View Full Version : Honda Civic / Del Sol (1992 - 2000)
- d16y8 motor pull ?New Eagle Steel H Beam rods/ JRP pistons any good?
- P2P ecu wiring diagram? HELP
- about my future swap....
- have a coulpe swap questions (d16y8 w/ p28)
- 91 integra disks on 93 civic
- anybody help me why does vtec jump
- Help me decide today. Stock H22 or Built D16?
- Whats the Part # for-OEM 99-00 Civic SI strut bar- on hondaautomotiveparts.com
- TIMING: cant get to 16* without notching the dizzy????
- starter installation
- vtec solenoid???
- sidemakers help?
- Automotive paint
- 99-00 si airbox in a del sol question
- air/fuel ratio pin/plug?
- 1995 Civic b16a Stalling Problems Please Help
- HELP! MADE A MAJOR NOOB MISTAKE WHEN I PULLED MOTOR!!!
- help please metal on metal sound when i turn
- knock off Mugen header
- JDM Parking Pole
- MORE HORSE POWER
- ek eg sway bar ???????????
- Randomish Questions (Carpet / Studs / Moonroof)
- Ericks Racing OBD2 ECU programs
- DC5R 5 Hub conversion on a EK ??
- Quick Question for Engine Swappers
- what size tire??
- FIA race seats,are these seats expired??? pic of FIA certification inside
- OFFICAL PICS OF EK'S( HATCHES ONLY)
- WHat do you think? And whats it worth? Im new to Honda-tech .
- Sludge in Intake Manifold?
- leaking fuel
- help me with my cluster nothing works
- ITM and TB Question
- Tranny Fluid Advise
- RADIO STOPPED WORKING! (CHECKED ALL FUSES AND SEARCHED ALREADY!!)
- rough idiling and black white smoke
- Yet Again: Good deal on EG hatch?
- WTB: Del sol factory intake and box
- New Member.
- Whats better??
- I'm crossing over
- Clean Motor?
- how do i install my hood release cable?
- Best induction kit available for b18c4 (b18c1)
- Tuning
- NOVA/DC/MD 4 DOOR LUV! Ferio 88-07
- will new headers fix this?
- Looking for B Series Vtech solanoid?
- RSX seats in an eg
- Looking for new cat
- Blocks made out of what??
- ctr momo wheel
- is all 95' civic EXs sedan have sohc vtec?
- PLZ HELP. Motor Quit out of the blue...
- Can anyone tell me where this goes?
- NEED HELP HX wheels rubbing against break caliper!!!!!
- Paint Code HELP
- suspension swaps???????????????????????????????????
- Few quick questions on Civc bumpers
- 92-95 qaurter panel
- Quick question about exhaust swaps (really quick!)
- 1998 Honda Civic Dx SWAP??? HELP!
- Need help passing smog ECU question
- y8 on its deathbed.
- abs light
- Skunk 2 or Edelbrock intake manifold????
- Where can i find right hand drive clips for an ek??
- i dont know wut to do
- Question regarding evap and fittings, check out link
- should i tune my car if i have I/H/E/TH body/ Intake manifold
- Wiring help needed ASAP.
- switch out the dash now stuff doesnt work
- will a 97 Civic Ex rack and pinion fit into my 93 Civic Dx ?
- Question on my b20
- Integra dash in 92 civic hatch?
- how can i tell if its rod knock or head thats knocking ... someone help plzz!!!
- gsr brake booster
- Shift Linkage Bolts.....
- have to hold car in start possisition
- Intake manifold question.
- 00 civic si rims?
- will a d16z6 cylinder head fit on my 1.5lsi
- inerchangable parts
- repainting exhaust manifold
- question about vtec
- Best coilover or shock/spring combo for DAILY DRIVING?
- How To: ST Swaybar with ASR Brace - EK <56K INTENSE>
- Parts List for Timing Belt replacement
- dizzy wire colors for +.- on tdc,cyp,ckp plz
- Aftermarket Radiator Support
- Found a good FPR for cheapz!
- clutch replacement Q's
- What kind of exhaust is this....link inside!!!
- Best header for D16y8
- RS*R exhaust question
- aem uego or any w/b gauge question
- jdm power doors
- EG dashboards: does the hatch fit the sedan?
- help.......
- Del Sol si intake for EK EX
- LS VTEC question
- Which ECU...
- Help on fuel pressure.
- a few ecu questions?
- Lowering Springs & shocks Help
- ABS?? which models!
- Removed head, do i need to do a valve adjustment and adjust the timing?
- tuning with wideband, but remove stock oxygen sensor
- new question....
- oil stained seat
- LS swap in a ek coupe
- Omni test pipe?
- Motor shakes at high rpm shifting,but fine under 6k?
- Quote, originally posted by Syndacate »
- cams? cam gears?
- USDM axels on a JDM motor???
- turbo charger vs super charger
- Car wont start. Help please!!!
- Vtec Wiring
- Sway Bars
- I have a 96 ej d16y7 turbo what fmu ratio should i buy
- GM Synchromesh FM or New Honda MTF?
- Parking Light wire for newly installed AC S7 Gauges on 00 Civic
- black seat belts coupe/hatch into sedan
- D16Z6, IS THIS A VTEC ENGINE?
- Suspension Travel and Possible Damage
- What temprature should it be to paint interior of car
- obd 1 obd2 problems
- 96-00 civic driver side engine mounts all the same (b16/D16)
- Jumper Plug Question
- Real Mugeun Header PIC REQUEST
- Rear disc conversion
- Installing Indiglo Gauges on a EG.
- Exhaust question
- Tie Rod Ends
- ZEX 105300 cam VTEC higher or lower?
- Quick Question?
- HELP!!!! problem with ignition possible causes ???
- CEL 68????? WTF!
- Need Help with a suspention question
- vtec is jumping in my 00 civic si????
- Injector question
- NEED D- SERiES HELP. 94 Cx Block, 96 Dx Head
- type r valvetrain in a gsr
- why do i have an erratic idle?
- 1995 civic wiring diagram for radio????? needed a.s.a.p.
- Good Tech Site!
- y7 valves in z6 head?
- 96 Civic AC installation
- stock headlight Q
- Can someone tell me what these are for?????
- EK, Spun Wheels (preferrably Green)
- Question about removing sideskirts
- lsvtec swap
- i need help with a Airesearch turbo for a d15b7 engine!
- street "legal"?
- ctr valve train
- 92 Hatch Rear Quarter Window
- ls transmission problem need help
- hey does anyone have a 92 d16 1.6 v-tec 5 speed ecu ?
- new to car modifing help plz =P
- will an accord shift knob fit a 97 civic?
- tranny
- what size tire should i go with on on my si???
- WTB. Anyone out there have axles for an h22 in a 92-95 civic. Preferably Hasport or DSS 400hp
- civic eg 1.5 lsi ... what head can i put on it ??? plzz help!!
- Help me find a duckbill for my EH2
- Problems with the clutch... is it time to replace?
- MD LOOKOUT: 2x Red EG hatches stolen same night, at my apartment
- I need a new OEM/Stock Fog Light Switch for my 97 civic ex coupe..
- Password JDM exhaust?
- clutch replacement or adjustment?
- auto to manual... done it?
- 1994 Civic VTEC Auto Transmission problem
- Scary steering problem! NEED HELP!!!!
- b18c1 pistons
- HOW LONNNNGGG???
- Fuel Injectors...
- need help with axle
- Someone PLZZZZZZZZZ????
- quick question
- HOW LOng dO I HAVE TO WAIT??//
- dope tow hooks! front and/or rear
- Honda Civic roof racks?
- Best light bulbs Polarg, Raybrig, PIAA, or passwordjdm's?
- finaly got my 92 hatch
- J'S RACING
- Twin Turbo Civic?
- swap question
- Homemade catback for Del sol
- D series shortblock weight?
- d16a6 to d15b7 swap
- B20 Motors
- chipped ecu
- 97 civic /b20 need help
- b16 with cable tranny question
- spark plug socket stuck need help
- Heres what i got
- anybody know what the box on the fuel rail is called
- sohc v-tech Boost or B16b Boost
- ek cluster
- just saying hi and a civic question
- Level of Difficulty on Suspension Installation for EM1
- Motor is running lean?
- when i buy skunk 2 cams should i buy the p28 and tune it
- Code 22 searched vtec pressure switch
- 1994 civic dx fuse box diagram
- Speaker Swap... anyone done it?
- 4Wheel disk brakes for EG
- How hard of a hit to set of air bags?
- new driver badge
- b16/b20 need boost
- Best place to get body panels?
- JDM Cluster
- Help 98 civic MOMO steering wheel [ install HORN ] HOW~~~???
- please help me with timing issues
- Big Surprise, Fogs went out.
- Jdm cluster lighting
- HELP! Car wont start.
- 1993 cx want a little more power
- Noo power windows don't work
- HELP!!
- s2000 ckuster in a eg question.........
- alternater belt and underdrive pully
- Delsol fog lights not working???? need help
- new to the eg
- B18 TURBO how much safe boost need to beat srt4
- pictures of no cat
- OBD on B16
- Link Inside: What brand is this wheel lock???
- del sol gallery?
- b20 vtec need help
- im sure someone knows what this is
- help needed with 93.civic.DX.auto winter beater
- Huge paint chip
- need some suggestions... no this isnt really tech related.
- Swap put radio and now my gauge cluster doenst work
- Climate Control & Dome Light Issues
- Burnt Smell
- help with ITR sway install EG - end link alignment
- Passenger Side Air Bag Question
- Confessions of a ricer
- anyway you can take these out? 99-00 hatch tail lights.
- SWAP HELP
- PCV question: to remove or not to remove?
- GSR cam and camshaft?
- ls motors..
- TO Slow
