View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 9003 to h4 bulbs
- Horsepower and camshafts for 92-95 civic
- OVERHEATING : need some input
- flat tire on a dropped suspension ... ? plz help .
- ctr headlight install
- ?tokico blues with skunk 2 coilovers
- B16 Bottom end..... Please help....
- red 91 crx si stolen from Bay Area....help!
- Need 96-98 Civic ECU Pinout ASAP!!!!
- GOING NUTS!!!
- Just got my Omni's
- 94-01 integra and 96-00 Tokico suspension are same?
- [FAQ] How-To: Install a B&M Short Throw Shifter. PIC INTENSIVE!
- Need help with OBD code P1457
- B20/vtec. Need Opinion on Axels.
- Headlight hid wiring harness!
- Adding power windows and locks?
- quick axle question car is on jack stans now !!!!!
- 94 integra coupe apexi axleback on 95 civic coupe w/apexi piping?
- b20 block
- act clutch
- DOING A SWAP NEED SOME INFO
- Trade 02 civic?
- rhd conversions
- JDM Side Skirts
- injector position
- Anyone know what globes go into a 92 import civic hatch???
- TECH MEMBER QUESTION, HELP???
- ITR Steering Rack on a EK
- ek manual door panels to si door panel conversion
- check engine light came on?
- Altenator Fuse?! Underhood or Underdash....
- HELP ABOUT PMING!! I Know im not suppose to be in this forum but idk where else to go!!!!
- 1992 CX radiator.
- fog light help?????
- obd2 to obd1
- Clutch release wierdness
- Custom mounting for radiator for civic 95
- differents between obd1 alternator vs obd2 alternator bseries
- B16 Question
- question on re finishing a cf hood..
- looking at buying an ek civic with a b20b4 block and gsr head *GOT A FEW QUESTIONS*
- SRS Question.......
- What Chassis...
- Would you trade a .........
- best cams for LS...
- b20 eg what ecu
- Best Header for a 98 Civic LX Sedan D16Y7?
- Where are you people getting your salvage cars?
- what are some cheaper struts for an eg hatch?
- Security Code for OEM CD player
- Double Clutch...?
- clock for 98 hatch ej
- Motor Smoking oil at idle!!! LSVTEC
- GSR swap question
- heater core hoses b18c eh2
- b-16 problem...
- V tec misfiring with new ecu, helpppp
- How much hp out of the greddy kit on a sohc @ stock psi?
- Question about wiring harness
- h22 motor swap in 99 civic
- cant install cd player, any help?
- disc brakes for my eg
- Low oil pressure problems..
- Salvage title perchased ( 2000 civic si )?
- vtec pressure switch code 22 bad ground?
- Name this part!
- How can I take out climate control from 2000 civic?
- NEED OEM CAT!!!!
- tachometer
- Is this a sign of a bad alternator?
- Help with tires
- Pic Of Baked Headligts On 92-95
- knockoff apexi n1!!!!
- Ebay ECU chips good/bad?
- GOOD INTAKE?????
- please help! engine installation ques?
- problem with keyless entry
- **How do you put on a front lip on 92-95 civics??**
- gsr tranny with a d series clutch fork will it work?
- 97 Civic tranny problem?
- Swapping an F22 into a dx civic
- Switching suspension pieces
- d16y8 running rich, stock engine WTF, please help
- final gear
- Aftermarket Exhaust
- Symptoms of low tranny fluid?
- ONE last code to kill: code 22 vtec pressure switch (goin off memory)
- Will GSR front/rear sway bar fit on my 96 hatch?
- 02 civic new block
- tokico illuminas or kyb agx!?!?!?! you make the call
- Speed limiter in a 04 civic?
- Sealing / Finnishing a paint job
- Quarter time (EST)?
- o2 sensor for d16y5 (civicHX)
- Low idle problem/idle drop problem
- Oil leaks still through valve cover after new replacement.
- best brakes for 03 civic
- Vtec problems again:(
- Spare tire strut bar
- Gauge cluster swap out, possible?
- Advice Please
- Ignition 1 or 2 pulse
- ls/vtec help
- weird idle problem w/ b18c1 in ek
- Primary O2 sensor Part # ?
- Interior Swap
- s2000 seats in ek98
- where to buy a carbon fiber CTR spoiler for the 96+ civic h/b
- b16a intake size/throttle body question.
- how much for a stock hatch wing?
- Car Site
- SRS light, Where to put the resistor.
- injector info
- hard shifting into gears most of the times.. already searched
- Will a Greddy turbo from a 99 GSR fit my girls 99 Si?
- Squeking noise from suspension when driving slow?
- Downstream sensor, not pluged up two o2 cat, its makes my car run hella bad?
- JDM headlight Instal Help Help ASAP! Alignment issues!
- what kind of bumper is it
- head gasket decision....
- Rod knocks!!
- ECU not at kicker panel
- Starter problems, searched need help!!
- need help on eg-integra front end conversion
- Header-Any noticable gain in power 97 Civic DX (non variable timing)
- I BROKE IT.................
- Anyone Riding 17's on a EG HB?
- b18b in 95si Overheating-- Done a search.
- water leaks
- how long before axles will break? (clicking already)
- EG frontend argument
- intake manifolds
- Should I turbo or supercharge my d16y8
- CEL light..
- dumb question about flywheels
- Are all 96-00 civic springs the same?
- how to tell if i spun a bearing
- can i fit 13' steelies on 00 Si
- Looking for HB civic.
- Vacuum Diagram (searched)
- B16 Question!!!
- ??Will I get Hydrolock??
- ECU question
- Q: Gears shift without the clutch
- timing belt slipped under boost
- Air Intake !?!
- HELP!!! CIVIC TRANSMISSION TECH'S
- Si's Sensors, same as others?
- unable to find the ECU jumper in 1.6L 92 civic ex 5sp manual
- How can I get rid of Hard shifting in my transmission?
- Torque mounts in a 98 Ek?
- Need help what is code 6???
- BENEFIT CAR SHOW FOR RAY MCCARTHY
- Brakes question...
- ZC swap?
- I can't turn off my fan
- I traded my EJ, for this... just thought you should know.
- Are d16 z6 and y8 blocks the same(interchangeble)
- EG headlight intake air scoop - where can you get this??
- wheel question about 96 civic thats why its in here....tire guy said i cant put 17's on?
- Final Drive FD and LSD info plus questions (gear teeth, fit etc)
- roll cage for 2000 civic coupe
- going from DOHC back to SOHC
- 255lph Walbro fuel pump too much for stock B16?
- speed govenor.. internal/external
- Got rear ended (hit & run)
- HX RIMS PAINTED
- GSR vs Type R stut bar
- Upper door trim question
- integra susoension question on civic
- Need advice on power adder for 93 d15 eg hb
- bottomline
- do the INTEGRA GSR REAR SEATS fit perfect
- Smoking Battery?
- Dc5r brakes on civic eg
- see-thru cat?
- jspecautosports.com ?
- New to porting...Can I reduce performance by porting it "wrong"?
- koyo 1" vs. stock dual core
- tekniq 965 or momo tuner
- ported my stock jdm gsr header
- D16Y8 wiring
- Major stumble...can't figure it out.
- EK wieght differences
- civic 03 wit evo wing???
- Question about converting from auto to manual
- DX Intake for HX??
- dumb Civic question...............
- CTR N1 crank pulley?
- Stuck on MSD install & I have college in the morning :( PLEASE HELP !!
- squeeking
- Civic LSi Rattle
- doing a swap soon.. got couple questions to ask..
- Need HELP w/ lighter rims?
- Crank pulleys?
- are 92-95 coupe and sedan bumpers the same?
- Will a b20vtec pass emmissions??
- <^Armrest for 98 hatch^>
- sensor problem
- what valves do i have? (black/red)
- Shifter Problem
- HOW-TO?-Alarm installed, use OEM lock actuators.
- z6 into 96 hatch
- b20 swap, SIMPLE questions...
- resonator question
- most effective HEAD swap for SOHC, what is all required?
- Will this suspension set up rub? *searched*
- Kyb Agx on my hatch?
- Troubleshoot this: Clutch Pedal sticks
- water building inside my windshield
- Who has helms for Z6 engine...come inside please EASY QUESTION :-)
- D-series motor w/ a B-series head??
- anyone gsr blades, webs, or si rims??
- Door wont lock
- HELP! D16Y8 running rough...tach going crazy...
- Really Weird??!? Lights Pulse, then Stop Ect... (searched)
- SPORT COMPACT PRO
- is a 97 hx auto tranny same as 96-00 auto trannys????
- Show your Delsol pics here.
- axle and hub question
- NEED HELP ASAP
- will civic ex calipers fit on my 97 civic dx
- Acura 1.6EL front on EG?
- Couple IM gasket questions
- S2 IM and Bar??
- Need new paint color ideas for my eg hatch. Would like to see pics of your car!
- eg jdm center console <--- any ideas to hold 2 gauges
- B to D series ignition coil?
- Will snow tires be enough?
- ^^^Question about tire size?^^^
- OBD2 check engine light codes
- Civic SRS/ Airbag light
- 98 civic ecu
- Alright here's the plan........
- How to plug 02 sensor hole on a cat convertor???
- My Starter Cracked!
- hydraulic for rear hatch on 92 cx
- WTF? Car is RATTLING like mad...
- carfax guys need some info
- Anyone able to run a quick carfax for me? 2HGEJ6610YH924890
- Tire Q, need a quick response!
- Power difference between jdm b16a and usdm b16a3
- Damper Adjustment On New Coilovers
- air intake
- Does anyone know how to check codes on a obd 1 conversion ? ( researched )
- I keep getting holes in my coolant hoses???
- Side Skirt Installation?
- Rear wiper...?
