View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Gas Tank Related
- Fan question??
- exhaust ?
- Need to find OEM SiR Lip Hardware
- Cage in a civic?
- where can i get my gsr insalled
- who's dc got stolen last night? cause i think i found it
- korbach frame locks for sale
- Depo Fog Relay Part #
- chipped crank pulley, question...
- Headlights?
- b16 and performance bolt-ons.
- counter shaft speed sensor
- need help with wing
- problems starting
- 95 eg coupe 5speed ex part out
- pin stripe
- is taking off the belt and pulley ok?
- SRI Intake: Is a a heat shield needed????
- cluster gauge question
- What is the best race header for my EK4?
- fuel injector cleaner????
- mini me or complete swap ?
- need help to remove climate control 93 civic
- control arm bushing EG
- Quck Mini ME IACV problem
- Quick rear disc question
- Coupe door on a hatch
- Dash & climate control lights
- Question about a few things..
- eg seats/ del sol seats
- ALTINATOR HELP!!!!! HELP!!!!!!!!!!!!HELP!!!!!!!!!!!!!DOESNT CHARGE THE BATTERY!!!!!
- 97 motor,99-00 intake, 00 ECU and harness......2 hoses from starting. Need confirmation.
- Brake Lines
- eg front lip fit on ek?
- Help with a turbo/
- JDM D15B Internals???
- big brake kit for 16". Largest discs i can run?
- Del Sol Lip
- 94 ej. wit 91 ls motor. what axles?
- is it worth it 1200
- starter cut relay
- need help on Armrest
- VALVE COVER
- gsr throttle cable???
- nissan metting.
- OBD port problem: POWER
- my engine won't start. you know why?
- Anybody add a glass flip up lid on their hatch?
- Doing a ls/vtec swap in my 97 Civic HX
- 5th Gen Hatch climate control/heater problems
- B18B1 question
- d16a6 crankshaft fit a d16y8?
- b16a3 smog issues(CA)
- Tranny mount
- starter cut relay????
- How to Rebuilt my motor ?
- 92-95 civic fog light switch pinout diagram
- Help plz - thinking of buying a Sol?
- integra Type r swap into a VX sohc vtec eg hatch
- Reason why '94 EX keeps blowing distributors?
- power wire from star6ter....................
- Ek Eyebrows pics and painted grill?
- fog light HELP
- Oil Leak from Driver Side - appears to be from between head and block
- tbs callibration
- Tranny won't separate from engine
- EVAP Purge Solnoid and performance
- power steering removal and b16 swap
- im new here, a little help please!
- E-brake doesn't work after installing new calipers.
- Turn Signal Return? Broke Maybe?
- OEM 94 eg civic spoiler question ?
- Hatch with gsr, can i charge it?
- Civic CX suspension
- Am I missing something?
- gravity bleeding???
- Universal 02 Sensor Wiring?? HELP!
- gsr compression results 180-200-200-200
- hatchback/coupe springs
- location on the fuel pump fuse help 93 eg
- eg6 LSD diff with 15 bolts
- D16Y7 in EG, trying to keep power steering
- what causes my oil to dirty up so fast?
- Fixing EG JDM cluster fuel gauge
- IACV problem... need your help
- Many Thanks
- Dynamat-Loud Exhaust
- 93 hatch
- Type R swap in a 94 del sol si(sohc)
- IDLE PROBLEMS AT FIRST, varys between 1 and 2 grand for the first 15 min.
- !HELP! LICENSE PLATE LIGHTS
- Where's this hose go?
- y5 with y8 head, which ecu should i be running?
- Using DA rear disk on a '99 EX coupe?
- Problem Starting JDM Type R
- 94 Civic EX auto transmission filter
- FUEL TANK/PUMP ??????
- reoving cruise control...plugging vacumme line?
- HOOD_latchQ.civicSI
- Suspension setup...
- LOOKING FOR EXHAUST!!
- bumpstops?
- Purpose of a catch can
- Easy to replace rear hatch window? EG hatch
- white smoke
- Removing Engine
- Where do you take your old blocks?
- rear strut tower brace
- HELP! Dashboard lights shut off, stereo lights flicker...
- Lynnwood, WA keep your eye's peeled!
- car wont move
- d series swap HELP! ON A COUPLE THINGS?
- all motor B16A2 vs. boosted JDM D15B or USDM D16Z6...need suggestions !!!
- New member with some questions regarding hood fitment
- What do u guys think this sound is?
- HELP!!
- Crank Sensor Replacement?
- SUNROOF ISSUE HELP!!!
- well im a bit let down with my swap.
- EXHAUST SYSTEM!!!!
- EM1 / GSR stock header fitment question
- Fuel Gauge Malfunction
- in need of help
- hurst short shifter
- Which belt with AEM pulley?
- b16 1/4 mile asessment
- Spark, Fuel, No Start...How do I check timing?
- Exhaust Leak
- Keyless Entry problem.
- radio anti theft codes
- Anyone around remember me?
- Rear disc brake conversion/camber problem...
- Rear disc brake conversion problem...
- Need a diagram for power mirror switch
- Koyo radiator + FAL fan = what the phukk!
- can someone tell me what this sensor is used for. (intake manifold ls obd2)
- How hard to install a head?
- Help please
- Motor
- CTR 5 Lug Conversion
- check engine light help
- rear brakes drums
- New b16 swap, some questions
- EX tape deck into a DX? Noob question.
- hey can anyone help me out
- so my coolant reserve/overflow tank is empty...
- New Swap and Clutch is acting funny.
- Skunk2 short shifter + knob
- Request Pics of Ek with SHAVED Side Molding PLease
- 95 honda civic ????????wth
- Turbo SOHC
- Test a civic ECU
- weird noise?????
- D16Z6!!!!!!!!!!
- Clutch Adjustment
- Brake proportioning valve what car do i need to get it off of for a 95 ex coupe
- 2 piece Megan Racing SS Header keeps blowing gasket??
- Headlight Assembly
- fastbrakes rotors
- Bad gas mileage?
- 92 Eg Gauge Cluster Question
- I am lookin to out Lambos on my 4dr civic Need Cheapest Prices...
- horrible idle
- Car Freeze ~~ Help?
- Help looking for rims
- stock p28 in a b16a motor
- D15B7 swap for B18C5
- B16a in my 97 civic idle problems
- need quick help! leakingFITV
- amber corner
- jdm headlights
- Anyone have experience with D2 Coilovers for Civic EG/Integra DC2
- obd-1 stereo pinouts
- transmission for swap
- Gauge Mileage change?
- Winter brake problems
- extended wheel studs
- D15Z6 need info fot tiuning
- BONDO: how do you remove pinholes?
- ITR Aem CAI into a Em1...any problems?
- Sunroof EG info please
- body kit help please
- someone with Hondata RomEditor software S200
- Type-R cluster question
- EG Hatch Exhaust Fit EG coupe exhaust?????
- Which clutch is better???
- Fuse Diagram 2000 civic??? HELP
- Brake rotor removal help please!
- need the order for distributor/timing from distributor
- SRS light on after CTR Steering Wheel install.
- Civic Dx Gauge Cluster
- two map sensor plugs?
- Ek K-Series Swap Info???
- Need del sol help ASAP
- what radiator is this?
- Transmission Problem (?)
- timing belt for jdm d15b
- gsr and p28
- ls vtak
- Check us out!
- Project EG2
- b-series nuts/bolts, what size how many how much?
- car wont fire...
- PCV box question
- Good compressiona across the board...but oil on #1 and #3 spark plugs?
- Exhaust question
- Help? When braking from high speeds I get a jerk?
- Tire size, quick question
- Does the starter solenoid go bad?
- rim plastic stripping
- Clutch problem?
- Where to buy JL Del Sol stealth box...
- side markers stencil
- Need immediate help BAD!!!
- odb-o engine mounts
- D16Y7-D16Z6
- Clutch Changeout Help
- no clicking from starter, no cranking........
- so ....ed at my sedan
- anyone hooked up a trunk cargo light on a 92-95 hatch that dont come with it?
- d16y8 header, which gasket?
- HELP! proper timing belt for a d15b7 with a d16z6 head w/ skunk2 cam
- SOHC z6 vs LS other?
- force motorsports
- DIY -- Obd1 to Obd2 Distributor Conversion Harness
- CAR STOLEN IN MN
- 1999 SI W/ JDM B16A2
- Help
- GSR w/ B16 Head??
- antifreeze everywhere
- Hydro to cable clutch
- which shift linkage to use?
- Just my current honda progress...
- How do you put an Integra cluster into a 96-00 civic coupe?
- auto to manual
- 93 Civic going power mirrors, windows and locks with RHD parts
- H4 - 9003 light bulb rating difference?
- how do i find out the mileage for an engine ?
- Dose anyone have some Vacuum diagrams for a 96-98 civic EX?
- d15 tranny and linkage with tranny mount 48k
- How to Wire JDM b16 Sir II into 97 EK
- Just a comment you should always remember.
- d series cam question
- MSD possibly an issue?
- my speedometer won't work and........
