View Full Version : Honda Civic / Del Sol (1992 - 2000)
- b18c5 low end power
- ECU manual to AUTO??
- swapped b18c1 into cx, valve cover touches hood
- attention GSR interior gurus
- 96-00 Civic Type R style Side Skirts, where can I get them?
- Confusing motor problem
- a how to? rdh conversion for a 92-95 civic
- Website that sells parts?
- Installing a cf duckbill
- ecu fuse
- HELP ME!!! Pulling codes 71, 72 , 73, 74 on a 98 civic
- fuel reg.
- CEL - crankshaft speed fluctuation sensor
- Question about Del Sol and Civic Si Throttle Cables.....
- Does anyone have a problem with their TRUNK lining up in there 96-00 Coupes?
- headers.
- Alternator Belt Squeeks every time I accelerate. What does this mean?
- ticking noise coming from engine.
- A/c trouble...
- Suggestions to jolt/loosen up/remove frozen bolt?
- would it be better to switch to synthetic in older cars?
- searched but dont understand what it is i need to do?helP! asap
- Question about installing new chip?
- b16 swap.
- 92 civic dies
- Did I just ruin the front knuckles (ball joint removal)
- Jacking up my civic...
- Type R ECU in a VTi Civic?
- Cooling Fan Switch. Help
- I posted awhile back here, and now I'm back I'm planning on getting my civic
- would evo recaro seats fit in my ek civic???
- Crack pulley came off
- 95 EX CIVIC ?'S
- Help me determine which axle is busted
- anyone who has a 92 civic hatch with a b16.
- Motor Mount Question
- integra seat in civic HB
- GSR radiator into civic? How to.
- Which ECU for my DOHC ZC swap?
- tach question
- Engine holding back
- 96-99 civic mini TYPE-R intake swap?
- gsr rear seats in a 2000 civic hatchback?
- Gas Tank Float
- Comptech Icebox w/Apexi filter??
- b16b block (is it worth fixing?)
- TODA Clutch Kit?
- Brake line (hard line in engine bay) leaking...help
- can we get the tranny codes posted ?
- what is all in a full swap of a b16a2
- Car acting funny since AEM V2 Cold air intake
- Hidden Hitch Trailer Hitch on my 96 Honda Civic EX
- KYB 5way/Neuspeed Race Springs or Tokico 5way/Eibach Springs???
- Having Issues w/ Rear Camber Kit Install (2004 Civic 4DR)
- MB6: Honda Civic 1.8 VTi - Help me find an intake system!
- aem fuel rail question
- Turbo with or without VTEC - Which is better?
- CUSTOM DUAL Turbo System.......LOOK
- anyone use the Eastern Catalytic Converter High Flow 2.5" from ebay?
- z6 to y8 intake mani switch
- gauge cluster lights not working
- Girlfriends H22 EK Hatch, Now with turbokit
- My friend wants to trade me his car plus 3k...
- Anyone ever install a s2000 push button start?
- 96-98 99-00 rear bumper
- immobilzer?
- axle ?'s
- Utah Emissions Hookup?
- ........DOES ITR P VALVE BETTER THEN CIVIC...DOES IT BOLT UP.....
- Does this sound like a good idea for a year round car?
- del sol bracket
- 94-01 teg coupe oem carpet same as 92-95 civic?
- sedan door lock problem
- how much should I offer..
- Problems with a 94 civic hb si
- weird Sound @90 mph and above
- Brake pads wich one?
- PROBLEMS WITH MY B16 LSD TRANNY
- car wont crank (searched) help asap
- got crower cam...high idle...any suggestions?
- picture request. ek exhaust on a eg (hatchbacks)
- dripping, pinging noise after i turn off the car what is it?
- Tein Suspension Comfort Level...
- 00 civic si harness does not plug into p73 ecu?
- EK Swap???
- CEL at WOT... no idea why
- ZC engine height in an EG?
- smoke comming from where i put my oil??
- Strange sound while at half throttle ....
- Can Anyone Help Me :(
- Torque wrench: rear strut tower bolts ??
- OEM Fogs Clear or Amber?
- Any suggestions on how to take the spoiler screws off?
- alternator=fire
- Civic Si___EK prop valve question.
- HP Gains for around 350?
- d16a6 in a 92 civic ex
- idle problem after new cam installed
- motor sites
- 99-00 si gauge cluster in ek ???????? fuel lght doesnt work when emty/ tried many !!!!!
- eBay fender quality??
- Pos and Neg battery wire
- A problem hopefully I can get a quick answer
- how much are 99-00 si rims?
- will 96-00 struts/springs fit 92-95?
- Got some questions (i am new here)
- True or False : The Bigger the rim, the lower the car?
- Z6 into an EK?
- i need a cheap d-series in MN
- can you release & refill r134a?
- axle problems?
- electical stuff
- turbo hatch acts like it wants to overheat
- what can i do with my d17b
- TRANNY QUESTION INSIDE!!!
- will this header fit?
- largest size tires that can fit on stock 94 DX rims...
- alignment Q's after lowering car
- Need suggestions for a quiet exhaust
- what engine do i have? any help is appreciated.
- will this fit?
- Carbon fiber trunk for EG 4door, where to buy?
- need help with KYB struts
- FS: 99 Civic Mugen Style Lip
- hatch vs coupe/sedan
- EBAY clutch and flywheel combo($292 inludes clutch and 8lb flywheel)...anygood???
- Anybody have closeup pics of ek sideskirts on an eg?
- civic VX o2 sensor wiring. HELP!!!!!!!!!!!!!!!!!!!!!!
- anyone know why i need a differnt throttle pully for skunk2 mani swap??
- What AC belt do I use in My eg/ek with LS swap?
- Questions about my 1990 Civic Si
- timing belt tension affect performance?
- Cleaning The Engine Bay
- HELP. jdm d15b Vtec piston rings for P08 pistons
- Car-cost estimate please.
- cheap tricks for power
- what size LCA bolt and nut
- Calling all MARYLAND owners with swaps
- how to fix my window
- XSi <--- what does that mean?
- Swap Question
- Tricks to finding a exhaust leek in eg hatch???
- Kumho Ecsta 712 vs. Yokohama AVS ES100
- Hi!!
- missing throw out bearing in tranny?
- transmission fluid
- b18 wiring ?
- Just finish B20/VTEC.
- Anyone ever buy one of these?
- Vtec Engagement.. for civic vx
- help... o2 sensor wire....
- Post pics of Koni Perches???
- suspension ?
- 2004 Civic Engine Swap
- How to clean my brakes......?
- I need help quick. I found B18A1 swap for my civic, for a steal, will it fit?
- Newbie Here- How to replace drive side mirror, and where to purchase assembly
- problem with starting my civic
- can a auto-manual converted p28 ecu be chipped to run a jdm b16?
- any pics of a blue 99-00 si with c-west kit on it?
- Timing question?
- Bolt Ons for OBD1 92-95 DOHC ZC?
- Question about my first Civic
- brake conversion
- best d series trans for boost??
- Who made a green flywheel?
- Eg dash in to 3gen teg?
- please help me wire my alternater,
- SOMEONE BROKE INTO MY CAR
- GSR brakes on 96 EK..do i really need a Si prop valve??
- Suspension Setup for H22 Swap
- hella pissed about cross-member its on a yahoo auction and it TW!!! grr if only in the states!!
- Customization Ideas... need input.
- hybrid muffler
- koni yellow and GC question
- HID KIT QUESTION
- H&R Race Springs and Tokico HP Questions
- power enterprize oil filter...im not believing the hype but.....
- !!Help!! May have blown either my tranny or clutch...(just happed 10 minutes ago)
- 1994 CYLINDER HEAD TORQUE SPECS CIVIC LX 1.5LTR
- 1994 CIVIC LX HEAD TORQUE SPECS PLEASE
- Need to know ASAP, will a 96-00 ek swaybar work on my 92 cx ???
- question: honda-tech folks!
- I DONT KNOW IF i DID A GOOD BUSSINES
- civic suspension question
- JUN internals
- S20 Tranny?
- B series cat on the ol' d series header swap
- civic body codes and engines and..stuff. I'm stoned haha !
- Speedometer Problems
- Searched for: DIY for Thermally wrapped headers
- Sleeper Sedan Update.. Product review. and sever heatsoak...
- V POWER by Shell
- cheap tire site
- Stroking my B16B to 2000cc, what is best combination?
- *Pic Request* New Greddy SP2 mounted on an eg (coupe, hatch, sedan, what ever)
- Any special A/C recharge needed for brand new condensor/line?
- Multiple codes? what happened? please help! gotta get to school!!!!!!!!!
- mini me spark plug question
- clarification and advice on adding a ground wire to OEM Thermostat ground
- need help with wiring reverse lights(yes i have searched)
- Blue Megan's Racing H Bar..
- 92 b16 axle question *HELP ASAP PLEASE*
- D16Y7 slight detonation at 1/2 throttle
- post a pic of your 96-98 climate control WITHOUT A/C
- cluster lights dont work, headlight buzzer dont work, all interior lights dont work
- Tire Chains
- what body kit is this?
- red bulbs for climate control, defroster, hazard in 96-98
- Im not getting spark..why??
- b16 swap into 92 si hatch questions (already searched)
- Difference between seats?
- catback
- Header ?'s
- Pinstripe Removal
- 98 civic ex , weird idle & acceleration.
- stock b16?
- Ignition Red or white line?
- dizzy place,ent on 82 civic? ANYONE OWN AN 82 CIVIC?
- Best mods $0-1500 to do to a 95 EG?
- possible to turn headlights on with ignition??
- should i change injectors?? for my 96 civic EX fully built
- Car is un-even...why?
- Having problem re-installing dash in my eg... cant find bolt holes HELP!?
- questions about the d16???
- HELP!!!!!!! bout signal lights
- hatchback dash in coupe
- autozone rotors = duralast?
- jdm spring rates for 98 civic SiR?
- Wheel Locks
- Dropzone SHOCKS - better than stock???
- Nitrous question
- better flowing catback: sp2 vs. hyper medallion
- Why do I keep blowing alternators?
- how can i tell what my wiring harness is?? searched,
- Help Me Remove this header bolt!
- Help. Another car wont start thread. Please help.
- Reverse Lights are constantly on while car is running : Please Help
- auto ecu for auto car or 5 speed ecu???
- civic headlight wiring....HELP !
- newbie ?? about 93 hatch si
- Noise problem!
- advice/needed, should keep on the silencer or off the exhaust
- askin this question for a friend with a civic..
- cx fuel pump flow
- What to do best? Fried rings.
- ***HELP*** Auto Inspection
- 1998 honda civic died......
- best value header - toda, spoon, jun, mugen, comptech ?
- '97 Del SOL + B18C engine
