View Full Version : Honda Civic / Del Sol (1992 - 2000)
- quick torque wrench question (changing spark plugs)
- Flywheel resurface
- B16A problems...
- Installing vafc 2.Need help with wiring...
- shift linkage or tranny?
- 92 hatch with ls vtec swap. oil pressure help
- clutch problems need help!!!
- is my EG chocking with a hairball? pics..
- eg coupe wing
- Benen rear tow hook question
- HELP!! CRANKS BUT WONT START, FUEL AND SPARK ARE GOOD!! CEL COMES ON AND GOES OFF.
- Help i have a zc Itakemanifold and dont know what gasket to get!!!
- 1998 civic ex oil pressure light coming on intermintly while stopping
- will i blow my motor?
- ECU
- Rpm gauge wont work
- can people tell me what i should do next to my car looks wise thanks
- 99' 4D - Exhaust/Headers? Which would you get?
- legal advice needed maybe sueing my engine builder..
- Need x1 Inza Red Painted Driver Side Fender for 99' 4D with Side Markers.
- ??????? 99-00 Si complete front suspension into a Del Sol?
- Puddle in the sol
- New here...
- how can u tell real SI rims from knock offs?
- ? for people who know exhausts
- Benefits of JDM Type-R Cams in a 99 Si B16A2????
- is my car slow !!
- A Power Steering Mess Up.
- carpet / tracking device
- Tri-Y headers toughing Trani housing... should I be concerned???
- f*cking pissed!
- RPM Activated Switch??
- eg fog lamps installation
- Lower control arm
- Engine Harness Plug Pins?
- car runs fine but not popin vtec please help!!!!
- aloha everyone!! first post and need help already. starting problems on 92 civic
- B&M short shifter question tread pitch 1.25 or 1.50?
- gs-r cams vs b16 cams
- Took me 2 years, but at last. My Pride and Joy!
- D16Y8 mme question, *searched extensively*
- Tranny bolts
- CEL code?
- Unusual overheating
- Tranny Problem
- trunk question
- Key wont stay in ON position while driving
- car wont start. push start runs fine
- B16 swap Harness question
- help with a b16 in a obd2a. iat sensor problem
- Steering wheel Inquiry......
- tunning, looking for a tuning shop that offers Neptune RTP in southern california
- Del Sol Lip VS EG Lip
- code 10?????????
- let's see your JDM eg's
- Distributor busted?
- ls/vtec with jackson racing supercharger
- 92-95 hatch and 96-00 hatch exhuast interchangeable?
- JDM Sir cluster brightness questions (eg6 - searched)
- help..help... ek cf hood
- Gas mileage of a turbo-d
- does anyone make a hydro to cable conversion for trans
- Whats the yellow sealant on my brake lines to proportioning valve?
- Sunburn windshield
- ITR 5 Lug swap on 00 Civic Si,soft pedal with that goes to floor??
- tryed to search had no luck
- Projector headlights
- HOW MUCH WOULD VALVE JOB RANGE FROM
- Increase D16Z6 displacement
- euro tail lights?!?! no question, just want opinions.
- Suspension problem. please help
- one prob to the next
- i need some help!
- noob question
- Speedo not working/CEL on my 99 Coupe.
- So I got rear ended..
- Headlight problem
- What IACV?
- B16 swap
- RHD Conversion in EJ1
- 2000 Civic wheel alignment specs
- valves still noisy after adjustment
- Bubbles in coolant overflow, no coolant loss does it mean the head gasket is going?
- Dizzy Help
- just bought a cf hood good deal?
- i searched and found nothing
- test pipe-cat?
- need help dome light
- professional wire harness job pricing?
- drivers side window giving me problems.
- type r steering wheel?
- TBI (Throttle Body Injected) Civic?
- New and introducing myself
- EG CROSSMEMBER IN EK
- Help! ITR Knob question
- ls vtec
- 92-95 corner light fitment issue..
- lets play guess the code
- can't get bolt out?
- ebay exhaust?
- question about some springs
- Tranny Removal
- Cooling fan will not come on, switch is not bad, relay is not bad.
- Skunk2 coilover, shocks?
- WIRING HELP...ANYONE!!! H22A4 INTO 95 EG! PLEASE HELP
- How Do i swap out my ignition switch?
- D16Y5 in 94 Civic, which distributor?
- Brake Lights?
- e85 conversion, is it worth it?
- H22a plastic shifter?
- manual window help!!
- Is this the best place to pick up a sideview mirror?
- Body Parts Question: OEM vs Aftermarket
- How to adjust rear brakes 2000 Civic
- Rear Wheel Bearing 2000 Civic
- Axle Issues - H22 in Ej6
- Emission/Idle/MPG Problems
- Is there such thing as a 96-2000 civic hatch ex?
- NEED HELP!!
- Broken Lug Nut Studs
- Headed to tokyo tommorrow!!!!!!
- My D16Y8 keeps on stalling coming to stop or pressing on the clutch pedal.
- Is this true???????????
- EG Measurements Pls Pls Pls Help!!!!
- Sensors, wiring and gauges (HELP!)
- do wheel boots work??
- some questions for civic MB
- (Z6) Weird rattling/jumping sound coming from...
- 1994 eg hatch si (salvage title) "new owner" Thanks again man!
- Need information about D16 B VTEC series..
- looking for a good engine
- Help, Advice please!!!
- vtec diagnosis help d16z6
- Bogging issue (yet another thread of my car bogging)
- IAVC noob question
- b18a1, b16 vtec.
- NEED help with B16A2 Build
- LS/VTEC Tapped Head Question
- Steering wheel question
- Tailight water leak EK OWNERS HELP!
- Rear T Bracket Question
- help - power loss while driving for a sec.
- Si 2008 seats in my Del Sol ?
- need help car turns off when im on a stop light!!!!
- 1999 honda civic si
- Where to find A/C lines.....?
- 1992 Civic LX 4-Door Gauge Cluster/Climate Control backlight not working (my dd)
- car shut off
- WTB: Stock 2000 si exhaust.
- intake swap question
- AC bracket question EK with b series swap
- 94 a/c system into a 92
- ep3 seats in a ek.
- k20 swap 96-00
- head gasket tips?
- Bought new 92 DX Hatch with Z6, Jackson Racing S/C and wiring nightmare!!!
- exhaust for sohc?
- From Maunual to Power Steering swap 97 Hatch
- Before I replace my cat P0420 code.
- AEM Fuel Rail leaking...
- tach jumping , new distributor, same problem??
- eBay head gasket and bolt sets?
- Problem with engine bogging down
- POST your ,tan,off white or crembrulay eggs
- b18b swap
- Idling problems B16A???????
- 1994 dx 4 door swap (help)
- help wiring my car.
- Ac/heat noise
- How to pull codes on swapped civic
- How do you tell difference in auto and stick ecu?
- d16y8 intake manifold diagram PLEASE HELP with plumbing
- DC2 = EG6 latch cable?
- ebay fogs switch wiring diagram
- just got my first honda...
- GSR Leathers in 95 EG Coupe
- Best wheels
- driver's side sits lower
- EK9/EM1 wont start, distributor? timing?
- just got 92 si
- OEM suspension options for a 2000 Hatch
- diagram for obd2a to obd2b distributor conversion
- Stalling / Starting Problems
- tie rod problem
- oem integra b pipe fitment on a civic
- ***Official FS/WTB/WTT Thread*** (Read the rules before posting)
- Stumped. . .
- del sol foglights....help
- after valve adjusment Loud knocking noise with oil leak? (video included)
- exhaust help RASPelstiltskin
- Convert automatic ecu to manual?
- 1997 civic ex air tube under air filter box
- What's the cheapest place for AEM V2 Cold Air Intake System?
- what kind of ARC is best for my EK????
- 97 CIVIC brake conversion SI
- DIY Ek Maps Lights In Your Del Sol
- idle on start up question
- identify this sensor
- Need help with running vtec...
- Bluish-white smoke
- OEM carbon fiber bumper???
- question> Rack & Pinion
- need complet rear eg interior asap trade for z bar kit
- help with stock wheel specs!!
- 99 honda civic bucks
- just got my transmission in and having a little problem downshifting to 2nd.
- what color on this eg?
- *** CAR STOLEN *** MS
- Need help with a ECU
- CTR Swap Questions
- driver side mount?
- ARC parts for EG Coupe!
- ECU help. P07 on D15b8
- Oil Consumption Problems?!?! is this normal?!?!
- Has any body replace A 99 Integra ls rear caliper dust boot???
- 12.1 compression
- parts i need to do a ls swap in a 97 civic
- Turning/vibration issue
- Is this AEM for a eg?
- Side Skirts and stock exhaust
- 2000 Civic EX "Re"Build Thread
- Just got my new wheels!
- Will this swap work?
- Need Some Help
- Cleaning your IACV
- gague wiring for door panel wires
- B20A5 in a 96 dx?
- quick smoke question
- 99 SI acceleration problems
- WTF Rear caliper rebuild
- Im new to Honda cars, how to adjust the idle??? pls help.
- few questions
- What civic exaust will fit a del sol si
- Ls/Vtec
- Labjunkies?
- Whats the use of the bottom red light on ek tailight
- PITA non typical or beginner charging system problems.
- GReddy Turbo in an 00' EX?
- Intermidiate shaft ?'s
- Weird idle problem
- need help with smog!!!
- 2000 Civic EX just acquired, need tuning options
- Please Help IAC
- what else???
- jdm hood tilt on a turbod ej8
- broken bolt. (welded)
- Which motor should I upgrade to>
- intro
- steering lock issue.
- Does anybody have a stock 95 honda front bumper up for grabs?
