View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 98 Civic Coupe lip kit
- Swapping ECUs! *Easy quick question*
- whirling sound...need your best guest.
- 92-95 Honda civic Throw out Bearing ??? 5 speed
- Circuit Suspension
- losing oil every 2,500 km's or so..
- Wheel locks with no KEY! How to get them off?
- Can't find radio screws in 98 civic
- Where is the IAT plug on a 97 Civic Harness?
- B18B auto swap into EG
- Cheapest place to buy a intake filter??
- code 41 oygen sensor on my poor mans type r motor turns on and shuts right off.\?
- h22 in an ek
- Brazilian Honda lover... I'm rookie here!!! hehehehe...
- siregcivic asked and i thought it was a good guestion
- VAFC II
- JDM 92-95 hatchback gauge clusters
- '00 DX and '00 SI o2 Sensors the same?
- Stolen Hatch NOVA!!!
- Help Car wont Move
- HELP!!!!! SPEEDO!!!
- do they make the traction systems with radiator supports for eg6
- help me. throttle body is sticking
- Freebie: Injector Seals
- Help me get this bish' started...
- CEL Code 21
- Plugging a hole in the tire...a reliable method?
- Integra Cluster into 92-95 civic
- What do u get from the owner to make the engine legit?
- quick oxygen sensor question.help?
- will a acura 1.6el front lip fit a 96 civic hatch?
- something simple for my civic`
- HID conversions on EK civic post them up!!!! all of you please
- NEED HELP I THINK ITS THE RIGHT AXLE!
- 2000 civic rear bumper fit 1996
- How do I remove front bumper on my EK civic?
- what do you guys do about the srs plug with a sir gauge cluster?
- Hiding wires
- Im a newbie!!!!
- measurement for EK sidemarker HELP
- 1989 240sx se forsale or trade
- ToDa Cams V-Tech KiLLer
- how do you change headlight bulbs on a 92 civic lx?
- Must-Have Mods
- Did a B18 swap in ek and wont start!
- Civic/Sol Pedal Compatibility
- 97 DX Headlight
- 00 si front sway install
- Blowing ECU fuse....help plz
- ES rear mount insert
- GSR front brake swap help - read, did search.
- I need rear calipers
- Can someone help me with this????
- Need to clean VSS harness... any tips?
- Replacements Lens for Integra style headlights?
- can someone tell me about 97 civic tech tips
- 1.7 engine swap
- Outer Tie Rid Movement????????
- 1993 civic interior door handles
- weird sound from the wheels or tires
- SOMEONE PLEASE HELP!!! i have no clue on what wirning harness i need for my swap
- Spark plug help, Pic included
- 1994 EG Civic Radio color codes
- del sol wiring diagrams
- Turning over slowly = dead battery?
- 92-95 Civic Ex Block w/99 head?
- RHD EG how to guide
- ep3 seat in EK
- 96 civic question
- reducing intake heat soak and noise
- Question regarding painting?
- Tried 2 different integra mounts, both don't work?
- HELP!!!!!!!!!!!!!!!!!!!
- Need a new INTERMEDIATE AXLE - What yr/car do I need??
- break in period? timing belt and camshaft
- towing options
- EK USDM powered mirrors on a EG hatch?
- Radar Detectors
- Honda Civic has hard time starting when cold.
- These crazy gas prices... I love my lil hatch!!!
- is rce gas ok to run on stock ls engine
- o2 sensor problem need help???
- rear disk question
- suspension question
- Timing belt jumped 4 teeth
- anyone have vacuum diagram for gsr in an ek coupe
- Y8 intake mani install questions with pic.
- I think I have decided on which Rims to get.......thanks to help from HT
- honda and acura acessories
- LS swap in a 92 CX...idle problems
- H23 OR H22 TRANS
- hard time getting mounts into brackets?
- BAR question
- Panting header. Need advice on prepping.
- 94 civic with a 97 integra front end for sale!!!!
- Car Acting Up!!
- weird idle
- TRANS REMOVAL H22 SWAP
- Licence Plate relocator.
- Car loses acceleration during first gear, but second is okay. thank you!
- compression numbers too low????
- fitting questions
- 2000 si for sale
- 92 EG Suggestions for mounting racing harness to chassis?
- what could be wrong...?
- uregnt - header torque spec needed
- Structural Integrity of Stock 95 Crankshaft/Pistons
- ECU
- some hose disconnected, dont know wat its for (1993 Civic DX)
- Polishing Crank
- Cooling Question...(new radiator)
- Interior Dash question
- civic A/C won't mount on jdmB18C-R bracket????
- Rattling or "chatter" coming from Auto Trans
- i'm seriously going to blow my car up...
- so... which is which?
- Adjusting your distirbutor???
- 97 Civic Odometer
- Anyone know about the clipless jdm side moldings?
- NEED HELP!!!
- Carpet for a 93 Hatch...
- 13 BARO - atmospheric pressure sensor ??
- Do LS rotors fit on a 93 civic's hub assembly?
- where are the Ek LIPs!!! ??
- Compression numbers
- DO U KNOW WHICH CODE IS THE MOTHER OF B16 CABLE TRANS CUZ I DONT WANNA SCROUNGE
- dc headers torque
- AEM LS/ITR CAI in EG
- is it possible????
- Will eg shocks fit an ef?
- Gsr in EK..(over-heating)
- ctr rear lip help
- 99-00 civic cf front lip
- IDLE problem need help quick
- buddy club cams
- Car won't start.... help!!!!!
- head values problem
- Engine advances timing and adds fuel when A/C is on?
- 94 4-door civic with an integra front end fs or ft
- civic type r
- NEED IACV!!! PLEASE HELP GUYS!!
- 1992 Civic EX, is it a VTEC motor ??
- Power Steering question..
- Compression readings good or bad. 95 Civic Dx 171k miles
- >> Please Help, Axle Nut problem... Can't get it off <<
- help with rare rims! anybody seen this?
- Rear Wiper Delete for EK Hatch
- Mirror Housing/Shell Question
- [D-type] Engine
- What to do?
- Just wondering why?
- problems after GSR swap, relay?
- Coupe Spoon N1?
- 6100rpm redline?
- need some ideas
- Fuel Injector
- problem with projector headlights
- 96 d16y8 starter Rebuild?
- big 18
- What kind of clutch do I use on a d16z6?
- code 20
- shifting problems
- 99 ek9 hatch for sale b16aturbo engine holla
- heater cable replacement
- i want pics of civic 4dr 95
- d15z1 (92-95 Civic VX) injector flow rate?
- What should i sell my 99EK hatch for?
- deck/stereo stopped working
- How can i run a automatic harness on a manual trans?
- DEL SOL problem!!!!!!!!!!!!!
- People doing H22 swaps - base plate choices (please read)
- rough estimate of d16z6 motor n trans
- or Those That Have Different Clusters?
- What am I getting when I buy a Vtec "Long Block"?
- Fudge...
- Difference between 99-00 Si catback and 95 EX coupe catback?
- p28?
- Window problem
- I need a smog in Orange County area
- Quick dumb ?
- vtec not engagine..CEL when vtec should engage
- i have no idea what the heck is wrong here.
- Would this car get 25mpg?
- I NEED SYNCHROS
- Trying to paint rear taillights...problem...
- how to fix an axel seal leak?
- age old fued
- d16y7 Help ... check engine light.
- nEED HELP on how to take o healights
- 99 civic si cluster question
- b16 gearing compared to 96 itr gearing??
- why am i losing rpm's in 3rd gear?
- Homemade turbo on 2000 EX
- D SERIES TRANS
- GAS MILEAGE IN HATCH W/SWAP
- B16B vs. B16A2
- i thik i made an uh oh
- rear trailing arms for sale will fit civic and crx 90-99
- pic request, es oval stylestainless muffler
- SiR B16B Motor
- DC lca on an EK, will it work?
- What oil filter fits better
- JDM B16a SMOG legal?
- Higher elevation = slower car true? or not?
- quick interior color question
- Z6 Swap into CX
- Bent trailing arm or bent hub?
- WTB 96-00 manual steering rack civic asap
- 1995 Honda Civic EX - Looking at one right now...
- Civic Door Trim
- 96 DX (D16Y7) question about CAI
- Replacement Motor Mounts [polyurethane bushings]
- Quick painting your valve cover question.
- Clicking in front pass. wheel?
- jdm obdII b18c idle problem...vss...iac...
- What is the service interval for the timing belt on a 1998 Civic LX?
- Any recommendations for a tachometer and/or shift light???
- My front / rear disk is on but???
- 99 dizzy wiht 98 car...cel or no..
- 99-00 Civic Si Climate Control Double-Din Measurements...
- Overheating at 100MPH
- i need a carfax asap can anyone help"friends car just blew up"
- Anybody Know of a 6 speed for del sol?
- p30 ecu
- EK HID retro fit
- BLANG BLANG Civic Style...?
- My 2000 civic stolen tuesday morning
- Need opinions for type r jdm header **what are you using?**
- Replacing back seat
- LSD?
- In order to boost my car should I...?
- How to know for sure that a Shock is damage?
- Homemade Cold Air Intake? Does It Work?
- Anybody selling a camber kit...
- B20B in a EK Swap
- Slight tap feel, cant really hear it though
- Trans Whining
- Need a good Coil Over for my civic ...
- inner tie rod locking clip?
- Del Sol question?
- hard to remove yellow connector in fuse box?
- Painting Your Car By Yourself. What am I missing here?
- hazard switch more than just a switch?
- Steering Wheel Shakes VIOLENTLY Going Over 50 mph, HELP!
- Timing Belt/Water Pump Replacement
- which ls ecu for 98 honda civic ex
- where can i get 96-98 civic EX engine harness?
- Hot brakes = drag
- drum brakes
- will a 94 integra dash fit in a 99 ek?
