View Full Version : Honda Civic / Del Sol (1992 - 2000)
- abs yes or no?
- Update on my New Honda!!!!
- red lense paint/brake light check
- what are the torque specs and series of a d series ex manifold
- hp 1/4 mile times
- My freakn' Sweet BAD ASS honda >>>> Look!!
- ls vtec
- RSR exhausr on EK?
- HELP!!!! Steering wheel Shakes when I go over 70mph (PART II)
- car died while on freeway, cranks but no spark, igniter?
- Obd2 - ob1 si swap helpp
- What does it mean when there is fuel in your oil?
- Exhaust Question
- Radiator!! which ones?
- removing windows in a coupe?
- are coils interchangeable
- help!!!: car hesistates and bogs with new ecu!
- advise
- Help!! car idles then shuts off, then won't start back up?
- Grinding noise when car is moving. Wheel bearing?
- 92-95 Civic hatchback [ Manual Door locks ] -- Want to install Actuators
- Bay Area me need help with tranny...
- 98 coupe to 00 hatch, 1st problem
- EG Dashboard Question
- 5 stud conversion on eg (tryed searching)
- Fresh Hell, Distributor problem
- What is the black EVAP Canister for?
- Setting Stock TPS Voltage?
- FAQ: Wiring OBDII Dizzy and Alternator to OBDI harness
- 4 alternators killed ... on 5
- need advice or help PLEASE
- EG6 hatch or S2000 ?!?!
- Question about rev....
- car wont pass 3k
- Power steering pulleys
- turn up the boost
- brake lights dont work need help
- 00 front end conversion?
- My 92 Civic wont start
- Abnormal Revs
- pic of back of a cluster
- Gauge Cluster swap question. New civics
- intake manifolds!
- which spark plug do u use for nitrous on a z6/a6 motor?
- is there any way to tell if my d16 has been replaced before?
- D16y7 to D16z6
- replacing mirror?S
- LoL. The Fast and the Furious 3-Drifting video and pics of the Mustang/Skyline
- Still need help to clear an SRS driver side air bag fault please?
- Valve cover question
- Dash harnesses
- lsvtec arp head studs
- b16 to b16a head swap
- Aftermarket header
- Stud bolts and nuts.
- NEED URGENT HELP... 94 Civic SRS fault
- Oil Pans
- we have civics ls turboed!
- should I change my synchros?
- Help! intermittent spark and engine dies when warm.
- can i put a ex cluster in
- Stud Tq down specs.
- ex coupe question?
- B16A Gen2 torque
- JDMCIVIC
- Do honda ECUs still use the o2 sensor if they are throwing a code 41?
- TPS WIRING
- replacing the key internals on an igntion switch?
- hmmmm... civic hatch beats gto.
- NEED HELP WITH CAMSHAFTS
- FS: JDM RHD 93 MAZDA RX7
- Wheels don't tuck in
- Anyone here run the edelbrock turbo set up?
- head question
- Gas Card for you
- ITR valvetrain upgrade on B16a2.
- ABS brakes into non-ABS car
- Auto to manual vtec ecu conversion question
- lca and sway bars with a drop
- 94 Civic problem- when it rains, car doesn't start- just chugs
- arkansas
- B series flywheels compatible?
- shift knob
- new car suggestions...
- ECU question!!
- how much does a Vtec head cost
- **** Civic Si**
- ****Rear disc conversion****
- CRX amber lights purchase from Ebay. Any problems?
- Some help: front running lights dont come on...
- K series in an EK..................how HARD?
- lowering ek? will my tires hit the fender?
- Del sol targo top latch..
- new to Honda tech
- EK codes
- whats the diameter of the tip on a rsr exmag exhaust for 92-95 civic hatch?
- Help Buying a hatch. Opinions? New to Honda Scene.
- vafc = no vtec?
- 92 Civic Auto climate control - emitting plastic burning smell
- H22 fully built 4 sale /95 Ls motor 4 sale or trade 4 a sohc turbo-kit
- Rims for Sale
- No Heat!! Please read situation...
- cap&Rotor removal problem
- Timing belt mount really needed??
- 97 Civic with Integra DAsh conversion ?
- Swap help B16A2 into a 94 EX, Wiring Harness
- Check engine light need help! Around L.A.
- Need HELP reinstalling stock Rear lower Arm PITA
- H22 downpipe hitting oil pan!!
- what steering wheel hub fit will fit my 99 ek
- Someone help me wit my civic plz
- 99 honda civic si + eibach springs
- dyno pull gear
- installation help request
- vafc an blue box
- Hallelujah! I have my swap back!
- B18c1 or LS/VTECH SWAP
- DOHC VTEC timing issues.
- Painted Lights
- Master cylinder install problems and questions....BAH!!!!
- Civic lights and SI lights
- EGR Valve
- eg6 ex zc
- Is there a way??????
- will a 99 civic si brake master cylinder fit a 94 gsr?
- head type
- yo man b16 valve spring help
- mini me dizzy question
- motor mount question?
- power mirrors on a EK hb
- 95 eg6 check engin light
- what caulk to seal the plastic in the doors?
- Want to get your opinions on what to do
- Turbo help!
- Cold start problems.... 00' Si... Any suggestions?
- which cat?
- Want a good laugh?
- Dash Lights Dimmer not working
- Adjusting position of Exhaust
- car keeps dying.....
- how too know if my p28 is what OBD????
- Motor mount insert question?
- teg door panels on 92-95 civic hatch..
- look what i found. anybody buy from there?
- Just checking in from the windy city
- DSM injectors
- del sol rear brake conversion question
- GSR ECU = SOHC VTEC ENGINE
- haseTerrible highway rpm's?? b16 turbo w/ls tranny
- bought a new winter car tell me what you think
- B16 running issues. Missing and jerky.
- oem part # for vtec selonoid gasket??
- Tranny installation question
- ABS Spoon Sports front lip?????
- power steering reservoir problem - please ASAP
- B18C Stroker kit to 1925cc??
- LS Vtec.... what is it? how does it work? pros and cons ? ??????
- small crash - possible price damage?
- wire harness
- clutch petal limp
- FS/FT: Complete B16A swap for 92-95 civics
- 2000 civic hatch ek
- question about posting a picture in forum
- weird question trust?
- dimmer switch removal
- Short intake. Pros & Cons
- EK4 vs EK9?
- Civic RHD K-Series Turbo
- Integra floormats in H/B?
- Rear Speaker Brakcets...
- looking for omniman's paypal address, need ASAP!! not sure where to post...
- what is SPLINE COUNT
- Buying My First Honda Tomorrow!
- testing water on parts.. tell me how much u think it worth.
- New Here! Got $$, Need Ideas!
- just did a valve adjustment...(B series)
- Anyway to find specific springrates for the OEM Perch?
- b16a and b16a2 question
- Disconnecting shift linkage in EK need help (pics)
- Blue tip exhaust the points down
- Tokico Illumina and H&R springs?
- car keeps dying
- Falken Ziex ZE-512 VS. BF Goodrich g-Force Sport
- i asked this question 3 times can any one help (real help not BS)
- OK, someone educate me on all the abbreviations...
- ecu help!!!!!!!!!!!!
- is this hot?????
- Torque specs on civic sway bar
- Will Eg hatch side skirts fit on coupe
- WANTED:GSR MOTOR AND TRANNY
- longblock shortblock ?
- Search is outa order!!!!!!!!! DAMN !!!!!!!! Input on the H brace Thanks
- Help: Car feels sluggish...
- welding catback exhaust?
- S2000 Cluster in EG6
- Topic
- Removing haze
- Civic DTC code
- Help w/ Lower Ball Joint
- Please help. New project car... HX
- 5 angle valve jobs
- First time honda owner
- new tanabe exhaust
- obd2a h22 to obd1 *HELP!*
- 2000 Civic Stock Speaker Size
- fuel pump types
- Ls vtec?
- car doenst move
- spark plug wiring order
- eg coupe side mirrors
- remove hatchback rear wing
- OEM foglights...bumper cutting?
- do i need sleeves?
- spark plug question for turbo dx 1.6 non vtec
- Ek rear engine mount same as integra/Eg mount?
- 95 civic engine swap
- how do axles break
- idle problems
- need help removing del sol license panel
- Radiator and FAn Questions
- 5th gear bump?
- Hatchback Spoiler For Sale
- f22b1 power steering swap isues
- swapped stock clusters in my EG...HELP!!
- Hello Honda-Tech members i got a ?
- eg seats in a del sol. will if work
- where do i find the engine type
- Which spoiler should i get?
- production #'s for Dark Amethyst Pearl Clearcoat.
- My ride "Pimping aint easy"
- What up
- PAINTED SI WHEEL PIC!! WANTED
- code 21
- eh2 brake upgrade
- Help. PCV broke and fell into oil separator
- QUICK HELP -- What is the size of the allen bolts on the Skunk2 front camber kit!
- car won't start????
- EXEDY clutch question
- Rear Speaker cover
- Not enough back pressure
- Steering Rack & Pinion NEED SUPER HELP
- can bad wheel bearing cause the steering to feel lose??
- Exhaust Smoke / Fuel when cold
- Apex'i WS2 resonator clearance...
- help arospeed cam gears on ctr cams
- Suspension
- bodykit tape
- what to do... need serious advice
- ITR CAMS/ ITR MANIFOLD/THROTTLE BODY
- SRR tie bar + ITR sway=??? Sway gurus look here
