View Full Version : Honda Civic / Del Sol (1992 - 2000)
- whats the diff between ls cluster and gsr cluster?
- no compression
- Most aggressive SOHC Cam?
- Sunroof on EG is struggling, got any suggestions?
- overheating, tried the basics...
- Solid motor mounts
- Higher compression in my D-Series
- srs steering wheel swap
- ek with cai hole
- turbo b20 question something wierd is happening
- Car vibrates while driving, NEED HELP ASAP!! PLEASE!!
- B18 Supercharged
- <>Another Header Thread<>
- FMU!
- might get a turbo or supercharger
- IAT and IAC Wire colors (SEARCHED) Getting CEL's GSR SWAP OBD1
- What is the stock air to fuel ratio for a b16?
- Weird Smell after hard runs
- intake filter question
- cranks over but wont start
- headgasket leaking or blown someone approve what i found.
- obd2b distributor on obd2a engine
- <<<another MY CAR WONT GO INTO GEAR thread>>>
- could this be a problem?
- Identify these shocks. Aftermarket or stock? 56k no go...
- hesitation, stalling, choking, rough idle.
- eld (electronic load detector)
- question on lojack
- looking for a little help.
- weight reduction
- gsr intake maniforld for b16a3
- 00 civic ex
- hydro to cable... what is needed??
- D16Y8 - What can be done...
- stolen motor?
- Buying a 2000 Civic Si
- 99-00 Si lip same as the CTR lip?
- so yeah...
- HELP PLS... D16B7 SOHC
- Lower Compression and Redline
- distributor
- how do you post pics
- What's the best B-series transmission for a turbo?
- what car came with d15b7
- photoshop or pic help?
- 4-1 Header exist for AT?
- ANYONE RUNNING SINGLE CAM SUPERCHARGED?
- 92 cx with 96 gsr swap...car not wanting to turn over....need some help asap!!!
- civic eg b16a cam?
- D Series Header
- slave cylinder woes
- proper oil pan install?
- Tein S. Techs on Tokico Illumina adj shocks
- TRANNY help
- all you all motor d series guy, got a question on my exhaust manifold
- EG COUPE GSR MOTOR MOUNT BROKE OFF PROBLEM
- Moroso oil pans for turbo B16....??
- Fuse Diagram 1994 Honda Civic DX
- Dash Backlight Light Bulbs?
- code 9
- crankshaft pulley key holds what?
- Window tinting removal
- Tire pressure and weather
- exhaust tubing size?
- bumper diagram eg
- Engine flushes…or Seafoam?
- guage problem
- Anybody know when HIDPlanet will be back up?
- My Car ruined my marriage
- cel, wont flash codes, did search
- vtec problem
- WILL A HATCH FRONT BUMPER FIT ON A 4 DOOR 92-95
- Just finished swap but knocking noise... Help
- turbo problem
- what tranny to get for 99 dx
- Megan Racing Headers, will they fit my b16?
- questions for all the smart guys out there.
- How did you boost your Ek and keep your a/c?
- Need help diagnosing the trouble with my Honda civic ex 95.
- People with HIGH Spring Rates
- Are 92-01 Civic Hubs interchangeable
- where to get an lsd for b18
- squeaking noise from pass side wheel well.
- drum to disk brake question
- Dumb Question About Intake/Filter on d16y7
- 96 engine(obd2) into a 95 body(obd1)
- how do you verify you have raxel axels
- RED recaros or RED s2000 seats for my WHITE 95 hatchback
- and other one!! stolen epb 00 si LAS VEGAS!!!!
- d16y8 stroker motor help
- Help a n00b out
- I have a really bad idle problem....HELP Please
- wheel stud broke
- deciphering OBD2 check engine light flashing
- Ek roll bar harness bar chassis
- my fan wont turn on, i read threads, have questions
- honda civic DX automaticm,lower A arm / suspenion question
- EG6 Tire Size
- spark plug wires
- car starts then dies! need help
- EG owners with HIDs. Check here.
- please help! brand new clutch is slipping...
- should i get forced induction
- **** PASSWORD JDM.COM****
- my car still idle so high...2k start up, 1k warm up
- suspension question/opinion...what is your set up?
- K20 In 95 Civic HB
- Heater core removal....How?
- Redaitor made of copper ??
- motor question
- apexi ws2 help
- canadians who order from EBAY usa
- ebay EK headlights??
- MACHINE SHOPS IN MN?
- Del Sol / EK Civic Front Bumper compatibility
- ITB's
- quick question about b16 tb and fitv
- 99 ej8 -> em1 help...
- HELP WITH WHAT TO DO ON VTEC ENGINE
- Question: '00 Civic Coupe - What holds the back panel in place?
- wtf is a code 67?? help me out
- need help plz
- Dark Grey 2 Versions????
- Ferio: Power folding mirrors one is nt folding all the way....HELP!
- rear disc help
- how do u do a grease job when installing clutch?
- torque specs for b-series header?
- :DC2-R trunk bars...:
- Car Wont Move!
- Need help ASAP, headgasket question.
- Rattling Exhaust
- NOISE NOISE NOISE!!
- Replacing OEM Fenders and Bumper with JDM parts
- transmission problem Need HELP!!
- D15 Vtec not starting?
- WTB: 99-00 CIVic SI Stock suspension
- Engine/Serial number on the B16A?
- guage pods
- NEED SOME INFO...
- Ignition problem
- best place to purchase carbon fiber parts
- Hello From Austin, TX
- manual transmission fluid fill level
- HELPP!! I NEED SI's, webs swirlies, or rotas or anything 4x100 lemme know--NJ thanks
- What would you do?
- head problems
- Did I just buy a 2000 B16 transmission?
- Selling my Civic coupe w/ITRswap
- Timing belt issue could turn serious
- del sol swap help
- b20vtec tapping noise
- south carolina help?
- 92-95 window moldings
- Transmission trouble
- Help with datalogging equipment. whats what?
- WHAT AXLES WILL WORK ON A JDM B16?
- NEED HELP WITH CD PLAYER PLEASE HELP
- McColluch 6000k H4 HID Kit
- ek will sir cluster jus plug and play
- SI swaybar question.
- Could this be anything else besides the alternator?
- JDM Civic SIR Climate Control
- Side rear view mirrors wont work
- Fuel Prob OBD2-ODB1 Swap
- jdm h22 vtec pressure valve issue (I SEARCHED)
- almost there!!! eg project car
- My 96 vsm sedan!
- Engine Trouble...
- Anyone in the Germantown, MD Area
- How much would this cost?
- clutch slipping
- Regarding CV axle replacement ... Ordering Parts, need help
- DAY 4: Swap is 98% done... Just Wont Start
- I need the hanger for the header in my 92 civic
- ej1 with a type r front
- cams question
- Startup problem with 95 Civic DX
- what is the best b-series motor?
- Axle question
- Will a 95 Integra Heater core fit my 92 dx eg?
- Changing dizzy, is this all i need?
- red and clear tails
- 99 si for sale! Very fast! JRSC on it! 12psi
- New tires...etc....help
- do EK side skirt fit EG Coupe
- I did a search but.... how to ls vtec?
- Weird, My problems are fixing themselves
- Swap help
- boosted now idles weird
- if this is a open discussion, why cant i post what i want?
- converting my '93 civ coupe to an integra front endd
- '95 Civic Fuse Box Diagram
- Problems Installing Wheel
- 98 Civic Valve lash
- EMS Question
- 97 EX, injectors not pulsing, PMGFI relay good
- Side Mirror Adjuster
- THIS IS MY Ek
- K20 into EK with EG cross member,, which rear support?
- HOW DID MY SINGLE CAM BLOW???!
- AXEL TROUBLE, PLEASE HELP
- JDM wiring harness
- PLEASE help me with this civic.....
- what mounts do i use for a sir 2 into a 1994 honda civic ex
- gsr strut bar in ek chassis?
- want too make money
- datalogging question.
- strange door lock problem
- headlight modification..
- where to find replica oem lip for 99-00 civic SI?
- will 13" steelies fit on a 98 ex coupe
- car turns off when idle! HELP PLEASE
- ///////////////////fuel problem please help\\\\\\\\\\\\\\\\\
- need help!
- need diagram to hook up vtec.
- need help identifying this pug/wires
- b20vtec swap, temp gauge not working
- del sol problems...again...
- B16a motor is Overheating. What could it be?
- Motor Swap
- I got a 94 del Sol VTEC. What should I do?
- Need Help!!
- 1 WIRE TO A 4 WIRE O2?
- del sol project
- removing melted spark plug boots from head
- Suggestions for a wing on a EK
- **Who has a 96-00 with an Aftermarket Steering wheel? Which hub to get????**
- Direct Ignition System
- Please Help Quick!! Sensor Question on 2000 EX
- Proportioning valves explained and why it is not necessary to change them
- anyone has swopped a 96 civic dashboard into a 92 civic hatch?
- Are integra and civic 's hb rear trailing arms the same?
- Is The Benen Fuel Rail Still Availible?
- Write-up for bottom EK brake lights?
- Civic 6G Criuse Control install information request.
- Just started a new project car
- REMOVING TRANSMISSION, NEED HELP ASAP
- Oil Filter brought after changing oill PICS
- How do you install this...?
- Anyone know of a cheap place i can buy a distributor for my 99 civic ex?
- H22 hasport motor mounts for EG
- Front windshield defroster is not working
- i've hit a wall
- Rev Limit problem!!
- EK Cruise Control Removal Q&A
- my first motor swap, what am i forgetting
- d15 smokes after head rebuild
- What axles for CTR 5 lug w/ D series
- knock sensor code help??????????????????????????????????????????
- where is the temp sensor
