View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Please help
- Thermal Exhaust
- h22 in del sol
- D15 motor
- b18c to ek swap problems: vtec solenoid
- Guage Install
- Header / Cat Question Need Opinons on what to do
- Concern of a crack in my engine bay.
- B18 in civic people what kinda cars are you beating?
- Did b18c1 into a 97 civic hatchback. IACV problems.
- 98 Civic EX not starting [completely]
- RSR EXHAUST...fittment
- need help on replacing radiator support!!
- URGENT HELP: Brake conversion GSR to EK civic.
- Axle. '00 Si. Compatibility??
- Ex/Si Wiring Harness
- Need help with timing on 93 civic dx
- HELP!!!!ESTIMATE ON GOING AT 2 MT????WHATS A GOOD PRICE?
- a nice upgrade for my D15b7 motor
- Who's got an OPINION?
- help with a trustable site for si grille
- D15VTEC motor
- Whats Wrong with my o2 sensor??
- rear lca bushing question.
- calling Si owners...quick request plz.
- Mugen Twin Loop exhaust.
- Can somebody help me diagnose whats wrong with my civic.
- c-piller !
- Looking for a break light
- How Do I Install An Oil PRessure Gauge
- how do i remove crank pull and get lots of leverage
- Requirements For CTR 5 Bolt Brakes on EK
- Umm...i dont get it
- Need ball joint press that works on the car
- BROKEN EXAUST BOLT ON MY HEAD.
- my 94 b16 brake calipers are gone does any other caliper fit?
- Gas Gauge/Tank Help
- help!! emissions!
- Transmission Gurus UNITE!
- civic HB v6? Rear wheel Drive? possible?!?!..
- Power locks
- Eating tons of oil
- LS vtec clutch!
- 96-98 front end, 99-00, what the difference?
- Oil pan leak problem, did it a million times...different techniques...same results.
- Honda Swap Information
- B16a
- Adjusting Distributer on EG. engine running hotter than before...
- about 3 piece bar
- Regarding stupid sticker removal!!!!
- CX DX SI hatch question
- does obd1 gsr engine harness have four plugs
- 1999 Civic OIL LEAK *HELP* ASAP
- would silencer lose hp
- Lookin for a d16z6 or d16y8
- type r ecu
- Losing rmp's in 5th gear
- LS Rod Bearings???
- What is the weight difference between the 93 si and the 93 EX coupe?
- headlight advice please...
- my new ride
- pistons / ls vtec
- d16y8 manifold on d16z6
- 1992-95 hatchback hood
- Ingalls front camber kit front upper ball joint?
- pic request. eg's with b18's and A/C
- vacuum port questions [pics]
- kinda weird? my vafc2 wont read my rpms dropping only raising
- clutch disc can only go in one way?
- noob suspension question
- rear sway bar
- Cold Start
- I think I blew My Engine Help!!!!!!!!!
- ok, when one radiator hose is warm and the other isn't? bad?
- Ls/Vtec?
- i need help turnin off my srs light
- Need Hondata
- H23 into civic wiring (searched)
- zc jdm motor
- eg Bumper spacing
- AT to 5spd swap....
- quick question on iacv
- Cost of B16A2
- Fuel Type/Economy
- Speed Sensor Q's
- tranny wont stay in 3rd
- frustration and potential warning - centerforce dual friction
- Im new and need help
- Who makes this rear strut bar?
- MSD on a 1.6 sohc vtec
- Any problems with the carbonfiber parts from PASSWORDJDM?
- rear disc - swap hub/disc w/ drum
- NEED HELP! AXLE?
- NEWBIE QUESTION, DONT LAUGH
- How much do HX rims go for?
- what does offset mean
- small battery for honda?
- eg hatch rear lower tie bar question....
- ITB
- Engine Price?
- water damage..but from where?
- eg6 sir-s long armrest
- top fuel's web site
- Do you have real HID's?
- engine mounts yay or nay ?
- Ek arm rest in EG
- WRX seats in a civic?
- D16Y7 head on D15B block.. cam timing issues?
- anyone know what that bar that goes across your rear window in the ek hatch call?
- PAINT CODES
- newbie shifter question
- holy n00b question! Si CD player into EG
- SRS light on steady and dead horn. related somehow???
- Suspension?
- swap question
- help with specs on a b18c
- calling all of HT's sickest EK's
- hub centric rings
- momo steering wheel bolts stuck? any ideas
- how many people have del sols?
- shell???
- 92 civic w/ gsr swap
- Upgrading Injectors...
- 93-95 Si Gauge Cluster - Gas light?
- need help car shuts off
- SuSpEnSiOn QuEsTiOn???
- Would these fit?
- s2k injectors?
- Auto to Manual.
- Need help with an exhaust
- axles or allignment?
- Springs - 97 civic hatch --> 97 del sol *searched*
- leaking oil after oil change
- BLOWN PISTON RING I THINK. NEED HELP!!!! STUCK IN PHILLY!!!
- d16 vtec 4 sale
- Gathers CD Player Connector....
- throwing cel codes 4,8,9
- gsr/ctr camshaft installation Q.
- How To Really Preformance tune ur D15B2 Engine
- where does this vacuum line go to?
- Tranny Fluid Leak After clutch replacement
- Alignment after 5 lug swap????
- MOROSO VALVE COVER????? searched
- How do you know when your transmission or your clutch is going bad?
- How much is my Civic worth?
- Removing Stupid sticker line off your car!??!?!?!?!
- clutch slipping
- whats the fastest way to go fast and cheap???
- OMG..please help!
- rebuilding b18c block
- swap help
- high comp with nitrous
- stripped cat bolt = exhaust leak?
- engine temp sensor
- What interior color do i have? confused 96 hatch
- Need some more help.
- Dynoed My B18B1 (low compression built for boost)
- I buy a new headunit and WTF...
- hydro to cable conversion
- help! code 10, ECT sensor causing vtec to not work??
- HOW MUCH IS MY HATCH WORTH?
- need help : rear seat in eg hatch
- Planning on running nitrous on a B16a SiRII motor.
- tuner toys rods
- Removing door panels on the EG
- clutch keeps grinding sound when...
- ***Would a 92-95 4 dr Civic front seats fit on a 93 Civic Hatch????***
- need a quick verification with door swap
- ls/vtec red line
- Q's on Advancing the timing?
- wtf??? axle help
- painting gauges needle what to use?
- Motor Mount Question
- chipping a p07 to run a d15b vtec-e
- TOKICO HP SHOCKS & SPRINGS
- Where is the horn located on the 92-95 Civic ex?
- WH Hmotors? WHY?
- obd II diagnostics port
- how much is my si hatch worth? N/A cleanly modded in running order.
- Brake calipers
- 5 lugs conversion question *HELP*
- 97 hx coupe what engine should i swap in????
- ek rollcage
- wheels squeeking and slipping
- I need some help.
- Does a 93 Civic Si Hatch Come With O2 Sensor???? anybody Know's ?
- feedback please
- Brake lines upgrade on an EK?
- Conversion harness?????????
- is it possible to replace this stud?
- DC-2 Exhust would fit on 98 EK?
- emissions help
- About to begin my project EG.. My to-do list. After opionions
- Ghetto repairs- repairs made with what is handy
- Could a stock crx beat a stock del sol?
- ABS Teg disc swap for 92-95 hatch
- i need bearing for my b16
- Anyone have a wrecked 92-95 coupe for sale???
- Outer Tie Rod Replacement....
- Will an Auto P75 (obd1) start a 5-speed EJ w/swap??
- Side Indicators on an EG.. amber/clear/none.. its a poll :)
- ITR Suspension Conversion on EG Coupe....
- 95 CIVIC EX STOLEN OUT OF FRONTYARD!
- 1997 civic totaled, what should I expect?
- Brake and Headlight inspection
- Replacement Exhaust Piping on APEXi WS...
- what oil for a b18c1 turbo?
- is it smart to....
- f/s or f/t b16a tranny
- header/cat question
- od1 b18 F/S or F/T
- Turbo or Jackson supercharger?
- EG headlight weight differences?
- Question about EG headlamp
- nos hard to install or no
- I was told to post this here..its about my mechanic situation (Bay Area Specific)
- B16a2 into a 1997 Civic
- my 1996 dx to y8 non running swap
- can a mess up wiring egr valve and wrong timming after changing an ecu effect my performance
- need wiring diagram for apexi turbo timer for 98 coupe
- wheel spacers for 4-luggers
- Del Sol Fitment.... Please help me with this question.... Thanks
- help on swap
- swap question
- well installed the depo fogs on my coupe and it does not work.
- Help me decide on swap for coupe.. yes I searched
- help please, b16a in 92 civic (wont start)
- tach and speedo dont work
- swap with a/c?
- FREE B16...come get it and its urs
- 96-00 front bumper license plate hole covers , question
- ROLL CAGE
- Shift Linkage-BSERIES.
- need si foglight info =]
- Air/Fuel Gauge giving a CEL
- POWER DOOR CONVERSION HELP!!!
- h22a vtec problem... plz help
- B20 Vtec Turbo or K20
- I need a Honda
- What is this?
- About to drop a b18c1 in my si....
- HELP! 99 a/c controls in a 96!! (differant from DIY post which i read)
- h22a vtecin EK problem please help
- how can i increse voltage to aftermarket blinkers?
- do i need a WALBRO 255 FUEL PUMP for an all motor h22a vtec?
- Picture of b16 and ctr pistons.
- gsr sway bar
- What seats do you have or do you want in your civic?
- del sol w/ sr20det
