View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Slam it to the ground!
- Idle problems!!
- Tire help!!!
- removing power steering..
- Stolen! 92 civic hatchback
- My New Del Sol Si !!!!
- 93 hatch help, my car is revving and then drops it
- newbie ...here's my Car
- 1994 eg h22a/M2B4 Lsd... which cv axles?
- What type of cam gears are these?
- A Thank You To Everyone Who Is Helping Everyone Else.
- integra suspension on eg lcas
- universal turndown style exhaust
- URGENT HELP!!! Rear wheel locked in place
- D16z6 Sputtering/Missing
- Question on CTR WING
- whining sound when in gear and applying gas
- 93 EG ZC DOHC swap help
- need help with my b16!!!! please
- rear lower tie bar?
- my 95 civic ej1 d16z6 help!!!!!!!!
- a/c controll knob
- clutch is whinning need suggestions/help
- integra front end swap?
- knocking/clunking noise
- anyone know how to install EM1 lip??
- auto to manual eg
- obd d15b into a 97 obd2 ex coupe
- CAI or SRI??
- replacing my head. new timing belt?
- EX exhaust On EK?
- 95 si motore in a 96?
- Flushing (cleaning) out cooling system after gasket failure (D15B7)?
- Noob question....Where to post first??
- tets pipe
- tokico illumina's + itr h&r sport springs on 92 civic si
- driver side bracket, help me
- Take tranny casing off, bearing ball falls out?
- staggered wheel setup
- Aftermarket EG suspension fit an EK?
- My 94 civic Leak...Look inside if your out of options
- OBD2b to OBD1 Harness
- Is this true... about a crank pulley?
- 99 civic cd/stereo in 94 civic question. What are you guys using to secure it down??
- 93 cx squealing
- Gsr motor,one cylyinder no compression!
- tune your car?
- How to start building a nice d16y7
- b18c5 problems!!!
- Best turbo D series head gasket?
- upgrade camshaft?
- B16 swap into 96 dx civic
- This is not right.
- question about ebrake cable on disk swap
- Spring Fitment Help
- Stupid Knock sensor question.
- 1995 civic coupe come w/ ARMREST?
- Noob on civics. Got questions and dont know where to ask.
- Washed the engine, now corner lights are stuck on?? help!!
- need help sputters/flat spot at vtec
- GSR swap harness question
- CTR/ITR cams vs SI Cams
- Antenna power problems
- Help!!! A/c bracket???
- Any Suggestions on where to buy a b16a2?
- YS1 internals.. LS Tranny
- SRS Light after Alarm Install
- After-marekt HID headlight?
- new header,cat,midpipe, throwing CEL420
- missing screw?
- how do i chip an obd1 ecu
- Spark Plugs
- Turbo XS Manual Boost Controller Question W/ Pics
- eg,srs light and cc light on?
- Bolt Pitch and size for b16 valve cover
- B series Valve adjustment question
- i need help locating accessories
- sacramento, CA
- 94up Teg suspension on 93 Delsol
- Brake light problem
- SRS Light
- Choices, Choices...B18C mods in EJ6
- caliper lock up
- Type R mirror question?
- Water leak
- Problems getting interior door handle trim to fit
- Need Questions answered about s2000 oil filter
- D16 IAT Sensor Plug?
- 93 D16A specs knock sensor?
- EG Hatch Tail lights Different?!?!?!?!
- B16 Head Gasket Help
- Coupe - Sedan REAR BUMPER Q
- 94 ex tach issue
- PLEASE HELP ME!!! Distributor was making noise and now trans fluid is leaking near it
- Clicking nosie when i turn? why?
- Trunk dampers...where do i get them?
- Suggestions for my car! I'd appreciate the feedback!
- check enginelight help plz
- B17a or b18b trans..
- dumb question
- EDM kluster
- fuel pump problem...need help
- how to remove rear glass from eg hatch. HELP!!!
- 00 ek with jdm itr suspension
- hey guys need some help with my eg hatch
- rear speker question
- WS2 exhaust question
- OBD1 Integra Engine Harness plug into 97 civic coupe main harness?
- trouble w/ vtec harness & non vtec engine
- Cruise Control Light Is Always On & Cruise Doesn't Work? Help?
- painted or flat black look
- vacuum diagrams?
- 1992-1995 EG Civic Hatchback Rear Seats
- o2 sensor problem (ls-b1)
- ac turns on only on 2 speeds
- Please help-Stolen: 99 Civic EX Coupe - San Diego
- EM1 Owners - AC Compressor question
- will a jdm p30, in a 92 hb, pass ca smog
- Need help rough idle
- Radiator fan not coming on
- eg w/gsr swap half shaft question
- photoshopping rims please help!
- turn the key and nothin!!!! help
- My car has a bad case of the hicups lol
- D15 HEADGASkET QUESTION.NEED INFO
- D17 Crank into D16
- 94 Civic - Replaced Distributor & Rotor, won't start
- 96-00 Civic Non ABS Axles In My 94 Civic Coupe Non ABS?
- help on timing on a 96 civic
- civic won't start
- rod bolt torque ?
- What wheels for a silver ek coupe
- octane rating
- Best website to get oem honda parts?
- Y8 intake ?s
- Burning lots of oil, or is it normal?
- Car Died While Driving! Help ASAP!
- coupe carpet in a hatch...will it fit?
- Help Finding Buddy Club Spec 2 Style Tip
- *****Car died on freeway, no spark****
- EJ8 Tranny Shift Linkages
- OEM D16 rebuild
- Atl varsity meet...
- LS swap into a 4dr ej6
- My Poor Honda
- Doing a 5 speed trans swap
- AC & Gas Issue
- 4WD Civics
- ebay header
- ECU Chipping
- Automatic Transmission?
- Major loss of power, temperature related, increase in MPG...
- EVAP EMISSIONS (P1457) check engine light? (99' civic Si)
- Regstering Car under NPO?
- GSR/RSX Rear Seats In EK
- PCT or P73
- '93 Hatch with a K20A2...worth? Link with pics
- $2000???
- Rear hatch leaking/need to find part
- Anyone know a quick fix for a stuck ICV?
- Ilde?
- First time swap
- d15b with y7 head?
- Leaky Roof Panel What to do????
- vision motor works
- Can this be done on a eg?
- Main Relay
- SRT4 seats into a EK...
- Fuel Pump Not Kicking On And CEL LIght Now
- what HG to get?
- Put 2001-2009 or the like exhaust manifold on older civic?
- Welcome my $100.00 Del Sol to the H-T family!
- 99 civic cd/stereo into 94 civic coupe. Will I need stereo code for the 99 player??
- dash wireing issue! little help?
- problem with 92 hatch window!!!
- Del Sol Clutch Problem
- annual smog check?
- few questions about hmotors (HELP!!)
- dual bend shoft shifter guestions on effect
- hondata s300
- walbro part #?
- J's TI exhaust
- need help!!! d16y7 no spark
- Honeymoon with my EM1 over. P1457 came up
- suspension help
- Need to pull a switch out....
- Ebay Exhaust with swap question.
- Pic request:Oil lines mounted on firewall
- d16 i have no clue
- Is the Automatic transmission starter the same as the Manual transmission starter?
- 95 ej1 gsr swap a/c ?
- Visor help, quick!
- Quick Del Sol Question
- Looking for some input
- center console getting very hot
- EG ac compressor D series fit on B series?
- ek power door conversion (door locks don't work)????
- civic ej8 door problem.
- how to put integra seats in a crx
- tranny swap issues
- what are civic si wheels worth?
- mounting b series to a engine stand
- Oil pan gasket instructions?
- 2000 civic DX check engine light code
- Manual Steering Rack / Interchange Question
- 95 civic coupe B16 swap
- b18a1 TRADE!!! need d16z6
- 94 civic coupe ingition problems
- Is it possibele? Suspension Quest!
- aftermarket camshaft?
- Car shakes when i turn heater/ac on ...
- vtec controller setting
- 94 civic ex rebuild questions
- b16a sticky throttle body
- Fuel Injector
- quarter panel help
- clutch issue, not popping up quickly
- weird engine squeak
- Another ej1 coupe victim to the chop shop
- bad strut mount?
- Horn desn't work
- power mirror switch
- Noise after shifting...
- Camber Kit
- NEED smog check done! HELP!!!
- ITR header question
- 1995 honda civic ex engine swap
- 00 hatch rear emblem
- Prelude 4x114 11" brakes on 97 coupe
- Are Integra 94-01 seats interchangable w/Civic 99ex ??
- axel life
- Engine Turns A Little But Wont Start
- 98 acura integra 1.8 non vtec interference or not??
- Quick ratio steering for 94 hatchback
- Bitch Pin... Removing w/ Ball Joint Press
- recommend me a set of coilovers
- need help with check engine code 43 (fuel supply system)
- vtec oil leak b16?
- My Civic with Swine Flu?? :o
- Cam gears for a ZC
- Help please!! rear suspension question
- have some questions for the experts
- Please help STOLEN: Flat Black 94 HONDA CIVIC COUPE EX ON MUGEN MR5Z
- any DIY's out there for installing turbo
- intake manifold
- New member needs advice.
- car will not rev past 4500...please help!!
- green plug ???
- running rich i think please help
- firing order
