View Full Version : Honda Civic / Del Sol (1992 - 2000)
- quick question
- woohooo. it passed..
- how to install TEG radiator
- what exhaust for my hybrid
- east coast portable dyno?
- Clutch Master Cylinder help needed
- quiet exhaust
- HID ---projector or factory headlights????
- tach question
- WTB / 92 - 95 civic Coupe Trunk Lid
- HEADER SEARCH!!!!!!!
- Spoon Air filter?
- DO You have a Front Lip----I need pics of Your LIp
- H22 in an EG...Axles?
- b18c5 fuel pressure
- Post your EG/EK with a JDMH22 time slips.
- Clutch problem!
- Who has write up for Teg rear sway on 5th gen?
- What's your car Dynoed at???
- Idle surge after swap, HELP
- lights go dim
- WTB: 96-98 OEM PARTS
- How long before you swapped?
- winter tire sizing
- winter tires
- over the hill
- Greddy EVO..
- Is the tray/pocket in the 2002 Civic single DIN sized?
- Rear disk swap and sway bar
- someone tell me how to fit a b16a1 into a 94 civic?//
- Emission Help
- P28 conversion = Code 41 Primary O2
- CRX si cam in D15 motor...I need help...
- WHO'S IN GEORGIA!!!!?
- Rubbing in the rear with 16" wheels and 205/45 tires on EK, help!!
- Can someone get me a CarFax?
- can i use any b series shift linkage?
- brake lines
- where to get 92-95 OEM JDM corner lights 4 door
- used act clutch
- GSR Brakes on EK: Problems
- Civic LX 4door 2001
- steering wheel pulls to the left and right after gettting new rims?
- difference in aem cam gears?
- Where to buy DEPO fog lights for my Eg??
- Help with wiring
- is $175 a good price for a used clutchmasters flywheels?
- Tell me what you think of my front bumper......
- Eg Interior Swap
- just rear ended some wagon! (long)
- CV boot/ joint HELP!
- tell me what you think of my new front bumper?
- quick question.....................
- MIL indicator for 89 Civic
- wings west civic hood
- Will sparco brackets and sliders work with Recaro SRDs???
- Updates on my Ferio wannabe....
- b16a or b18a?
- CX injector flow rate???
- Please help my car still won't start!!!!!!!!!!!
- 00 Si gauges in 94 Civic
- Found a solution to slow SOHC's you have to see this
- need help with my CF hood
- DX Fuel Pump
- whats the best way to boost sohc??
- how do i become a regular member
- Show me your turbo set ups
- turning on heater when racing? myth or truth
- Just did the timing belt.....
- Vin Plate and Block Numbers (HELP!)
- Something to Think About...
- jdm cluster ?
- What parts do i need to get disc brakes in the rear??
- J's racing intake?
- Pics of my 00 EBP SI after a few mods
- For anybody who has aftermarket Shocks/coilovers, I need your help plz..
- Carfax Report... Anyone?
- help with p08 ecu
- rear discs not working.
- do 17" rims and boost mix?
- Need help ASAP w/head swap
- how do i become a member!!!!!!!!!!!!!!!!!!!?
- My wheel shakes when i hit the brakes.....?
- GREDDY EVO vs. GREDDY SP 60mm
- question about cams in my b16a2
- Cleaning rust off of rotors?
- Which brake lines- '92 CX, Fastbrakes 11" rear?
- Speedometer signal wire to gauge cluster...what color?
- Heat shield painting/removing problem
- EBAY strut tower bars
- tore apart the motor
- Intermittent wiper write-up. Anyone interested???
- will this give you gains!!!
- headlight bulb questions..
- Thoughts on the Dunlop FM901???
- florida to new jersey!!!
- Driver side door rattle?
- Just got myself a 92 cx
- Feul Gauge Problem
- What side skirts and front lip, rims are these?
- MAP sensor schematic
- my car lost power
- Integra dash on EG
- Hybrid Garage Service?
- custom HID setups..???
- Siezed Caliper?!?!?!?
- Does the car have to be moving for vtec activation?
- where did you get your engine?
- Difference in engines?
- Carfax, yes i searched
- 3 quick Q's
- Is a fuel regulator needed when adding I/E?
- Door Panel Heeeeeelllllppppppp on EK
- Zex cams still Backordered?!
- need help:wiring y8 iacv to y7...
- a/c line needed!!!
- head question
- **HELP** Car's in the bodyshop, striped to shell.. need to pick color (EK)
- vafc harness for obd1 p28
- I'm selling my engine soon, should I leave it in the car for test drives or take out and pack?
- what do i need...converting obd2 to obd1
- d15b swap in, throwing cel code 20
- Need some help
- del sol headlight question
- exhaust wrap
- Engine Swapping place in SJ, CA?
- custom spring rates for a H22 hatch
- PLanning on getting a b16
- Parking light problem (electrical)
- 2000 Civic
- A/C Question
- 96-97 del sol vtec ecu
- Do you have the problem with the windshield wiper control when you shift hard?
- ctr motor, but what transmission?
- Beaks reinforcement kit with Progress 24mm rear sway bar.
- Exhaust?
- h22 ek cross bar
- OVER HEATING Check list...questions? here are the answers
- overheating problem...
- Question about the vx model.
- CX EX Tranny questions on FD
- What will happen if i disconnect my ps pump?
- Instuctions for removing 99 civic radio?
- H.I.D. and Driving lights (fog lights)
- ITR Rear Sway Bar & Teg LCA in a 00 SI ????????
- How do I wire my OEM fogs to stay on highbeams (&/or city/parking lights)
- what rails do i need for ep3 si seats to fit in my 00 civic(ej8)
- please no more trial member!
- How to???
- speaker question.
- How to install autometer Air/Fuel and water Temp gauge???
- 99 fog light question
- Cant find service connector!
- Free Carfax
- best cams for a 2000 civic si
- need part # for EK passenger side air bag tray
- 205's??
- Got a CF hood from BODYKITS NW, and let me tell ya!!!!!!
- SRS Airbag sensors to deploy them? Where are they?
- Exhaust Opinions?
- 92 cx will over heat unless I run the heater. Why?
- which will give me more hp
- SRS Light Help. How to shut off without seat plugged in?
- roll cage?
- Pics and mods of my 97 EX
- Anyone running Wilwood calipers (fastbrakes) with OEM 99-00 Si rims
- What engine do i have
- Engine Swap Question
- Lightened flywheel - idle problems!
- quick question about the B18a and B18b
- Swapping Springs...HELP
- Would you guys buy an imagengineering header for 480?
- Pic Request: white coupe with black lips and sideskirts
- h22 vs. h23 throttle body? (Searched)
- Clunk
- What kind of down pipe is this?
- how many washers to correct camber in the rear?
- black housing for civic 2001 4door
- Just Picked up a Set of VX Wheels...(Gearing Tech Included)
- are D part In changeable with B parts
- CTR Light Question
- best clutch for power
- Pics of my hatch....
- Electrical Problems! Too many!
- B16A MSD 6AL Installation
- my car wont start!
- might buy a del sol b18b1
- Anyone parting an EG?
- Help with Tein S techs needed
- Intake manifol
- good stock replacement AIR FILTER?
- Anyone have Slipstreams? Pics please!
- Shop in Orange County with good CF
- swap done monday night-crashed weds morning!
- whats next after i/h/e? cams?
- a question bout coolant flow
- HVAC filter?
- Where do i buy my b18c1
- help on adjust valve with the head off?
- what do you think of these wheels?
- Any sites for DIY: repaint bumper
- AC blew up!!
- Carbon fiber hood question
- prelude seats?
- anyone have rims forsale
- how do you post pics
- PAINTED STUFF
- wiring diagram for eg foglights
- How to remove that yellow stuff on headlights?
- Pillar Bars
- Tailight pic request.
- Throwing Code 45 & 65 - how to fix?
- Symptoms of main relay, but fuel pump seems to be kicking on....
- Anyone make replica mugen m7's??
- whats the best way to remove the purple tint that people try to put on themselves?
- Problem with my 99 CX..
- Quick question before I do my swap......(pics)
- Hondata S200b or 2b
- Wheel rub on stock height
- Amber Corners
- h22 in eg all done.
- anyone have those cheep Air dynamic seats?
- Need help, is this serious?
- Who has an account with SEIBON.com (carbon fiber products?)
- engine bay question ASAP please...
- wtb 92-95 hatch cf hood
- well i have del sol seats now but.....
- EX have a 2 core rad??
- Best Canadian Shops for parts?
- JDM CTR rear lip
- Comments on LS hatch
- WTB: 99 civic turbo kit
- yet another oil leak case
- whats the best springs/coils for civic 97?
- Will paint match?
- Need a parts list of a d16y8 turbo kit set up...
- z6 turbo question!
- EG COUPE (EJ)
- camber kit?
- Another axle question
- roll bar for EK
- How to install access visor on a EK..HELP
- engine info
- i know its the wrong forum, but please help!!
- P08 code "N11" auto or 5 speed?
- vafc harness?
- another mini me question
- Anyone have any info on the 2006 8th gen?
- Tokico Illuminas and Skunk2 coil-overs
