View Full Version : Honda Civic / Del Sol (1992 - 2000)
- will this work with my 92 hatch CX?
- I'm officially pissed off/stumped. v.tranny problems
- Speedo wont work
- VSS interchange question on my swap
- lookin to make the switch over to honda..
- What is this ORANGE plug for??????? *Help*
- all motor gsr???
- Bad CV joint???
- 99-01 P2P Civic EX ecu pinouts
- Stolen Hatch in Palm Springs, CA
- 96 Civic Auto Door Lock
- who can tell me what thread pitch and size these studs are?? motor mounts...
- oil and vtec question
- !!!JDM EG6 HEADLIGHT QUESTION! WHO HAS THEM, DO U HAVE THIS PROB!?
- what i need to do to run ls rods in a d16z block?
- Wiring VTEC, 96 CX, B SERIES. IVE SEARCHED.
- PLEASE HELP Horrible gas mileae d16y7...already searched
- d16y8
- assword jdm ha ha where do i find my jdm parts for my delsol?
- 2000 civic headlight kind of faded/foggie, any way to make them clean
- Poll of the hour: Will My shocks/struts blow???
- Using D16z6 wire harness for a b18b swap
- 93 civic interior
- d15b help arp studs and gasket
- Engine Swap - Need Help Pretty Bad
- what's inside cold air intake?
- EG HATCH rear shock covers
- Would switching IAT and Evap Cause this? (PIC)
- CAMBER WEAR
- noob question.
- HELP!!!! my SRS came back on again
- civic front rotors w/abs and w/o abs..different sizes??
- rsx greddy evo II on EK HB ?!?!?
- Need help with rough idle, no stalling and no mods
- why does my profile say trial?????????????????HELP
- my friend got an EG 6 but vtech not working???
- Radio Harness Dimmer Wires !? Help
- window visors
- Hard driving. Longtime effect?
- honda civic turbocharged
- rear spoiler.
- help for my d16a
- ebay coilovers good or junk?
- Engine questions
- Egay, i mean Ebay 92-95 Hatchback fiberglass wing... Question.
- help!!! installing door visors on eg
- stupid question..so easy yet confused. slotted rotors..which way???
- instead of ITR Throttle cable bracket and Cable. Can 99 SI be used?
- lowering problems ahhh!!!
- B16, GSR
- VAFC install help!!!!
- virginia people
- axle problems
- Small black smoke in Vtec
- DIY door panels...what kind of fabric?
- 96-99 00 front end conversion
- Quick question about oem civic spoiler
- JDM EK HID install for 96 up Honda Civic wid Pictures.
- car cuts off for no reason..
- Lowering about 2 inches. Camber kit nescarry???
- Accord or Prelude leather shift knob
- HELP! can't swap my o2 sensor?!?!?
- trying to get 11:1 out of a y8...
- good turbo setups for d16s
- CEL code 41
- will a gsr block girdle fit a b18a for a ls/vtec?
- Wont go into 1st gear, sticks in 2nd(after tranny swap)
- 3rd gear grinding while driving? Not grinding when shift
- which wires go to where? 92 honda civic hb si
- overheating
- Clutch n Tranny / LS Vtec ?
- a way to pass emissions in MD...HELP
- noob question
- Info on Ferio vi-RS?
- hood bra
- Where to pry to get axle out of transaxle
- D15B7 in a 95 CX?
- Engine importers of So.Cal? where they at?
- OBD1 ecu connectors pin removal ???
- traction bar info
- Carbing roll cage for EK
- How much power
- F.S/F.T-CRISPY EG HB TAIL LIGHTS AND DARK GREY TRUNK W/OEM STICKER AND H
- Will a obd0 alternator work in obd1 car?
- need torque specs
- Need help You HT guys
- car wont start after putting in a different bottom end
- Throttle body from hell!!!! NEED HELP.
- car ran hot , now it wont start. help
- what do i need left? motor swap
- EK FOR TRADE!
- tranny question
- Cluster question ek
- Parts for sale on turbod16
- another weird noise thread, another mystery
- Chargespeed Lip Kit for EK
- water tube from d15b8 block not on b7
- Car is overheating when I stop at lights.
- Japanese p08 ecu and CA
- ek9 center dash peice
- Skunk2 coilovers
- what do i need to make obd0 to obd1??
- hp question
- BETTER WATCH OUT, better not cry....cuz im tellin u why!
- RACK AND PINION BAD? Moves about an inch up and down!
- where r can find (speed pro) rod bearings and main bearings?
- koni yelllow perch settings
- EK hatchback Tail light gasket.
- Pulley Sizes From Different Motors Question.
- Type r exhaust del sol?
- Rota gt3 or dr16?
- Radiator hose question
- Is this Del Sol worth it?
- i have a b15b7 engine with vtech head need help!!!
- need some advice on a EX head/tranny swap
- Smoking at startup rings or valve seals
- LCA once again
- timing for 1999 civic si
- Looking for old SOHC Parts Please Help
- 1996 Civic EX d16y8 how many O2 sensor on the motor??????
- CEL - New York Inspection - Auto Manual Swap
- how to fix code 21 and 43
- Question about these mufflers..
- new to the honda world nelp help with cylinder head
- Exhaust
- OEM foglight switch on Password/Depo ek fog kit?
- quietest exhaust??????
- vtec not kicking over
- Time for a new engine????
- CTR replica Grill
- HAZE CLUTCH!?!?!
- Cluster problem
- Whose all using Innovative Motor Mounts? Post your reviews
- Quick Release?
- Help Cleaning 93 Civic EX - EJ
- just brought a 96 civic
- door lock noise
- Tein s colpete coilover for sale
- Will 01 dc catalytic converter fit 99 ex????
- Turbo D15B8: CX Motor? [Searching Weird/Uncommon Setup]
- Yet another potential stolen civic topic
- dx y7 to ex y8 mini me swap
- Vtec wiring??
- Blew Air Bag and now i got a NEW air bag do i reset srs computer?
- del sol guage cluster pin-out'
- EK wire harness questions
- rusting enigine bay???
- door panel on '92 Civic Hatchback
- Anti-Theft CdPlayer Problem
- Mini-me Swap Dilemma
- door locks not working
- WTB 96-97 Del Sol front bumper
- im need of helP!!!
- ef wire harness to an eg coupe
- Anyone chipped a P30 ecu?
- car eats way to much gas
- HID p&p kit in JDM Headlights...?
- lowering springs
- need some answers
- EJ8 frame and chassis specifications
- EK side skirt?
- How do I tell EK floor harnesses apart? 96-98, 99-00, EX/Si??
- transmission
- VX tranny and boost?
- Have floor harness, possible to use only P/W stuff?
- Question regarding mudflaps
- sleeving? what is it?
- obx twin loop
- Where can i get these for the front plate holes? Help/pic
- flat tapped-Roller rockers?
- B16A G2 (Sir II) Swap Question
- adjusting Perch Levels
- how do i install a drivers side wondow?
- what tow weight is needed for a Del Sol, trailer, etc
- How low does your gas gauge go (eg)
- Tail lights
- delsol front end conversions
- Brake Light Problem: Need help ASAP
- post pics??
- Are the rear ctr seats anything that special?
- 94 civic ex tachwire
- ecu problems
- 99-00 ebay projector headlights??
- Car jerks shifting high RPMS!
- si rims
- d series cranks???
- EG6 rear disk brake conversion
- parts for sale!!! blew my 1.6 sohc vtec and im selling everything off it call for info 3014650646
- Will a 93 stock oem full si catback exhaust be a direct boltin on my 95 civic hatch cx.
- Need help asap
- jdm d15b with y8 intake manifold
- ecu ???....what is a p61
- oem fog lights..
- gsr cluster in eg..
- Ice man to V2
- Performance Muffler
- R.I.P My Dearly Beloved EJ6 (pics inside) :,(
- GSR in EK wire harness help
- 96 civic with LS swap HELP PLEASE
- New Exhaust Poll/Question
- took off PS today, now it won't turn, do I have to much fluid in rack and pinion steering?
- Amber Cluster Question?
- car wont go into gear!!! NEED HELP!!!
- B20 with Dohc ZC tranny
- 1999 honda civic air intake?
- valve clearence d15b7
- D15B Swap Cranks and Turns over but wont fire
- air bag tray for RIGHT Hand drive EK's
- has anybody replaced the under dash main harness ?
- RHD
- EK H22 civic broke motor mount need help
- d16z6 hybrid build...hepl if you can
- difference between auto Y8 and manual Y8
- is there a step by step h22 swap guide on h-t??
- Just Bought a 92' Civic LX
- Tein SS coilovers vs. Skunk2 Pro series coilovers
- Compression Test numbers HELP ME OUT PEOPLE...
- Lsd ?d15 b.
- swap p/s pulley ?
- good website for buying parts
- Merry Christmas!
- question abotu powered breaks?
- B18C1 Into 95 CIVIC DX
- Anyone ever write a DIY on removing power steering?
- Damn you Meguires Cleaner Wax!!! Look what you've done!!!
- AC Delete Duct Part #?
- rear disk
- s2000 inside door handle same for 92-95 hatch?
- Need Help with Fuel Issue
- replacing brake hard lines with steel braided ones?
- power steering problems
- better radiator/cooling ?
- fog lights in 93 civic hatch
- cel code 3. need help quick
- HELP! Engine is Putting?
- FOGLIGHTS!!!!!
- Stock radio w/ amp
- HID on projectors
- weird vtec point
- I got stupid question... Can you swap the disc brakes on a 95 prelude SI to a 2000 civic (4 door)?
- Mid-swap crisis
- Difference in 96-00 and 92-95 turbo kits
- i need help
- d series transmissions?
- Clutch help!
- Civic noob. Want to boost my Si, but has to be cheap, and still have AC... doable????
- My EM1 got stolen last night.. read for details..
- Used MANUAL EG rack and pinion
- fuel filters.. which to get
