View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Tranny Swap COST$$$$$$
- Del Sol Greddy EVO 2 into my EK?
- Some1 school me in sensors IAT and IAC especially.
- antenna...
- slight vibration at 70 -80mph whats wrong?
- **Auto Idle control system NEED INFO
- Cable to Hydro kit
- High Flow Cat Question
- Rhd Conversion Need Help????
- zc possibilites in a eg
- Drilling holes¿
- GSR & LS compatiblity (intake manifold)
- Axles
- fog lights ?
- Too much oil pressure????
- HELP ON SOME JUICE!!
- comprestion check done what do you think
- this may be off the topic...
- F1 clutch kits, any problems??
- weight?
- Help with D16Y8 Rebuild
- best year teg cluster to buy when swappig into 97 ek?
- removing steering wheel
- alternator not working...
- want to trade my ef for your eg
- rpm drop when holding constant rev between 2k-4k
- Matching with a D16
- Tanabe USA is looking for socal EG hatch
- Has anybody used the SiR stock suspension? I tried searching...
- Just Got My First Civic!!!
- i need a how to guide to swap a b16a sir II Auto in a EJ1
- (I NEED QUICK ANSWERS PLEASE)y8 intake manifold or z6 manifold??? (already searched)
- bigger brakes for my 94 dx
- where good price for green rota gt3?
- D16Y8 Transmission
- B18A??? Vtec??
- si cluster problem PLEASE HELP
- I have a question...please help me out here
- integra rated Tein S.Tech question
- Just picked up my First Honda Civic!
- I.D. All the sensor on the Intake Manifold -D-series if it matters?
- lSohc d16
- Best Way To Mount 2 10inch subs in my EK hatch.
- b20b v. b20z
- clutch/flywheel combo I'm planning to go with....
- So who all has......
- Air filter question
- How do i take off ball joints???
- TRANNY PROBS HELP ASAP
- Mini me I need help with what block to run
- Cat question
- Those darn thieves!!!!
- How much would it be?
- Civic EX Coupe 2000 - Noise at specific rpms
- differnce in FPR vtec or non..
- d series mani question?
- EG duckbill spoilers
- how do i jack the car from the front?
- im looking for mike from prostreet
- Wheel paint from DupliColor vs Rustoleum
- engine light update.
- Friend hatch wont start...heres the symtoms
- Swap question
- how MUCH tranny fluid?
- swap question
- PCV replacement
- del sol drivers.....do u have alarm/keyless entry..if so what
- CF ITR spoiler
- 5w-30 or something else? 2000 Civic
- broken speedo
- My timing will not advance anymore ?? ...and intake temp senor chip
- low idle after replacing cap and rotor
- Charcol Canister/Evap System *CEL 1457
- Calling all gutted cars that are not trailer queens -
- can't find DA to EG brake conversion
- oxygen sensor change ? will it give CEL ?
- TRANNY HEPL THINK ITS BLOWN
- Guage Cluster Swap
- How can I tell if its a JDM B18C5 Type R motor??
- What tranny is s80?
- CAN ONLY SEARCH 1 time every time i get on ht is this normal ? I need to search!!!
- d15b8 to d16y8
- Trying to convert O2's.....help!!
- Opinions/pics please, 15inch or 16inch on 92-95 civic 4door????
- ECU ground question
- New Information
- i just bought an H22!!!!!!!! HELP!!!!!!!!!!!!!!!!!!!!
- Exhaust Piping Recommendations
- minie motor
- 94 EX Coupe - is distributor failing ??? did I waste my money?
- alternator wiring d16 to b20z
- honda civic OEM clutch 2% left....driving car is horrible....
- can't see when driving eg6 in rain need bulb
- air/fuel and boost gauges
- Installing a shiftknob, I think i'm missing a screw?
- jdm gs-r idle/stalling problems
- Squeaky car :( :( 92cx
- some help with wiring plz
- water temperature reading for SOHC
- 95 hatch dx bogg prob.
- which have more potential? b16 or b18?
- need some help ...quick
- Maintenance Requred light is RED - 2k si coupe
- T1R Power Exhaust Muffler
- what are the symptoms for slipping clutch?
- *EG with an ITR heart transplant*
- Bad/horrible gas mileage ..plz help
- blown fuse and a cel, I cant figure it out
- difference between b16 and GSR trans
- AUto Trans PLZZZ HELP!!!
- Factory tinted windows
- FLYWHEEL bolt size?
- EK Auto transmission
- Side black stuff.... duno what it call.. and i am a noob. help please
- Are rear disk brake e-brake cables interchangeable?
- EG?
- my pig named EK
- Power to B9 to get motor turning over
- d16 block 1.5 head
- GSR clutch for b16 tranny
- grinding/rattling
- DIY- front mount intakes
- axel is making a noise?
- Door Sills
- Bad smell in motor
- My A/C makes a "squeak sound" when i shift into 2nd gear???
- HELP: replacing AC belt
- Throwing p0141 code
- Where can I find some good D-SERIES AXLES???
- B16A Install: Professional or Do it yourself
- time for new car
- Can a new Timing belt change cause low mileage on gas ? Honda civic 97 lx
- check engine...any honda-tech guys around ATLANTA?
- D16Y8
- carpet question??????
- RETURN TO FACTORY CLUSTER.... GSR cluster and wiring harness ----> stock 96-00 ek cluster and wir
- What's better bang for the buck?
- Need Help Fast!!!
- swap problem part 2
- overfilled trans
- hp?
- EG Weight differences
- How Can I tell its OEM?
- Help on engine problem?
- Something broke off my alternator – pic inside
- My hood will not close on my EG - help :(
- shocks?
- Del Sol or Civic DX
- Car stolen May 2, 2005 White hatch, NYC area..
- help me interpret my dyno graph! power dies too early
- Exhuast Rattle!
- New To The Hatches
- cool jdm exhaust smoke + burning oil
- Fuel Pump Quit Working!
- cat converter
- does anyone know how to install jdm navi system
- Need help with OEM fogs on a 97 civic
- Power Steering Went Bye-Byes...
- turbo and foglights
- Cluster Problems
- Help! ECU question....
- Finally!!!!!!!!!
- Which JDM motor SOHC is better?
- SOHC PULLEYS
- throwing code 10 41 gsr eg
- Mini Me Problems
- D16 performance
- k20a2 or boosted stock internal b18?
- flywheel type
- Need to change spindles?
- 6x9 Speaker Installation (EJ8)
- Tie rod replacement, Difficulty level?
- d-series axle question
- h22a labor
- do jdm sohc zc motors comes w/ vtec? tia
- help with going jdm
- Anyone have a problem shifting?
- CLUSTER QUESTION
- Which Kit
- lsvtec question
- h22 in an eg NEED HELP
- carbon fibre hood problem....
- Help removing the @#$@#$ window crank.
- cluster swaps?? help
- Loud Exhaust
- Car throwing CEL 54 - my smog check is due today, will I be able to pass??? need answer QUICK!!
- OEM rsx shiftknob fit Eg?
- d157-mini-me into 99ex...plz help
- odd noise when i step on the gas
- any one got shift linkage for a 94-up integra????
- odd noise from steering wheel
- D2 coilover fitment question
- Where to buy EG rear 1/4 repair kits
- Steering column boot repairs
- ls or gsr swap
- Need help with 93 dx civic hatchback
- ek interior parts
- Does a turbocharger *need* heavy weight oil?
- NSX caliper on EK hatch
- Install Shifter
- SPOON SPOON SPOON
- AC gurus...what's this black box in the cabin called?
- Steering/3rd grind
- rsr exhaust can someone help me out???
- Stock CX hatch turns off mysteriously.
- how to check cel on 98 hx
- Anyone here running the Megan LCA?
- Emissions for OBD2 SHELL with OBD1 SETUP
- tach bouncing
- d15b7 to a factory b16a2?
- Injectors
- tranny went crazy
- INtake manifold any truth to this guys claim?
- I need your guys' opinion on this hatch
- What is fuel tank capacity for 97 Civic LX ? and what mileage per gallon should i expect ?
- Bye Bye Civic
- is this good 1/4 time
- test pipe???
- Need help with towin in central Jerzey
- hondata/ v-afc2
- itr final drive
- are honda wheel studs 1.25 pitch? (Specifically EGs?)
- Anyone with SRR LCA's + Swaybar?
- brembo rotors: quick question
- need help with my rear tire...what do you think?
- Brake Light
- best axles for h22 in a del sol
- cel stays on before start???? car dead
- Anyone trying to get rid of their VX rims let me know, i'm intrested
- Screw on the end of the Fuel Rail
- IAT sensor help needed
- EP3 Axel Back to fit EK??
- valve cover?
- High idle on Cold start and surging
- HEY I HAVE A 1997 civic hatch please help
- Del Sol Air Duct???
- OEM Ehxaust pipe diameter
- New guy with 1999 civic SiR coupe
- What kind of fog lights are these???
- Site to buy 99-00 black or gunmetal housing headlights...
- Proportioning valve
- Do all D series flyswheels and starters work together
- 2003 Accord V6 swap into 2001 civic ex 2dr
- can anyone explain this?
- 94 civic in distress, need help!!!
- New JDM Swap Site?
- help
- exhaust piping question
- EG engine advice
- 99-00 civic si front lip
