip and side skirts on a 96 civic....
- CARFAX HELP?
- spoon obd1 vtec controller civic
- Does an RSX-S cluster fit into an EK dash?
- Wrong spark plug gap?
- Rough idle and won't Rev!
- Civic Coupe Lip
- b18 in 92 hatch wiring???
- DESPERATE help with electrical issue (CKP code 4)...possible short ? [PICTURES]
- mr. gasket hoodlocks fitment on eg civic
- New Member! Check Out my turbo '99 si..
- ohh my gosh!
- Wheel Bearing IS F***ED!
- change tranny fluid.......
- Car shakes n leaks tranny fluid after tranny swap
