View Full Version : Honda Civic / Del Sol (1992 - 2000)
- chipped p28 ecu's......timing question
- What's the loudest exhaust you can ever have?
- JDM EK coupe for sale in WA state. ADVAN TEIN etc.
- What Tranny?
- I lost my KEYS!!!!!!
- brake pressure problem...
- cant get axles back in after clutch job 96 civic i believe
- EK/EJ-B18C5 Timeslip...Let's compare
- Stock exhaust drilling???
- Ls Or GSR block ?
- Different size rims front and back?
- Tranny Mounts
- BauleyCivic's transmission disasembly
- Alternator from a EF..will it fit?
- are axles supposed to compress in at all?
- eg hybird question
- RIMS ON EK HATCHBACK !!!!!! 16" VS 15"
- Disengaging VTEC... trouble?
- Will stock injectors + resistor box on my EG hurt my car?
- obd0 b18 into a obd1 eg civic
- d16y8 bottom end
- ECU Question
- Is 00 Si shifter shorter than DX shifter?
- aftermarket window motoors
- Speedometer and Odometer not working
- VAFC 2 not correcting fuel curve
- i did rear disk conversion...is integra brake master cylinder 7/8 good enough?..and wat emergency ca
- quick question: plug wire has a piece of wire protruding ?
- where can i buy a filter that will fit a sc61?
- Clutch Master Cylinder
- SMOG AHHHHHHHHhhhhhh NEed help!!!!
- koyo radiator
- question about my b18c1 motor in my 93 si eg
- What did I do to my valve cover nut/stud?
- brakes/ rotors on 03 civic ex
- more displacement out of a "D"
- Help with code 3 22 and 41
- need throttle body for skunk 2 manifold.....
- will del sol si disc brake fit?
- GReddy SP2
- need help with LS swap into vx civic
- HKS Hi Power review
- Carpet Replacement? Anyone done this?
- Mini Me possibility or not?
- questions on interchanging b series parts?
- Throttle Body Help !!
- Striped Spark Plug hole! What to do?
- JDM ECU
- best rods for high revving ls(light weight costeffective)
- obd II into EG6?
- What oem civic front ends will fit a 96 civic without any altercations?
- VSS on 93 civic going out, cant figure out if its bad or a wiring problem
- A/C Compressor Swap Question
- Mirror clarification for EK civics
- How can I roll my new odometer?
- and cool del sol headlights?
- SRR LCA's
- case of disappearing coolant?
- eek my cluster lighting is screwed up!
- Need Help Installing New Antenna On EG and guide line broke
- ej1 project
- torque specs on head
- clutch bypass, 2003 civic
- power windows
- Removing TPS
- custom piping
- CAM GEAR + or -
- holley 68mm itr Throttle body! install
- Proform Shift light blinks randomly.... WTF???
- tach needle sticks.....
- alternator whining?
- Engine Damper. Where does this bracket go?
- General questions. Gotta learn somehow. Please help the newb!
- have i forgotten anything ??
- NEED help with Boosted b16 Ek Hatch, car won't start....
- Low compression Piston
- light engine mod ideas
- I'm (relativly) new!
- how to
- Does anyone know of anymore websites like this one?
- pros and cons of this product?
- body kit installation
- how do i remove A/C? (98 ex coupe)
- need help with eg h22 dog
- eg hatch with gsr swap
- Car overheating again suggestions?
- Need Help!... CEL on...code 65
- OEM optional center console for EG
- 92-95 civic coupe OR 92-95 civic hatchback= which is the lightest?
- no o2 sensor = power loss??
- wuts the difference ??? wut kind should i get ?????
- What to do next?
- what lowering springs should i use ?
- Engine Swap 02 civic
- couple of questions on motor swap prices???
- If my car is stolen, will I get screwed?
- Setting my Apexi Vafc I need help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- help removing back seats in eg hatch
- kybs and race springs, 2 low?
- best engine ......?
- Comptech intake+ice box in a swapped EG?
- TEIN SS on '97 HATCH
- Need Help
- shock compatability question
- CDM SIR gauges what do they look like?
- distributor id number?
- Proplem shifting into 2nd from 1st
- anyone heard of DIY rear 5 lug?
- ek rear disk brake conversion
- LS/Vtec EG Hatch Air Conditioning
- Tranny leak
- ECU ground issues, Need Help Fast!!
- civic hatchback cx 1/4 track time
- how does Vtec work
- AM i going to mess up my motor?!!! HELP!!!
- Advantage of jdm itr ecu over usdm gsr ecu??
- windowfell off track
- BARO sensor
- Does any1 know anything about this engine...???
- k&n filter recharging kit
- p08 or p28
- how hard id it to install a b16a1 comparing to a h22?
- Civic Was Stolen...Now What?
- noise when coming to a stop "ching ching ching"
- Shifter hits the exhaust
- ignition problem/ timing= wont start
- problem w/ tranny or ????
- 1992 Si EG civic...
- fuel pressure regulator ,set at what with set up d16z6?
- Need quick help, please!!!
- Gunmetal Civics
- Size bulbs for 96-00 dx gauge cluster?
- spoon mirrors from an eg to an ek is it possible???????
- Crazy/Irregular Idle Question....
- ckp cel code 4?
- Fitament
- parts
- distributor 0-ring question
- Arm rest for 97 vic
- What Bulbs for 99-00 Civic Fog lights? H3 or H1???!!!
- stripped threads in engine block
- need pics of SI / SIR
- Selling price
- SNEEK PEEKS: TECH43'S K24 EG VTi AKA "ktwizzle"
- Help Brake Swap Master Cylinder Fittings
- B16 Intake mani on a B18 head???
- ***Um...tranny issure or is it clutch?!***
- 94-01 Integra Dashboard in EJ2 [searched!]
- buddy club wheels
- DC Rear Upper Strut Bar
- cant deside what to do paint or engine build? let me know what u would do
- TEIN FLEX...I Got Questions!
- need help please.
- Just got a Sol - Goals
- Should i trade my 98 jdm itr ecu for a 98 usdm gsr ecu??!!
- A/C problems with swap in EK
- oem body kit for a 2004 civic?
- will a cat from an eg fit a 91 crx hf?
- Question on a Turbo Civic.....Too much Pressure + Oil comming out of exhaust...
- read my plugs, please
- milled head...opinions!
- Collector Sizes
- what r the #s from a y8 tranny
- Exedy Organic clutch kit vs. Exedy Racing clutch kit (opinions) for B-series
- 91 Civic ECU/Air question
- just sold my wrecked car...you think i let it go for a good price!
- NEED HELP with factory Honda civic radio
- which company should i trust????
- Ican you resuse d16z6 slave clutch cylinder on a b16 swap?
- CRV Wheels on a 92-95 Civic Hatch
- Accident / Need advice.
- How does a stock 94 CX handle?
- where to get ctr wheels
- Aiming headlights?
- What is the best to mini-me???TB question!!
- !> B series tranny for sale <!
- how hard to change ecu
- 89 integra seats in a 95 civic?
- Why does an HX have more power than a non-VTEC-E Civic?
- wtf is up with my cooling system!?
- Will a 92-95 CAI fit into a 96-00 coupe?
- obd1 obd2 p28
- Cant Get my Car Started...NEED ANY HELP I CAN GET!!!
- Putting tranny back together...how to tell if it's right??
- Something is getting tossed around under the valve cover :/
- new exhaust for mildly modified 94?
- good bye to honda's
- any dyno #'s for mini me?
- crankpully bolt trouble
- Hcp hydro to cable tranny kit
- SOHC D15B VTEC valve train
- FYI: How to read alternator belt sizes from a aftermarket company
- b20 vtec
- stipped axle bolt...
- Small Tachs?
- differenc between b18c5/r b16b/ctr
- Building a '98 Civic EX Coupe on a Budget
- custom pipes?
- Power Issues
- gsr rear discs on eg hatch
- GSr rear seats dotn fit ?????
- EG air con
- which amplifier?
- trailing arm bushing question
- 1997 Honda Civic throwin some codes..
- GSR and B16A valve seals the same??
- stripped axel bolt
- IS THERE A DIFFERENCE BETWEEN THE VTi AND THE SiR STOCK REAR WING????
- plugs ngk platinum vs. denso iridium
- EK Civic CF rear numberplate holder (thingie)
- Please help: Painting and Minor Bodywork Q's (and hopefully A's)
- fuel pressure ? on b16 w/ mugen ecu
- which bar is better?
- where is main relay fora 99 civic ex is!!!!!!!!!!! i searched
- need torque specs for d15b8 head and valvetrain...
- Pic request: AEM short ram Civic 92-00 EX ... still searched
- Bseries swap saga continues..
- window crank removal
- 1995 Honda Civic EX Won't Start
- CEL 70. automatic transaxle. but in a manual car?
- EK gods..... 99si forks & lca..... (URGENT)
- good deal or not ?
- !!!!!!!!!!!!FOR SALE!!!!!!!!!!!!!1
- question for everyone about a civic. DUH!!
- AC with Teg radiator?
- Lean Fuel Vtec-E Bypass
- How do I remove bump strips from door?!?!
- Looking for an AEM Cold Air Intake. What would fit with my setup?
- dynoed my 92 jdm h22 civic hb this weekend
- fuel injectors
- Newbie- Downshifting
- wow!!! help just finished b16a swap and it's broke i think! lol HELP!!!!!!!!!!
- Newbie Question: Chevron Delo 400. syn
- Rebuilding motor, what parts can i get from Autozone?? D16z6
- EDM Del Sol body kit
- Hub assembly...
- Need advice on tire size
- ZEX camshaft dyno..... kind of disappointed
- Spoon shift
- amber signal bulbs for 96-98 headlights?
- eg FORCED INDUCTION INTAKE?
- b16a, where do i find mods? Sorry if u hear this everyday
- Brake Difference Between EK EX and DX
- 99-00 si cluster in a 92-95ex?
- Can the speedometer/rpm clear cover be removed?
- Tricky Question on a part off of Tein SS Coilovers
- GSR T3/T4 need info
- DIY GROUND KIT FOR EG/B16 (YES I LOOKED)
- Pirelli PZero Nero M&S????
- testing waters DA for del sol
