View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 96-98 rear lip on 99-00 Civic?
- help
- 93 d16a vtec..? ( I did search )
- EM1 style carbon fiber front lip
- b series engine swap d series harness
- 97 Civic H22 swap questions
- GSR Rocker Shafts
- RPM idlleing issue in 98 ek with b16a swap..HELP!!
- motor problems, please help.....
- My 95 civic EJ2
- eg changes?
- Clutch Pedal Soft, Hold's High, Just replaced, didnt fix.
- mini me
- sway bar questions?
- Keep Spinning bearings on Dseries.
- put new batt. in n now car idles CRAZY LOW!
- D15B8 build 92 cx hatch
- Condenser fuse blown in fuse box under hood
- Problem with FPR (Fuel pressure regulator) bolt.
- B16 ?
- Getting another hatch WOOT
- Squeak from wheels! Rim or Tire? or somethingelse??
- What's consider high for fuel pressure?
- question about swap
- Exhaust help (EJ8)
- ek swap to ctr motor??
- Should i worry?
- Del Sol Bumper Question
- Need help b20b
- Exhaust fitment QUESION....
- using d16y8 intake manifold on d16z6
- Gas pedal problem =[
- Help with SOHC
- Si brakes on 97 hatch
- B16a swap in 98 ek
- clunking sound from back of car
- which cat???
- 98 EX Spedometer and turbo times quite working, CEL came on
- Civic brake upgrade
- Installing gauges and dimmer is weird
- Wrong ECU?
- hole in trans!!!
- Auto to manual how hard is it?
- Injector question
- spun bearing is crank still good??
- Rear control arms...
- Fuel pump help. 95 civic
- 97 dx civic hatch d16y7 failed smog co % levels only
- its an ongoing question...
- D15B swap and a code 1
- cluster
- How do i remove the glass for my driver side mirror?
- question about p28 obd1?
- EG Dimmer Wire Colours?
- Anyone own del sol b16a3 intake manifold, ecu p30-a00 and want to trade
- What is this? and where can i find it. Steering Wheel
- How to remove A/C
- will this fit?
- how do i transfer my pics from photobucket
- Can u use d series injectors on b series
- gas problem...when going to get new gas it wont start
- Hardware for 3pt Strut bar
- Youve done a swap? Any tips or advice?
- Timming Belt keeps backing off.
- del sol ek conversion
- swapping axles?
- gsr turbo headgasket
- hatch back corner lamp on LX
- B16a Axles in 98 ek coupe
- A/T not shifting right
- Looking to upgrade the rear sway bar on my EM1 ... Any Suggestions?
- Swap Help : d16y5
- Sqweeky problem comin from the rear of the car
- re break in ?
- audio capacitor problem
- b16a motor trouble
- what do you guys think?
- transmission service costs
- Window tracks
- power door locks in 99 civic hb
- exhaust Help!!! quick question
- Mirror switch doesn't stay in
- LS harness question
- new walbro pump question
- apexi GT exhuast
- Engine won't start, Key turns No ignition
- Location of the B-Series VSS?
- What is this connector?
- Drag slicks, size?
- D16Y8 tranny rebuild
- Cooling Fan Not Kicking on 92 Civic 4 Door Lx.
- Help with engine swap in RHODE ISLAND
- help gsr in eg
- replaced battery and now turnsignals dont work
- what swap
- ECT code (Water temp) help
- my SRS light is on.....
- THE Four Door Civic Project
- Confused... Pictures included (3)
- HELP!!!!! installing v-tech controller!!!!!!!
- sprint lowering springs
- 97 ek Hatch dx Radio station static help!
- type r seats fitment
- EG Power Mirror Trim Panel
- New cluster question
- Fuel system cleaner
- raising the redline.
- Civic EX Alarm Install...Where to pin lock/unlock wires?
- hp rating on this block?
- Is it worth the One-Fifty?
- K24 Block + K20A2 Head swap -- Help Plz
- Cheapestnd easiest way to get ek9 red/grey and black full interior?
- speedo not working!!!
- blox LCA bushing question
- Does the D16Y8 oil pan fit on a D16Y7
- Rear Wiper Problems!!
- B16 Help!
- Car not starting please help :(
- WHAT IN THE WORLD. My crankshaft pulley bolt just fell out today. I have some questns
- Pic Request: Gsr/ITR rear seats in a 96-00 coupe
- exhaust issues
- 93 civic si power steering pump LOUD noises
- b16-b20?
- GSR swap... Factory intake??
- Quick Distributor question...
- 95 CX + Power windows = Non closing window
- New Hatch - but have questions
- exhaust ideas. 2000 civic
- Clicking/grinding from front driver's side wheel
- SIR swap into 92-95 Civic
- I've been keeping this a secret but.....
- hey fellaz question about chassis brace...
- how to tell what year my motor is
- eg window visors?
- coolant...
- No rear lights and no starting?
- put on c10s, now i get a clicking noise.
- wiring up own wires from the iacv to ecu?
- Help=[[
- Leaky injectors.
- Budget D16 turbo - FMU 10:1 ?
- help me please
- Password JDM fenders with sidemarkers. HELP
- Interested in dyno tuning my b16 Jackson Racing Superchargered Hatch
- 1995 b16 hatch keep blowing ecu fuse, plz help
- chipped p28 or p72 on gsr?
- H2B, B16A2, B18B1 with a GSR Trans. Need some advice
- AC Question
- bushes
- pic request: white eg hatch w/ slips
- My car started over heating after using heat wrap...
- Another GSR master/C and B/B EG swap question
- GREAT STORY.... Pager Alarm Saved my Car Last Night
- Ignition Timing Service Connector
- b16a swap trouble
- gsr ecu ?"S
- what would be the best tranny for this setup
- wheel bearings?
- how to check these, know what to replace?
- 1998 Honda si door
- Code 13 Atmospheric Pressure Sensor
- B16B pistons in JDM B16 tuning?
- missing oil
- 95 Civic EX Cluster swapped into 92 civic CX Hatch and now blinkers dont work! HELP!
- Help!
- d16y7 not starting need help!!!!
- death of my b16
- power fold mirror relay location ?
- are my cylinders good?
- ap1 cluster into eg using speedohealer
- Freeway street tires?
- need help, cel code 74 = burnt valves?
- 92 civic hatch speaker question
- b16 idol problem
- 13"s on a EG???
- Y8 IM Swap into Jspec d15b
- Redline problem
- b16a power steering
- Shock suggestions for 2000 Civic EX
- b series rebuild question
- Car won't rev/bad idle....ignition timing?
- JDM D15B OBDII Swap
- Changing from manual heater controls to electric?
- 93 civic wit d16y8??
- My New Sedan!! Any Suggestions To Make It Look Clean?! No Engine Stuff,It's AUTO DD
- which tires?
- Shifter issue....need professional opinion
- are mud flaps all the same for 96-00 coupes?
- Header Poll
- Swapping clusters into a 97 DX
- 99 Civic gives electrical shocks? Help?
- Em1 Si running funny***
- parkin brake light
- Ok dont hate but i got a question
- Replacing Window Regulator motor.
- Installed tranny, but wont start.
- Bad starters or something else?
- Question about my P2P
- volk wheels
- exhaust?
- a little help....new? evaporative emmissions question
- 99 ex bumper same as 99 si bumper?
- Post H22 swap into del sol startings sporatic?
- EK front forks on eg with ITR
- rusty bolts
- QUICK ROOF sound deadening. Check out this video. Has anyone tried this???
- New to EG's Ive got some questions...
- Need help 96 civic Ex
- 2000 Civic Front Bumper Needs Help with Alignment.
- auto cluster in a manual swap pics
- i need a new project!! B16 or B18, HELP!
- 2 problems!!! shifter and emissions!!! :0
- Smog question - plz help! Im drained =(
- Garage done ek.....
- 99 civic? k20a3????
- CVT Shift Cable?
- 98 Honda Civic CX..Boreing....im lost..pics
- D15b oil light
- b18c: most reliable power i can get
- del Sol problems
- started after 3 tries!!???
- More horsepower?
- Gsr leather seat is crooked.
- 3rd gear grinds . .
- Torque specs for the Harmonic Balancer.
- Car problems with bogging down at 5800
- need 02 sensor wiring after b16a swap
- JDM Folding Mirror Wiring EK
- need advice on rims
- Need help w/ my A/C
- bezel for a gsr cluster in a eg?
- check engine light code - vtec spool solenoid valve (code 21)
- B20v ITR cams?
- 1997 Civic B16a2 Tachometer problem
- How do i know if its a GSR Shift Linkage and not a LS Shift Linkage
- idle bounces after warm
- ls vtec oil in throttle body
- help my exhaust came off my headers?
- primary o2 sensor heater
- oil in coolant reservoir
- help with swap
- d16z6 in a ek coupe(ej7)
- San Antonio Tx area Machine or performance shops
- sohc 9-10k rpm possible?
- 95 si b16a running hot
- d16z6 on engine stand !!!!!!!!!!!!!!!!
- Foglight question
- JDM engine zone?
- Rear Disc brakes!!
