View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Is it my fuel filter? (searched already)
- which better aem v2 or secret weapon r intake?
- best spark plugs denso or ngk?
- b20vtec or b16-T
- $50 bucks to the guy who can figure out the problem!!!! jdm itr hatches please come in....
- Cost of building an SiR II?
- Buddy needs a new cylinder head
- Buying block and head seperatly cheaper?
- Do you think after market HIDS made for Accord will work in my EG civic lights ???
- fog lights
- high idle
- How to install turbo?
- Please help me get my car UP and RUNNING again.
- d16 tranny probs
- Chicagoland Body Shop
- Control arm question for 96-00 civic/94-01 integra
- 96 Ek cluster and checkengine light prob!
- MY CAR WAS BROKEN INTO (Columbia Mall, MD)
- D15B ECU ERRORS???? not enough octane for the motor to run right her ein the USA???
- does anyone kno specs on skunk2 pro series 1 cams and im
- free oil (not classified) (just info)
- I can't seem to fix my Del Sol.....running on 3 cylinders!!
- check engine light on EK(gsr swap)
- idle problem please help
- OEM FOGLIGHT WIRING QUESTION!
- OBD Code 1259 VTEC Malfunction
- Idle and then shutdown, and jumping rpms
- Whoa, huge help needed.
- Transmission problems!!! need advice
- Need help with turbos
- Car wont start, tryed lots
- Koni Coilovers Stuck!!!
- CAMCORDER MOUNT
- Problem - I need any help I can get
- Del Sol Keyless Entry!!???
- Grinding d15b7 tranny in second gear.
- Any one see the 802WHP civic vid?
- DEL SOL + DEER! ( I HATE DEER )
- D16Z6 swap info and rebuild opinions
- Header question!?!?!
- Best Way to Test an Engine
- Sea foamed and changed oil today...BIG difference
- d15 and want vtech
- can someone answer this for me, i am lost
- What would be the best option??
- Analysis of Plug... how's my motor doing???
- worth it? or not?
- 93 CIVIC AUTO/MANUAL
- Axle is stuck!
- Need some opinions on a Civic/Legend Hybrid car I'm building...
- Best ECU to use?
- Electrical problem
- Replaced Slave & Master cylinder still no pressure
- need advice .... hear water inside 95 civic
- price for jdm integra conversion
- short throw Q
- Barely Failed Emissions.. how do i fix it?
- d15 mini me or z6 for boost??
- Confusing ECU information??
- '92 Civic Dx Hatch-What's it worth?
- H22 in EK with H22 axles, springs, shocks, rotors, brakes etc...?
- Help identify which part # is cam seal.
- Evasive Motorsports harnesses.
- H22 ground clearance
- underdrive alternator pulley?
- high flow, comparable to stock muffler
- alternotor belt?
- trunk?
- oxygen sensor questions 95
- TRANS HELP
- Damn Flywheel!
- Does anyone had experince with FUZION ZRi tires?
- ***The End All Del Sol Roll Cage/Bar Thread***
- Benifits of changing headgasket to up compression?
- Where to get euro spec rear bumper?
- EK ITR Question
- drivers side door panel vibrates like crazy...
- sohc transmission problems
- b16a into eg pwr steering
- Greddy header?
- Bad Battery affecting alternator while on driving?
- Kteller 3" Exhaust, site only has coupe/sedan, anyone know how to order for hatch?
- Pics of integra wheels on civic
- lights?
- how to turn on ecu?
- need advices about civic turbo?
- Removal of a/c & p/s ?
- Spoon side mirrors ~ EG
- Snap off Quick Release
- Boost controller mounting problems! Need advice
- Fuel Pump issues
- Questions about my '89 crx si
- "Need a fuse diagram for a 1992 civic dx"
- Rotors rubbing my Rotas
- Need Help! With Cluster Install!
- D16 performance without turbo
- Cracked tail lites
- Brake Line Question
- Intake for 02 Civic
- Hose question next to Fuel Filter B16A2
- PASSED SMOG IN SAN JOSE, CA...THANKS TECH 3!!! BAR'ED EK WITH B18C1!!!
- d16z6
- Help with civic
- tein hood shocks? fuck that.. i did mine for FREE
- what paint for tails lights??
- Exhust stay/brace on B16a2+JDM ITR Header?
- b16 head
- what the best thing to do?
- MSD Mount Pics
- Tranny wont drop???
- 5W-20 oil
- Post My H22 Civic Photos?
- How Fast Is A B16a
- Help B16 Engine codes
- shift linkage for auto to manual swap *already searched*
- Could PCV be my problem...
- 93 civic b20z motor swap need help HELP WANTED!!!!!!!
- Underdrive again!!!!!!!!!!!!!!!!!!!!!!!!!
- Automatic vs Manual shifter console peice different?
- UNDERDRIVE PULLEYS OHNO!!!
- Mini Me Swap or EX motor swap in 92 Hatch?
- B16?
- Looking for air temperatur sensor on my civic 96 ex
- dohc zc performance
- exhaust question
- Clutch - Master/Slave Cylinder Problem
- I Dont Know What To GET!!! $5000
- For all the 4 bangin sohc lovers. Whats the Best Header made for theD-Series motor?
- Clutch pedal extremly soft?
- 7th Gen Civic? What is it called?
- cx motor- How to get better mpg
- asdf
- Simple question ****need advice****
- Gunmetal paintjob
- SQUICKY CLUTCH
- recked my beautiful hatchback :(
- Timing off
- tranny problem. in gear but car does not move, mph goes up, tranny noise
- help on my ek swap
- how much would you pay for a 98 Civic Ex 6disc changer and face?
- 96-98 HX's, was the TRUNK plastic insert, around license plate, painted?
- H&R OE and stock shocks?
- 96 del sol with y7 obd2a- obd1 problems... Help please sputtering...
- Easiest ways to remove CX dash?
- Tranny switch
- Cracked Header!!!!!
- Where can I find a plug and play o2 simulator?
- weird burning smell after racing??
- Engine oil Motul/Mobil 1?
- gsr front brake swap
- 99 Civic Hatch DX HELMS manual REQUEST
- Clutchnet Clutches
- Brakes....
- check engine light help
- Would porting the stock exhaust manifold do anything???
- ? struts??
- check engine light go's on after driving on 4 gear for 5 min
- "Rattley" noise from my shifter......
- Del Sol Roll Cage
- Fix for leaky Del Sol roofs?
- 4RM NEW TO DRIED OUT
- 2000 honda civic ex coupe
- Installed Tach know having problems
- Omni front control arm (camber kit) failed.
- problem with dash lights
- HELP NEEDED!!!!
- Gauge cluster removal question...
- I have a question...please let me know whats up
- Hydro Lock Oil
- My brake pads don't fit. HELP!
- i need some little secrets
- Low Idle.....MIL Codeskeep comeing back.....Sometimes wont start......PLEASE HELP!!!!!
- 92 honda civic
- clutch chatter
- B18C swapin into 94' EX coupe Exhaust Question
- New car whoa's... :-{ (doesn't start anymore)
- B18 Civic swap
- EK ITR Question
- 5zigen border 304 exhaust (looks like spoon) does the jdm eg have a shorter cat?
- 1999 civic crank shaft pulley
- omni powers not fitting?!?! wtf
- Perches or not - Koni question
- Trouble installing ITR LSD into Y21 trans, speedo gear rubs on case
- O2 sensor?
- Bad fuel injectors causing my 96dx EK to die on the road?????
- sputtering
- 2001+ Civic Owners, Problem w/ Power Window Switch
- eibach rear sway with rear break conversion?
- help me with my harness!
- clean coupe?
- Need help with no Spark... newbie..
- b16a3 (94-95 del sol) check engine light
- 98 civic dx: power steering belt tensioner
- working on friends car... now need radio code
- Civic H22 suspension
- D16Z6 Head with D16Y8 Manifold?
- how much is this worth?????
- which ecu should i get
- what tranny can fit a y7??
- Engine Blueprints/Schematics.....
- who made del sol seats?
- B20 w/ B18 Head
- o2 wire length
- y8 intake mani swap...
- where is the iab
- Lca Question
- What Tranny Should i get for my y8
- Whats the b16a hp rating on the euopean version?
- Looking 4 a 95 Civic coupe si..4 sale..
- help with d16y8 swap into a obd1 del sol..ive searched
- speedo help
- Searching for a muffler
- vtec wiring
- my roommates' car has been stolen in the roseville ca. area
- HELP NEEDED ASAP!!!
- Passenger side window repair
- radio code.. dash wiring?
- Idle Surging, bad iacv?
- Climate control swap need help quick...
- Is it worth throwing a JDM D15b head on a USDM D16y8?
- green something cleaner.
- Strut/Control Arm?
- does anyone know how to properly disconnect airbags so they dont go off on a ek
- doing tranny swap
- Yonaka Motorsports Axles?
- Sohc v-tec power?
- windshield wiper control question
- civic 99' head lights
- SOHC V-tec power?
- Where can i find a 93-95 roof spoiler with LED ?
- Steering Wheel ...
- WINDOW VISORS ???
- first swap, can't get running correctly.
- Ignitor problem.......I think
- Where is the Airbag Computer/Module in 92 DX hatch?
- parking light short
- Crank pulley?
- gauge cluster/ climate control lighting problems
- header question..... how big of a difference
- Exhaust
- obdII to obdI help
- code 22 (vtec pressure switch) d16z6 quick question
- Painting Muffler?
- putting 99 civic ex on jack stands
- Mini-Me Question
- LS GSR B16 or H22
- Any Honda Engine decoders out there?
- GSR brakes on Civic Q's
- check engine light test isnt doing anything?
- engine code
