View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Cat carb legal for cali to pass smog
- Hondata s200 Help
- Suspected shift solenoid issue? Could use help
- Help identify wires
- Speedometer stopped working while changing bulb
- 1998 Honda Civic Ex Door Jamb Pin Out
- Bad shift linkage in ek coupe?
- Del Sol Fuel Sending Level Unit
- wierd ratling when cranking an engine
- How do i fix this
- EM1 gauge cluster restoration
- B16a2 spuddering when accelerating
- 2000 Honda Civic HX Automatic
- D16z6 swap issues
- Civic no start issues after swap
- 1999 civic ex won’t start I need opinions
- Auto Civic getting: P1298, P1768, P0700, P0705
- Winter Project - 1996 Del Sol L15B VTEC TURBO Swap
- 1993 Del Sol Si Integra disc brake swap
- Looking at a 2000 civic SI
- 00 Automatic Civic SWAP B18b1 Manual
- 93 Civic coupe, Is this the sign to replace my axle shaft?
- Smoke coming from exhaust manifold wires
- Where can I find all clear tail lights for 95 hatchback
- Car won’t go into gear
- Tranny Issues?
- Tranny Issues?
- Just picked up a new to me 94 civic hb
- Drumbrakes self-adjuster moving the wrong direction
- 1999 Civic EX MT noise
- 2000 Honda Civic Si ECT
- This is cold start..
- 1999 Civic Tower shock harness pin out color codes
- B16a2 idle problems after headgasket change
- When Restoring a del sol Keep it Simple & Clean
- 1998 Civic Coupe Auto to Manual ECU no fuel??
- 1994 HONDA CIVIC WONT START...
- 1992 Honda Civic
- Starts but I have to crank it too long
- shifter rod wobbly
- Si vs S Wiper Switch
- Help with leaking transmission fluid
- Brake reservoir still losing fluid
- Need Help or Sugestions
- Dash Light Don't Work
- Musty or moldy odor coming in from 96 civic air vents
- NEED HELP AND OTHER ADVICE
- A/C compressor manifold
- Relocate original radiator
- NEED HELP OBD1 diagnosis wiring
- Trip odometer reading wrong
- 95 VX Cranks but wont start
- 1998 Honda Civic ex head gasket replacement
- Oil pan or crank seal leak?
- alternator and AC belt replacement
- 1993 civic dx sputters and dies help!
- Del sol seats
- Central Locking & Power window issue
- Misfire after valve lash ajustment
- D16 5000+ issue
- Ecu issues
- Broken pcv in motor
- Start/No-Start | Overcompensated Injector Fuel Cycle Issue LS/VTEC TURBO
- Honda Civic 2000 Sedan has 4 pin window regulator
- EK HATCH Yonaka Exhaust midpipe needs shortened
- 99 Civic LX Header to Exhaust Gasket HELP
- Should I keep my 2000 Civic?
- Car wont start
- Random misfire code (Help appreciated)
- Turn signals light up but won’t blink
- Knocking noise from fuel pump?
- 95 Civic Ex Coupe - Brake Lights Don’t Work (Running Lights & Blinkers Do)
- Feal Coilover experience?
- Noise at high rpm
- Cv axle replacement... seal?
- Help 1994 EJ1 B20 motor mounts
- Car won't go past 2k rpms
- Help with mini me swap
- Hard bucking accel/decel
- clutch replacement questions
- Would you do anything differently if you could build your Civic again?
- Need help finding coolant hose replacement
- D16y7 to d16a swap
- Suspension Bushings
- High dipping idle after o2 sensor change
- distributer plugs both sides 99 civic
- 97 del sol b16 swap help
- 1992-1995 civic motor mounts
- D16Y8 ignition timing question
- B Series GSR Transmission
- 99-00 civic/EK9 key question
- Wheel hub bearing question
- Question about my stupid idea for preventing winter rust
- Auto to manual
- Idle fluctuation
- Misfire, zero compression, and oil on spark plug ends
- Y8 Bottom & Z6 Head // ARP studs
- Code 41 from obd1, ej1 b20b swap
- Help with radiator fan
- Can anyone name this HID kit connector?
- Civic 2000, when attaching tire inflator to cigarette lighter socket, it clicks
- Need help!! No Fuel pump prime and no start but I just replaced few day ago
- best place to buy d16y8 oil pan gasket
- Cluster housing with board interchangeable? 99-00 ex/si
- D16Z6 EK coolant loss
- 95 del sol 1.5 CEL codes
- Test trans with car sitting still
- 98 Civic 4dr SRS
- 98 Civic Keyless Entry and Dome Light Not Working
- Kmvguy83's 93 EG Build/Log Thread (Rebirth!)
- Crank no start - No power to distributor
- 92-95 hatchback speedometer goes all the way around and won’t read speed
- B18 into EK stock driver side mount ?
- 97 Dx hatchback w/b18b1
- Is my head done for?
- Wire thing on my steering rack?
- What could be causing this kind of wear on timing belt?
- Recently purchased modded EK - Exhaust HELP!
- Mystery electrical issues
- 98 civic auto to manual conversion
- Help Identifying Wires in Cabin
- 1992 Civic VX - Valve Stem Seals Condition and Replacement
- Split exhaust system on my newly bought 98 hatch
- Highly Specific Distributor Internal Swap Questions
- Detailed oil flow for VTEC actuation ?
- B20Vtec oil pressure sensor questions
- Where to find stock seat brackets? 95 del sol vtec
- 99-00 EK9 RHD HVAC System
- high pressure power steering bolt
- I am Stumped.... Crank no Start
- How to get your project car going?
- dumb question
- EG cluster male connectors to make adapter harness?
- crank no start condition, Distributor
- Help identify a jdm zc engine for my ek engine replacement.
- EG civic build plan (looking for tips/suggestions)
- 1992 Civic EX D16Z6 No Start
- G101 wire bad 00 civic si
- Instrument cluster swap
- dash brake light randomly come on
- 1999 Civic/ Auto Transmission and engine limp mode
- Feast your eyes on this mint hatchback I just picked up in the Netherlands
- Check Engine light sensor issue D16Y7 1998 EJ6
- B20 swap p06 OBD1 ECU
- D16Z6 - Ignitor/ICM to Ignition Coil Wire
- Idle issue on 95 civic b16a motor
- need help with ECU and Harness
- Something came apart inside rear brake drum?
- Looking for 2000 door wiring plug pinout diagram.
- 1994 Civic EX D15B Swap - Build Thread!
- Where to Find AC Fittings for EG
- 1995 EG4 ECU replacements?
- Help on a list of parts for a build
- Remanufactured d16z6 head
- Honda Civic 98
- Transmission Grinding
- Brake light on Dash stays on. Brakes bottoming out
- Need help with 91 jdm D15B engine
- ECT Gauge Sending Unit Connector Broken
- Change out rear engine mount for oem?
- 1994 DelSol 1.6 SOHC Vtec crank no start-burns out distributers
- 93 civic running super rich
- What is This
- 93 Civic Hatch - Leaking From Roof
- Do I really need to modify my wiring harness?
- Show them EM1
- temperature gauge fluctuating, alternator possibly?
- Help with KYB AGX struts.
- 3-4k idle and bouncing
- B18c1 vs B18c5 mpg/reliability
- GSR swap reliability.
- Bad power steering belt or pump? Bad serpentine belt?
- MAP Sensor 95 del sol S
- Inexpensive D16Y7 header replacement?
- B16 vtec issue
- K20 Eg won’t crank over but primes
- D16A Engine stamp on my 1998 EX coupe
- Transmission Problems
- Compensator bracket hole tore open. Advice needed
- 99 civic dx crank no start issue
- Iacv continues problems.
- Old Builds that I’ve moved on from.
- d15b obd1 code 8 won't start
- D16z6 w turbo vs B18c1
- EG B-Series swap
- Honda Civic 1997 Clutch Pedal Fluid Bleeding Issue
- 97 EK Hatch Circle track build help needed
- Okay alternator plug discussion
- 99 civic lx (manual) Missing 02
- Vtec-e swap? OBD2 D16Y7 to D16Y5
- 2000 Civic EX Y7/Y8 Swap Questions
- Help
- 1993 Honda Del Si (automatic)
- Head gasket replacement help
- Tps calibration problems
- EK automatic has been sitting for 2 years... want to start it up
- 00 civic ex b16a drainage problem
- Help with Quote on Repairs
- 97 Honda Civic Ex 1.6L D16y7 Crank no start, no spark or fuel pressure
- 2000 civic bogging issue & detonation when shifting. Is it my fuel pump ?
- Civic 94 wont start
- Window - horizontal weatherstrip for 2-door Gen 6
- Anyone know what this part is for?
- Coolant all four spark plugs
- (EG3) Water Leak from Ventilation under the driver-side tail light
- best boost level for daily driving?
- 5 bolt pattern 15 inch rims on 4 bolt flange?
- Civic EG fixed corner lights
- DX Front Subframe Crossmember
- 92 Civic SI revs, goes into gear, but no va.
- Hey guys I have a Ecu question
- 1999 Civic Dx Warm Engine Hard To Start, Idle Dies
- 1992 VX to CX under dash wire harness
- Fuel pump will not prime
- 2022 Oil Filter interchangeability
- Yonaka del sol catback
- Installing motor from the bottom
- Timing marks.
- 2000 DX HVAC Mode door backwards?
- D16z6 intake problem
- 93 EG civic sitting forever trying to get it to run
- B20 into a EK
- Civic harness help
- Tuning help!
- AEM FPR Not Fitting.
- I hope this is the right thread
- 93-95 4D eg VTI
- Battery charging slowely / ELD cel
- Civic 2000 with D15Z6 all sensors voltage fluctuation
- My $200.00 Si is Almost Ready For Paint
- Throw-out/Release bearing compatibility
- Honda 1997 Civic DX Lower Brake Lights not working
- 1997 civic lx engine swap
- My stock Horn is 3amp, Can i replace it with a 1.5amp?
- Phantom massive coolant leak?
- No spark, distributor Rotor not spinning, what to do?
- Em1 w b18c TR swap IAT plug
- 2000 DX runs poorly when warm
- Temperature gauge not working correctly
- Delsol HVAC Heater control Valve
- Half shaft seal replacement
- 1998 Honda Civic ex coolant leak
- D16Y8: What sensor is this on the air intake?
- AC went out in sunny Arizona
- No electrical power to dash and engine unless CEL ECU jumped
- 96 civic ex speedo and radio intermittently stop working
- Crank no start
- PKE Installation Help!
- B20V missing in vtec
- Picked up a 94 Del Sol that was sitting for 8 years...Help
