View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 95 del sol windows won't work
- ohh, what goes here? (IM question)
- Whats parts off an Integra for my Hatchie???
- what size rotors for 94 nsx brake calipers to integra brake??
- I need a 2.5 inch High flow or straight thru cat for the greddy evo 2
- tourque specs on a 92-95 d16z6 header? where to get the cheapest o2 sensor?
- looking for pulley that will mount this compressor bracket
- jdm civic fogs...
- just trying to get an idea what its worth, am i asking too much
- icebox CAI's - Problems?
- CRV AC bracket on b16a2 WITH power steering?
- Door Panel
- All of my cars brake lights stopped working, need to fix asap
- Steering Rack Issues
- HELP PLEASE. d16z6 tranny obd1 diffrent from obd2 Whys it got more crap on it?
- EG Rear Motor Mount
- RHD Near Completion
- Questions about my engine....
- apexi n1 vs greddy evo 2
- intake question
- Anyone use this site.
- Shakes when I accelerate
- CANT FIND WHICH FUSE UNDER THE DASH LEADS TO ILLUMINATION... HELP!!! =[
- gm synchromesh........use as additive or actucal fluid?
- UK only hood pins?
- integra ls Cluster????????????????????????????????????
- no front trans mount
- Studder at 2000rpms?
- Speedometer wiil not work!!!!
- RSX Caliper??
- buying a civic, has some weird problems. help?
- What is wrong with my shift forks? **video**
- tranny question PLEASE HELP
- Dek sol headlight adjustment
- Need a walkthough on changine out fuel pumps
- What the model for the BULB
- RPM signal
- Jammed glove box. Get around it w/o breaking it?
- gauge cluster question
- Power steering
- Alternator Fuse going bad.
- Help me please,.... snapping cam journal bolts
- Running rear sway bar WITHOUT tie bar? Thoughts?
- wiring questions
- Do coupe tails fit Hatch???
- I need a picture of a fuse schematic of a 95 civic DX... HELP PLEASE!!! =[
- coilover problem
- power window problems?
- Are 99civic front knuckles and 94 integra knuckles the same??
- missed 4th gear last night....
- VTEC ECU wire?
- 5 lug question
- Alternator Fuse keep going out???
- exhaust question
- Thank you
- brakes not working!
- Is there an aftermarket replacement for factory trailing arm bushing?
- have a brand new dizzy and still no spark
- tailights
- Del Sol Vtec AC bracket vs. CRV bracket
- Need help asap: Can't get drivers side axle all the way into tranny!
- Disc Brake Conversion in my EK hatch
- quiet exhaust for b18c type-r?
- car wont start some one help me out
- Mount Help
- why do these things always happen to me? car won't start need help
- wiring problems
- hondata??
- i need help finding d15b7 fireing order
- which chip for my p28?
- i am looking help for mi civic si with motor d16a1
- EK/EJ side markers
- clutch & mounts **help**
- Relieving Fuel pressure
- 00 si convertion on a 96 ex ***help***
- b16 7200 rev limit
- oil leak, not distributor
- name this part
- Clear rear lights??
- del sol body
- a little help
- dyno vs. street tuning
- 99-00 civic shell
- attn: EG cx owners
- whats the best nitrous brand? price, quality, etc?
- JDM d15b vtec JG CAMSHAFT
- Help with axle issue with B-Series swap
- ebrake cable question
- eg6 climate bezel replacement
- d16z6 with a custom cam
- Something quite!!!
- Need help, axle just broke when i was parking
- mini me swap hp
- BC 3+ cams. Opinions for my set up, is it a good choice to go?
- Difference btw 99-00 and 92-98 Thermal exhausts?
- sparking on distributor cap, car no start
- Swap Question
- IMPOSSIBLE axle nut...
- major help... overheating?????????????
- Can't Decide
- Brake Caliper Slide Pin Maintenence
- jdm d16a vtec??????
- i finally got a b-series, now i have some questions about the JDM b16
- i have feel some slite vibrations coming from my steering wheel
- automatic transmission install
- Honda-Tech has a bunch of know it all punks
- super noob here
- swap anyone??
- ebay twin loop
- how do i put in a test pipe for my ek?
- *QUESTION: CHIPPED TEEH on toda flywheel
- d16y8 intake manifold
- main relay question
- need help on k20 swap in a ek4
- What kind of muffler should i get??? suggestions would be great here =]
- what year is the obd 1 system in
- US honda dealer=jdm sir lip?
- engine mounts
- CEL = po420??
- Turbo Question
- would a v-tec engine start with a non v-tec ecu?
- i plan to boost soon. exaust?
- check engine light problem
- Help....for the love of Pete!
- Dang coilover problems
- Eg Hatch Interior panel question
- How to mount 96-00 CTR lower rear spoiler?
- sohc zc vtec
- Lowered car question
- iacv clicking when key is on
- swap info???
- How much faster is the Civic Type R over the GSR. Which would u choose.
- Problem with idle-help/opinions?
- 99-00 HB / D16Y8 question...
- Awsome Civic Video
- Help! New HID ballast, but wiring harness keep popping fuse.
- sqweeky clutch!!!!!!!!!!!!!!
- 98 Civic LX Oil Light???
- turbo
- 99-00 si gauge cluster in my 96
- Making room in the dash
- Oil Pressure Still High.. any thoughts?
- Dizzy leak HELP!!!!
- 3 wire iacv
- Resting ECu?
- what type r carpet do use in my Eg hatchback?
- JDM DC2 rims in 00 EM1
- car wont crank
- NEED HELP MAKING CAR DECISION..EK Hatch or DC2 4DR
- Code 14 and 22 after ecu change
- 99-2000 Civic Center Cluster
- cluster question
- idle problem
- Noticable difference between b16 hydro tranny and LS hydro tranny on a gsr swapped EK hatch?
- Driver side mount insert install on Si
- need help with my d15b2
- Two broken bolts..
- Higher Octane = Better Mileage?
- need charging system help
- i nead some cilover help
- clutches? which one to get?
- RPM needle in my 00si won't light up
- will 91 integra l.c.a fit 94 civic coupe
- tachometer question...
- No spark on cold start up - 1998 Civic EX
- Spark plugs...
- Anybody from North Eastern states/Eastern Canada?
- casper lens
- no power-key on.
- Car dies when it warms up.
- Overheating at highway speeds
- Del Sol Center Console Removal Help
- recommended machine shop in SoCal
- Header question
- H22 HATCH
- light bulbs
- Check Engine Light - Code 420 - Need a New Cat
- Lowering Springs
- Window Regulator Help
- HELP... I messed up!!
- cheapest place to get an oxygen sensor
- Lower balljoint spins - help!
- Del sol S cd player question
- removing srs on ek
- del sol trunk
- Water Bubbling In Overflow - Leaky Rad Would Cause?
- 8.8 lb flywheel in b16a2 hatch.. good? or bad?
- motor mounts for a d15b
- what company do i ship my motor with?
- need help 93 ls in to a eg
- Need help please help me answer ?
- Header and Exhaust help....
- CTR folding mirror BREAKDOWN???
- Work Meisters Advan AG 5Zigen FNO1RC Enkei RPF-1
- 94 civic.. i need parts for my body doesnt matter what color..
- extra holes in AEM intake
- How do I know if my starter is dead?
- 93 del sol starting problem?
- Do you have a hitch?
- putting together a turbo for a 1995 honda civic hatchback si
- Performance chip
- quick transmission question
- dizzy help
- HELP weird cooling problem?????
- Exhaust question Please help
- i got a simple question.. but i cant find it
- B18b1 into EG Hatch question
- power issue
- D15B7 Vs. D16Z6
- dc2 cluster in an EK9 civic
- Got a brake question...probably an easy one.
- Maximum Towing Capicity for Civic....?
- Look What I found
- OBD ? HELP
- turbocharging a 2000 Si...
- 95 sun roof help....
- B series HELP
- Did we gwt ripped off
- getting alarm, experiences and opinions needed ASAP
- changing harnesses
- which would be better?
- fog light install on EG help!!!!!!!
- JDM RHD del Sol dohc vtec shift linkage in usdm sol
- specs on strut bars
- LMA's replacement doubt
- Mini me motor mount question????
- Havi'n some Problems with intake manifold swap
- Overheating Problems?!?
- Hood spacers. Dangerous?
- How much power??
- where can i buy water pump t.belt and tentioner for my B16A2? (VAN NUYS AREA)
- Disk Brake Conversion: all 4 wheels stuck - checked ebrake cables, pedal height what else?
- type r or gsr gauge cluster
- Dash Lights/Power windows
- please help need to find right DIZZY ASAP. b18a1 sawp in 94 civic coupe P28
- turbo manifolds
- s2000 side markers on my eg2
- Snow and Light Flywheel
- Wrist Pin Locks
- got the cam what about ignition
- civic d15b vtec auto w/ aem pflow sluggish from start
- Searched, 94 4dr seats to 98 4dr
- Piping size??
- civic Type-r
- No Spark + no fuel = no run. Help plz
- Interior Noise
- tachometer not working
- P0135 ECU code question???
- Electrical Problem?
- Door help! I've already searched...
