View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EM1 blower moto transistor overheating
- 97 Civic cx - getting very frustrated with misfires
- 00 Civic DX - Need advice on replacing damaged exhaust
- Trailing Arm Bushing Tool
- 93 Del Sol Si - Brake/Throttle Body/Sensor Questions
- passenger power window issues
- D16y8 block with d16z6 crank. Possible issues???
- 93 civic d15b tach not reading right?
- 95 honda civic 1.6L crank but no start
- Civic forum re-organizations?
- Del Sol coil over suspension kits
- EJ1 - Re-attach Rear View Mirror
- Oil leak with pics
- Quick help on brake compatibility.
- 1992 Civic Hatchback Rear Compartment Questions
- 93 Delsol Si intermittent no crank no start (solved)
- 97 Civic si EJ9/D14A4 - Need help with distributor
- 2000 Honda civic running rough
- 96-00 civic camber question when lowered.
- 94 eg bound up front hub
- Are these original Del Sol SI seats?
- 95 civic gets stuck at 1500 RPMs when rev-ed?
- 97 CX Hatch D15B2 Block D16Y7 Head Turbo
- worst honda ever.
- Cheapest Place to buy an Apexi WS2 exhaust
- 93 Civic EX Coupe - Power window, speedometer, and turn signal problems
- I need help finding Service Manual...
- LOOKING FOR INFO ON RARE EDITION PLZ HELP!
- 93 Civic Door Lock
- D16 to B20, how difficult is this?
- 1997 honda civic ex coupe (ej8) interior leak
- D15B Wiring help needed
- My EJ1 clock no longer holds the time
- Keyless entry help.
- Do I need rear sway bar?
- d16y8 Best crankshaft swap???
- EM1 AC Expansion Valve Removal...before it gets too hot
- Coolant Sensor Issues
- '98 D Series Clutch and RPM Issue
- Project Storm Trooper 94 Civic EG
- 99 Civic LX - Auto Transmission shifting problems
- Opinions on camshaft scores and grooves
- 1999 Honda Civic DX Power Locks
- Putting on oil pan gasket dry?
- 00 em1 misfires at idle and lacks power in vtec
- 93 del sol, rear quarter panel
- why is my timing belt rubbing.
- My 97 z6turbo LX. 5lug and Widebody coming soon.
- 00' Civic Ex, Starting issues, Misses and Idles Poor, Dies.
- 96 civic - relay and granny mount questions
- 1999 Honda civic idle problem
- Mini-Me Swap from S to VTEC
- transmission for fuel economy
- Ej1 D to B series Swap - Is B16 or B18 easier to find and less expensive?
- SRI vs CAI 99 EM1?
- Air in clutch line after driving PLEASE HELP
- Blower Fan Wiring??
- EJ1 - driver's side caliper doesn't work
- 1993 Civic dead silent
- Customizing lights in cluster
- d16a6 in a eg hatch no start
- need help intake air temp sensor
- 2000 dx type r swap code 23
- Window Trim Removal
- 96 Honda Civic EX Coupe No Heater/AC Fan.
- Manual for 1994 Honda Civic EG Hatchback please
- 96-00 auto to manual swap QUESTION
- Steering squeel
- 1999 EM1 fuel pump wont prime
- 93 civic, wont start. help asap
- Need help pulling CEL codes
- Inner tie rod DIY issue
- Jdm b16a in 94 ex coupe
- My Honda's exhaust smoke and "tick" sound
- Returning to stock muffler
- Fuel/idle problem '98 Civic
- CKP Sensor (Crank Position Sensor)
- clutch choice
- Weird no crank/no start issue - 98 honda civic
- HELP evap plug to short??
- Black specs on my dipstick?
- 93 del sol Starting to rust.
- cant find 97 cx misfire cause
- Question about EJ9 Civic body parts color
- bad rack and pinion?
- 97 Civic EX D15B, Parts assistance needed!
- Taillights and cluster lights not working..need help
- Some issues with my Sol
- EM1 Gas Mileage?
- B16A2
- Use a P28 with auto D15B7 then on D16Y8 manual?
- ECU not reading HO2S?
- Ek buddy club lower ball joints need grease
- German 98 CRX (del sol) - Paint, audio, turbo, and roof rack questions
- HP increase with Del Sol S SOHC
- What's your opinion on fusing an upgraded/added wire from ALT to Battery + terminal ?
- 6th gen jdm engine with a 5th gen manual transmission
- 98 civic 2nd oxygen sensor heater
- 98 d16y7 operating temp?
- Squeaking noise when clutch engaged
- Why isnt there a standard spark plug reccomendation per model
- 94 Honda Civic Oil Consumption
- B16a Swap, Need help!
- Skunk2 mega power, blown out in 6 months?
- 94 civic si swapped B16A - What wire harness and ecu do I need?
- I need help finding my Rear Window Defogger fuse..
- Where is Data Link (OBD-II) Connection on 97 Civic?
- what seats can fit
- Carb Clean "chokes" my engine? (rpm drop/stall)
- Yonaka catback exhaust.
- state referee question
- Dc strut bar 99 civic dx
- any key or thing starts my car?!
- B16A EJ Hatch help
- Civic Trunk Leak PLZ HELP! Pics INCLD
- EJ No start issue makes no sense.
- 99 civic d15b block y8 head no spark
- 4040 proportioning valve fit on Civic EG ?
- CEL light on but no flashing
- dome light bulb.
- 00 Civic will not start after driving (solved)
- Main relay problems
- Brake Pads for EK4
- Requested: Honda Assembly Plant Manufacturing Markings
- Passenger turn signals blink fast, but both blink?
- Can I use anti seize or lock tite to seal off fuel filter?
- calling all del sol transtop owners
- 95 civic dx overheating problems/maybe head gasket
- Pulling CEL codes on b16a2 P30ecu?
- A few security questions 98 lx
- EK3 Mini-E Automatic
- 1993 Del Sol Front Bumper Help
- 1996 civic hx restoration
- 92 Hatch Clutch Problems
- Help with 1992 Civic Transmission?
- Del Sol Wheel Size and Speedometer Calibration?
- changed vss but speedo and odometer still drop out
- 95 Civic Sunroof - 2 and 4 door glass the same?
- Oil in spark plug tube d15B7
- Cigarette lighter will not charge
- 0bd2b y8 into a obd2a y7 hatch PLEASE HELP!!!
- Are OBD-II codes stored without resulting in a CEL?
- civic/integra lca question
- car dies completely while driving
- 1998 Honda Civic Hx Trouble Codes
- New to Honda -tech and need some help. D4 light on
- More Poaawweeerrrr
- Head Gasket Oil Passage
- Part number for water outlet?
- HELP ASAP, broken head bolt
- 93 Del Sol exhaust question
- 92 eg hatch clock radio climate control lights don't. Work
- 92 eg cx headlights wont turn on.
- 97 civic driverside pop when u turn right
- Central locking damaged
- 98 trans fitment
- 1.6L in my 94 civic dx?? please help!
- d16y8 TB / WP / HG MAINT JOB Questions thread help!
- Mysterious Stall Issue. Please help. (+video)
- lhd auto climate control for ek?
- Is it a Nippodenso or Mitsubishi alternator?
- Tapping noise in head, bad idle, won't stay at operating temp
- mini me swap 98 civic (engine wiring harness and intake)
- Optional Center Ashtray for 97 Civic Replacement
- How do you tell if you've got rods knocking?
- map sensor reading on scanntool question
- Parking brake adjustment
- 1995 Honda Civic EX just did clutch rough start sputters under load
- Quick question about an auto-to-manual swap
- Yonaka Exhaust Review: Almost Great
- What Is Making This Sound? (13 Sec Clip Included)
- 97 turns off when it stops or turns
- Strange idle speed problem
- have to choose
- My 97 Honda Civic EX
- Alternator power wire problems
- Del Sol - Volt Gauge Issue
- 1998 Honda Civic EX running too cool
- 92 si question
- D15B7 and the adventure of valve seals.
- Best Fuel Pump from Rock 99 Civic
- Replacing srs module in 94
- Coolant Issue
- Central locking fault
- help with clutch
- Radiator and Condenser fan wattage
- dc2 front brakes on eg
- speechless car wont pass 4500
- 96-98 glass molding part oem
- How sensitive is the 1993 del sol1.6L engine to fuel pressure? I'm reading 40 psi.
- Silencer for 96-00 Civic Coupe Yonaka Catback
- 00 EX can't get to "OP temp"(at all) with the heat on.
- Where can I find D15b VTEC piston rods
- 2000 Si upper control arm/coilover help
- d16y7 - Rocker Arm Push Rods
- 96 Civic - Exhaust and problems lowering the car
- replacing drivers seat w/passenger seat?
- 1998 CX Ebay Radiator/Fan vs. OEM
- Civic no start
- Info on Terada
- Miss fire trouble shoot 96 civic hb
- Car won't crank after stalling
- 99 civic EX - primary O2 SENSOR is missing
- Transmission Snap Ring problems, please help
- mind helping me with replacing a transmission?
- Tachometer swap question
- b18c1 swap into 98 civic ex, lacks power/hesitates
- expected mpg??
- Rare JDM Parts...OEM EG6 P30 Airbox
- 96 civic with cranking problem
- 1998 Civic Front End Squeak
- Leaking! What is it??
- 1999 Civic EX Won't Start
- 94 Del Sol roof rack
- 99-00 Civic Front end conversion - Inner Fender Liner question
- Acura RL - Fan switch Gremlins
- B18B in an EK - What kind of axles do I need?
- 93 civic with heating problems
- Car shakes with A/C on
- evap control canister vent shut valve: Q
- Fender rub
- 94 Civic - CEL doesn't work
- Rear Disc question 97 HX
- Battery Light doesn't work (solved)
- Civic won't rev, help please
- Ignition switch ripped off column during break-in = fuse issue
- need help re wiring my car
- starting problem
- d16y8 shifter linkage
- 96 EX keyless entry question 99 key fob
- oil on tranny?
- Replacing front end - DIY anywhere?
- Getting more HP out of my D16Y5 VTEC E Engine.
- Koni/GC did I assemble these correctly (With pics)
- 99 civic IACV gone bad?
- What speed/rpm do y'all shift your ex's in the city?
- 1996 honda Civic CX squeels like a pig when turning!!..
- 1993 Honda Civic induction
- Anyone know of any Rywire.com discount codes?
- Upper Control arm's directional?
- Need help reading civic cel code - video
- Car Wobbles - 5th gen hatchback. (Solved)
- problems with 92 civic hatchback d15b7
- 97' civic lx exhaust manifold crack/ CEL on/ idle issues.
- Cruise controll install in a non cruise control chasis
- 97 civic ex 5 speed - loud knocking sound
- D16z6 no start
- Straight pipe loses torque?
- '95 EX with; what kind of motor is this? B16? B18?!
- 93 Honda Civic hatchback won't start. Please help.
