View Full Version : Honda Civic / Del Sol (1992 - 2000)
- test pipe question....
- what type of tranny????
- how much would it cost for my eg cf hood to be painted at mob works
- how much do low mileage d16y8 engines cost??
- Broken cd player
- wont start...tried everything i can think of
- Honda Civic Coupe EX 2005 headlights help ..
- ..... easy question... are all D series throttle cable the same?
- is it possible for five lug conversion from a preludes to civics?
- oil level question for b18b
- Just wanting to say Hi
- yellow carbon fiber
- Is a SOHC vtec head on a non vtec block
- ok how to fix thing
- 97 ex with 99 b16 wont hold an idle
- Car pops out of gear and no radio
- any way to eliminate gasoline smell?
- Hydraulic pump problems
- EG lip on Del Sol?
- Broken piston :(
- front mount ?
- idling question
- vtec on my d16z6
- engine cutting out bettween 1500-2000rpm why?
- camshafts
- ls rods and gx pistons in d15
- Car leaks only when parked uphill?
- ok..im very confused
- d16 lsd tranny in 96 ek
- ball joint snap ring - where is it?
- PLX M-300 or AEM UEGO?
- Any problem with out having the TPS or MAP connected???
- repairing my civic:(
- broken exhaust opinion if $$ to repair or get new exhaust
- is the skunk2 pro series a good choice
- WTB:Built Gsr head
- Does any1 know
- GSR cluster into EG hatch.
- where to buy stock parts
- str throtle body gasket..
- engine code
- Buddyclub wheels
- b16 in a eg
- 5 wire O2
- BEST PLACE TO GET HONDATA S300
- d16y2
- professional paint in a can?
- wiring vtec to ecu
- 96 hatch to 00 conversion: What's needed?
- reverse lights staying on
- How to pass inspection with coilovers???
- Swapping my 95 Cx
- NEED SUGGESTION ON MY very first PROJECT ~~MILD UPGRADE
- V8's SUKK!!!!
- 94 Civic EX, Gauge cluster problem..
- Someone help me out here. This is for experience techs
- Stock B16a Redline!!!
- lsd
- Headlight Harness?
- I searched! Brake swap question...
- ALT question
- Check Engine Light with Turbo Kit?
- P28 question
- Rear Disk
- Will my tires fit?
- Car fires up but then dies.
- Been away for a while now i got the itch.. looking for where to jump back in
- d16y8 Mugen Valve Cover?
- OEM fuel pump flow rates?
- auto to manual swap parts checklist
- EJ door handle question.
- Quick lug nut question!
- Civic hatch/coupe front end on 92 sedan?
- Draining refrigerant from a/c system
- oil pressure switch circuit
- brakes, the fluid, leaks.. need help. simple stuff...
- 2/3dr eg mirrors into sedan..?
- Invidia rear sway kit
- helpp my car wont get gas
- no 2nd gear
- Clutch pedal question...
- Not another fluctuating idle thread...
- Need quick help. datalog not working. help asap
- o2 sensor question
- Climate Control still on when car's off: Help
- my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!!
- who makes a good 2.5" exhaust?
- i got a 96 coupe ex shell
- H22 swap
- Got my civic and its already broken into....
- Clutch Master Cylinder
- Finished Paint. What do you think?
- Does anybody know if the jdm 96-00 ctr console cup holders will fit in a 2000 civic coupe?
- mangaflow vs apexi WS
- where can i get a OEM (or oem style) fog light SWITCH only? (EG)
- Inegra GS sway on a 96 civic hatch?
- Vtec not working, code 1259 and 1298 help
- buying a car with highmileage with freeway miles
- exactly what swaps over between an eg and an ek
- Help me with naming manifold
- my 96 ek with some JDM
- O2 Sensor Problem
- Nitrous on a d16 ????
- Whats this?
- Eg Civic Hatch
- someone keyed my car!!!!!!!!!
- What header for jdm b16a????
- 96-97 4 lug ITR conversion??..quick question
- Timing belt and water pump question *searched*
- what is this?
- how to get check engine light to go out or reset
- Instument Cluster Question
- Will a tranny out of a 93 civic ex soch vtec work on a 97 4 door civic non-vtec ?
- i hate my car
- Would these light fit?
- Overheating...again
- knock sensor w/ p28 ecu?
- Why don't LED 1157 bulbs work?
- What kinda manual tranny fluid?
- R.I.P NorthKai3's Civic
- car won't start... bad gas??
- brake calipers shaking
- changing the fuel filter
- Mold on seats :/
- Help me out
- Knock sensor, connect and zip tie somewhere else?
- Timing Help ASAP!
- EM1 Head Unit into 96-98 Civic?
- Catz Zeta question
- Oxygen Sensor for 95 Civic.
- When was the last time you changed your transmission fluid?
- just checking
- will a rage header bolt right up to rsr exmag exhuast no mods?
- gauge sending unit? where do i put this dam thing!!!
- Help with 1.6 non vtec to 1.6 vtec
- jrsc on 95 dx w b16a SIRII JDM
- weird ecu cel ? wiring nightmare
- ..>> Radiator / Condenser fan assembly....where? how much? 2K Civ HB <<..
- universal oxygen sensor for downstream what wires colors are what
- Body Panels needed-->looking 4 online site to buy
- tach no work after swap
- Car hesitates/sputters at heavy load in low rpm
- Z6 manifold on y7
- EG EG h22 built head track times
- Need Help ASAP!!! Harness Problem
- Small/Quick squeak when lettin' off brakes
- 88 civic won't START..............PERIOD!
- Replace original civic-hub to something stronger
- s2000 gauge cluster
- Grease Upper Control Arm???
- Rear subframe brace...
- port match needed? someone please!?!!!
- Car runs very rich.
- broken gas needle on si cluster..
- charcoal canister??
- problems with my cx clutch
- Transmission housing busted... is it possible to weld?
- motor question *need help*
- why did my thread about the '06 quarter mile get locked?
- Brake line compatibility?
- 4 people w/a 92-95 civic hatch w/gsr engine
- '06 Coupe Si has a 15.68s quarter mile?
- what clutch would you recommend? 93 4 door d15b vtec
- jacking points... did i screw up someones car?
- looking for CF front lip for '00 Civic Si
- 4 point belts...
- Weird Noise!
- question about smogging 2000 si civic with b18c
- Header Questions
- Any one know a good site to get neons?
- power steering bracket question..*searched*
- Throttle body swap
- over heating and NO HEAT !!!!!! please help!!!!
- the last race
- hondata problem?
- Del Sol RSR exhaust
- .....EG OEM header.... having figment issues with flange
- Z6 map sensor
- v-tec>?
- Windshield Wiper troubles
- EGR, PCV, EVAP, etc.?
- code 90?? help me.....
- Vtec working?¿?
- Changing Dashboard light on a 95 2-Dr Civic Si
- jdm style fogs
- Please help with advice
- Leaking Sunroof-95 civic ex coupe
- Where to get valve components for a z6 head?
- what o2 sensor do i use for a p28?
- Chipping an ecu
- Help with Exhuast setup...
- looking for main relay on diagram. help me confirm this picture.
- annoying rattle in 94 coupe
- Uncomforably revvy....
- 94 civic what motor swap?
- i know
- Another ThrottleBody Post!
- B18C5, LS crank, CTR pistons... work? ASAP
- lsd tranny
- Polishing the lip of a rim?
- anybody have track times on a build h22 head stock block in an eg
- what do u think?
- introduction--didnt see another place.
- are all tps interchangeable???
- Front trans mount
- CRX SI trailing arms on EK hatch
- Northern Iowa glass
- 94 Honda Del Sol
- F1 Racing Stage 1 Clutch
- idle will not stay where i set it.
- Mad VTECH yo!
- Where can I get a JDM Gauge Bezel for an EG
- Gauge Question
- Sun Visor
- Cams
- 99 civic si CEL code
- can someone ID these civic pedals?
- Brake lights not working.
- Swapping 94 civic ecu with a 2000 civic ecu
- Need Clutch? Help Plz
- Can distributor handle 11,000 RPM??
- Weird Noise coming from rear....... Please help
- Top or Bottom Sensor?
- My 2000 Si turns off and on while i am driving. Please help!
- vtec ecu with a non-vtec motor
- stock b18b internals is it safe to run dry 50 shot ?
- TECHONE HID installation troubles...8(
- 92-95 Korbach Performance Frame Locks 6 month Review
- dizzy
- CEL code 41...!!
- Hard Radiator Hoses
- how to install the fog lights
- LS Swap into 93 EH2 HELP PLEASE~~~
- need help please!!!!
- Question ? Please help
- fuse box under hood
- Touge civic?
- GSR PISTON
- Check out my Eclipse.
- will this work... efficiently
- No o2 sensor on dc header
- Photo Request: Upper Balljoint on 92-95 Civic when it's in place.
- Head gasket???
- Hondata S300 In Si.
- DIY City Lights Jdm conversion
- ls vtec reliability
- Help with motor install into a 92 DX???
- Rattling Noise from engine bay.
- 93 honda civic DX... New Exhaust
- 96 hatch with ctr exhaust?
