View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Tire sizes?
- 98 Honda Ek hatch b20 motor issue help
- A good reminder to never buy a parts house compressor.
- 99 civic Ex smokes when you throttle
- NO INJECTOR PULSE
- 94 Civic dx
- eh2 gsr swap ecu/wiring questions
- Timing issue
- Type r swap in 99 civic ex
- Front end fender bender. Now what?
- '99 CX Auto - jerky under light throttle
- Trunk issue on the 95
- Can someone help me with main fusebox under hood
- Plug and play power options?
- Code issues
- USDM OBD1 P30 ECU
- type r
- B20v map
- Fuel Filter Washers
- Burnt wires under hood... what are they?
- Speedometer and odometer not working!
- Where to get the best tune?
- Which valve spec do I use?
- 92-95 civic hatch side moldings
- 17CL-14VN Front Brake Slide Pin questions (94/95 Civic Si ABS)
- D16Y8 convertion into a OBD1 body CODE 41 need advise
- B20b block with Gsr trans help!
- replacing crank pulley on 2006 Civic 1.8
- 95 civic coolant leak?
- Big bore on b18a
- B18C1 Rebuild
- 94 doors on a 98
- New Project! 99' Civic EX
- Eh9 won’t start until check engine light turns off
- B series turbo wont idle anymore
- Honda 1997 won't rev over 2000rpm
- 1998 Honda Civic DX Hatchback
- Why is the EM1 clutch pedal weighted?
- No Start after ECM Swap
- EJ1/EG B16a swap instrument cluster???
- What's the most economical air compressor/tools for working on engine?
- Need help diagnosing a problem
- 98 ek hatch with a b20 ecu issue
- OBD2A Alternator In OBD1 EG Civic
- Transmission
- 98 civic window issue
- B16a2 Swap wiring dilemma
- ALittle help
- Civic Type R exhaust install
- Possible steering upgrade?
- 98 ek hatch with a b20 fuel issue and etc
- It looks like I might have got the last 2 front moonroof drain valves around
- check engine light
- eg Gsr swap sudden loss of power
- 1998 Civic misfiring engine. Don't know the cause.
- 1992 Civic VX no crank no start
- Replacing fuel lid opener cable - do I have to remove the seat and QP trim?
- over rev missfire
- electrical issue
- Choosing the correct 5 Speed
- What ecu goes on a 2000 Honda Civic si ?
- 2000 Honda Civic ignition coil test results on a no spark
- Eg b16a lean after wot
- B20 Vtec Start But Will Not Stay Running
- 2000 Civic Passenger Window
- Starter Interchangeability - 92 vx Mitsuba SM302-48
- Obd2 & 1 sensor question
- 96 civic suspension
- 97 civic misfiring
- 95 EX coupe starter wiring issue
- B20b swap into 93 civic hatch
- Help b16 timming belt replaced at local workshop (in spain) and noises everywhere
- D16y7 ek hatch , swap with a B18B1 out of a 1994 Acura Integra ls
- b18a 1993 high rev at startup
- 2000 Civic EX PO136 won't go away
- Getting Shocked by Door
- How to repair starter
- help on window seals and trim
- B20b running like shit
- 97 Honda Del Sol abs question
- Knock sound when accelerating in first gear
- EGR Valve
- No hot heat after heater core replacement 99 civic ex
- B16A5 cylinder head gasket
- Replacement sub-ground for 97 Honda Civic CX D16Y7
- 93Eg sunroof slide problem *searched*
- Check Engine Light 8 flashes/blinks
- Very unique steering column question.
- B16A1 ONLY FIRING ON 1 CYLINDER
- D18Y7 Vs. D16Z6 Crankshafts
- 2000 civic b16 swap trans mount issue
- 97 del sol a/c testing ?
- JDM B16 Trans Rebuild in SoCal???
- 99-00 underdash srs wire hardness yellow wires
- D16Z6 whine at speed, weird idle noise
- Little tube that connects to a hose rotted and broke off. What are my options?
- D16y5 turbo
- 98 civic hatchback with a b20 need help
- Need some info
- fracture rpm (AC ON, P or N)
- Replacing driver door and rear seats on 96 Civic Hatchback
- What engine are these Arp head bolts for
- D16z6 dizzy with D16y7 internals
- Overheating problems
- Help
- 98 civic issue
- 1998 ek hatch el front end swap needing help!!!
- 1992-1995 Civic "OEM style" headlight quality and beam pattern compared to Genuine
- D16y8 and d16y7 transmission differences?
- 95 honda civic acts like it has no power but the battery is good. What else to check?
- left rear turn signal not working
- hesitation
- Speedometer needle flipped all the way around.
- Noise that goes away when clutch is pressed
- 1994 Del Sol si LSD
- Worth fixing or no?
- Cel code 20
- Skunk2 Cat Back to Stock d15b7 exhaust manifold/cat?
- Ek manual steering questions
- Bouncing idle
- help bleeding brakes 95 del sol
- very loud squeaking noise
- D16y8 swap options. Maybe a D17?
- CEL and Hole in Exhaust Pipe
- Have a problem
- Inspection
- #15 Fuse Keeps Blowing - I NEED A WIRING GENIUS
- Ac
- 98 civic ex with H22. No primary O2 sensor and high idle
- 93si HB feels lose at high speed?
- Old new battery for e.g. Civic: will it hold a charge?
- Cluster lights
- Need Good coilovers - 1997 Del sol s
- popped a virgin cherry (6th gen coupe) this weekend
- 94 civic air filter
- 98 Honda Civic in limp mode won't pass 3500 rpm
- Vents
- Aftermarket stereo install issue
- Exhaust system
- 95 GSR EG HATCH OVERHEATING
- Alternator readings varying. 12 then 14
- Ignition Switch 5th Gen
- B18 S80 tranny only third and fourth gears
- Piston Slap ? Collapsed lifter? Worn out camshaft lobe?
- Help! With Condenser Fan ON My 1995 Honda Civic
- Trans Am (T/A) Screaming Chicken Decal for EG Hood?
- Main transmission shaft to large?
- Mystery relay (96 Hatch, DX)
- 92 DX Main relay clicking rapidly, dim check engine light, no start
- Help! In need of window track rubber.
- 97 civic cx transmission leak
- Will PS rack seals be damaged by running car w/PS belt removed?
- Honda civic 1998 1.5 problems
- Intermittent wiper problem
- How much power should I be making with my setup?
- Blown head gasket?
- stock em1 0-60?
- CR-V T bracket compatibility
- 1993 Honda Civic del Sol Si - previous NA d16z6 build and current JDM GSR build
- Swaping a d for a b.. Motor mounts???
- Best engine and transmission swap?
- 2000 civic won’t start after fuse box relocation and wiring converted
- Type R Replica Seats Update/Review
- 93 Civic goes in gear won't move
- Issues with replacing a CV axle on a 95 civic with a d15b7 swap
- Rear Caliper protector purpose (5th gen)
- drive train chatter
- Slightly larger injectors with stock ecu?
- Is it worth putting performance mods on an automatic 94 Civic hatchback dx
- Battery replacement: using a 51 instead of 51R?
- End of crank sheered of from loose crank bolt?!
- Lost bolt under slave cylinder
- 92 civic won't start or runs horrible
- Good spring rate for coilovers
- 51r-c? battery
- Need help Ek hatch with a b20
- P2647 VTEC Oil Pressure Switch High Voltage
- D16z6 solid mounts
- heatercore vs headgasket?
- high/low beams not working
- Spare Tire Replacement
- 1996 ex civic p0155 & p0135
- b series rebuild help/ideas
- Possible fuel pump problem
- REAL QUICK what is this clamp?
- Clean EG coupe side skirts
- ECU Help
- 93 si HB brake sticking
- Poorman type r leaking water
- Brake light
- My first post, General Power or Electrical question Honda Del Sol
- 2000 Honda Civic. Running Rich Help!
- another year another rebuild. D16Y8
- Plan on getting into the car scene need some suggestions
- Need crankshaft pulley for Del Sol
- Clutch pedal goes soft.
- Final preperations before start up
- 94 Civic D16Z6 Throttle Issues
- Upgrading the brakes of my ej9 1996 civic hatch
- 3 pin iacv testing by using battery
- Air intake help
- Motor upgrades
- 1997 Civic DX - No start
- civic EJ new motor d16y7 but wont turnover
- Discount Body PartsFenders, Hood, Bumper Cover
- wood trunk setup?
- Need some more ideas
- 97 D15Z7 CVT FLUID??
- No start 1995 honda civic has fuel pressure has no spark
- 96 civic vtec
- D16Z6 intake with a B18 throttle body
- 5th Gen Manual to Auto Conversion - Backup Light Wiring
- Steering column swap
- B18c5 timing help
- 1998 Civic DX Manual Trans wont turn over?
- Walboro require fuel pressure regulator?
- Car almost dies
- A good place to sell my wrecked del sol.
- 1993 honda del sol D16Z6 VTEC silicone hoses?
- Speedometer repair DIY
- 1994 weird electrical stuff
- Sticky stuff on window
- Civic EJ1/2 chassis code location
- Please help
- Help please
- Civic EX 99 cat problems
- 92 CX B16A3 Swap Runs Poorly, No CEL
- P06 ecu Fuel Priming
- B20 upper alternator bracket bolt hole stripped
- 93 Del Sol Si Coolant issues
- 95 civic with d15b
- RHD '93 EG6 AC lines, R12 or R134A?
- No power, good fuses?
- cruise control surges
- CEL code 9 on initial start, disappears after 2nd start
- 2000 ex auto to b18c1 manual?
- Em1 and Del Sol Oil Pan
- 99 civic ex stalls
- 2000 Civic Ex Automatic Use 97 D16y8 Manifold that does not have air injection.
- 2000 civic ex vtech
- 93 d16 swapped low idle/stall when cold
- Fuel pump not priming(99 ex B20 swapped)
- Difference between 93 EG spindles vs LS?
- 92 Eg with ZC swap Po6 loss of power
- H-techs VS Eibach Pro kit preference
- What tools required to unbolt header from block and from exhaust piping?
- oil pans not the same???
- What down pipe for my stock ugly B20 header
