View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Unused sockets and wires
- Floor Harness ?????
- wierd problem im having on the ek....
- what would you do
- y8 trans to z6 trans?
- jackson supercharger for d16 motor
- Fog Light Bulb
- dry nos venom on gsr
- Is there really a drop in fuel economy on the civic HX?
- replace blower motor?
- USDM & JDM parts
- 1996 EK Coupe auto trans problem
- 1994 b16a2 in 1997 civic ek9
- eg bumper mouldings?
- Oil pans: D16Y8 pan on a D15B7 block?
- P72 Throwing a code 23?
- Battery light
- K-Swap into EG, can I also convert to RSX brakes and power steering?
- Del sol gsr swapped POverheating issue
- s2000 sw in a civic?
- Oil all over the Valve cover, WTF
- is there a difference between the integra rear disk and Civic si rear disk conversion ????
- H22 EG master cylinder question
- 96 HX window troubles
- spittin and boggin
- Civic Hatch Rebuild HELP NEEDED
- B20B With P75 head.
- Mileage on cluster not working...why???
- Surging / Hunting Idle PLEASE HELP!
- Prelude steering wheel into ek
- BUILT D16- I know I know, just hear me out!
- Radiator Support
- b18b1 ls-v ?'s
- FINALLY DONE.....
- car stalled when driving, wont start...diagnosis?
- radiator fan on=rich?
- D to H series swap
- Hello People!!!
- Pin for 96 civic pcm
- Del Sol EK Fog Lights.
- CEL Code P1768 please help
- JDM D15B???
- swapping to jdm doors . . .
- 99 Hatch W/ LS Swap. A/C Question HELP!!!!!!!
- Ran into a little snag pluggin my motor
- will a GSR tranny fit in a d16z6 motor???
- Loss of Horsepower with A/C?
- vtec wiring question
- does the del sol handle any different than a civic hatchback?
- ASR subframe brace w/Civic Type R sway bar making loud clicking sounds
- will anyone please??
- How does my plan sound?
- CAR STOLEN 99 civic hatchback with sunroof
- alloy wheels
- need help with springs
- ECU Relearn?
- B18A1 Swap Into 92 Hatch
- High Flow Cat and Header for D16Y7
- 2 qiuck questions :) help
- just tunning question???
- ALl electrical stuff flickr in 2000 Civic
- 94 ex motor into a 97 civic hatch?what mounts?help.
- help disc brake question
- What is this? rad Fan install
- clutch break-in
- need help: problems starting
- Fork in the road.....
- d-series tranny s40-2008513. whats it from?
- HELP ME...pic and question inside...
- Fog light? 2,5" x 2"
- CEL ...problem
- Dutch guy's EJ1
- Any web sites for importing cars??
- Integ front end question...
- Apex-i Q
- what's the diff. from EJ and EK??
- HONDATA OR CROME?
- Starting issue, new issue..
- Hi, Im new too Honda-Tech
- hi all,
- Deal or no deal?
- is it important to bleed it?
- Strange Noise after Short Shifter install
- 1997 Civic DX CD Player Issues
- emissions!!
- 93 Delsol Si brake caliper
- PLEASE HELP! A/C Question!!!!!
- Headlights not bright
- Car pulls to the left when accelerating
- Fluid Motorsports WA
- grinded gears, now no gears will go in while car is on
- i need some help please!!!!
- Should I part out my EM1 before I go to U.K. for a year ?
- auto to manual with change OEM subframe, WORKS?
- how can i tell if my 2000 civic is LX or DX
- shaking while accelerating?....(i searched already...)
- the new ride
- offset of stock del sol fat fives?
- Which Integra MC has both brake lines on the driver's side?
- Engine help
- where can I get another motor?
- need more fuel
- Tokico Illuminas with what springs.....
- Question about speed sensor throwing a light plz Plz help ty
- ek automatic door instalation
- engine problems
- motor swap need to wire v-tec
- 96-97 del sol front bumper cover
- What's involved to bolt a B series auto swap in a Civic??
- Need help with my b18a1!!!asap!!!
- Car Mold?
- NEED 96 EK MUDGUARDS!!!
- Can royal purple harm a civic tranny?
- p30 pistons on b18a/b rods????`
- EG front suspension parts interchangeable on an EK?
- No voltage to fuel pump connector.
- where to buy inner transmission bearing? help!!
- center air vents
- no acceleration
- b18b1 reving problem..pls. help
- INTAKE SYSTEMS FOR HONDA EK D16Y7!!!!!!!!!!!!!!!!!1
- 95 civic engine swap question
- fuel problems with a b16 si hatch?
- he n
- need vaccum lines for b18a1 in eg
- Need Help. Need to wire the doors from my 95 ex coupe to my 93 si hb
- Mushy breaks, my fix (on drum equiped vehicles)
- how to reset the check engine light.. 95 civic eg
- jdm civic type r 1999
- hey
- h series questions
- Hi all!
- AC wiring Diagram
- cruise control - quick fix im sure
- blown strut...
- What is the Brand of this Jasma Stamp Header?
- how do i know if its a good head
- Simple question about calculating gear ratios
- obd2 b18b in obd1 del sol issue
- 93 EG Civic Hatch LS Swap
- spark plug wire sequence & fuel filter question...HELP!!!
- sway bar rubbing exhaust
- is this worth it?? and what is this engine's horsepower
- Can you use a eg civic IACV on a obd1 LS
- rising fuel pressure guage
- Will 96-98 GSR harness work for a D16y8
- B16A head gasket??
- D15b2 with y7 head..What head gasket?
- under drive pulley and timing prob
- Skunk2 Quality
- CTR city lights?
- Starter is'nt getting signal!!!!!!!!
- Fed 1992-1995 Civic ECU into 1996-2000 HX?
- turbo eg
- Air Conditioner Squeaking/screeching
- p/s reservoir problems
- headlight warning?
- AC Conversion question
- maintenance questions
- how to tell what tranny i have
- crank regrind
- Alternator Bolt removal
- b18b in del sol IAT CEL
- Leaking oil from beneath, HeLP!!
- l/s headlight harness
- 94 civic how big rims???help
- Engine whine, like a supercharger???
- i have a question on smoothness.
- Ek Si project questions / Introduction
- is it a vtec head?
- Hydrolock help!
- OBD1 question
- Cruise Control Kill switch?! (searched)
- Car paint and wax
- reverse lights dont work
- 94 ex rear bumper
- Is this car worth the price???
- smog help
- Can I use 88-00 Civic Adj Coilovers on 97 Civic?
- car wont start need help.
- Crank pulley came off!!!
- ek4 fog light and intercooler question
- 1996 dx problem
- 93 civic si swap
- Smooth riding coilovers?
- SKUNK2 PRO 2 OR PRO 3 vs TODA SPEC 2 OR 3
- eg fog lights need help
- Where to get a B20 swap in socal
- does innovative make mounts for the ej6? k series?
- Should I boost?
- Blown Head Gasket?
- eg a/c system
- Need help on a couple of questions
- EK LCA question
- gsr rebuild finished today!!!
- Battery light
- CD player not getting power
- 99 civic sir problems
- climate control is outta control...
- stock eg axle back?
- Oil leak?Whats wrong?
- NEED help
- Binding Brakes
- MSD HVC-L pn 6631
- head gasket change
- 93 hatch, problems with electronics and radio. HELP!
- Harness question
- civic with h22 swap question
- Del Sol spark plug question.
- 96 ek hatch dx cluster problem
- pic request: nrg engine damper installed pictures
- Will a 99 DX AC condensor fan fit a 97 HX
- Need help with right size trottle body fof my SiR
- have SiR ek4, will a skunk2 intake manifold give me more hp
- Radiator fan question
- Need a color code and or paint name for OEM Del Sol Teal.
- Weird noise after connection IAC cable to ECU
- code 15 when using an obd2a ecu
- gasket question
- 93 Civic b16a2 just bought, struggling, running rich cant figure it out!
- will this rs-r exmag fit the EM1?
- How long will the water pump last?
- hey, bushings, ek bushings on eg/teg
- 2000 Honda Civic EX 3-piece OEM Air box
- What's the Dimensions for a 97 Civic Hatch DX muffler
- just wondering..how do you guys install your front lips??do you guys install it different then me??
- emissions question. . .
- question for a new guy
- skunk2 IM on a D series.
- size and lenght of brake lines civic hatch 97
- Changing rear brake problem
- LSD Question
- Power Folding Mirrors...
- how to test tranny shifting out of the car?
- clicking noise even after oil changed and rocket arm checked
- did rear converstion but some how the brake pad kinda stick to rotor
- where to find rear ferio seats
- Advice for fellow enthusiast?
- !!!!!!Plz PLz i need help with building up my d15b!!!!!!
- Seat Swap options for 99-00 Civic Si...?
- 92 civic torque converter not locking into overdrive?
- help!!!
- power washing wheel wells on 95 coupe
- Odometer problem - VSS Issue?
- does anybody know the name of this lip?
- Hi everyone!!
- Exhaust Options in a Sedan??
- NEED HELP WITH FRONT LCA
- 96 civic dx no start troubleshoot - help a noob hotline
- Is a stock 2000 Si radiator sufficient to cool B18C1?
