View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 00 civic si. werid clicking noise. and vtec ?please helppp!!!
- new civic
- Solved messy oil filter change
- Problem with bleeding brakes
- GSR oil pan on LS
- EG hatch: stereo, clock, reverse lights went out? and slight buzzing sound
- Best place to buy replacement hood?
- something broke in suspension...need pointed in right direction how 2 fix
- DOT 3 brake fluid
- can not get vtec in gsr 2000civic
- Anyone know of a good Power Door Lock kit?
- 92 civic engine problem!!!
- WTB: d16y8 ecu
- b16 throttle body are they all the same???
- SeaFooooam in my 135k 99 lx civic
- Help!!! Vtec pressure switch & solenoid wiring connections @ engine harness D15B????
- 96 coupe
- Ebay or where else??(looking for parts)
- 1993 Del Sol GS-R Turbo build project. UPDATE Oct. 3/09
- (Jezebel) EJ1 Build Up
- sir lip
- Fog light help
- Carbon Fiber Hood
- 5th gen Civic Question...Front Bumper...
- tein s-tech camber?
- E7F Transmission? WTF?
- compression ratios?
- Horrible smell from A/C?
- taking off intake manifold paper gasket
- need help with tire size.....
- Need help rebuilding brake caliper
- My Album of my project eg
- door lock on driver door, locks its self when you unlock doors
- Replacing a 1993 civic cx windshield
- 01 gsr into automatic eg coupe not starting
- NOt sure with mount to buy
- an em1 with amg ?!?!
- Stripped Motor Mount Bolt JDM D15B
- b16a2 questions?
- oil in pcv valve..
- sunken clutch pedal
- jdm recaro rails question
- 96 ek with planned non op. fees HOW MUCH?
- what you think..?
- single cam engine fit in civic dx??????
- How much boost for the auto?
- Figuring out which exhaust to get for my EG2.
- how to extend o2 sensors w.o buying extensions?
- 1992 honda civic
- Anyone here have unlimited car fax?
- Bad Flywheel Bearing?
- how to install gauges?
- do delsol seats fit civics
- What Upper P.S. Bracket will I need?
- Cleaning IACV
- door difrences
- Car stereo Problem
- 92-95 si engine harness on vx motor
- Car wont start... bad injectors?
- stock floormats?
- 98 4dr exhaust
- Boosted Z1 questions
- some oldtime trick for cleaning that engine up real nice internaly w/o disassembly!!!
- What would you do with 2gs and my car?
- What is the fuse called that controls the dashboard gauges?
- running lights and interior lights dont work?
- weird mystery type noise inside the car civic lx
- 92 civic about to be put to the fire
- Project EJ1 Help
- taking out IM d16y8
- CEL Code 2000 Civic SI
- eg inner tire rod end replacment
- B16 problem?
- Getting ELD code and no ELD
- jdm white faced gauges?
- civic D16Y5 swap to B16A OBD0
- Cutting holes in bumper
- CRX trailing arm on a eg
- Overheating only when A/C is running?!?!?
- need some ideas.
- 92 civic help!!
- alarm after power door conversion
- D16 WONT START PLZ HELP!!!!!!!!
- civic license plate lights cant find them??
- 95 civic bent frame
- What's the CAT and Muffler of choice
- honda civic D16 engine gasket
- Problem opening up vtec b18c gsr
- Need Clutch Help Please
- 92 civic hatch.. need to know what this is
- em1 stolen front license plate!?!?!
- mileage help please
- 97 EX- No dash Lights
- Brake Light Switch Tutorial/Info?
- pcv valve d16y8 help dropped broken pcv valve into hole
- Busted Engine
- D16 motor problem! PLZ HELP WONT stART !!
- Carfax
- I can NOT get a cel light (need for timing)
- Short Shifter. good or bad?
- trouble starting, not sure whats wrong.
- master cylinder relocation..?
- Need help ASAP WITH COOLING ?
- hollow sway bar?!
- my j32a2 del sol
- Rebuilding my head
- Poor mpg, pls help.
- Help a girl out please! Check Engine Light
- suggestions on wiring problem??
- 3 stage vtec D15B - CVT/Multimatic - With paddle shifters?
- ctr intake manifold and piston to b16a
- Quick question about a header
- Update on Denji Retrofit
- *Power Folding Mirror Question*
- foglight help
- Cruise contol not working..where to start
- 93 EX..heater control unit
- anbody run lucas oil stabelizer?
- will the windows fit
- Overheating problem after cleaning TB
- Why K20 over H22a?
- Civic ex vs SI radiator question! confused.. plz help
- Another Ebay EK fog light question.
- Need help figuring what this does....
- Calling The Honda Gods, You know who you are
- EG hatch/coupe bumper on sedan
- Do DA Coilovers Fit on a ej8
- gauges into headunit
- regulator spraying fuel with fuel return line out?
- Need bumpers painted in So cal- Opinions and advice needed!
- TPS help
- Just trying to sell my 99 EK
- Battery was drained, jumped it, messed the battery cables up, now won't start.
- power mirrors on the fritz
- Few questions on a b20vtec
- what's this noise?
- D16z6 stock flywheel, quick question...
- fuel injector
- Del Sol Rear Bumper Screw Size
- What would YOU Do? Scenario
- Megan gauge wiring diagram??
- [DIY] Honda Civic 92-95 EDM Heated Seats DIY Retrofit Install Guide
- Del Sol vs GSR trans
- HELP REBUILD COSTS INFO
- b16a2 into eg question...
- are ITR, GSR, SI have the same injector size???
- 96 ek harness with p28 problem??
- are skunk2 itr intake manifold the same as b16???
- speed sensor help
- BEST WAY TO HIT 300hp
- Which bushings are better?
- Please help with vtec not working
- b16 timing help
- where to get oil filters in bulk cheap?
- shift linkages... is it compatible??
- RonJ (all others disregard)
- expected MPG for 93 civic
- help del sol roof warning light
- California Smog Searched
- need some help on how to become a driver.
- speedometer not working need vtec back!!!
- Suspension troubles
- People with AC autotechnic intake help.
- 92 Civic si w/b18b1 swap wont start
- b16a2 throttle body on a y8
- Cam Help Please lmk ur setup
- Car misfires and has terrible gas mileage after B18 swap
- problems with gsr swap in EG. help me out!=]
- B18C Type R question
- help
- eg coupe doors on eg hatch?
- 98 Civic DX B18c1 what exhaust will fit?
- z6 vtec solonoid camparied to a vx solonoid?
- B18c1 EG Hatch Trade for Single cam EK hatch
- WTF Stupid healight problems.. pics!!
- Help Out A Buddy With An Oil Leak
- eg headlight housing...hole
- exhaust louder between 3-4k rpm
- Mushy brake pedal/pedal drops to floor even after a brake fluid bleeding flush
- B16 Tranny/clutch PROBLEMS HELP!!!
- D16z6 to B16A
- FS:TWM short throw
- i/c piping question
- EG cluster
- Will a SOHC ecu start a DOHC engine?
- how to break 300whp wid b16turbo!?
- New to the forums, few questions.
- eg6 b16 or crx d16b turbo
- 99 lx civic fluid swap help !?!?!
- WHAT DOES A EXHAUST RESONATOR DO?
- Over Heating question.
- will car run without ckp sensor? obd2?
- 1995 del-sol rear disk brakes for my 2000ex, what all should I get from the "doner"
- 93 del sol Headlight Bulb replacement
- 92 civic lx wont start
- Bad O2?
- vss 3 wire plug on a obd1 civic help
- ek9 supension
- Sportmax XXR 002 15x8 with 0 offset on my EG
- Sportmax XXE 002 15x8 with 0 offset on my EG
- honda civic D Series need help
- TPS SENSOR CODE! NOT THE SENSOR.. LIL HELP
- Water Temp Gauge Goes Crazy- HELP!!!
- GRRRRR FML. Overheat
- clutch question
- check eng. light!
- PHOTOSHOP ME BABY
- EG8 door will not open
- ctr ek turbo pops codes
- new transmission in..but wont go...updated. still need halp!
- exhaust problem need help
- HELP! Motor cranks, has spark, but no fuel (sometimes)
- help identify these engine mounts please
- No O2 sensors....
- short shifter questions
- no spark.... need help...
- torque converter lockout
- 93 EK B18c Wire tuck (NO CUTTING)
- B20vtec conversion kits
- no fire on d18y but have spark an fuel.
- *EG TYC PROJECTOR HEADLIGHTS! *
- Automatic shifts really high?
- B20 swap w/ wire tuck... Pics!
- Wheel Bearing!
- machine shop in so cal
- HELP! H2B problems..
- fuel pressure dropping quick
- 1995 del sol from rice to sleep
- suggestions for my gsr eg
- Help OVERHEATING!!!
- Headlights, fog lights won't turn on
- Stutter when accelerating and CEL...
- obd0 to obd1
- would you but this?
- rear diffusers question?!!! need opinions
- what would be better for my DD eg
- B20 Non Vtec Dyno
- power windows electrical issues
- thermostat or fan switch?
- fit motor in del sol?
- manual to power windows/lock help.....
- quick question can any1 help
- Will B16 mounts work on B18? noob ?
- Looking for good Security system with Remote Door locks 1999 Civic LX
- code 22
- Cold Air intake?Rain/Damage?
- B18B swap into a '00 EX
- High Idle Y8 Mini Me Swap
- Engine Mods for a b18c1 (Cam selection, Intake Manifold Selection)
- need help asap willing to shoot $$ for help... fuel pump will not prime + no spark
