View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D15b7 engine idle rpm very high after intake manifold install
- 96 Hatch to Sedan trunk difference?
- Headlight search
- No spark turbo civic
- auto intake to manual
- D16Y8 to D16Y7
- Interior instrument dimmer adjustment not working.
- Jumping RPM on acceleration EK1 HX (CVT)
- D16Y7/8 engine stiffener in D16Z6?
- OBD0 vs OBD1
- FITV question d15b7
- Ek4 type-s
- No power to starter
- 1997 Civic with burning smell from engine only with A/C on
- Seized Caliper?
- Honda civic flywheel bolts
- Honda Del Sol trunk plug
- 99 Civic - SERIOUS front end problem
- Help my lil civic ex has erectile disfunction
- oil in rad hose
- D16z6 build questions
- My daily needs more power
- 1992 civic dx hatchback electrical issue
- Car not starting??
- Wheel Bearing Size ???
- loping idle/wonky idle
- 99 EJ Civic EX Coolant Leak
- 1993 Honda civic hatchback eg
- Mini mi help
- ACL race oil pump
- water pump install
- Vague Steering - Caster?
- Help fuel pump not priming and main relay not cling all fuses are good
- Anyone know why l'm reading half the power on my rear right speaker than my rear left
- Honda Del Sol
- Honda EG D15B7 acceleration issues and stalling, bogging down and slowly getting wors
- wheel speed sensors
- 2000 civic hx crank no start. Have fuel and spark.
- Head gasket
- Crank no start NEED HELP ASAP
- Car won’t start
- b20b4 head on b18b1 block
- Ek hatch brake light problems
- Driver power window not working after re wiring
- Need a little help on ecu
- B series turbo build
- D16y7 cylinder 3 low compression misfire. Where do I start?
- 1999 ex with B16A issues
- D16Y8 p28 Timing
- How to read a dip stick?
- Will this VTEC Solenoid 15810-P30-005 fit my D16Y1?
- B18c idle issue // sits at 3000rpm
- 2000 civic sedan dies when warming up (d16y7)
- 95 civic dx D15b7 need help please, battery boiled over.
- Keyless entry/ door key hole delete
- 95 Honda civic ex d16z6 overheating issue!!
- P1336 & p1337 98 Civic d16y7
- 98 Civic Ex misfire mania - any suggestions?
- Honda del sol bubble kit
- ABS Light on-I dont HAVE abs
- Coilovers for sir loop eye .
- Lsvtec won’t pass 4500rpm but as soon as cel light comes on it lets me gas it all
- CSM Build
- b16a 7500 redline?
- 95 eg front sway bar install
- B16A2 SOME TIMES CRANK BUT NOT START AND MIL LIGHT ACTIVATE AND FUEL PUMP DOESNT WORK
- High idle issue help
- 1999 Honda civic dx caliper bracket bolts keep spinning
- Fuel Filter Squirting Gas from Intake Side
- No Spark Issue
- 96-00 rear disc brake swap. No brake pressure
- Main Bearing Clearance
- B18C2 head on b16 block?
- 2000 Civic Sedan A/C oil questions
- Fuel injectors
- Harness
- Fuel relay not priming
- Engine ADVICE PLEASE !
- Help loosening tension on timing belt
- b16a2 wont start, no inector pulse?
- 97DX EK W/k24a2 05 element ecu. Blown ign coil fuse.
- No Power to fuse 19
- Ek Hatch DC2 Trailing Arm Swap Help
- 98 civic p1336 & p1337
- erro code 22 Civic ex 93 aut .
- Idle issue/Misfire on 1992 Civic CX
- b16z6 cyl 3 no compression
- rear disc upgrade
- Question About my B18C gsr manual Gearbox
- Trying to find side skirt for 98 civic dx
- Door handle rod keeps falling off
- I messed up
- H22 crank but no start
- Fluctuating/High Idle
- P0132 sensor 1 high voltage
- Thermostat & ECT SENSOR REPLACED
- Changed fuel pump, worked fine, crank no start the next day.
- Blowing but no heat
- 98 civic fuel issues
- Fuel injectors
- Crank No start
- D16Y8 block with a z6 head
- D16y8 Fly wheel bolts
- 93 civic GS-R swap high idle
- Motor Mount Replacement
- EDM Power Adjustable Headlight Motor Repair
- No 1st or 2nd Gear HELP
- Eg race bumper help
- Need Help
- P0505 fluctuating idle
- Tail Light Wiring Problems
- EK Civic Engine Mounting Issues
- Civic eg reliability question
- B16 Trans To GSR trans. Do I need a retune ?
- 96 Civic LX Compressor and Fan with always on signal
- Emissions Label under hood
- 1993 Civic EG ITR cluster (speed correction)
- 97 Del Sol OEM Radio
- B16a1 in limp mode
- 98 Civic EX Crank, No start
- Replacing Fuse Box on a 00' Civic
- SRS light always on and 3 modules giving error
- Rust please help!!
- Condenser Ideas for a EK civic
- Need Help Adding OBD1 Connector After D15B Swap in '92 Civic
- Del Sol Head gasket replacement
- Body Harness and Interor Swap
- Need help. I just found some brand new axels and have no idea what they're worth
- AC install issue 2000 civic dx
- B16A2 Misfire / Hesitation Under Load With AC Only
- Adjusting my Del Sol Coilovers
- CV axle may not work.
- EM1 3.5" straight pipe. Resonator that will fit?
- B16A Backfire problems
- D16y8 head on a d15b6
- Misfire on cylinder 4
- Code 20...
- 2000 Honda Civic won’t start after replacing head gasket
- 98 Honda Civic crankshaft position sensor bolt broken off
- Help! Skunk rear long arm BUSHing size.
- D16y8 rods in a JDM D15B?
- CRANK NO START
- VTEC Pressure Switch Wiring
- Different color connector wires. HELPPP
- Discontinued coolant and vacuum hoses
- S40 housing bearing race stuck
- Electrical
- Modulo ABS
- 94 civic help
- No turn signals
- Inner Weatherstrip for front Door (felt window strip) deteriorating
- Water leak under dash
- Crank no start d16y8
- orientation of Skunk2 rods for B18B
- Speed Sensor - OEM or Aftermarket Okay?
- NEED HELP
- 99 civic ex d16y8 automatic transmission
- EG Civic Keeps Overheating
- 2000 honda civix ex coupe 2d
- Window Not Working
- Turbo civic giving me hell
- Odd issue with my 2000 civic DX D-16 auto with air
- Oil light remains on for 5 seconds after cold start
- Hard Bucking During Acceleration / Running Rough
- Double din conversion from single din pre facelift
- Rattling between 2500/3000* rpm
- 00 civic D16Y8 P0122 getting stumped
- ECU questions for a D16Y8
- Saving a 97 dx.
- CRANK NO START 1999 EJ8 B18B1 AUTO - MANUAL SWAP
- ek brake pedal on eg pedal bracket
- 92-95 Civic D16Y8 swap… need help with wiring and ecu issues!
- 98 Hatch Fuel from Charcoal Cannister
- Foaming in radiator when engine is running.
- Manual civic ran fine then wouldn't start over night
- COP - Snake Mini Dizzy
- oem central locking system
- Main relay
- Strange Idle Issue on Auto to Man Swap Ek
- Breather hose vacccum leak
- Both P0131 and P0505
- 1998 Civic Steering Column Rattle
- 1996 Civic DX water pump fitment issue
- OBD2B auto harness ecu pin out ?
- D16y5 rocker arm assembly install
- B18 Cylinder Head Coolant Hose Thread Pitch
- Aging inner weather strips and window streaks
- Race car engine upgrade. Oval track.
- SRS Code 9-2
- Need help finding a solution
- Honda Outboard Help Needed
- A/C clutch nut replacement and size
- '95 Civic Ej1 coupe Build Log!
- Putting an EM1 back on the road- some questions
- tires
- Leaking under distributor looks like RMS?
- Having issues pls help
- 98 civic rev limiter at 5500 rpm
- Radiator Fan not coming on
- Secondary o2 sensor wiring to ecu
- ESi and CRX badge dimensions (EH6)
- B16A Timing Belt Question and Headgasket..
- Looking for help on buying a 1999 Honda Civic LX
- Code 21
- ECU info for vtec
- Y5 crankshaft questions
- I have a crv 5 lug on my em1
- Temperature level goes up even with the ignition
- D16y8 swap and auto to man ecu
- Valve Springs replacement
- 1994 D16a9 head gasket change
- Power loss issues for acceleration/ won't come out of park
- Violent jerking in 1st and 2nd gear / 98 HX
- eg OBD1 connector pinout help
- Swapping D16Y7 to D16Y7
- How do I get the bolts off the Cat Flange?
- B16A for California "Engine Replacements"
- Throttle body upgrade
- B16A oil light then stalls
- Idling issues/P0505 *UNSOLVED*
- Integrating a 2001 Civic ECU with a 1992 Civic Instrument Cluster: Challenges and Sol
- 92 civic coupe w/ b series and p/s swap into 94 civic hatchback?
- Camshaft 180 out of phase
- 00 Civic EX Coupe OEM Front LCA bushing options?
- Ecu or O2Sensor?
- Help!
- Best brand suspension parts for 2000 LX
- Throttle Body Replacement issues
- Vtec engine wire harness on non vtec engine
- Rough Idle after injector change
- Fuel line snapped to fuel filter, what to do?
- Intermittent Cranking no start
- Rt t-lamp and ctr rear brake light stay on
- 1997 Civic Ex fuel/timing issue
- Clutch master/slave problems
- Em1 clock spring difference?
- D16 compression still low on 1 cylinder
- 2000: Window exterior molding compatibility
- 2000 Ac issues, working sometimes then won't work at all
- AC PROBLEM
- B16a / Gsr Turbo Build HELP please!
- Valve Adjustment Problem D15 B8
- need help in wiring!! urgent!
- Shift linkage slop
- 98 Civic LX, Transmission swap question(s)
- Collapsed PCV hose
- 96 hatch awd s1built trailing arms- rotors and calipers kissing
- Spoon rigid collars
- Anybody know the correct part # for front lower control arm bushings??
- '00 auto Y7 car, '97 manual Y8 swap - help please
