View Full Version : Honda Civic / Del Sol (1992 - 2000)
- up and down idle 95 d15b7 cel 41 after timingbelt/headgasket/waterpump change
- Where is fuel pump fuse located???
- #2 Cylinder dead. Found out why. What would cause this to happen?
- 94 Honda Civic EX overheating
- b20 in eg Cold start issues
- My EG Build
- Motor Setup Decisions for a B18B1
- Back Drum Brakes to Disc Brakes -96 Civic
- Is my ecu/main relay bad?
- OEM IAC or OE IAC and other questions???
- 95 civic d15/y8 head. weird noise when idle but stops when clutch is in?? HELP
- what hose goes here on the back of the gsr block?
- Need help with rear disk conversion..pls help!
- AIR CONDITIONING
- B16 idle question
- Overheating?
- Questions about sir ek4 front disc/gsr rear disc brake swap into 99 civic dx
- B20 vtec lost power to fuel pump and no spark.
- is having my car too low bad for shocks?
- firewall grommets
- o2 heater circuit is off and a/f ratio high
- 2000 ek hatch - when i hit brakes the turn signals and parking lights wont turn on
- Help! Put in cd player and cluster and fog lights went out!
- EVAP Monitor Not Ready
- radiator overflow tank question..
- 95 Ls Hatch Turn signal problem
- Harmonic balancer bolt help
- 93 civic startup problem
- B16A2 injectors wont fire
- h23 Swap help Obd2b into obd2a
- New guy! 93 civic hatch single cam v rpms bounce at idle
- Ek9 fitment traction bar
- Coupe axle back vs Hb 1996-00
- Fuel vapor return line is rotten.
- questions about seat conversions?
- CEL Code #15
- LS/VTEC or Turbo?
- B16A2 Timing Belt?
- Replacing front brakes in 98 LX - need advice on choosing pads and rotors
- Z6 Build, Need Advice
- Most common tranny fluid for a 5speed?
- Fresh engine build starts, runs rough, stalls, and kicks backward 1/2 revolution
- where can i buy Skunk 2 lower control arm bushings?
- gsr smoking....whats new
- What does the secondary hO2 sensor do?
- 94 del sol fuel pump only comes on when its warm
- d15 high compression / turbo.??? helppp!
- 94 Si hatch/JDM GSR engine/USDM P72 ECU -- Confounded Tach Problem
- Oil leak from head gasket near oil dipstick?
- 98 civic ex back up lights is not working.
- machine shop questions d16y7
- 95 Del Sol rattle @2200 rpm
- help with camshaft choice for d16z6 -- which is best (see list)?
- My 1995 civic sedan build thread
- [Pics] Oil Leaking Through Axle Hole.
- cam gear question
- Need help, rpm needle bounces around
- B16a1 - Need help with part number for crankshaft gear compatible with CKF sensor
- H22 civic misfire (LIKE CRAZY)
- b18b1 bogs and sputters
- 93 CX Hatch - GSR swap, engine lost power when CEL came on, VTEC non-op
- D16Y8 Manifold
- Hunting Idle After ECU Reset?
- Buddy Club seats help!
- Missing radio knob on 92 VX hatch!
- What shifter sits further back towards the driver ?
- Dizzy Frankenstien problems
- humming noise from head B16A 2ND GEN need some help
- 5 Lug Conversion ?
- 2000 Civic EX knock sensor issue
- Looking for a EG6 left back window
- D16 Built to BOOST Parts List
- NEED HELP FINDING A GSR VTEC SILONOID
- Timing belt keepers?
- D16Z6, theaded holes under oil filter
- ls swap into eg, what linkage to use?
- RC 440cc injectors on b18b1 help????
- Skunk2 alpha b series header
- Quick ? about OBD 1 car with OBD 2 Motor
- 99 auto trand to a 96 auto
- 92 civic starting problems
- oil pan gasket being a bitch
- will 96-00 civic front lca fit onto 92-95 civic??
- obd2 engine, obd1 harness ???
- 92 VX HB missing rear speaker wiring?
- cant Align 95 civic ex
- timing belt, while doing a headgasket....?
- motor bogs when giving gas
- Is this twin loop made for an EG Hatch?
- Will golden eagle 81mm head gasket work on 81.5mm bore
- 96 Civic, Brake lights interfere with signals lights.
- how can i tell if function and form type 1s are fake?
- Replacing vtec solenoid gasket 94 civic ex, part number question.
- em1 shifter has vibration with a grinding noise
- 93 eg si sunroof tilt issue
- replacing 1997 civic cx engine with 99 civic ex engine
- d16y7 head replace
- Video! Help - Power loss in higher RPM + Sputtering sound
- 98 civic overheating
- 99 honda civic steering problem
- Tire Size
- e-brake not working. cables move, brakes work
- 93 Delsol exhaust bending/length specs
- 98 Civic rear disc brake conversion part list
- Driver side making a ringing noise from wheel
- DIY: 92-95 Civic Saggy Front Bumper Fix
- B16B valve cover gasket question
- 94 civic speedometer
- 1997 Civic SI: Jerky throttle and IACV CEL
- Del Sol exhaust...Greddy Evo2 vs. Skunk2 Megapower
- hid headlight retrofit
- Civic VX parts compatibility?
- clutch slippage?
- Guys need some help emissions....
- help!! vent keeps on opening...
- 98 dx hatch problem
- Replacing headliner
- JDM ITR OEM Muffler Sound Clips??
- REPLACING F23A4 WITH JDM F23A
- 1992 civic dx wont start
- how to install a pressure sender on a b18c1
- check out my valves(b16a3)
- help: edm headlights and SiR climate control.
- Hi! I'm new to the board.
- 2000 Civic Power Outlet Popped Out!!
- Need answer asap
- Which rear garnish is worth more?
- EDM 98 Civic 1.8VTI Vtec MB6
- 92 eg hatch tail light problem
- ITR Idle issue help!!
- d15b7 running really rich
- HELP!! d16y7 intake manifolds to d15 engine? :cry:
- EGR valve block off
- I introduce myself in here?
- Switching obd1 ecu to obd2 for emissions
- New igniter, still won't start
- High Idle Problem...out of ideas
- Turn Signals not working
- do differrent markets badge differently?
- please i need help
- D16z6 starting issue help!
- Shaved/Pop doors issues
- Weird Noise
- 5-speed trans for my 97 civic dx
- B18c starter solenoid location
- Need help with harness
- Toda Spec B or Cs on stock bottom end?
- CAT Help
- advice on tie bars
- D16Y8 - Info about the VTEC?
- LS gas mileage?
- 92 Civic VX rust repair pics
- 99 Civic EX 4 Door - Acceleration problem/ Rough Idle
- 94 Civic EX overheating
- gsr brake help
- 99 civic type r style grille
- Loosening Rear Brake Drum Self-Adjuster? 2000 Civic EX
- 00 civic DX oil on plugs no smoke d16y7
- Tried everything I can think of and still have code 14
- weird no start issue
- help..car struggle to pick up speed...
- 97 hatch speedometer doesnt work
- bouncy idle and high rpm
- Common Places of Vacuum Leaks
- Clutch took a shit after >1000 miles. Re-use flywheel?
- Stolen car recovered, questions about repair.
- Play in clutch pedal..
- 00 civic si - how install speedohealer?
- D16Z6 EG Si Crank but no fire?!
- JDM B16 sir II running A CTR ecu
- headgasket..leakin...barely..do I buy the Leaking HG?
- brakes have to pump to stop
- 1997 hatch build thread
- Gas smell and gas leaking from tank (92 civic DX)
- seats
- How do I turn Distributor Rotor
- Question on 00 EJ6 sedan
- Shifter issue would love feedback on...
- 97 hatch won't start
- B18c Type R Swap > 1996 Civic EX
- How hard is it to replace a starter in an EG
- Ebay intake filter, washable with k&n filter kit?
- Accord seats in 6th gen civic LX
- h22 civic traction bar fittment?
- Any idea what these wires are? PICS INSIDE
- built b18b1 bogging problem
- Replacement Price for Bad Ignition Switch? (94 Civic DX)
- z6 block y8 head eg hatch help!!!
- gsr front sub frame and stearing rack on civic sedan
- Firecracker odor in car
- EG Civic Speedo not working/jumping PLEASE HELP
- B18b dipstick length
- EG Strut tower bar fits an EK/EJ?
- seat type - gsr blades
- What do I need to throw a ls swap in my Ek hatch?
- Del Sol carpet
- 96' EK coupe DD project
- 98 civic throwing a couple CEL's and oil light is on.
- Any difference between 99-00 civic ex and 99-00 civic si engine harness?
- b16A into 93 CX with P30 ECU... Wiring help...
- Temp Gauge does not work!
- Civic wont start
- Headers for B16B?
- what do i need for a y8 convert from a y7???
- Hood Spacers..??
- B16A High Idle Problem
- EJ6 4-door Question - rear tow hook (aftermarket) question
- Nissan engine and tranny in civic?
- eg8 b7 to y8 intake manifold swap
- 95 EX Coupe Knock on Acceleration
- Compression Test results
- EK Tire noise and handling problem
- DOHC -leaking front oil seal
- 97 and 99 civic coupe rear bumper differences AFTER the rear lip.
- Checking my oil
- 99 civic climate control (does not iluminate)
- D16Y7 mystery bracket on block
- EK ebay fog light install with no switch.
- ID Z6 short block, has tap for thermoswitch on block
- Vibrating in tire
- 98 civic ex - Vtec solenoid leaking oil
- JDM b16a, hesitation/sputtering/laggy bottom end??
- 95 civic ex, having idle issues only with ac on.
- pr4 rev limit issue
- HELP!
- b18c in 93 ex wont idle cold?
- power steering oil question
- 98 civic distributor cap screw tap size?
- alarm installed- more security needed
- new clutch on gsr swapped eg..problems..
- JDM hatch rear seats into USDM 96-00 Civic
- idle drops when brake is pushed 2000 si
- 96 Civic EX. A/M Headunit install
- 1995 Honda Del Sol VTEC Build
- d16y7 idle issue
- 97 civic high NO (smog test fail)
- 95 Del Sol Cabin Wiring Help.
- How to wire vtec, knock sensor, 4 wire o2 sensor guide
- 97 ek b16b ref question
- No power at fuse #18
- Tachometer not reading correctly, someone help?
- keys wont open door
- Cigarette Lighter Not working?
- head gasket
- what would be a nice engine swap for a 1992 civic dx sedan?
- need help b18b wireing
- msd ignitin coil burt?
- high idle after intake manifold and throttle body gasket change...HELP!
- Any Experience with Blox Street Series Shocks?
