View Full Version : Honda Civic / Del Sol (1992 - 2000)
- new to honda-tech
- JDM eg2 si project $6000
- need help with engine problem
- Mysterious symptoms<<stutter/bucking P0131 and P0132>>
- B16A Spraying Oil? NEED INSIGHT PLEASE!!
- Whats the news with Jdm motors in california?
- can anyone help me?
- Replacing my clock problem
- Compression test results
- civic brakes
- Help electrical!!
- FRUSTRATING PROBLEM!! TPS / THROTTLE BODY ISSUES
- heating problem
- automatic problem
- Will I benefit from D16Y8 head on D16Z6
- exhuast ?
- My can run rich.
- Throwing Code 12 Help
- Just bought 97 civic ex d16y8. need help!!
- How to take off dash?
- Help new honda owner!!spark issues!!!
- help! engine has scratching sound!
- will these wheels make my car slower?
- need help with a 96 civic and a d15 swap
- Question- Skunk 2 street struts
- idling and speedometer issue
- clutch for ~200hp
- power steering help
- Trying to track down my old EBP SI....
- will a del sol exhaust fit on a eg hatch?
- power steering Q's
- PFAB VS AutoWorks Vs Spoolin Manifold?
- D16/D17 turbo ???
- B20b vtec problems
- How to install 00 oem si front sway bar on 96 civic dx
- b20 header in a ej1?
- brake booster delete
- 99 Civic EX engine rebuild price.
- 99 Si (HELP)
- Anybody have a list of OEM color options for a 95 EX coupe?
- Speeo stuck at 20 MPH
- Skunk 2
- greasy alternator
- ws2 ?
- help w/ check engine light
- Starting up Again
- no brake pedal after all new brake system, please give me pointers!!!!!!!
- help to pass state ref smog
- Shops???
- Rear suspension swap into an 98 Civic HB
- b16a or ls vtec with b16 head
- 95 axle in a 96
- Tranny making noise???
- Will this work at all?
- 2000 ex starting problem
- Another auto trans issue!
- Anyone got a List of Injectors that fit into the Civic rail?
- bad caliper, warped rotor...can i only change the rotor and caliper?
- !990 infectors, is there a groomet in the intake maniforld?
- b16 head gasket?
- VSS connector question
- J's Racing
- 1995 Civic Si
- b18 header on a d series?
- Not getting any spark..
- question about plugs
- i need some help!!
- Eg sedan doors onto a hatch?
- brake pad clips
- stainless steel header questions
- Starting issues, maybe distributer?
- Oil change seem there was no oil in the filter
- Checking in like a good Noob
- can someone tell me how to change iac
- rear disc brake conversion?
- APEXi VAFC II Display Issue
- Throwout bearing going out?
- acura parts...where to find
- SPOON Engine?
- Car dies while driving
- d16 idle problem
- 99 civic si won't start...
- B16A Exhuast help please!
- head swap; car wont start
- ECU Code 15. Car wont start. SEARCHED!
- Sun Roof Question
- b20b wont start in eg
- b20b in eg cranks but wont start
- Engine Problems Need help ASAP D16y8
- knock knock, whos there?
- EG swap with K20 shifter linkage
- 99 SI cluster in my 93 EG *pics*
- del Sol power window control module - how do you get to it?
- GSR camshafts in a Si motor??
- anyone know a good wheel repair in western washington?
- mini me swap???!!
- I need my mounts installed!
- JDM B16a SiR II motor question
- B16 94 Civic swap question
- 1999 OBD2B D16Y7 Intake Manifold Setup onto 1996 OBD2A Y7
- ej1 project h23
- Whatcha think B20B motor for EM1
- 98 civic ex auto questions
- my honda`s aniversery
- Ek Passanger side trans mount help
- Code 21 Wont go away
- best intake for b18c5 swap?
- Stolen 92 Civic
- Missing jumper plug to check CEL.
- inconsistant idle
- del sol helpppppp please
- Timing belt question
- ECU help
- help what rims should i put on my blue em1
- backfire when racing.
- Type R steering wheel hexagon screws
- Front LCA/Tie bar help please
- ITR rear seats in a eg sedan?
- o2 sensor help!!
- Coolant, low idle problem EG
- Rear T Bracket for B16B in an EG?
- rough cold starts
- Cruising idle and vtec problems..
- delsol shake prob.
- Will a obd0 b16 cam rail work on obdI head
- Rear brake disc question
- buddy club exhaust. test pipe?
- Main relay is clicking
- aluminum radiator question
- How do i re pin the ecu?
- b18 swap with a b20 oil pan
- Cost of B-Series Swaps
- Brake splash guard question
- b20 bottem end or gsr
- Can a virgin P28 run a B20 Vtec?
- 14b turbo downpipe...?
- 92 Civic Cluster Speedo Question
- Timing and Mileage when Changing fluids and major maintenance
- Stolen car, New Ignition :/
- 94 Sol with a SOHC non-VTEC ZC runnin a P06 ecu - will not rev over 3500, any advice?
- b16a starter compatibility
- front end conversion
- What are these wires/plugs for?
- buying D15B7 block, things to look for
- toda b spec cams
- 99 civic SI - Need coilovers & want a header + test pipe + o2 sim
- 3 gear grind plzzz help..
- B series axles
- B swap motor mounts not lining up, worn/sagging?
- Failed CA smog
- Tape deck problems.
- Hi, owner of car says he doesn't use power steering, no ps fluid
- speedo is acting crazy
- 2000 si Overheating ISSUE HELP ASAP!!!
- Help! with CEL code 12
- Install AEM intake
- Clicking sound
- Replacing Amber Bulbs On My EG6 SiR Cluster HELP!
- need help!!!
- Stock 94 Honda Tape/ Raido Deck
- ive searched google, need to know where to buy honda mtf
- Turbo, LS, H2B?????? Im lost
- 92 civic dash problems
- question regarding thermostat
- cruise control problem, wtf??
- 99 civic Overheating Problem!!! NO Clue WHY
- EK CX A/C Install?
- speedo problems.
- hub adapters : 4x100 to 4x 114/ 5 x114 how safe are they / how do they work
- Flashing CEL light
- ek coupe struts on and eg hatch?
- Motor Mounts ?
- Installed Hondata 300J, now I got CEL 13 and CEL 16
- Has Pedal Is Hard
- help will integra 4 door back seats fit in my 2000 civic coupe
- trunk leak no trail
- Vtec Wiring P91 Ecu D16z6
- 94 Hatch no start
- EG 4 door rear disc swap
- lucas 80w 90 gear oil for a d16z6??
- Need help witha misfiring LS engine
- Vtec don't engage after accident
- i couldnt find it P2F-HA-1
- Mini me on which bottom end?
- 2000 em1 alternator/speed senser fuse
- my current build
- b16a dd build question
- Parking light bulb replacement????
- my ek9 just got rear ended
- Manual RAck in an EG???
- New project 98 hatch was never undercoated.What know?
- 98 hatch "3 wheels" when on jack stands.
- HELP! Car acting strange!
- 93 Del Sol B16A Fuel system noise...???
- LS swap issues/air fuel
- Brake lights staying on
- idle problem, can't find the answer
- help installing a tachometer
- del sol exhaust?
- tuunnee help!!!
- help how can i get leather seats in my ek coupe??
- ej with b20 swap??? HELP?
- 94 ex d16z6 crank no start
- 92 eg8 just got it
- Good place to find a swap....Searched
- Fusebox problem, quick question
- what seats are these?
- What is right price for 92-95 hatch si?
- Is bar sticker for b18 good for any b18?
- 1997 HX Intermittent rear wiper problem
- WTB: Front light including bulb, Fender, rims
- D15 Vtec Good idea or bad idea?
- Map,Dome light doesnt work?
- B20 Vtec question?
- erratic idle have done it all any help
- new guy needs help with a6/y8
- EG/LS Header?
- Anyone burn a little carbon after winter?
- o2 wiring issue (infamous code 41)
- D Series Head ?
- need help fuse15 keeps blowing out
- Which altenator do i get for JDM b16?
- B17? or no B17? that is the question.. your oipinions???
- Aerocatch locking hood latches... opinions?
- Ek Sir bumpers question
- Greetings
- 96 Civic EX Sedan: front driver-side squeaking
- 95 civic NEED HELP!!!!!!
- Motor lagging big time
- Feeling like a noob: vtec issues
- My first honda!
- exhaust compatibility
- 98 Civic Windows
- B16B CTR T bracket question
- info help ek sir
- Want to put AC in my 92 hatchback
- need help: Window installation
- B16a Head Help
- How good is a B18a1
- Domani/Gemini Questions??? Help please
- exhaust question
- help with windows
- Help! Almost done my B16A swap in 99 civic
- D16Z6 Timing Belt questions
- SCREW SIZE?
- looking for seat brackets for EK hatch
- Energy Suspension mount inserts question
- 00 civic lsvtec not starting!
