View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 2005, civics running with I-6s?
- Took some pics of the Snatchback today(56k your on your way)
- bad alternator?
- Z6 and Y8 swip swap Q...Searched, need more!
- brakes, I have a few questions.
- EG: Hood Shut, front looks weird- pic inside
- zc block with a z6 head????
- Stuck fuel pressure
- Pretty new suspension goes in
- Bare GSR Block, I need it to be cleaned??? Please help??
- question about oem steering wheel
- Which Would you do? Everyine look....
- how to? calibrate sensors
- Does letting your car battery go dead once, drastically decrease the performance of it?
- 2002 stereo installation problems
- CAR CARPET for CIVIC
- problem with a 92 civic si
- My friends car won't start
- what size tires should i get?hellllllppppppppp
- Help With this Problem What is it ???
- Opinions open: D16z6 Setup 1/2..which one would you choose?
- my car idles at 2000 can someone give some info
- AEM V2 PICS
- OEM Honda Part - help!
- Locating oil sensor on d16z6
- Anybody on here have an off brand exhaust?
- what settings to preserve the life of...?
- b18c1 or b16a2 for all motor?
- Will DA mirrors fit an EG?
- JDM B16A timing belt slack ??
- would a stock cd player from an ek fit in a 94 del sol?
- any silver EK hatch stolen in NJ lately? I found your car.
- i want to run my car into a tree please help!!!
- ZC rods in a y8 block?
- Question about header-wrapping. Yes, i did my research....
- ran a 16.743 @ 82.156 mph at palmdale yesterday
- Another benen EG MIA
- GSR / RSX SEATS?
- Service Manual: Replace Bolts and Gaskets?
- Compression test numbers
- Car won't start :(
- Best tires to get?
- What causes an engine to run VERY rich?
- autocross/roadracing.....do a need a swap?....build d15b7 ?
- New Times for 92 Hatch near stock!
- Computer reset
- Need your help with drum to disc conversion
- smog woes. help needed!
- $10 torque wrench !!!!!
- has anyone done a rsx gauge swap into a ek??
- hx wheels on my ek??
- kyb agx install help?
- 99-00 Civic owners with OEM Fogs.
- Is JIC suspension any good?
- Cliking-type noise coming from rear when braking moderately-hard.
- Anyone have pics of a 96+ Civic w/ ABS Dynamics CTR lip kit? and/or info about ABS Dynamics? Anyth
- 99-00 ek front end conversion question
- JDM vs Eurospec lighting cut off pattern
- need to pass e-check
- JetHot Header Ceramic Coating Pricing
- Curse you midori EK owners!!!
- IAC ACK!!!!!!!!!!!!!!!!!!!!!
- Anyone have detailed instructions/pics on how to install 2002 si seats in a EG?
- where to get light weight LCA's
- Need help. Front suspension sqeaks
- Anybody no where to get Top Fuel tower bars for a good price?
- what does a 94 h/b si weigh full weight with a gsr swap?
- FUEL PRESSURE PROBLEM
- help! never driven a honda, friend's car won't start
- kyokugen lug nuts
- Exedy Organic
- Guys I need help getting a cel code
- 99 5 speed trans?????
- Help Immediately!
- Passenger Power Window doesn't operate as fast as drive
- Running Rich
- are there just ex. manifold flanges out there??
- Getting a new cam today
- EG interior rattles--- ?
- So why is my Apex WS exhaust about an inch too long?
- Exhaust Issues
- 02 Civic EX 5spd. AEM price?
- Tein S Tech Spring in EG?
- rear gut ek info
- Ottawa Area Install Help
- anybody got the 99-00 back coupe lip for sale
- Whats the curb weight on the hatches?
- How low is Low?
- MPG on 5th Gen Si
- Car feels unstable at 70+ mph
- Engine cost?
- Need help
- Sell GS-R for hatch?
- back to the dyno on the PFC, i'm starting to like this thing.....
- where to find ????
- B16A
- EBP SI with gunmetal powder coated wheels????
- integra cluster into civic anyone got the codes or labels ?
- 2000 Civic SI Radio/ CD Player Harness Help???
- Hope im not screwed(hydrolock)....
- ctr wing question...
- Friend wreck GSR..
- obd2 motor in a obd1 hatch
- how to paint hubcaps?
- CF strands...touch up clear coat?
- Cryo air intake (cryO2)
- Ground control fitment questions???
- 92-95 E-Brake cable ???? For rear disc conversion????
- Cam Gear Settings
- Comptech sway\tie bar combo
- need help. big short shifter PROBLEM. searched
- 00 si to 92 cx steering column swap.....
- 92-93 si/ex valve cover?
- vtec controller...for honda civic ex coupey
- Louisville Kentucky
- Will a DC exhaust fit an EG....need asap
- just a question for knowledge.
- gsr gauge cluster
- <<Guess what exhaust this is!!????>>
- more alignment problems...*pics*
- HELP Car wont start fuel/electrical issues?
- SOHFAST.com ?
- ? on delsol seats in EG
- Sound/Video clips of the Spoon N1??
- New wheels for Civic Question
- b18c5 in a del sol
- Does anyone know where i can get a good how-to on setting timing on a d series?
- Please be careful out there and think twice about racing on the street.....
- Chipped p28 for D16z6? Any Advice on this?
- Video/Sound clips of my Magnaflow exhaust.....
- jdm eg pics here!!
- I dunno if you remember...
- PLACE YOUR JDM NON-JDM EG PICS HERE!!!!!!!
- Searched: Trouble with HX wheels.
- EK front bumper differences?
- JDM stanley corners for sale for 92-95 civic hatch/coupe
- my 2 ugly cars eheh duno if pic will work.....
- Look what I just found..... ES oval muffler in BLACK!
- Stock spring rates ; '99 Hatchback
- NE1 have Apex Worldsport Exhaust?
- bent axle? Wheel? Something is wrong, help! !
- APC Short Shifter, Any Good?
- Magnaflow dealers? Carsound cats?
- stock si rotors?
- excessive engine vibration pulling through 3rd and 4th gear
- Advice needed: Buying Used Headers
- YEAH!!! Got My Header on :)...ah shit...whats wrong?
- tumping noise after installing coilover.....HELP
- Brake booster check valve- which way does it face?
- main relay part #
- intrax coil overs..
- Painting Corner Lamps Amber?
- Suspension tuning --- KYB AGX/Ground Control!
- Brake question
- searched: top tranny mount on a b18c1?
- hybrid b16 a/c bracket + compressor '92 si
- Message Board for Del Sol's....
- Found a nice deal on a solid '96 EX coupe
- Searched: D16z6 Build Questions that I can't find answers too.
- OBDII Question
- B16A power problems
- searched: jdm b16a2 distributor cap question
- Anyone have a B18C EG w/ Ground Control?
- skunk D series intake manifold...
- is it worth it to put air intake and header in auto civic
- EK9 (ctr) exhaust on a EK4 DX hatch, does it go straight on?
- B20b Questions and a little problem
- Kumho 712s
- Does Any One Know Where I Can Find A ITR Front Clip
- Pics of (Spoon92Hatch) Car....
- GHETTO Trailing arm BUSHINGS??
- How bad is stock Z6 header?
- Apexi GT Header
- Is Hatch really a sleeper?!
- Hmotorsonline, h22 tbelt, and also need advice.
- What else do I need to drop my H22 in?
- b16 swap
- 96-00 center console in a EG.
- Where to buy Z.Speed Products?
- anyone have pics of a 92-95 4 door on gsr 5 spokes??
- power window keeps coming off track
- my rear agx shocks adjust at the top with a screw driver, is this the correct one?
- Sway bar for my 97 Civic CX hatch
- 92 civic nh roll cage pics
- Where To Get Somethin like This...
- CEL code 22 23 45
- POST UP YOUR PIXS OF YOUR JDM CIVIC EG'S EVERYBODY!!!
- blue plug under IM on ex engine harness
- Car acting up and other misc problems.
- '93 Civic VX fuel gauge questions
- where's a dyno near jacksonville florida?
- h23 and h22 injectors same cc's????????
- vtec lost of power?? confusion
- Lowering Springs Question
- My car just developed a "no balls" syndrom, PLEASE HELP
- civic with b18c runs great until it warms up.. then bogs like a motha... my friend has searched long
- horse power difference between JDM b16 vs USDM B16a2 ?
- d16 swap
- Camber Kit for 92-95 Hatch.
- Lightened flywheel question
- Pics of my Coupe
- 92 si P28 ECU vtec and sotck front say question, plz help
- Open or Closed End?
- wut all do i need to do to the b18a???? help asap please
- burned bumpers
- Help with my smog results
- Resonator install
- is 3" over kill?
- B16A turbo setup?
- I need some good advice please
- Valve float and lightweight flywheels
- Lug Nut questions
- Do benen hoods still exist?
- B20 header?
- Honest to god 200
- hx civic
- What type of A/C does 92 civic hatch DX uses?
- would anyone just put raing seats in front...
- is there a difference between stick or automatic tb
- does anyone have component speakers????//
- Would Cv Boot kit for 97 Civic Auto fit my 95 Civic Dx 5 Speed
- Moon Roof no workie
- I want a D16z6!
- hub removal for wheel studs!!
- Milage and ECU - read this please!
- Neuspeeds x-brace.
- The Ferio got a new pair of shoes... 56k its worth it
- can a rsx type r go into 2000 si?
- how to remove a seized lug nut?
- Turboing 92 EX
- just bought 92 hatch any ideas what to do with it
- using tranny cooler for an oil cooler
- Tune up. What all should be done?
- JDMShit.com...Good or bad shop? URGENT.
- One year of work BEFORE AND AFTER Pics and timeline of mods on my car(56k lots of pics)
- installing new brake kits on the eg
- 5g lude cat back on 95 eg
- I um....BENT my car.....help
- i need a vin number check please: planing on purchasing a used car
- Camber Install Need Help
- bouncing temp guage
- will shift linkage from 90-93 integra fit b18c swap in 94 hatch.
- need help oil pan
- gauge swap
- HCP mount kit, eg, h22, whats the deal?
- parts question
- Spark plugs soaked in oil and white smoke! help!!
- think your a honda expert figure this out???
- where did u get ur real ek9 ctr rear lip?
- what to do with this ITR front clip
