View Full Version : Honda Civic / Del Sol (1992 - 2000)
- k20
- Exhaust info help
- ~~~HOw to get a Mercedez-Volkswagon to Honda key?
- Do i need a retune or just Aem Wideband
- GSR Lca's on my Eg
- wiring harness
- 98 Civic EX KEYLESS REMOTE HELP!!
- ok i need help identifyin this engine!!
- Adjusting Spoon Cam Gears
- exhaust question and engine problem
- power steering pumps
- Cam gears
- 99 SI With GSR ?'s.
- 00 si tranny options?
- were can i find this?
- Need Help: Swap wont start
- changing out torque converter pull motor or just the trans???
- cd radio appearance
- Just swaped. no fuel? bad ECU?
- Intake manifold QUESTION!!!! PLEASE HELP!!
- Top speed of a D16Z6 Transmission
- retrofit hid's for 92-95 civic's
- Wiring Wizards: Modify Connector for Cruise Control?
- cv axle bearings?
- some advice
- NAPA starters? possible to get 3 bad ones?
- jdm b16 obd1 wireing harness question
- Car vibration above 70mph
- another intake question
- GSR Hatch
- d16y8 tranny problems.. needs a new one or fix?
- problems getting rockers on... 2000 hatch
- alternator problem
- what and where is IACV ?
- tire size steel rim width
- 00 civic a/c promblems and power window problem
- Broken steering rack? or Something else? What to look for?
- H22A4 swap in 94 civic dx
- misfiring z6
- Ek w/GSR What throttle cable?
- 98 Civic EX alarm sytem HELP!!!
- Problem With The scale
- does 91 civic ef hatch lowering springs fit 99 ek sedan?
- obd 2 motor in a obd 1
- b16 engine with b18a bearing
- NEW MEMBER FROM 671 GUAM
- Spring Rates
- Autozone Employees - Special Limited Time Offer
- GRINDING LOL!!!!
- B16 engine problem
- D16Z6 to D15B
- NTB: 99-00 fog light housing
- BIg car problem need help asap!!!
- Tech Article: B-Series Cam Seal Replacement
- Automatic to Manual EG HB Swap
- ls cams and b20 cams...
- 2.5" piping on d16z6 eg? good or bad?
- EK hatch GSR swap question
- jdmcarboy p28
- 93 ex extreme idle
- Need Help With Headgasket Leak!
- return line leaking
- how to take off rear bumper on a ek
- anyone want to help build/ or build for me a d16 set up for boost
- Whining sound when turning right, help please? (96 Civic Coupe)
- need parts for b18a1
- Remote oil filter/coolers show me what you have
- ARC PARTS
- d-series crank pulley?
- help wit build please help help help
- ***Need Advice...Which exhaust???....99 Si***
- Recommended Clutch Kits....
- what one... i cant decide!
- axel nut ?
- Help with transmission
- where to get Fog lights
- 92-95 hb cx vx si dx gas tank
- Want to see what happens when you hit 10k on stock valvetrain!!!!!!!!!!!
- D16Y8 Cruise Control
- cf trunk problems flies open hard and fast
- Need help on removing strip bolt.
- bad axle, tranny or clutch?
- wanna see what a chevy 350 looks like in a 97 honda civic ? check it out
- IGNITION HELP PLEASE!!! CAR WON'T STAY ON!!!
- AFI turbo kit vs Boostflow kit, Anybody using these kits ? ?
- Koni Yellow pressure and Ground Control spring rate for Civic EG
- JDM map lights
- integra dash/door card swap in ej8
- head bolts
- Car won't stay alive
- swap ?
- Power/Ground distribution box?
- Type R 5 lug brake conversion
- Type R Rear seats in eg??
- blah bitch blah
- 97 Del Sol A/C Cabin Filter? A/C weird noise?
- Wow look at this wiring. Plz help d16z6!
- d16y8 high compression engine tuned/converted to obd-1????
- D15Z1 out and in D16a6
- D15 vs D16 motor mounts ??
- lowered civic
- 93 eg still surging
- b16a2 in a 96 ex coupe
- Actual size of JDM Road Flare
- Engine misfire (b16) on cold start
- distributor ?
- EK SRS Reset
- coupe spoiler???
- tough question, is 92 hatch rear H emblem the smallest size? pic
- Alternator
- Resurfaced B16a head, Ready to be put all back together just a few ?'s!
- em1 steering/front knuckles on ej1
- ls swap problem.
- failed smog need help
- Head Removal
- plz help i swear i cant find the cel code
- o.e.m 36mm 4 lug hubs?
- noob question
- I Think My Engine Jumped Timing After a Cam Gear Install! *HELP!*
- Not sure What to do.....
- Clutch Slipping
- wire questions
- help with rear seat for eg!! really need help
- si front lip
- 98 civic dx ac problem !
- I've never seen a vtec solenoid like this??
- DEL SOL SEATS IN EJ2
- y7 question
- Honda intake manifold question???
- depinning OBD-1 injector clips
- Here is my coupe also tech question inside
- ~~~Some advice please "95 Civic coupe 87k OG miles~~~
- Honda Civic EX 99
- Finaldrive ratio for 99-00 SI?
- How can i tell when the ECU is popped?
- corner light connector
- water leak narrowed down.
- SR*S exhaust for eg
- Can any one help me i need to know the top speed of d16z6...
- ls turbo hatch compleatly stock on crome program???????
- 4 wire o2, and vtec diagram please
- interchangable starters? Dseries
- Bisimoto Headers! all who think theyre expensive checkit
- 2000 si HID help!
- Cheap Modifications for 1995 Civic
- WIRING DIAGRAM FOR WIRING IN A VAFC I
- 2.5 inch exhaust
- importing parts
- driver side window falls off track wtf
- gas gauges dooesnt move it just stays in one spot at all times
- all motor bulid
- 95 civic looses all electrical power while driving. Please help!
- Fuse 30 Insturment Light keeps blowing
- Ek9?Eg?Ej1?? wtf!! I'm lost
- ~~~gas tank pressure sensor question~~~
- Where to get Weak SOS decals??
- Brake problems and noises
- Anyone know if an NRG lock will work on a BOSS quick release?
- MY 93 HONDA CIVIC HATCH CX
- ground control coilover help.
- dumb questions need anwered too!
- Help with sunroof/moonroof visor, Need measuments.
- IAVC code with stock ecu
- Need helping hooking up air/fuel gauge
- 95 Civic looses all electrical power while driving. Please Help!
- ex/si transmission
- flip a COIN please........i need advice about swap headers!!!!
- h22 tuning/wire tuck??
- high fuel pressure
- Tell me what you think
- Rough Idle
- car lighter help!!!
- Tail lights ?
- 3 stage d15b vtec sound
- Kanyo Racing Radiator Slim line fan
- wire vtec strait to the battery???
- My ZC Swap
- 96-98 civic hood to 99/00 identification?
- my first swap??
- Overheating Hatchback - Awesome! - Help?
- o2 sensor clips different? round clip 1 wire and square 4 wire?
- Civic Vx pistons on a turbo setup
- anyone shopped at k2motor?
- to all owners of a jdm console for 92-95 civic
- cel 8
- Help about Ground Control Coilovers!!
- New Here, 97 Civic Turbo (rice warning)
- Looking into H2B possibilities, question regarding AC/PS
- weird problem runnin rich...idk what it is. need help!!
- Rapid Performance EG engine swap and a few other random pics
- car smells bad when AC on, what is the solution?
- how to join the eg squad?
- Integra dash conversion
- o2 sensor bad, po135 code, which one? top or bottom?
- Several questions...
- anyone have an old busted 99-00 si cluster?
- 92-95 cat fit an ek hatch?
- Should i trade my dx coupe for an EF with a B16 swap?
- motor swap ?
- water reserve bottle/cap
- supra injectors on b16 fuel rail>????
- Help - jumping out of 5th
- EG/DC seats in a DELSOL? Perfect match or not?
- unervsial o2 sensor questions??
- Paint code question.
- help...i am in emergency situation
- Catch can
- Full-Race T3/T67H.O. EK
- Winter Project....
- si cluster
- OBD2B wiring diagram for VTEC CONTROLLER
- will 92-95 2/3dr headlights fit on my 95 lx 4 door?
- vtec controller???
- might be getting a '94 civic dx.. input!!
- what is a fitv listed as ?
- were are the pic
- What fuel line to use/B16 in 98 civic
- Quick Door Hinge Question
- Recommend a suspension 92 EG with H22
- Dont know what to do
- Tank size
- horrible fuel economy
- Fixing a code 92 EVAP Solenoid/Valve/Vacuum Lines
- CODE 15 Ignition Output Signal
- honda newbie
- How did this happen?
- Header Question
- crank bolt 2000 1.6LX
- wierd electrical problem
- cruise control problems
- cusco b pillar side bars question
- EM1 exhaust question?
- 93 civic auto wont shift
- Your Opinion
- please help guys
- swap questions after reading faq b16a1 into EG civic, sort of.
- squeky belts on a 99 dx
- obd1 vtec and knock sensor
- Replacing Left Side Lower Motor mount?
- H22 mounts?
- what is a fitv
- sir front and rear from jdmcarboy ?
- Converting My Lambo Doors Back To Regular. Quick Question.
- ep3 seats into ej8 hatch
- gsr oil pan on b16a?
- BYS/AirWalker bumper for 96-98?
- Ricey McRicerton..
- Can i Turbo kit a stock 92 civic Lx??
- A couple questions??
- 94 hatch w/ls swap--need help/problem shifting gears
