92 civic runs like ****, help!!
Hello, ive been reading this page for a long time and got great answers but never needed to register until today when i really got fed up with my car.
so... I had a fully built d15b (jdm vtec one) that i blew up. Just did an engine swap and put in a stock d16z6 with a z6 head and skunk2 cam. I hooked everything up just like the way it was with a d15 block and im having some problems that i cannot figure out. The car runs for only 1 minute when cold then keeps dying. The only way to keep it running is to hold the gas down, When i slightly hold the gas the rpms bounce like crazy around 1500. Does the same thing when i drive it (stutters at 1500rpm unless i change to a lower gear and raise them up) Seems like there is a power loss. 2 seconds after i start it the check engine light comes and stays on. The lightshow autometer stays on green. Sounds maybe its misfiring sometimes.
I checked the timing maybe 20 times yesterday, I even put the stock camgear on to make sure its dead on (thought maybe skunk2 was off), I reconected all the sensors. Any ideas would be great. thank you.
Re: 92 civic runs like ****, help!!
No i did not retune the hondata, Im scared to drive it at this point. The car was just running with the exact same setup except for a d15b block and head. I replaced the cam from the d15b head to the d16z head. so bassically everything is the same exept the actual block and head. The car was running 3 days ago with 0 problems on that setup but i screwed up and overboosted it. Now i had to move it out of the garage because they are repaving it so i had to do the swap quick. Im 100% sure that i hooked everything up the same! I just dont understand what couldve went wrong. Does a d16z6 need something done different than a d15
check ignition components.. distrubutor cap and rotor button, spark plugs and wires i had a similar problem with mine and the tune up had it running like new again
Im going to recheck everything for 1000th time today, if everything seemes good the car is going to one6 for a tune.
Also yes, i had a shop swich the cam and do a valve job because i never did that myself before.
lil_dp
02-20-2015 03:11 PM
TravisCadello
10-01-2009 09:50 PM
