View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How do you remove complete power steering out of a Civic?
- what cat to use for b18c1 eg hatch?
- L3 SI Tranny
- Wide body?
- H22 engine?
- Cheap A/C?
- Front bumper sliced...
- EG FMIC piping same as EK piping?????
- quick question on high flow cat and emissions/inspections
- Where to buy top fuel bars?
- EK Interior
- How much to torque down bolts on tranny?
- **ADAPT A D-SERIE LINKAGE TO A B-SERIE**
- Need Some Help Please
- difference in ecu's
- where can i get this sticker?
- Help with turbo
- How do you tell if a ECU is Manual or Auto?
- Rear Disc Brakes
- will 200 pounds make a hugh difference in speed?
- ES tuning muffler
- Stock OBD1 P72 spec question
- Quick Tranny Fluid Question... SEARCH IS DOWN
- B16a1 Into '99 Civic DX, Possible?
- Code 43
- Hondas New Concept (Mugen V8)
- anyone ever heard of "axas suspension"
- Just got rear ended.. here are the pics.. need opinions.
- Need Help w/ Swap...
- Wires Cut and Harness Disconnected Under the Hood
- How to connect defroster wires to eg hatch glass
- something stuck around spark plug! help!
- gsr front strut bar on civic?
- Weird plastic piece in block
- If I take of the IACV to clean, is it going to leak stuff everywhere?
- Removing cat worth anything?
- battery question...
- Any GOOD dyno tuning shops in SCNJ?
- Anyone know what adapter or gasket seal fit DC header?
- clutch adjustment on d16y7
- Runnung extremely rich 99 ex help
- 92 Civic EG climate control/radio bezel
- search is down, quick question
- Z6 Intake Manifold - How to tell if it is....
- Throttle body cable...
- 98 CIVIC KEYLESS REMOTE PROGRAM
- VTEC and Speedometer not working.
- throttle body calbe.....
- Del Sol lip question?
- What makes a car back-fire?
- Where to Buy Auto To manual Mount?
- 92 dx 1.5... is this an interferance engine???
- my cluster
- Megan Underdrive pulley doesn't clear crankshaft fluctuaton sensor
- del sol weight
- injector resistor on d15b8??
- tps sensor
- hyrdrolock or water in engine?? How do you know!
- The dreaded "Check Engline Light"...catalytic converter???
- Brakes CRX Del Sol help
- HELP! Trunk light staying on all the time...
- motor swap or rebuild n go turbo?
- WHat is the rev limiter on teh PR4 ecu?
- S2k steering wheel
- SOHC ON a 50 shot n2o recommended fuel pressure
- HID retrofit
- auto to manual swap (what do i need?)
- exedy clutch on ebay
- How To Regloss CF HOOD?
- cf hood won't tighten/regloss
- Need help with suspension swap!!!!!!!!!!!!!!!
- tire size for 15X7 rim?
- ECU/wiring harness question for 97 civic dx
- Power steering question... Part 2
- FOUND: silver civic front bumper, some tires... (possibly stashed from a stolen car?)
- PROUD OF YOUR HONDA ? POST YOUR PICS HERE LET EM KNOW WHO'S THE BOSS
- NEW HERE NEED SOME HELP
- hey everyone
- Drag Racing suspension questions
- clicking noise when turning
- crank pulley problems?
- 92-95 Civic Interior
- JHPusa.com order
- Quick question on construction of OEM seats, namely Del Sol seats
- worn motor mounts?
- Would a 1996 Civic DX have cruise control?
- RSX dash in a 5th gen civic
- sum opinions..please
- jdm B16a2 and usdm sir 2000 compression test
- 99-00 Civic OEM Fog install,...I need help wiring them to light up when just parking lights are on,
- DEL SOL SHIFT LINKAGE
- Interior Conversion.. Viable? How much?
- probs with my cluster
- Looking for NEwer MOtor for 01 civic Lx
- B&M short shifter scraping
- Upper Control Arm castle nut thread size?
- Compression Test...how to?
- Any Experience With OBX Radiator Hoses?
- Flywheel opinions?
- Omnipower LCAs....., Anyone have them & are you happy with the product? Pics?
- Help me remember what to plug onto this
- Shifting Problems
- Flywheel locking tool??
- How do i get this shock off ????
- Help with lowering my 98 civic coupe ex 2 dr
- Thinking about air ride.
- Questions about residue on spark plugs... pics...
- Turn Signal???
- list of error code meanings
- fi e/m fuse keeps blowing
- Cluster Swap done!
- d15b8 question
- What are the gains on a JDM D15B 4-2-1 header?
- Fluctuating Idle RAWR!!!!
- has anyone plexiglassed or modified thier sunroof???
- little oil on sparkplug threads
- No start, 2000 civic
- Del Sol Power Steering on Swap
- HELP!@
- exhaust greddy vs apexi vs skunk2
- RS grill emblem?
- quick question
- How do I put the alternator on?
- opinions on OBX camshafts
- interested in pics of a german civic sedan?
- Looking for who owns Black Civic and Yellow Jetta in Clarksville, TN
- problem with d16z6 stalling
- 96JDM ITR 4 by 114 disk brake conversion into EK
- How much power can i make???
- Clutch or Tranny
- mini-me o2 problem
- GSR rack in EK?
- d16 tranny jumping?
- 95 CX (d15b8) headgasket choice... You must use the updated b8 HG!
- obd2 to obd 1 performance???
- Fidanza Lightweight Flywheels? Need Advice.
- JDM B16A Distrubitor Rotor Question
- fuel injector problem
- Clutch leaking...help please
- Cold weather / raining driving ( bad defroster ) HELP!!!!
- HIDs in procarparts black housing 92-95 civic headlights
- Tips for cutting out an intake manifold gasket?
- El Nino Effect in my Sols trunk?
- Which engine would u pic?
- Zex/Comp Cam Cheap Look inside...
- QUESTION ABOUT EMISSIONS
- difference
- it was running fine but now it is acting like it is out of gas
- I got own3d
- sitting uneven
- differences in 1st and 2nd gen b16 cams
- Coolant Fan Problem. Help!
- Is this what I should get?
- auto trans fluid
- Need Help!! Civic '97 Problem!
- Random misfire cylinder #1? Cold related?
- Hi-flow car for my 00 Civic coupe...
- How's the damage????
- b18c5 into a 94 ex auto
- P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage HELP!!
- Sub $900.00 Coilovers.
- Do you guys know what is weight of 00 SI wheels with stock tires?
- buzzing sound?
- 99/00 OEM fog light install in a 96
- anybody sellin 15" 16" black racing wheels for a 95 hb
- anybody know how to get the cd player out of 95 hb???
- Does anyone know how to put on a flywheel and clutch the rigth way?
- Something real weird... Please help.
- Window Visors JDM / Weathertech / other post pics.
- swap info from GSR to LS
- turbo or supercharger for my 99 si...and why...
- exhaust muffler inlet to piping question
- Quick question. Do you guys know what is weight of 00 SI with stock tires?
- convert an obd1 or obd2 distributor to obd0?
- d2 coilovers?
- '97 Civic DX - Idle/Acceleration Noise
- abs light
- how low should i go?
- Worse fuel economy than my Saturn...
- electric circuit for civic 1992 cx
- Will an ITR shifter work in a 98 civic?
- BG syncro-shift II
- temp gauge on cluster does not go up
- duplicolor wheel paint
- cant get mah new motor started
- JDM EG REAR SEATS
- weight difference EG6 Vs. EK9
- Super Sprint 4-2-1 header
- 96 EK hatch with 98 ITR motor, which p/s and a/c brackets?
- Omni front camber kit users! allen bolts ? - 98 civic
- Brake Pads DX & EX Same?
- EX doors on an Si
- IDLE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- A very sad history... Please help me...
- *** Stolen 2000 Civic - San Diego, CA ***
- Broke the hood
- Looking to turbocharge D15B2
- idling and driving problems on 99 ex
- what hid kit to get with JDM eg headlights? the h4h lights?
- fit in HATCH?
- can a gsr cluster fit in an EG
- 2 Codes after Going boost
- Whats the stock redline for the PR4 ecu?
- ALARM REMOTE
- I need help Minnesota Guys?
- Welded cat...? test pipe problem
- what are the gains of putting y8 intake manifold on d16z6?
- Need opinions for my 98 civic lx
- Skunk 2 mani for D16Y8 any good?
- Brake booster w/ master cylinder, options
- Del Sol Clutch
- My 2000 SI
- Can u put power steering in a hatchback that didn't come with it?
- harwood39's life agenda!
- my car is throwing a code 15(Ignition output signal)
- How bad is a hairline crack in exhaust manifold?
- How do i remove OEM non airbag steering wheel 94 civic?
- which is better?e-manage or buddy club spec A racing computer or apexi VAFC2?
- Rear speaker an option in 92?
- 94 ls vtec in a 94 civic is it worth it? fb
- Just bought Yonaka seats...
- 95 civic EX Headkne
- Deep sounding resonator???
- will a dcsport4-1 96-00 civic ex header fit on a dx 96-00
- LS SWAP: How to do it?
- Can anyone show me a picture of this?
- What part is this?
- Can someone identify these Si motor mounts? What else do i need for a B-Series Swap into EK
- I need some OEM part numbers.... EG hatch!!... Anyone ???
- who has an autometer air/fuel gauge? (hookup question)
- *new member* carpet install questions
- high revving when the engine is cold...
- dx > ex cluster, check engine light?
- Need help Removing rear bumper... Trunk won't open!
- civic eg b18c cat converter?
- Exhaust question about EG Hatches
- Buddy Club seats
- EG CIVIC B18C1 CAT CONVERTER QUESTION
- 92-95 civic hatchback B18B1 swap HELP
- RS*R Mag, Greddy SP2, Apex WS
- JDM SIR EG cluster question...
- jdm blue eg windows?
- 0.20 over bore question
- second battery
- gas gauge broke..
- Is this a PCV?
- Reset ECU after CEL without fixing problem
- Does a d16z6 head bolt on to a d15z1?
