View Full Version : Honda Civic / Del Sol (1992 - 2000)
- REAL QUICK: Shifter and Shifter bushing Question?
- Axle length
- Help me identify the part number... connector for EG hatch glass to hatch damper.
- LS/Vtec Help
- Speed Sensor
- Fuel Line Selection
- Will this fit my >1996< Honda Del Sol?
- side mount seat rails for Corbeau Forza II
- cold air intake on my 2000 civic ex
- ?'s about my 1996 civic dx hatch
- Civic 1.4 or 1.5
- 98ex power windows in a 96 ek hatch
- 84 civic overheating help please....very confused/p*ssed
- If I replace my oem A/C fan for a high CFM slim line fan... will it blow colder?
- Valve Adjustment and now there's clicking
- CX to Si swap
- rear disc conversion question ?
- Need some help w/part numbers for Civic
- Auto tranny going out
- Removed PCV, endyn setup, HORRIBLE mpg!
- 00 civic si hesitation and CEL
- yes another 3wire to 2 wire iacv conversion question
- trying to buy a tanabe super medallion hyper.....?
- d15b plug n play?
- HOW TO SWAP A USDM B16 INTO AN EJ8..
- 1995 eg jdm fenders?
- intermittent valve noise/knocking
- automatic transmission shifts too quickly
- Does the HKS Hi-power exhaust have a tilt up angle like the apexi n1??
- Injector troubles
- lost lug nut key
- 94 civic starts but wont move??
- 1997 Civic EX: Engine?
- ls/vtec bulid
- '06 si Kseries exhaust on EG...
- how do you post pictures..?
- Whats up everyone
- Factory bolt sizes for EG civic
- Mushy Transmission Feel
- 230000 miles, morw to go?
- clutch issue...need ideas
- 96 front lip on 99
- '96 Civ factory bra - rare?
- 98 hatch Idle Issues
- Two quick questions. Oil/smoking and CF
- External Coil
- Fog light harness
- SO CAL SNOWBOARDERS HELP!
- D16y7 into EF Si...
- 94 civic HB wiring trouble
- turbo or supercharge?
- hx rims
- 1998 civic keyless entry issues. any HELP?
- would it fit??????????
- JDM EK9 Navigation Question...
- Did I fry my ECU? CEL code 21 VTEC selenoid P28 ECU
- Automatic to Manual Conversion PROS/CONS
- Are rear shocks from 96-00 civic interchangeable with 94-01 integra rears?
- I cant pass 5500 rpms
- Starting Up
- best ecu
- trans fluid
- Hood Pins
- will a stock b16 intake manifold and throttle body fit on a d16z6
- Why was my post deleted? SRS how to?
- cel code 16?
- HELP d16y7 bearings
- Shift linkage install: a DIY for a beginner?
- stashed flywheel
- stripped oil drain plug
- Scared to install the higher ampers alternator please need help.
- b16a vs. b16a3
- S20 Syncros question
- Are new S2K oil filters still made by Toyo Roki???? Pics included....
- 96-98 vs. 99-00 EK, is one better?
- Yakima Rack Help
- need help!!!!!!!!
- Where can I find OEM side skirts for my EG hatch?
- Suggestions on how to plug oil pan bung
- whats it take to get a 2dr exhaust in a hatch?
- Low Position seat rails???
- 91 accord 2.2 in a 92 CX?
- Ac compressors
- HT help me get my car BAR 'd please!
- Rented a valve spring compressor from autozone, why won't it work???
- civic cd player
- Part# Dual Core Rad @ Autozone
- rev problem, 00 civic ex with si swap wont rev past 4,000 rpm, slow rev and bog
- Spoon exhaust for 96-97 Del Sol?
- Idle problem, Need Help Please!!!!!!!!!!!
- Why RHD conversion?
- Clutch pedal adjustment?
- buy a teg or civic?
- Help: Car has been bucking and shutting off
- LCA Bolts!!?
- Primary and Secondary O2 sensor heaters...broken?
- Lookin To Trade Rims?
- k, I need help here, doing mini swap (leaking coolant) *pics* HELP
- Lighten OEM Flywheel or AfterMarket
- SRS Light, how to elicit code...
- Waste time with better intake manifold? B16a
- Been searching, where to buy?
- help on my braking!
- ***** how it is possible to get worse MPG with new spark plugs ?
- 15' Light Weight Wheels?
- D15z1 head on D15b8.
- HELP! DOOR NOT LOCKING
- 92 hatch b18c1 swap. runs like crap
- Y7 Intake question
- need to replace stuts - have two questions
- Help: Exedy clutch good or bad for a 99 civic si
- problems
- I have a vx, will my stock ac system bolt up to a jdm d16z6?
- cluster milage adjustment/searched and found nothing definative
- 00 civic daytime running headlights
- Apex turbo timer
- Can u put after market pistons (NOA) on eagle rods?
- D16Y7
- Opinion Sir Turbo or ITR swap
- b16
- is tanabe suspension any good?
- where to get cheap chamber kit
- Has anyone seen this kar???
- finding cheap but reliable tires
- Now im in trouble....
- Was a sunroof an option on a 97 Civic LX???
- SKunk 2 pro-series manifold vs the first gen manifold
- OVERHEATING OVERHEATING OVERHEATING!!!!! I'M SO TIRED OF THIS SHIT!
- Black Anadized Nuts Bolts Washers
- Radiator Swap?
- 94 civic rear brake job
- car doesnt run right need help
- I'm Tapping my oil pan and i have a quick question!
- skunk 2 pro series cams
- Good paint and body shops in miami or ft lauderdale area??
- Question about minor parts swap compitability PIC inside
- Megan Exhaust Drift Spec Question!
- Energy Suspension Bushing kit for EK with GSR front and rear brakes??
- how to adjust adjustable
- Stock 93 hatch headlights, glass or plastic??
- what brand of coil over are these?
- fuel pump?
- D16Z6 into CX Swap Question
- Aem FPR HELP!
- PROTEST AND LETS NOT GAS ON JULY 14TH!!! pass on...
- map lights?e
- SIR Headlight question
- PIC REQUEST: Work emotion CR Kai
- Ok to use lower compression ratio ?
- Del sol seat into a 94 civic?
- Reverse Sumped Fuel Tank
- valve lash
- exhaust camshaft seal
- Knocking noise
- d16y8 vs. d15b
- heres a dumb question
- Spoiler/body kit Suggestions For My Baby
- header bolts
- Help Help
- 92-95 civic ?
- ECU question
- Need Help Please!! 95 Civic EX Mini me D15B2 bottom end Z^ head won't rev past 6500 rpm
- B20 confusion
- Brake question
- HELP how do you remove rear bumper?
- 96-98 to 99-00 defrost button wiring ???
- braided steel brake line install on 98 coupeski
- Look what I just ordered
- b18b swap
- 96-00 Civic SI seats -> 96 hatch?
- CEL code 15 Ignition output signal problem solved
- minimum length for bumpstops
- del sol with a integra type r front end
- Switches for FOGlights
- Fluidyne Teg rad in 2000 civic si???
- car stutters a little
- Cooling System Question
- 96-97 Del Sol Lip
- Incredibly simple brake question
- is 800$ a good deal?
- jdm b16a-What goes where?
- Windshield Cowl Removal
- My K-series EK: Final Pictures
- just spent all day cleaning my car.......then took some pix what you think
- type-r cluster
- Does anyone make these for '96-'00 Coupes?
- alright so i have d15b vtec and it bogs whats wrong?
- 2 Quick Questions (B16A2 Related)
- Civic differences
- D16 Cam
- Warm Idle RPMs is Low - How to remedy?
- a question about the honda civic Si 2 dr
- 15 inch wheels rubbing on '99 EX sedan?
- Headlight Question
- Headlight wiring diagram needed
- Weird noise in while driving w/ Auto Tranny
- need help-cluster/turnsignals are out
- EX/Si P20 Tranny
- do eg brake pads work for del sols?
- d-series tranny VSS speedo gear help
- HELP with type r header
- torque specs 96 civic head d16
- b16 or b17???
- Name these bulbs
- check engine light
- Whats missing here? JDM B16a in 94 Civic HB
- Just Some Questions
- B series compressor work with D series components.
- Help me
- help: help me name this parts on my b16a2...
- 70mm Throttle body on CTR
- Ek9 hubs with ITR ball joints?
- Coming Out Of 2nd
- hpde..Koni yellow vs zeal b6?
- B20z swap into a '93 SI
- EG Apex-i N1 Catback help
- no brake lights
- Help with my HID retrofit..
- So i just changed my brake pads and...
- How to fix overheating problems?
- 3 to 2 wire iacv plug, o2 sensor question
- hood release Broke please Help!!!
- buying a used civic
- Tokico Blues or KYB AGX shocks with Eibach Sportlines springs??
- Help wih Apexi N/A timer on EG
- Mechanic says I need a new fuel pump?
- Relay problem please help.
- trany pricing question
- Rebuilding Engine
- Worth buying? 2000 em1 SI
- Had a question
- Looking at a car, need some advice
- engine seized?
- Hmm what the heck
- If anyone is looking for Energy Suspension shifter bushings $10.51 with free shipping
- OBDI Automatic Transmission on a OBDII Car?
- header problem
- broken into = salvage title
- 98 civic with p0420 code
- Compression test results
- Help!! Which one is best??? Trying to decide on engine to get!
- b20v VS k20
- Adding Airbags
- integra knuckles on 99 civic hatch questions
- does any one know i the dc sport headers are ceramic coated inside?
- HELP!!! Trying to find BEST stock engine to work on for '94 civic
- Stalls and makes horrible noise while idling.
