View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Brakes locking up?
- the b16a2 tranny
- Help me solve this problem...
- How to adjust idle screw?
- 2000 Si - Got stuck because couldn't shift into any gear...
- clutch or master slave
- Disc Brake Conversion Question !!HELP!!
- electrical short? help plz
- does anyone know where i can get the rear lip for a civic coupe 1997 2dr
- car idles but chokes out when accelerator pressed
- maybe ECU problems
- Which ECU Dastek or hondata ?
- need opinion on my setup......
- Want to put SI motor
- 90 integra or 92 hatch
- SRS light is permanently on and fluctuating revs on the engine
- Any one have a pic of a 99 civic si cat back??
- What Oil?
- 96-98 civic 4dr red clear LED taillight?
- Alarm Issue for 93 Del sol
- without the throttle cable.can i still star the car?
- Cold Air Intake on a stock '95 civic?
- who has OEM full rear quarter panels replaced? 1/4 panel rust rusted
- 94 civic ex overheating?
- 10 , 12 , 14 gauge wires? whats the difference and which one do i need?
- LSvtec build
- compression numbers :(
- b16a2 mounts?
- need help I dont think my motor should be running like a boat....
- HELP
- how to add ac on my 94 dx
- Ack removed the tranny without taking off the shift linkage and the linkage came out of the hangar!
- bad idea???
- will 2/3 door front end body parts fit on 4 door?
- dx harness into an ex car. NEED HELP ASAP
- Throttle plate getting stuck during a bump maybe?
- ac belt question
- THEORIES OF PAINTING BLOCK.WHO MAKES BEST BLOCK GAURD?
- Throwing a code 13....
- 98 civic lx si conversion
- a/c doesn't seem as cold
- New stearing wheel
- How long does it take you guys to take off your intake manifold?
- z6 dizzy question
- --> HeLp! <-- not sure if engine is cooling...
- Sorry guy's my last resort ( User Question )
- Remus exhaust
- do i need a resistor box * i did search*
- Should I re-use my piston rings?
- usdm b16 b20
- Post pics
- Best ways to patch up a Sol seat?
- boost gauage wiring
- Question Installing FogLight
- h22 si question
- ont know how to use this... but im looking for sum BRIDE seats FOR MY BOYFRIEND...
- Quick question.. Redline/rev limiter on a b16a2
- SI RIMS
- buffed my headlights, now there are water marks.
- ebay radiators?
- using distributor obd2 on obd1 ecu???
- water methanol and N/A engine
- is the VSS in a d-series trans removeable?
- 93 vx d15z1 to a jdm d15b
- Car starting issue
- Idling problem!
- will a 92-95 sohc EX exhaust fit on a 2000 dohc SI?
- can someone help me with these bolts? which ones are tranny/rear mount bolts.
- how do i remove the door panel?
- Problems Idling...
- new car
- z6 piston toss up
- Throttle Body
- SS Lines
- TURBO SET UP FOR MY EM1.....
- H22 into a 94 civic coupe.. Ebay engine mounts????
- vss wiring question
- Fuse box from Integra into civic
- TA: Pin Stripe Removal.
- AEM V2 air intake
- ecm help
- B18 swap finished: Low idle, and "sucking" noise from TB.
- HELP! Car Engine Shuts off
- Replacing Inner & Outer Tie Rods - what should be replaced on steering gearbox
- antifreeze disappearing d16z6
- Bad Idle, help please!!!
- Fully built b18 b16 ls/vtec
- what controls the ac compressor
- Fuse - Instrument panel lights
- where do this plug to???
- A/C compressor oil thing??
- Window power problem
- air conditioning question
- jackson thermostat availability ?
- Civic stopped running
- Chrome?
- Bad Battery causes no start?
- Overheating
- Will Del Sol Rims fit an 96-00 EX?
- I WATER STEAM CLEANED MY ENGINE AND HYDROLOCKED *VIDEOS*
- 1st gen B16A going in an EK, what throttle cable & bracket do I need?
- VTEC Wiring help, picture enclosed
- mugen fan switch query ?
- ECU trouble
- oil pressure regulator
- oil catch can installation???
- D14A3 Stronger pistons and connection rods
- looking for a good and trusted mechanic for increasing HP for my honda in Palo Alto, CA area
- Does front lower H brace bar really help a lot in handling/coring?
- Shop manual
- b16 eg a/c problem
- ITR pistons on Ebay?
- b16 and gsr head parts interchangable
- Civic HX CVT - Lifespan?
- EG Rust in wheel well
- Cleaning a K20A3?
- THANK YOU!!!
- DIY: 00 civic ek oem fog install
- WTF U-FIX-IT Honda gone?
- Junkyard Turbo Encounters?
- which wire into cluster is the VSS
- VERY hard decsion . i really need opinions
- Whats the difference between Vtec and Vtech?????????????
- i need help with the belt tension on a k20
- b16 header
- How to tell type r oil pump from other DOHC oil pumps?
- causes of blow by????help me
- Side skirts, cant be that much...
- D16Y8 turbo questions
- I NEED SOME HELP... ON A 1995 CIVIC COUPE
- b16a swap
- clock issue
- s2000 question
- EVO 1 exhaust
- Is this complete to do a PW Conversion?
- [HOW TO] - Adjust the hight on your non adjustable steering wheel.
- d15b swap in a 96 dx ???
- LS1 in a 96 Hatch
- my supersonic blue ej9
- important question
- How To: Rewire Your Del Sol Aux. Lights (Pics!)
- A/T P28 ..converting to M/T... any suggestions?
- turbo help
- timing belt coming off
- VTEC solenoid?
- 1996 EX civic oil burn
- Car Dies While Driving
- has anyone put HID's in eg9 weaksauce amber fog lights?
- LED Spoiler Brake light needed
- Alternator HELP!!!
- Drain and refill tranny fluid
- 97 dx with gsr, problem with throttle
- Question About SiR Bumpers For My EK
- No heat or AC from my vents.....del sol
- Dizzy problems...searched...only happens when damp or humid but lately its just been doing it...i'm
- Honda del Sol headlamps
- Reverse lights doesn't work!
- Help water pump out?
- HELP! NEED TO KNOW ASAP!!!!!!!!!!
- D16Y8 Tranny question
- itr controll arms in ek
- Does anyone have an unmolested Civic VX?
- DRIVER WINDOW wont roll up correctly
- si rims
- WHAT IS THIS? PIC!!!
- WTF THIS IS SO GAY!!!!
- b18b in hatch
- help with CEL CODE ,1, 61, 67.
- Quick p/s to manual question!
- WOULD IT FIT???????????????????
- EJ6 wont shift out of park, brake lights no longer work, wtf?
- would the ac lines from the del sol work in 92-95 civic hatch?
- ls cluster (help)
- i have white smoke at high rpm most likely burning coolant
- exhust
- integra k20 1/4 mile question?
- Pics Request. Civic's on Eibach Pro Kit.
- Looking for a Driver
- are 96 dx and ex ecu pinouts the same? other than v-tec?
- 2 bolts to secure the ac compressor, strong enough?
- Vtec not kicking in evertime?!?!?!
- car accident...engine won't start anymore
- civic dash light problem
- del Sol won't start
- 98 civic hx
- D16 Turbo Over Heating
- Alternator
- WHERE to buy a new or Quality rebuilt B-series Transmission?
- Window wont close
- D16Y7 A/C Install
- built civic power question
- msd help
- where do u install the free-on on H or L ???
- Is A Si Catalytic Converter The Same As A EX One?
- will tein s-tech be ok with stock shocks on 96 civic ex??
- Injectors not working?
- 2002 seat rails bolt instead of ej8 rails?
- Torque specs for B18c1
- Will it work?
- car only runs on 3 cylinders? dsm injector wiring w/ inline resistors?
- I Have a Problem
- Oh no I broke my 97 Civic!
- Please help - recently scammed
- b18c gsr cams any better then b16a jdm 2nd gen cams.. help (did the search)
- Axle Shaft replacement: Which brand?
- window keeps coming off track
- GSR Seats into EK.. lol
- Stripped Fuel Rail Nut
- Do I have an LS Tranny.
- D15B and AC Compressor question..
- Hi, guys. i am looking for a 5 speed whirt 99-00 civic HB
- Help!!! Noobie question
- my next mod
- Putting AC back in....searched
- idle is bouncing whenever it feels like
- center console question
- Newbie from UK, Some pics of my car (eg Hatch)
- Newbie from Spain
- Ac stopped working.....
- throttle body cable???
- Leak on passenger side.
- help brake problem em1
- Putting 93 Del Sol seats in a 94 Civic Hatch
- Quick tail light question...
- Is stock LS oil pump good enough for LS vtec? Or b16?
- gsr or si
- Sunroof Window Flew Replaced now Wont close??
- removing headers question
- Tire Sizes
- should i get b20vtec tuned or is it ok w/o it?
- D2 Coilovers ...vs...Function&Form Type2?????
- No clue of what type of motor I have
- bang for your buck?
- Blinker Problem
- how to take a c/v joint off?
- any tips on how to make a single V faster???
- help with dash removal
- Type-r rear spoiler
- wut should i do
- how to change shifter bushings?
- Whats the performance data on a B16A Del SOL
- keyless entry fcc id question
- Starting Problems, Please Help!
- New comer.
- ignition issue
- Noob
- vtec and vtecE
- TPS - Code Seven - Replace 3x in last year - Searched
- Changed Alternator and Battery Twice, Car still dies!!! No Recharge? HELP
- SI Harness w/ B16A2 into a 97 DX Hatch Help
