View Full Version : Honda Civic / Del Sol (1992 - 2000)
- crank pully probs
- dual exhaust question
- better daily driver?
- EG Hatch Trunk Measurements
- Will 92-95 axles fit a 96 LX sedan?
- d16a1 problems! wont start.
- MY AXLE POPS OUT
- Test for Vtec?
- vtech problems
- Help needed. Unusual noises from b16
- trade my stock sol for a eg? what you guys think?
- symptoms of bad IAT sensor?
- Gauges ?
- Fog lights on a 96 civic with a 99-00 front conversion?
- Brighter Cluster bulbs?
- Weird hum/buzzing sound on 98 Civic EX
- stolen car
- inew guy....
- Driver side window problem and radio diagram
- chiton,helms,haynes,or honda?
- How long until I can pass an emissions test after pulling ECU back up fuse?
- Honda Civic H22 Swap Questions!!!
- Building b16
- brake purportioning valve question?
- Car won't idle right after turbo install, CEL says...
- Metal on metal no good
- quick question!
- identifying cams
- changing moods of my tranny
- Body Shops in San Luis Obispo, CA
- OBD2 GSR Swap in 96' EK Hatch
- Gurgling overflow? Headgasket blown?
- speedometer stop working
- OBD1conversion,which scanner to use for CEL??
- o2 sensor extension
- D16Y8 intake manifold swap for SKUNK2
- civic DX
- pgm-fi main relay......expensive?
- B16A3 throttle body **searched**
- Replacing distributor cap with a napa one, or similar.
- Does Anyone Know the Thread Pitch of these Bolts?
- Should I be able to do this...clutch fork question
- DIY: Cabin Air Cleaner/Filter thing
- need help on what pistons to put on my friends b20 vtec?
- Spark Plugs?
- Who owns this car
- aftermarket clutch
- I need a EK coupe.... silver or blk.. anyone have one for sale let me know..
- Where can I get a 2000 Civic radio delete/block off panel?
- need help on how to install 92-95 ex power doors onto a honda civic cx
- i need so help!
- Another "How much is my car worth? " thread
- Quick b16 head question. ( i did a search, and didnt really answer my ?)
- LS block or GSR for my EM1
- seatbelt mounting hardware...
- FF R/C Drag Civic
- B16 transmission rebuild...
- swoosh vart unit(v tec controller)
- need help
- simple question about wiring VSS
- where to buy denji projector headlights
- Where can i find one of these?
- Radiator cap question
- r ek's reliable?
- Window Cleaning Inside and Out
- Brake rotors
- brake problems with my eg si!
- ecu codes
- distributer
- skunk 2 mani vs. jg/edelbrock
- civic si 00 radio quest
- engien swap / is it a good deal ?
- wrecked EG, is it worth it??? oh yeah, wierd noise too.
- Hey what center caps are these on the rotas???
- Honda CiviC 91
- Top mount mountain bike rack help?? need to purchase.
- Are ZC DOHC VTEC possible ?
- H22 Civic questions
- Bulb assembly for Honda's, universal?
- OK another compatible ? 99 ex motor using a 97 ek hatch head what you think..
- help with stalling problem
- Teg clutch in civic
- radiator
- HID retrofit?
- Could I Use The Lug Nuts That I Have On My Aftermarket Wheels Right Now On Steelies?
- finally got a shell!
- windshield help
- Listen to this bull !
- Oem rods or Eagle for b18c1
- differences between eg6 years
- B16a2 question
- Ignorant Haters...
- Rev Limit?
- jrsc fmu
- Looking for EKK1 Hasport K-series mounts. (96-00)
- My CF hood has cancer. Need help....
- Are 97 ek hatches compatible with 99 civic ex couoe
- Need some information on swap for 95 ex
- what are these?
- 02 sensor question
- Where to buy slicks????
- Car won't start...
- Civic popping out of gear?
- rear exhaust piping and sway bar issues
- can't get 22mm o2 sensor bolt off ... i think rusted
- identify this problem
- EF rear window into a EG??????
- can anyone help with my stallig problem?
- passenger side window does not roll down, Need suggestions, pls
- Strut problem?
- my 92 civic keeps stalling
- Questions
- 95 del sol si...what mounts??? auto tranny shell
- turbo cammed si
- request for a picture of red top battery in EK.
- Need 95 Civic Hatch Fuse Box Diagram
- D series
- pic request:
- black/textured bumpers on 92-95s?
- Bride Seat Question
- will a obd2 dizzy work on a obd1?
- What's this for?
- Speaker Conversion
- new motor is smokin!!
- How bad is this turbo kit???
- Hub rings: What's the deal?
- Mounting Prelude Seats in EG Civic?
- How to change civic SI rear brake pads?
- ? about removing AC
- How much for this cluster???
- fully built LS/VTEC go boost ?!
- guys need help with rim choice
- Pwr intercooler question
- 95 civic will not start
- keyless remote broke... where to get replacement?
- High mileage SOHC Turbo
- Anyone with a 93 Civic Owners Manual Plz Look Here*****
- keep dc 4-2-1 or change
- what does it mean when my ecu throwing fuel supply system?
- Advise of building a motor
- what is bulb size jdm eg defroster?
- 5Zigen Fireball Cat?
- JDM GSR motor?
- need help finding a part information
- 94 si transmission on 98 civic
- Will running my AC without the fan hurt anything?
- 92-95 Civic Hatchback Rear Speakers (Search is down_
- more swap help
- What OEM LSD fits in my trans?
- NEED HELP NOW
- quick question about tokico illuminas...
- Catback, Weld or Replace?l
- technical drawings
- Help wiring hids..
- Swap finished BUT wheels spinning when not in gear
- Whats wrong with my windows??
- EM1 armrest?
- looking for a sir lip
- EG Jdm Window Visor Help?
- What is this part?
- white smoke from exhaust. Turbo or head gasket??
- JERRY BUILT RACING?
- lip kits
- dc sports header cracked!
- Will b18 spark plug wires work w/ b16 ::search down::
- is there a [faq] for this?
- Need Your Opinion H-T ers
- jdm intake manifold
- JDM Window Visors for EG
- rust hole o no's
- B18C1 vs LS/VTEC ??
- where to get HONDA MTF besides the dealer.
- Trans is out.. how do I tell if the mainshaft bearing is bad or not ?
- WTB: 94 ob1 ls wiring harness!!! and injectors!!!
- Found SOme vids Of mine and bros car
- Best E-bay radiator fo my hatch?
- Help!!!
- HOW CAN I ADJUST MY IDLE WITH NO RPM
- LS => Delsol swap trouble
- how to change or inspect the vss on 93 ex
- Connector to TEMPERATURE SENSOR....HELP! 93 Civic
- Trying to rebuild a pos 96 Civic sedan - which other years/models will fit?
- K20A questions
- Lime Away
- Mounting New mirrors? No Hardware?
- 99 EX Drum brake question
- Question
- hardest decision of my life, not which swap or turbo/na
- integra(not sure the year) gauge cluster in a 95 civic dx
- wtb stock 92-95 civic h/b spoiler
- Gude Bullfrog Ecu
- Engine Break-in
- header questions!!! 4-1 vs. 4-2-1
- value
- CV axle problem w/ the H22 swap
- del sol map lights
- Removing the Pulley Nut w/ out a impact gun?
- 91 Octane d16z6 build?
- Will rear trailing arms from a 90 Integra fit a Del Sol?
- Intake is to loud on 95 coupe & 94 hb
- Aligning headlight bulbs
- Radio code please
- Help! How to unplug electrical connections?
- Suggestions for 1992 Civic Si Distributor replacement
- sensor off, lost lots of water???
- Need VECI for 92 Si Hatchback
- looking for good condition tansmission EX or SI for 95 civic D16 motor
- I need help fitting 13" wheels on an EM1
- wich of these mani's give more air flOw??
- code check
- how do you check the codes on a 99 civic si
- Exhaust Question
- Piston Slap?
- need help
- will vx sohc vtec-e pully fit a d16z6?
- First mods for a 97 Civic CX Hatch
- SPARK UNDER HOOD AND NOW NO JUICE.....HELLP
- RPM's
- anyone know a link that show you how to check the timming?
- skunk2 coilover o-rings???
- check ingin light
- Sweet sweet spark!
- Falken, Toyo ??
- K20 swap Overall Height question.
- spark wire/plug problem?
- what is the best transmission for my 95 civic D16 motor SI or EX?
- Car is limp mode codes 17 and 41 help
- Do 91 Si seats bolt in to a 94 cx?
- SRT-4 seats into my EG (pics!)
- B16A2 engine mounting
- b16 a tranny
- b16a2 rear motor mount bracket question
- problems at the pump
- Civic Wont Go INto gear!
- 5 Lug conversion on a EK
- is the del sol considered a sport car by insurance?
- civic si wheels
- Has anyone ever put a B18B or A head on a B16 block?
- Could warped rotors make your car shake at certain speeds?
- Lowest offset??
- Corner lens drama. Advice. =)
- H22 GOES BOOM
- Type R Steering wheel into EJ, now throwing check engine light
- Swapping out D16Z6 for a D15B vtec....need help
- AC In GSR EG?? Help (belt related)
- Lug nut HELP
- The most stolen car!!!!
- To all worried about obd1 and obd2
- can i drive my car?
- Feeling really stupid can't find led bulbs to put in dash
