View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Possible Instrument Cluster swaps for my EG
- Gsr swap into 94 hatch.(Wiring) ???
- ctr vs itr tranny
- Eg suspension?
- 92-95 Civic EX coupe engine swap?
- skunk2 Intake manifold Question
- 93 del sol running rich at idle and lean at WOT
- 94 gsr
- huge problem with b16, no vtec, bad idle, etc
- Car cuts off at idle
- 97 civic ex auto to manual
- What steering wheel and hub is good?
- help on swap
- 97 civic dx wiring questions HELP!!!
- 96-98 climate control help!
- Which axles???
- For those experienced with Oil leaks, Please Identify, PIX AND DETAILS INSIDE /UPDate
- which axles for b16 in EG ?
- b18c em1 vtec problems
- Acts funny at 2 grand
- Can a B16 handle 9000 RPMs on stock rods?
- Cruise Control.
- Trying to find similar exhaust sound as most sti need help asap
- Civic rear disk brake conversion
- nitrous
- primary o2 sensor wiring "diagram"?
- ek4 interior
- 1994 Hatch slow progress BUILD
- your thought on this exhaust possiblity
- what wire is the high beam wire?
- Help please! 36mm 5-lug
- spindle woes....
- Need Some z6 Help
- Check Engine Light "Code Help"
- Ls transmissions
- Input needed
- Air/ Fuel Ratio Gauge
- I think my cv joints might be going bad but i am not sure
- 00 EK civic build
- Sticking Emergency Brake
- d15b8 + vtec head mini-me?
- 2000 VSS wire location please help??
- really rough idle
- 4/114 type r wheels and suspension for sale
- 195/50 15 or 195/45 15
- eg6 arm rest mounting bracket..
- 92-95 Civic gauge (8400 RPM, any solutions?)
- Anyone know how or have a DIY for Jdm console..
- EG Shift Linkage into an ej8
- I need some help from tech guru's(regarding engine/transmission swap)
- OBD1 B18C1 (gsr) intake manifold vac chart
- requirements for turbo?
- My H22A wont stay running...
- 99 si harness ?
- How to conect oil gauge
- 5zigen Header
- http://www.n1concepts.com?
- manifold & suspension
- Is my head gasket on wrong? Pic inside
- h22a prelude or b18c type r
- H22a Stock Intake Box
- D15B jdm Upgrades
- Is this what my car should be feeling like?
- 92 Civic DX Won't Start. HELP!
- Can someone tell me what was done here?
- Scrap yards in NYC
- Cel, no knock sensor, vtec works, b16..??
- Help Please! '96 Civic w/ B18 Tach Question [New Pictures]
- cruise control with sterring wheel
- Honda Del Sol Upgrades
- OEM exhaust size
- LS swap snafu
- mini me not starting :(
- brake problem
- Sensor help
- 99-00 ex harness for a b16a2 swap?
- y8 mani on z6
- HELP! lights not working
- Wont Go Forward.
- HELP on 2000 civic
- fuel injector help!
- Crazy Axle Nut!!
- Type R Intake Manfold diameter?????
- Timing Belt Advice: I searched also please hear me out
- installed new caliper, now soggy pedal!!
- Can't get spring off shock, advice please?
- QUICK QUESTIONS: Wheels low offset
- Windshield wiper compatibility?
- Few questions, uneasy feeling?
- how do I remove hub from spindle assembly?
- OEM honda 92 civic thermo opening temp?
- Springs (aftermarkt)...
- aem fuil rail or y8 intake manifold, what is better?
- Engine cutting out.
- Fog lights!!!
- '00 EX rear drums -> discs conversion (w/o ABS)
- gsr problems in my ek
- jdm d15b in 98 dx
- How to Adjust your EK9 Type R Spoiler
- will ek seats fit in my 95 dx coupe?
- eg civic coup with b18 exhaust question
- 99 Civic: SRS/Horn/Door Locks not working
- 96 CIVIC --- D15B OBDII -- what axles, shift linkage, and ECU?
- can you reuse head bolts?
- 96 Civic moonroof / sunroof rattle
- i need help choosing a wheel
- smog questions
- Swap from auto to manual???
- Wire Tuck Questions
- nub question
- smoke in car..
- Shift cable replaced and check engine light now coming on???
- 98 Door Harness --> 00 Floor Harness
- competition clutch?
- removing fabric of door cards ?
- I NEED AC HELP .. 98 Honda Civic.
- Skunk2 IM w/ Vacuum Leak... need help
- What type of gas to use in my HX?
- ecu question d15b
- S2000 Cluster swap in Ek4, hvere can i buy adapter ?
- Sell or Keep 92 Civic Si?
- camshaft and sprocket problem please help!
- Engine Check Lamp come on after 2500rpm
- Why is it doing this?
- b16a2 short block w/ spun rod bearing... TIME TO REBUILD FOR TURBO!!!!**pics!!**
- question about quick release hubs
- broken rear camber adjuster bolt head
- 2 step?
- replace motor mount on EJ1
- 95 sol ground up project!
- Dash lights? #24 to #74
- 1991 Nissan Maxima tires fit a Honda Civic 98
- Dipstick Blowing Out
- how do i tell what tranny is what?
- EK coupe sideskirts on a EG coupe?
- Dash light dimmer switch
- Any Pics of a EG with Stock GSR mounts
- Questioning about lowering
- can i boost a stock d15b motor?
- ticket for tinting
- LS/Vtec in EG hatch. Swap Complete!!!! (pics)
- Cams?
- cel em1
- oil catch can??
- Can you help me solve my fuel supply problem?
- Hatch misfiring, Need help
- Would a 95 civic hood latch work on a 99 civic
- bodyparts question (nothing crazy)
- Replacing Ignition On a 92-95 Civic
- New clutch questions
- obd2a gsr to obd1 ecu questions?
- help getting main bearings
- Opinions on Cam gears
- how bad is it to drive your car...
- Tips & Tricks On Taking Out The Crankshaft.
- B16A2 into EG--which top mount?
- Jdm Iacv
- need to sell my civic, what's it worth?
- Installing a Resistor box
- ? about mounts
- cruise control
- OBD2 communication Failure?
- b16a2 weird idle, die instantly. HELP!
- Chassis codes?
- Valvetrain package - Skunk2? Crower? Ferrara?
- Weird happening in burger king line today... any clues?
- rebuild and now car starting problems.....really rough.
- 2000 Civic wiring issues
- Bolt broke connecting trailing arm to lower control
- engine die instantly
- What Pistons For a D16Z6
- how to remove passenger airbag?
- how to determine an obd1 dizzy from obd0
- Help! How do you install a Buddy Club Voltage Condenser on a D16y8
- Will a Cam Gear from Y8 Fit?
- Need help with ID of Civic
- cel #9 help!
- $9000 civic transplant
- 92 Civic CX Starting then Dying (jdmd15b)
- Hood fitment?
- License plate stuck
- transmission problem d15b swapped eg. Help please
- Ek wiring help!!!!
- Car surging
- gauge cluster
- b16a1 and 700$ to spend
- GRIND IN 3rd......
- starting problem
- Driver's side torque mount issue
- Energy suspension bushings in Blox LCAs. I just need a little help.
- which rear seats fit in a ex civic coupe EK
- 1998 civic ex
- Sunroof in a 98 EK Hatch??
- ebay products.....
- Ravelco anti-theft
- Help me with my new project.
- need help finding some moldings!
- ek b18 swap questions
- is it a Bad Injector or a plugged fuel line?
- hello honda tech
- Car Feels weaker sometimes.
- Help w/ my Turn Signals!!!!
- Electrical Ground Problem???
- What do these brackets go to? Out of 96 Ex
- d16z6 head studs
- Help Wiring Power windows n locks 96-00
- would our local spec 92 - 95 be called a civic http://en.wikipedia.org/wiki/Honda_Bal
- Drivers side wheel rubs when I turn my steering wheel all the way to the right???
- gaskets
- Which Magnaflow Car Sound Converter should I go with?
- 99 coupe b16 not starting
- removing cc and ac components.help
- b16a swap trouble please help
- b series and d series sensors
- oem cooling fan?
- Code 43 help
- Re: need help a.s.a.p with my eg hatch
- charcoal canister
- RWD Del Sol?
- power door lock control unit
- B and D series transmission bolts same?
- Oh no!!!
- quick, stripping 92 si hatch
- b16a2 wiring question
- need help a.s.a.p with my eg hatch
- Pros and Cons of a lighter Crank Pulley
- Swapping out a manual steering rack and adding a power rack
- Engine Harness Plugs
- distributor ?
- y8-autotranny-question-pics-yo
- NRG do they make good CF hoods and hatches???
- bottom raditor hose is cold/upper is normal
- Moonroof Problem
- ARP Main Studs
- Double or Single
- 1998 Honda Civic DX / Shifting issues
- brakes are very mushy.. HELP!
- 98 civic ex bogs at low rpm
- timing belt jump help
- b16a2 motor question
- Cold Air Intake for 99 Civic Si
- i need help with my hood.
- JDM Black Housing Headlights?
- brake pedal idle
- Motor Mounts for GSR Swap
- Am i paying too much for a y8 IM?
- How do i know if its a EX/SI TRANNY ??
- Am I overpaying for EP3 Seats?
- 2000 civic si ground wire location
- F20C del sol
