View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 98 Civic P0108 Engine Death at Stoplights
- Tach is off. Will a new OEM tach fix it?
- Head HElp
- Anyone with a Koyo radiator for a del sol Vtec i have a question.
- Searched for fitv question and no answer
- Fiberglassing door panels
- First thing to buy after swap
- Underdrive pully question
- A/C in EG with b16
- OK i guess this goes here but i got a jdm white faced cluster and i got a question
- Rotor/spindle issue
- Think My B18C5 Might Be Messed Up a Little - Clicking Noise, Then Shut Off - PICS!
- d16z6 head on d16y7 block...?
- knock sensor wire up help
- 96 coupe w/ 98 SOHC in?
- 98 b16A swap
- Is a vtec head swap worth it
- Can Integra steering wheel fit on Ek9?
- EK BOSS kit
- nj catalytic check
- what the best engine/trans. for drag racing
- TB upgrade what do i have to do
- vtec head swap
- Tein EG Race Civic Hatchback
- Anyone with a EG helms that can help me?
- I think my CV joints have blown
- h22 into eg civic engine mounts. where can i get some?
- brake caliper grinding on rotor?
- SiR m/c + bb
- Possible to spray engine to clean?
- Seat rails..
- rebuilt sohc y8 tranny ?????
- painted valve cover
- will a 99-00 civic bumper fit on a 96-98 without changing headlights and fenders?
- Help: Will 2000 SI A/C System fit 96 DX Hatchback?
- gsr motor in a civic need help
- need help with nsx brake caliper to eg w/integra brakes
- Where can I buy flanges and donut gaskets?????
- intake vaccum
- Mini Me help PLEASE
- Ecu Codes
- 91 Octane is what i need for my mini-me, right?
- d15b into 97 coupe
- B18C1 motor not getting oil to the head valvetrain??
- HELP! experience technicians.
- bride seats
- ok need help...
- stock throttle body?
- ek hatch harness???
- removing DX LX EX logo
- 2000 Civic Rev Limiter...
- front upper control arm question (EK)
- Shift Linkage Info
- where can i buy a HOnda windshield sun blocker thingy?
- valve adjustment question...on a sohc vtec
- times
- ek coupe/hatch sideskirts
- Questions about methanol injection
- body repair
- Clicking sound when going on/off the throttle
- Times...
- so frustrating, i need help....again
- a/c car problems
- D16Z6 or D16Y8
- b16 swap axles and intermediate shaft problem PIC INSIDE!!
- Rear disc on EG hatch.
- My swap finally came in B16A
- Del Sol Fog lights
- obd-1 p72 with b16 code or no code?
- LS/Vtec bogging problems. >:O
- Metal/Carbon Build up in my exhaust?
- upper A arm bent?
- ? aboot turning it to a 5 lug thug
- hood latch problem
- Losing oil and can't figure out from where?
- what LS ECU
- ecu code....someone help!!
- Hello Everyone!
- Will Honda FIT wheels fit my civic?
- need help with painting rims
- Y8 clutch on Z6 tranny
- EEEK DASH into an EGG!!!! Possible???
- EJ8 manual swap, price and parts list needed (searched)
- ek 99-00 foglights!! help !!
- How much damage if any at all, water into intake.
- what oem cam can u put in z6 if any?????????
- Yes.. ? for GSR head on B16 Block
- vtec noise when under oil psi. no noise after crossover.????help
- At a big decision.. need advice
- am i going to ruin my brand new shocks?
- need help, tried hookin guage cluster wires back together..now car wont start HELP!!!!!!
- smoking exhaust
- Do I really Need Camber Kits....
- ground wires
- shift light settings ?
- venom intake manifold
- eg coilovers into ek what do I need ? serached !112
- Need help ASAP
- eg Bseries swap question
- Need to get B16swap running ASAP
- Help finding a frontbumper that "1Quikgsr" has.....
- 99-00 conversion
- quick master cylinder question?!?!?!?
- weird START!!!
- 8 vavle head swap
- Z6 help!!
- smoke issue
- tryin to help friend with ecu/swap
- quick question on 99-00 si cluster
- What exhaust should i get
- Compilation of nicest EK's worldwide
- Most comfortable seats?
- Will running an OBD2 GSR with a '00 Si (b16 P2T) ecu cause problems?
- evap purge valve
- Engine stand
- ls oil pump on a b16????
- D16z6 intake & exhaust valve springs?!??
- My 92 EG5
- b16a1 axles
- D16y8 intake mani on D16y7
- do 88 and 91 SI distributors have same plugs?
- 92 EG fuel pump won't come on
- Cross/Drilled Rotors
- t-belt on a d15b
- speedo going haywire
- 98 honda xs power turbo kit
- need some info on my 95 dx coupe please.
- which clutch do i get
- How do I oil an A/C compressor?
- NJ inspection... please help
- How do I make a Coupe Exhaust fit a Hatch (92-95)
- quick exhaust question
- tech: vtec solenoid question
- Anyone have 94 civic vti interior
- Engine Code 22
- SRS light
- Rotating clicking noise when braking.. Any ideas??
- spoon ek gauge cluster needed
- 4-1 or 4-2-1? 1 piece or 2 piece?
- IM IN PS PUMP HELL PLEASE HELP!!!!
- headbolts - SEARCHED
- Blower Motor Lubricant? Or just dust?
- What all needs to be done to.......
- Should i buy?
- Turbo question....?
- myspace
- Installing Drivers side axle
- header bolts/studs.... one snapped.... replace w/bolts??
- Overheating problems
- Strange Problem, need troubleshooting help
- Automatic to Manual conversation
- weird heating problem
- header and intake manifold
- a/c problem not cooling right
- Crower Y8 valve adjustment spec?
- ECU guidance.
- problem with brakes
- power doors on hatch
- 4dr Rear outer door handles, use as front door handles
- fake fog lights??
- Motor Mount Problem, need some help!
- Right hand drive conversion?
- How to Ship Camshafts??
- Quick EG Question...CALLING OUT THE EG GURU's
- smog fail
- Steering Wheel Removal
- bigger front disk brakes???
- has anyone had experience with skunk2 lowering springs are they good? are they bad?
- stock lsvtec vs. stock gsr
- need help removing sonruoof cover!!
- P28 Datalogging.... possible through DLC Connector with stock chip?
- my B16
- cluster lights, ac panel lights [searched]
- Spoon drop in filters...
- Eagle crankshaft flywheel dowel pins??
- 92 cx manifold swap
- problems with b18b swap
- spring and strut combo question
- prelude alarm on ek?
- OEM lip question
- Brake setup upgrade for H22 EG CX Hatch (insight appreciated)
- Windshield Wiper problems
- m/c + bb compatibility
- Brake pedal freeplay?
- lights dimming
- any feedback on these hids?
- d16z6 to d15b vtec swap??
- obd1 or 2?
- EK headlight prob
- VSS wiring colors, would love some help.
- WHERE?
- thinking about a nawer hatch !!!!
- wiper problem
- Is the B16 Crank pully the same a A GSR
- Rear Wing Applications?
- quick question...please help
- HELP d16y7 cranks but doesnt start good spark and fuel?!?!
- whats the highest rev limiter thats still safe for stock head b16
- Will S2k mirrors fit a DEL SOL?
- 98 cluster light went out.
- WHATS THE BEST CAM FOR MOST POWER IN A WORKED D16Y8 TURBO
- apexi SAFC
- ecu
- Getting Rid Of SOHC & DOHC Parts
- Swapping gearing too difficult/pricey?
- Is a LsVetch worth it...
- JUN Race Car for 11k on ebay?
- Prothane Rear LCA bushings
- DSM 450 injector install cant get idle right!
- AHHHH need Help!! Idle Problem
- Changed Oils, Spark Plugs - My Opinions...
- 5 speed reverse?
- compression tester stuck in spark plug well
- Which is better for a 94 dx hatch.. b18c1 or h22a???
- Where to buy honda coolant online
- ECU throwing weird codes help please!!
- quick BAR sticker question
- a little turbo
- Flea Fogger inside the car?
- Can't get my car to start
- 1995 cx stock but has four wire o2 sensor? anyways, want to swap 99 si motor in, help
- Fogging Issues in Honda's Interior
- Idle/Oil pressure Help.....
- ARP Torque Pattern
- The answer to the fogging up headlights
- 92 civic front lip
- Vacuum Canister thing
- Help with my A/c, it made noises before, now it stopped working. Help!
- so who is into bowling?
- Could bad axles cause the check engine light to come on??
- engine shake?
- does anybody know where the fuse schematic is?? is there one in the car?
- Cam gear Mayham
- Which wire is the tach lead on the distributor???
- Better gas mileage?
- what bezel is this?
- Planning To Buy Short Shifter
- Skunk2 Intake Manifold on a D16y7 question?
- What are the best brands of short shifters
- EG rear swaybar options?
- ****police scanners****
- Thermal Exhaust
- 92-95 honda civic shift linkage
- EK Cupholders and "Free Box" install questions
- h22a swap into 92 civic lx 4dr
- How much life does my CX clutch have left?
- Anybody know of a good place in or around Greensboro NC to get a tune?
- 92 Civic hatchback rear spoiler question
- eg sedan manual mirrors
