View Full Version : Honda Civic / Del Sol (1992 - 2000)
- JDM B16A 1st gen waste'n gas?!!?
- a6 cam in b7 head???
- will it fit?
- need help, is this a vtec head
- info on my motor
- bumpers
- mini-me swap in civic sedan
- smog legal cats for 95 and older obd1
- 93 civic SI
- axle question
- Wiring color question: OBD1
- Where to find a 5 inch silencer?
- rear wheel bearings
- opening my headlights?
- SI cluster?
- Clunking noise when move stering wheel or drive over bumps...
- SRI used to whistle...now only annoying hum
- b16a2 into 98 ex questions
- Biggest motor 2...last one locked
- Whats the name of this bolt?
- Which motor is reliable w/ lot of potential?
- Have any of you guys fit a hood from a civic into an EK Hatch???
- Bad gas mileage, WTF///
- will 96-00 shocks fit a 92-95?
- massive amounts of white smoke
- 4door GSR rear brakes on ek coupe?
- IM gasket removal question
- Del Sol seat covers,
- eg hatch shell????
- ITR Shocks on 93 si?
- 2000 civic si/k24 swap TESTING WATERS
- bearing like noise in my engine?
- head gasket problems?
- 13in rims on a 99-00 si?
- b18c1 hits rev limiter at 7k?
- best deal
- Suspension for my EJ1
- which axel? for 97civicek w/b18c5 my axel broke?
- injector code on D15, what is it?
- I need help finding this mount.
- SCAMMER!!
- Civic Seats
- Will this coilover kit fit a Del Sol?
- What is a 2 step
- Need help! h22a4 harness for 97 civic hatch!!
- Thoughts on getting ls vtec
- d16z6 into 96 ek
- car making a raspy, mid to high pitched rattling noise for like a second, when i hit like 1500rpm's
- v-tech wiring questions
- meaning of FI??
- d-series or b-series??
- ek hasporters
- front and rear strut toppers interchangable?
- engine wont turn over ....
- whats the widest wheel able to fit onto a 1995 civic hatch?
- motor qustion
- Apex-i Power Fc...
- new ek mini-me swap problems
- dx tranny and ex tranny different right?
- Password JDM 3-points reportedly due in Friday...
- does it cost less to ship rim/tires with no air inside ?
- Which tool should I buy?
- What the hell is that smell!??!
- d16a6 on b15b8 minime questions
- Where did this engine come from!?!?
- d16y8 trannys??
- Overheating problem - Changed thermostat, bled the system, new radiator cap.. What's wrong?
- QUICK QUESTION
- Still no keyless entry. Worked before, now it doesnt.
- Stolen Civic Las Vegas
- I need help!
- lowering question
- gsr swap-not gettin fuel-pump priming????
- Anyone know the CFM that the stock civic fan pulls in?
- How to install wheel bearings/lower ball joints (pic intensive)
- how can i bend brake lines?
- b20b vs b20z intake manifold question
- Power Steering Sensor
- Mini me help
- Stolen: 92 Red Civic Hatch in Central Florida Area 3/21/06
- Steering problem
- Not getting enough spark (really low spark)...
- ignition key code
- Hey Guys I'm a noob with some questions about rebuilding a 94 Honda EX
- Fuel, no spark no start:(
- USDM wire harness trouble...wiring gurus help.
- Confused??
- CX/DX EK Hatch - what's the diff?
- 99-00 EJ coupe all red taillights....
- Brake Swap and Issue's!!!!
- problem with clock & radio
- Pic request: Sidemount intercooler, installed
- what distributor for h22 swap
- Water purge kit...
- confirm everything i need to put a GSR B18c in a EK civic
- Eye lids
- a/c console lights?
- so cal del sol parts
- d16y7-zc?
- 2000 front end conversion
- i need suggestions
- Which header to buy??? Need opinions.
- Brake help
- Where to buy RHD conversion??
- 94 up integra seats into 92 civic eg...
- any 4 door eg civics with a 2000 front conversion?
- jdmcarboy 99-00 conversion
- Throttle Body coolant lines bypassed. Idle seems high, and bounces.
- Are the doors on the 2 door EGs the same as the Hatchbacks?
- getting new doors on my 92 hatch
- f/s gti . i want a civic
- foglight bulb
- obd1 or obd2?
- no dash lights
- Timing belt change: Different part numbers?
- hej guys i need help
- blown headgasket or coolant lines?
- Recommended Upgrades?
- Quick Sol questions
- megan racing?
- quick question?????//
- Map Sensor question?
- muffler removal gas mgp
- engines
- my speedo wont work
- Steering wheel?
- Help code 48??
- Wiring on an Eg Help
- this is ITR manifold right
- More Help...
- no CEL's but car still runs crappy... ideas?
- ANY SHOPS IN NJ TO HAVE SWAP DONE
- y7/y8 head, compresion test is telling me headgasket is bad, what do you think?
- H22 with ac ?
- help on swap
- whats the widest wheel able to fit on a 1995 civic hatch?
- d16 what to get next?
- 96+ turbo civic guys
- depo foglights
- clutch problem? *searched*
- engine question
- VTEC timer
- help dizzzy ecu question (solid cel)
- new to turbos, worth it on a jdm d15?
- OBDIIa vs. OBDIIb dizzy
- anyone have carfax?
- S2k wheel in em1?
- header ?
- sidemarker wiring
- door NOISE...... DAMN!
- What is this?
- anyone have the wiring diagram for the windshield wiper motor???
- wheels
- Tires
- Exhaust Question
- ECU question
- what intake manifold should i go with my d16y8??
- QUICK QUESTION,EG COUPE catback piping..will it fit an eg/eg hatch?
- installing springs quick question!
- putting acura dash in 92-95 honda civic is it true
- my friend has a question about his del sol
- What kind of exhausts are runnin on there EG's??
- blue/white smoke when gassing
- short clutch pedal ftw?
- my car is hesitating?
- Anyone found a solution to Skunk2 throttlebody Sticking??
- Vaccum Leak? Where do I look?
- Any body heard of.........
- d15b w/ skunk2 intake manifold. Gains.
- Will a Si control arm fit on an Lx
- clutch install not sitting right whats the deal??
- will this fit on an 2000 si
- Piaa or Nokya bulbs
- Crossmember/LCA combo question...?
- 94 civic dx....d15b swap questions
- Pic of engine bay
- 2000 Civic Si question.
- Info on Price for Strut
- gude non vtec cam
- y17 swap guestion
- jun flywheel what you think bout it
- My first del sol..2000 civic conversion
- clutch
- annoying gas light.
- Wiring Vtec w/ CX motor
- Noob-e post. Replacement axles
- CEL trouble...throwing codes 54, 90
- Shim size for 98+ ITR LSD into B16A2 tranny??
- exhaust help
- tranny shell
- Rear Fenders
- Help!! check engine light, cant figure it out please help!!!
- New motor swap... Now tach doesnt work
- Ls mounts into eg
- need to know how to put ARP wheel studs on..
- stock engine sources?
- rollin 40km/h
- Horn w/ nrg qr and momo wheel... using the honda-tech diy
- blogging
- Price CHECK Tell me if im gettin ripped off or not!!!
- quick reply needed: DC4-1ss header from b16 --> b18c5?
- NooB Question JDM and USDM
- What will happen if you don't have the stock pcv catch can hooked up?
- Just got the swap running this weekend.....2000 GSR in 94 ex. Pics are up!
- SOHC Beastliness
- Speedometer not working!!
- The proverbial "noise" from transmission...
- car wont die slowly died helpp!
- B16A swap and clutch slips unbelieveably!
- clicking noise coming from VALVE! PLEASE HELP!!
- USDM part can't fit in JDM parts?!
- rpm jumps, or bogs what ever they call it
- d16z6 vtec solenoids and B-series solenoids interchangeable?
- JUMPING IDLE
- o2 sensor
- Valvetrain question
- fuel pump?
- Need help: Removing engine. what to do with ac and hydro clutch lines?
- Oil pump?
- Coupe and hatchback foglights?
- Delsol Del Sol electric UK roof? where do i get one
- Gauge wont LIght Up..HELp
- Bore and Stroke
- HELP!!!! Radiator hose?
- Does this look right? *Pics*
- New guy needs help with project: B16, B18, etc
- GOT my NEW CIVIC!!!! Need Help
- timing belt broke while driving..on a 92 stock EG
- Squeaky clutch pedal,wtf is wrong with it?
- i have a question ?
- 99 Civic Si- Engine sound problems
- transmission slipping need some help please
- Lower Balljoint Noise or worse?
- Brake booster/MC opinions
- Drilled? Slotted? Drilled&Slotted? Blank?....
- spark plug wires
- 99-00 Si exhaust fit 99 Civic Ex?
- another 5g project
- OE side skirts...where do i get em?
- Where to buy? Cheapest/better quality replica CTR rear lip.
- picking up my first eg just some questions
- F22b2 intake mani
- EH/EG Pic Request of the IACV & FITV
- 1/4 mile time gsr and B16 engine and tranny swap.
- help wiring problem on radio
- .......Engine Gasket Kit..........
- del sol carbon fiber
- Anti-lock Axles on a non-antilock car?
- SAFC wiring
- Why am i running so rich?
