View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Will GC coilovers for 02 SI fit 04 EX?
- GSR Engine Swap
- sleeper exhaust?
- Is the fuel return line pressurizied?
- 96-98 to 99-00 Front end Conversion.,.
- help with brake swap? Ths
- another (2) questions about a/c bracket...
- it feels like im showerin' in my car...
- how big is dx fuel tank (searched)
- 1/2OFF: Not a "technical" topic, but very interesting video!
- 10.5K redline Del Sol Cluster?
- Brake Conversion?
- eg4 vs. eg6
- How to improve gas mileage?
- Got sent to see a state ref. WHAT TO DO!!!
- two ? for u guys
- ecu question
- need help on this one..car keep on dyin out
- PassWordJdm B16b motor Just got it.
- b16a3 ,del sol??
- My hatch is running lean
- what should i buy?
- SRS light on
- NEED answers...b18c in a 96-00 hatch
- How would I know if ignition wires are bad? Is there any way to check it.
- blown z6 motor, gold shavings in bottom end what is it.
- finally had to go buy struts
- will these swaps work?
- Tranny and dyno
- W.T.B STOCK SI WING 99-00 ANY COLOR
- Clutch choice
- Radiator hose....
- Quick tranny swap engine question
- RSX SEATS IN A CIVIC?
- What do you guys think?
- anyone know when vtec kicks in on a stock d16z6??
- Where can I get a Si badge for cheaper than dealership and a ques. about my Si tranny
- a V-X rear diffuser ?
- es n1 race muffler
- CTR N1 crank pulley war!!! when will it stop???????
- brakes
- HX wheels?
- cat back on del sol
- another whats this worth thread
- OMG brake pedal sticks....help
- quick q' just finished friends swap...
- How to install JDMShit CTR Wing?
- MUffler isn't a fix it ticket anymore?
- vandalized
- 92 civic hb si Power Window/lock install questions
- gsr code 22
- AC Evaporator
- where can i find this gauge pod?
- Civic suspension
- help with cel (code 22 and 41)
- Would this flywheel be ok or is it too light?
- Gsr leather in a ek coupe
- Ticking 97 civic dx
- how to put on short shifter on 97 civic hatchback?
- frame damage
- civic stickers
- type r ecu
- 93 Civic Coupe Turbo for sale
- Exhaust Recommendations 2000 Civic SI
- OEM Interior Conversions..
- Is it worth it
- good price for civic? I need your help
- 5 lug ebrake cables on a eg
- hydro vs cable clutch??
- Will a S2k antenna kit fit on a 92 hatch?
- 4 door ek side skirts :question
- Push button start
- Burnt??
- eg clutch prob need help
- Clutch Pedal Adjustment
- wizzards581's car. finally have pics.
- d16y8 head on d16z6 block
- I need quality pictures of BONE STOCK silver EK hatch, any links?
- BOV
- eg/ek lca's?
- ferio interior questions
- modify an auto p08 ecu to make it manual???
- swap or not?
- p54 ac bracket is from del sol b16 and CRV...?
- Need Help Passing Smog (California) Need Tips
- Jumped timing?
- cluster doesnt work
- price of a stripped eg hb
- black housing/clearer headlights ... need help!
- Ignition
- Where can i get the clips to hold in Side skirts?
- Need Instructions/Tips for DIY Grille Removal
- D16 final drive upgrade???
- 99-00 civic headlights on a 97 civic
- friends car got wrecked , is this a good deal?
- Just installed Skunk2 Stage 1 cams, now it idles rough and stalls
- can anyone help
- PROs and CONs on a light flywheel?????????
- help please
- Question about car I might buy?
- SRS problems
- Passing State Inspection with JDM Engine
- Stock Honda B16 parts for sale
- could anyone help
- Performance Mod/ Resistor Chip
- Engine tuneup - 56k on your own risk :)
- How to work an ohm meter?
- Will a bad heater core cause the engine to overheat?
- are eg civic si's brake booster/m.c. and 4040 prop valve the same as integras?????????
- W T F !!! cylinders are dry and kinda rusted ? HELP
- need help picking springs
- poll for my eg hatch front lip
- Transmission Conversion Help
- should i sell?
- new to h-t
- A/C takes FOREVER to get cold, recharge =no help..help me.
- removing ac under the dash.
- Should I buy this Car?
- 99 Civic Carbon Fiber hood
- SPECIAL Headunit Wiring!! HELP Experts!!! Thieves CUT Original Wiring... So cannot use Wiring Harnes
- IAT sensor '99 Civic
- Anybody know where to get JDM service manuals?
- Where can I find RS*R Mag II....
- 2003 OEM wheel fitment on EG
- help with engine choice
- Can i use a automatic wiring harness on a 5spd?
- NEW TIRES
- NEW TIRES WAY TO GO?
- Where could I get a knockoff ITR shiftknob ?
- gsr brakes on ek
- CTR master cylinder
- shift lock solenoid
- brake swap question
- Looking for a Del Sol in Michigan
- Where's the best Price to LongBlocks?
- tried a search cannot find any more hatch light stays on
- Shady hatchback found in NoVa Fairfax.. Stolen?
- What to look out for on swapped cars?
- tanny mount question
- EG pedal assembly in EK?
- How long does it take to be able to post on certain forums and send instant messages?
- k series head on a b series block
- Brake Caliper Semi-Stuck
- changed MTF? was there too much?
- obdIIa or obdIIb
- need to know the diameter of the rotors on a 95 del sol si
- blown shocks?
- Rotora Rotors...good or bad?
- Civic console?
- Simple question
- What Intake/Rad is everyone running?
- 99 SI sway bar size??? 22mm 24mm?
- retaining screws in the hub......need em or not
- the turn signal fuse is under hood?
- gsr seats in my 97 civic will they fit?
- Need help with friends 97 Civic
- 2004 Civic VP Tachometer
- steering or suspension, help me before i go crazy (searched)
- DEL SOL side markers / Reflectors
- COUPLE V-TAK VIDS.
- Has anyone bypassed/removed thier charcoal can?
- rear ITR sway bar only, lemme get this straight
- How to identify motor?
- for the swappers, whats your gas mileage
- Swap or TurBO Swap
- Will sitting time hurt my engine?
- are b16 header diffrent form b18c?
- v-tec e?
- 17x7.5 4x100 on a Civic Coupe????
- EK armrest rear bracket
- ebrake question
- wheels on eg
- what should i do?
- intake question regarding 94 ex coupe
- where should i set vtec on a z6 motor?
- Is cutting the inner fender a good idea?
- what times should i be running?
- anyone have the part #'s to EK4 SiR moldings???
- pic request: work rsz-r
- Problem w/ camber
- Anybody that has yellow'd headlights READ!!!
- D16y7 To D16Y8 & Turbo
- Help: EG hatch: Headlight Beam Adjusting Pattern?
- clutch install
- injectors or chip needed?
- question about magnaflow resonator that I bought..
- Please Help!!!---> 2000 Honda Civic Si Question
- HELP!!!!
- Looking for an EG in So. Cali. Does anyone one have any for sale?
- Power Steering and swap
- I bent two of my rota grids
- code 36 traction control on jdm ecu
- Engine Harness?
- gsr or b16 head on ls block
- would this header fit on a DX......
- will a dx oem header fit a del sol sohc vtec?
- Ran a 15.7!!!!!
- changed rotors today and this "bump" noise is happening....
- help need advise
- H22A into a civic?
- Engine Help
- ek gen si headlights
- Ignition hesitates every once and a while
- What goes here?
- What do all the different models' abbrv. mean?
- power steering fluid?
- Removing EG window handles??
- agx kyb and GC
- The Snowball Effect is Done!
- diff. between EK and EG rear struts????
- 205/40/16
- Import modification survey (for art class)
- any sites that shows videos of civics?
- how to fix timing problem?
- How to take out ignition coil
- Check out my alignment specs please.
- GSR Front Swaybar on an EK
- EK motor/trans swap questions
- Running lean, fuel delivery isnt there.
- NX nitrous kit on a SOHC vtec
- i can use integra calipers on my ek right ?
- Hood Latch CABLE stretched to $hit. Anyone use an alternative way of opening the hood?
- 95 LUDE nonVTEC brakes lying around. How to use them on my GSR calipers..HELP
- anyone EVER break a steelie?
- I need help with Integra dash wiring into eg.
- Questions about the new 02 Sensor I am having to buy...!!
- Help with JDM sidemarker install SEARCHED
- EK seats in an EG?
- SOHC Tranny Cases
- hydro to cable conversion
- Super quick question...
- CALLING ALL JDM ENGINES!!!!!!! HOW DID YOU WIRE YOUR 4 WIRE O2 SENSOR TO TAKE AWAY CEL
- cv joint for 00 si
- A/C HELP !!!!
- Miny Me swap
- hi about my turbo ls vtec civic
- water gauge
- looking for reviews/pics of new apexi WS2 (already searched)
- DID SEARCH, HELP ABOUT Z6 INTO DX/CX WIRING INFO
- HOW-TO...EK windshield wiper fix for posessed wipers.....
- How long have you had your coilover/sleeve and shock combo?
- Suspension...Most bang for the buck...
- any help on wiring???
- d16z6 or other sohc
- no flywheel cover?
- amsoil...what weight?
- Question about intake
- Lowering Help!!! Safe?
- FS: '94 Civic EX coupe
