View Full Version : Honda Civic / Del Sol (1992 - 2000)
- b16 swap power steering question
- 1992 civic hatch w/full 2000 gsr swap. Cluster problems
- install cusco lower tie bar?
- NEED HELP! Hasport hydro to cable conversion kit
- ES Bushings
- whats louder N1 or Buddy club spec II
- CA: Evergreen Smog Referee.. Who Hate's Him?
- what wheel size?
- D16Z6 Bogging and not reving above 3500 RPM, plz help!
- CAR LOCKED!!
- does falken make 195-60-14 tires?
- Custom D-Series Transmissions
- questions about a high flow cat
- header important question
- What side skirts are these?
- valve Cover Installation
- FOG LIGHT HELP PLEASE! (I searched)
- Distributor Rotor question...excuse the ignorance...
- CF hood, lip and bumper...
- 95 Civic engine swap thoughts
- Carfax anyone? VIN inside
- Question about fender liner clips
- Does the Turbonator setup really work.
- What's a good price (Canadian dollar) for new engine?
- 92-95 civic floormat question
- question: cost of a used/rebuilt transmission for the b16?
- swap help
- New to honda, tips on forced induction
- SWAP A 4 LUG HUB FOR A 5 LUG HUB
- Liter/Torque/HP specs
- Cage Pics! I want to see 'em! Roll bars too!
- short shifter
- How to identify type of engine in '92 Civic?
- Emblem
- mini me start to lose coolant
- TurboCalculator.com reliability... some problems with buying a turbo from them.
- Honda Brake discs info
- PLEASE HELP..EG6 JDM FOG LIGHTS INSTALL
- The worst looking Break pad EVER!!
- jdm d15b vtec cams vs d16z6. the d15b cams are different compare to d16z6
- Lookin' for a Genuine Type R wing?
- engine code for 91 civic
- Broke a valve cover bolt.. what do i do now? **pictures inside**
- Ecu Help
- idle problem
- coilover adjustment problems
- 5 speed
- ~Pics of my EG-2...Finally~
- cleaning buildup on inside of intake manifold...
- E-Brake
- Cheap HID conversion, is it good or not?
- NEED HELP anyone in upstate new york with a 98 civic dx witha stock motor please pm me asap
- vtec cams in non vtec engine
- STUCK!
- Best Traction Tire For Stock Ex Rims???
- Transmission Selection. D-Series Transmission gearing. Which is best for acceleration.
- EG side skirts and rear lip?
- Got 92 wrecked Cx hatch
- SUSPENSION bushing stuck.... help
- Super Secret civic Si Trick!!!
- ODB2b Distributor
- Which is a better head D16z6 or D16y8 ??
- start out turbo setup
- Good tuner shops in toronto area?
- JDM ITR Header Fitment on 99 Si
- Has any garage ever built an NSX powered EG?
- non vtec to vtec head
- Are there any D15 turbo setups out there???
- Extra battery???
- obd conversion
- NEED HELP!!! FRONT BUMPER QUESTION
- about how much would a F22 swap for my 99 civic DX cost?
- wto JDM type R grille
- Rear seats for 96 coupe....
- Carbon Fiber Tail Lamps...95 Hatch?...
- measuring drop on omnipower coilovers before install???
- Dreading smog, any tips for passing Test only this New Year?
- car not going into gear sometimes
- ek side skirts on eg coupe
- a question: Swpping from D16Y7 to D16Y8
- NEED HELP! Car Takes long time to start
- Will a +42 offset wheel rub against the fender?
- anybody know how to get th crank pully out
- Anyone know much about distributors?
- 97 Civic ex engine problems
- Cant find a connecter
- 96 ex Power Window Runner Track?
- Bolt Pattern
- D16z6 block w/ y8 head
- AFC problem
- front brakes
- Steam cleaning the engine
- del sol gas gauge
- What power steering line can i use ?
- 205/60/15 Wheels on my 95 EJ
- Need help with hydro tranny
- my car blew up!! my options
- CTR exhaust on an EG?
- rear wiper problem EG.
- Fuel filling problem...
- 1992 cx hatch Can I run a Cable Tranny from a 89 d16a6
- Stock Fuel Pressure setting for EM1?
- E-brake light stays on
- Wanted: Im lookin for some HX rims Or LS mesh rims
- kteller exhaust piping
- sig..sir
- To be NA or to be Boosted?
- cost of switchin tranny
- Tires for 14" HX wheels
- Hondata??
- 97 civic auto swap b18c
- about cold air intake?
- Where can i buy an Ek Squad sticker???
- rpms fluxate?
- idle at 3k?
- Integra Type R Seats in Del Sol
- Best set up for h22 in hatch? Looking for reliability and 250hp
- b16a2 reflash
- ek4 climate control
- Tom Motorsport Bride replica seats
- bs - motor form hmo- argh!!!
- how hard is it to put on coilovers?
- SI cluster
- FITV vs IACV?
- Engine swap wiring harness question
- fastbrakes 11" front oem kit
- Need a part number
- this little thing fell out of my b16 head WHAT IS IT?!?!
- CF hood fading???
- Spoon N1 muffler metal?
- 94 civic ignition problem
- question about exhaust.
- best b16a2 header for $150
- how long would it take to strip interior?
- help me take out my stock radio
- Trouble passing inspection
- Primary Oxygen Sensor Heater Problem
- Maintenance Light Turned RED in 2000 EM1
- how to tell what tranny i have and what parts of it i can interchange?
- will a 99-00 civic si mid pipe fit a integra gsr
- Quick question, Will the engine leak oil if I remove the distributor?
- Anybody know the quality/look of the PASSWORD: JDM Amber EG Turn Signal Lenses???
- gas consumption is bonkers!
- Another head gasket question- 1994 Civic ? Lots of questions!!
- CEL Code 41
- Gsr engine failure need some help asap...
- I NEED DEL SOL SEATS.... SELL ME THEM SO CAL>>>GOT CASH
- Surging Idle d15b7
- NOs N/x question
- fmu question ;-)
- WTB Power Steering Deletion Kit (little reservoir, lines, and breather)
- jdm itr 98spec motor. which is better for drag racing? 4.4 or 4.7?
- better track chasis
- Anyone know if a del sol 97 front end will bolt right up to a 95 del sol ???
- EG6 Transmission Question
- transmission questions
- Yet another y8 intake mani queston.
- half shaft cv joint?
- What bushing is this.
- best sounding exhaust
- Ignition Timing Question
- PLEASE help, rear disc swap PROBLEM!!!!!
- b18 swap?
- Anyone know a good forum for TT supras???
- A GOOD, bright, white headlight bulb? Is there such a product?
- what injectors do i get?
- New to the Forum...got an EG
- CARFAX help needed ASAP please?
- HID Bulb size?
- Setas swap
- ECU Qustion ? 93 dx civic and want to do a ls swap..
- adjusting FPR with engine on or off? noob question.
- B16 Idle adjustment
- Del Sol Brake-upgrade
- Alternator Problem
- knobs on adjustable struts?!
- Posting for a friend... side mount bracket question...
- Rear Type R seat on a civic coupe 95???fit?
- Spoon SW388 Replica question (I searched)
- Omnipower install need direction on preloading
- Need trim touchup paint...
- EK parts
- Throttle body problem??
- What is this called on a throttle body?
- shift linkage
- rust on wheel studs
- CAM GEAR ADJUSTMENTS
- replacement parts for jdm type r five lug?
- pics of my 00 si
- 2006 civic type r
- DIY : RICED out exterior TWEETERS!!! *56K* come in
- Block swap
- dash lights wont work 92 civic
- Bolt and washer arrangement for Skunk2 shifter?
- question about ek hatch with gsr
- JDM ITR rear sway reinforcement
- rattling noise
- 92 Auto to Manual search not helping :(
- Free sparco catalog
- question about car squeaking
- How much should this cost?
- iat
- skunk2 cams
- Best cam and ecu tuning for a d16z6
- 1.5L I4 - Engine question - Civic DX 94'
- Question about trade
- New swap... GSR motor in hatch. help with whistle noise.
- Shell/unibody compatability? EDM to USDM for Roll Cage/Bar Kit fitment.
- happy new year everyone (POSTING A PICTURE )
- Squeeky shifting!?!
- Omni Power kicks major ass
- What springs for my H22a ?
- can you adjust rear camber with just washers?
- EG Civic Wont Start?!?!
- wheel hop
- Any Recommendation on A/C Shops?
- 99 LX...decided to keep it!
- anyone using y8 pistons in a z6?
- will these tires fit?
- Dash, And Back side wall... Question ??
- Need some seats for my car.....
- Want a HID kit for your civic? Read this and think again
- ATTN: So. Cal My Car Stolen!!!!!! Please help me find it! =(
- Car doesn't get hot, was overheating now to cold.
- 92-95 Spring Rates VS. Dc2 94+ Teg Rates
- speed sensor issue
- CUSCO Zero 1+ITR Rear LCAs+EK Hatch= NO WORKY!!
- axel back exhaust question
- what is the largest size of tires for EG donut rims?
- Is there anyway a smog machine can read a VIN from an ecu?
- Will a d16y7 coil fit an f22a4??
- Can someone please run a carfax for me asap********
- EG JDM audio console for sale!!! For RHD only
- Might get a `95 Civic (Q's for you)
- Worn clutch, 100K... Time to replace!
- 99 - 00 civic cd deck install
- HX Wheels
- Clutch problem.. please help..
- Does this look like a y8 head to you guys?
- Just got a B16a1 swap done
- Vtec problem!!
- Fake price on Bill of Sales
- Code 91????
- Please, I need you civic gods to help me out on this one...
- If you remove the AC on your car will the defrost for the front window still work?
- Could you use any knock sensor for b16a
- d16y8 head question.. Last que I promise!
- 96 HX head fit my d15b2?
- Neuspeed Race Vs. Eibach Sportlines on 95 civic
- Danget, got more d series ques! Help!
