View Full Version : Honda Civic / Del Sol (1992 - 2000)
- '92 B18 Swapped CX.
- Question On Honda Motors?
- Mono hub horn issues
- Is this a good deal for this EG?
- Buddyclub spec 2 exhaust fits del sol's???
- B16A2 Rebuild help
- ls vtec, ctr head or itr head
- Please help im stumped!! really bad.
- Importing civic typr-r... NEED HELP!
- Mini me question
- CTR Front Emblem Placement
- b20 swap question!!!!
- eg civic hatch engine swap?
- 98 Civic Sparked but wont now
- Need help with taking off windshield / the adhensive thats on the windshield !!!
- new del sol owner here
- adjustable cams gears b20v
- What is a b18h5 block???
- will a 95 civic si trans fit a 96-00 motor?
- Ideas For EK Lower Console Area
- Suspension Question
- need help! speedometer and odometer issue...
- RSX Seats In An EM1
- distributor question
- Vtec ecu help
- Throwing crazy CEL Codes..Help
- oil in tranny!!!!!!!!!!!!
- P7J bracket wont bolt directly to a b18b LS block
- 99-00 JRSC install pics needed
- witch setup should i to go with??d16z6
- 90 civic steering wheel on ej1?
- question about gauges
- Swapping SI Tranny! HELP! (EG)
- low beams wont come on but hig beams do
- MY EM1 project
- Wanting to put 99-00 rear bumper on 97, does it fit?
- 92 hatch h22a4 swap axle problem
- how much would you pay for my car?
- 93 Si rear hatch lift support?
- Clutch Problems????
- Recommend me a high flow cat please!
- Where are these bushings at....tranny shifter stabilizer?
- Weird Shaking
- OK to drive without a motor mount?
- cup holders??
- NRG QUICK RELEASE ON A TYPE R STEERING WHEEL
- New To honda tech
- Mugen Showa 5-way susp. versus Koni/GC
- my wheel and brake rotor do not turn as one. what is the problem? please help
- Cold Air Intake Vs Password JDM Power Chamber
- What Intake Manifold Should I Get For My B16a2
- Stock ride hight '99 Ex sedan, +1 rims tire wear
- Hot as Hell outside and Temp guage
- Pic Request: From a Japanese-made 1996 or 1997 4dr Civic Sedan
- Homemade Intake
- Konig Rewinds
- Y8 Auto tranny removal?**UPDATED**
- obd 2 motor in obd1 car
- tranny expert please!
- CEL 22 VTEC Pressure Valve: Help Me Please
- Headlight Help
- 94 Civic dx clock problem..
- gas pedal question high idle
- 95 Civic CX ignition help!
- B18C GSR or B16B CTR
- what hasport mount kit is this
- ac still not running after installing a new condenser fan
- Question about B18b in eg
- D15b8 number match up q:
- Confused On CEL code..
- rpm tach is crazy
- 98 four door wont start help
- NEWB lookin for starting place
- Macco
- info on buying a new dizzy
- will dss axles of an eg work on an ek with k swap??
- ecu problem...need help asap
- Cam Cap question????????
- went through a puddle..
- d16y8 preformance upgrade questions
- HELP radiator fluid
- wheel clunks back and forth after hitting rock and denting rim
- HELP! Civic 99 Front on a DEL SOL
- Won't start, main relay clicks while turning over
- My 98 milano EX build
- Heating Issues
- What is the simplest way to tweak a timing belt on a 1.5..
- need help on mini me swap
- jdm b18c into 97 ek
- How hard is it to take out a dash in a 96-00
- What would kill a battery over the course of the weekend?
- GSP or Cardone Axle?
- oem tachometer swap?
- 1995 Del Sol S Build Thread
- 97 civic ex problems
- jdm p30 ecu vtec crossover
- new engine install running rich, engine light ?!
- ek9 ctr mirrors new evolution or something HELP.
- Blown head gasket...now what?
- 00 ek sedan overheating?
- Idle hunting & ECU CEL code #14-IACV
- EG Build *Help*
- NEED HELP ASAP
- b20b into an del sol??? wiring help////
- which tranny is better for boost k20a2 or k20a3
- lowered my civic but it sits up high in the rear
- y8 distributor on z6
- 99-00 civic coupe/sedan grills interchangeable?
- dash swap cluster ****
- H22a4 conversion
- Koni yellow/Ground Control setup Vs. Skunk2s combo
- my speedometer.
- power window module????
- cranks but no start.....AGAIN
- 1998 civic cooling fan
- quick q: will eg intake fit ek? for cx/dx
- civic running hot at idle...???
- looking for pistons, D-series
- what size are these wheels?
- cat question
- 1998 b20 swap wont start!
- D16 non-VTEC to D16 VTEC, Need new Trany What Trans is Best
- 95 civic wont start
- my car
- ek motor mount ?s on a b-sawp
- B20B in 95 civic coolant issues
- fish and civics
- D16z6 aem intake photo
- Muffler suggestions for stock piping
- Losing Top End Power ??
- b18C swap into EK question ASAP
- rebuilding D16y8 shortblock with z6 PARTS Quick help
- Jdm ecu vtec engage?
- Current car (with pics)
- jdm b18c gsr swap/wiring
- need a little help
- vtec pressure switch???
- running too rich?
- Probelms with 99 civic si. fuel maybe?
- Car is overheating daily help!
- Crazy idle problem...
- good deal?
- electrical helll, please help!
- EK Civic- K20 swap, or B18c5?
- I wrapped my car... EK hatch.
- Stock Fuel Injectors
- '96 DX needs new struts/springs/mounts
- Camber Kits
- Body shops??
- Radiator trouble
- D16Z6 with a cough . help please
- O2 sensor fault.
- b16 and b18 parts switchable???
- Dohc ZC Swap idle Issue
- hatch and window tint removal
- 00 Headlights
- TEIN LOWERING SPRINGS
- Fuel Injector Help
- SRS and Radio issues. Short?
- vtec setting help
- IAC valve wiring
- Civic EM1 idle issue
- state ref locations?
- Click here if you have a D-series with A/C
- Speedometer not working
- Speedometer works occassionally on my 00 Si (keeps cutting on and off)
- Do I need a resitor box?
- Y8 intake mani question
- Valve Chatter??? how to adjust?
- HX Specific Question
- Is This Normal??
- C32A Type II in a Ek chassis???
- problem with installing ek4 rear seats
- EK Coupe-Picture Request
- Everything I need to lower my car?
- what is this part of interior called and where can i find it
- minor problem
- jdm del sol front bumer
- ek hatch bumper ?
- help help??
- TB motorworx
- Easiest way to get LSD tranny?
- what wheels are these?????????????
- What do use for this V - Dub turbo?
- Sound Deadening??
- B18C1 bottom with USDM Type R head
- Which AC bracket for EK B-series Swap?
- motor build... would like advice
- Full size rad into ek
- Quick question
- Cluster went out!!
- D16Y8 clutch going out
- Do Manuals have a FITV?
- power/speed just cuts off at 80/90mph
- What should I do next??
- Dash swap and the cops
- Need Info On Exhaust
- is this all for steering wheel swap
- eg6 parts.
- advice
- need help to install ek foglight???
- p28 vs p72 help !
- How should I test my gas gauge to see if it works or not?
- Exterior side panel rubber thing.
- What is needed for SIR bumper conversion on 98
- New Bys Rear Wing?
- OEM parts site?
- Possible to retain cruise control with EK9 steering wheel?
- benen b pillar bar help
- Interior lighting part #'s plz ('00 ej6)
- d-series log??????
- 82mm (81mm, .040 oversized) piston rings?
- LS ina EK hatch
- radiator fan necessary?
- I'm looking for specific d16y7 motor build info...
- where can i get intermediate shaft
- Performing some more mods and finishing up a few things
- How Much Build Could $1200 Get Me?
- y7 muffler fit stock '00 civic?
- 2000SI Wiring Issues?
- LS motor, need help deciding where to go with it.
- LS/Vtec Help
- 2000 Civic Sedan, DX and LX DIFFERENCES.
- Guages in Radio DIN on 96-98 EK
- Need wiring help with b16a2 in 95 del sol
- Exhaust Help!! Pealse state police are @$$
- 96-98 front to 99-00
- B16A o2 wire help
- coilovers/shocks setup
- Clutch/Brake Pedal Lock kit
- how to remove
- B16a Power
- How much could I get for my civic?
- Any of you had your car painted?
- Rear seats for 1998 EK Coupe
- i need opinions EH2 swap or boost?
- sri tube with stock airbox
- MOMO steering wheel? Will airbag work if i install a SRS wheel back on
- Dtc p1298 what can be wrong
- gears starting to grind
- how to install coilovers?
- Weird Problem
- EG Driver Side Speaker Question
- first car
- need help
- 94 eg coupe (Car wont go into gear!) help not sure what it is
- HELP 96 civic si d16y8 KNOCKING AFTER crankshaft pulley failed
- rpm gague does not work
- 'high end tri-Y headers' by LogicMotorsports.com problems
- EM1 restoration project
