View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Intermittent Starting Problems '98 Civic LX
- 99 EX Lock Control Unit with 96 EX Radio/Keyless
- EK9 CTR Red Badges Question
- 94 civic ex no start
- 99 Civic Ac idler pulley
- Low idle even on cold start
- transmission interchangeable on 97-98 civic Lx
- Car won't start unless I jump it
- 99 Civic si - Speedo crazy
- gas leak...
- 95 Si - cannot put into any gear when I push in the clutch
- 96' del Sol SI: Engine surge off load (Scan tool data, pics, video)
- 94 civic cx hatch rally build
- Using d16y8 engine harness on b16a2?
- Possible A/C Compressor Bearing Issue and A/C Questions
- Interior Door Handles for 1994 Honda Del Sol
- Speakers for my 1994 civic ex
- 2000 Civic, d16y7 removal and installation, automatic
- OBD2b Repinning help?
- Replace Plastic vent on dash
- Speed Bleeder - Slave cyl
- Dealing with idle issues
- Cabin fan died (bad motor?) '92 VX
- Shift linkage??? b18 swap into ek
- Newbie to Honda - Stalling issue on 97 Civic w/ B18C1 Swap
- Z6 head on a D15B engine
- Rebuild ?'s
- front bumper corners ripped. looking for the common cure
- Trunk brake lights?
- 1997 Civic hatchback headliner replacement
- no one can seem to solve overheating problem
- 94 b-16 del sol. Rattle in motor
- Good deal on 96 4 door
- Favorite Rims
- Rad fan connector
- Is it time to replace my radiator hoses?
- MAP sensor CEL won't go away
- D15B VTEC head/block question
- 93 Civic - running lights problem
- Intermediate shaft noise? Wheel bearing?
- first auto to manual build (HELP)
- 96 Honda Civic Instrutment Cluster lights not working
- master cylinder help
- Stock 93 DX Hatch will not start
- 00 Honda Civic LX - ECU Not Ready
- Eg hatch brake lights and turn signal don't work?
- Brand new battery but stereo resets and no spark
- overheating
- 2000 Hatch rear disc conversion question
- Oil leak in 1996 Civic
- No power 92 civic
- 2 O2 sensor codes
- b16a head build
- Half Shaft (Axle) choices
- Strut/Spring selection
- are aftermarket upper control arms directional?
- Which motor has th best power an acceleration
- b18c5 2000 civic hatchback - parasitic battery drain
- civic revs automaticly and only runs with clutch pressed in
- '95 Civic EX I can't hammer out my wheel hub
- 94 civic coupe. EJ2 "D15B" clarification.
- tein H techs are horrible
- Rough idle after Bee*r install
- 1999 civic and a dream
- 97 civic coupe/auto/d16y7 - auto to manual conversion
- Honda Civic Code 14 trouble
- 93 Civic D15B low compression Burnt/Bent valve(s)
- Need info about cluster
- 00 civic si driver lock/unlock issue
- Fuel/Air sensor replaced, Still CEL 99 HX
- Changing Clutch Master Cylinder on 1997 Honda Civic SI, help!
- 99 civic - right front tire/wheel sticks out farther than other side
- 92 civic 4dr dx exhaust
- Inner tie rods
- 96 Window wiring need help please.
- 95 honda civic intermittent spark
- D15B 3 Stage Vtec rough idle when warm
- Wheel bearing
- 1999 Civic Engine Knock
- overnight battery drain
- D16y7 with y8 head
- no start
- Bogging after cleaning engine bay
- Aftermarket seatbelts
- Bought a 99 civic without A/C
- d16y8 head on JDM D15 Block?
- starter clicks but dosnt turn over
- Can't figure out what head this is?
- B16A2 Head build
- what plug is this?
- Windshield vent doesnt work
- 92-00 ICM/Coil Technical Discussion
- 95 del sol ignition problems?
- 97 civic ex vtech is not engaging
- Can't figure out why my 97 civic ex spits and sputters
- 95 civic rear drum to disk brake conversion.
- !!Build Advice!!
- Hi.newbie here, need help to shut down big V8 guy mouth!
- firm motor mount brands
- 93 Civic Si starts then dies
- D16Y7 Hard to start, and dies when given gas hard
- Electrical System Acting up....
- Hard starting, high idle and Cylinder misfire codes
- 99 Civic EX Drum Wont Fit Back on After Replacement
- stainless brake hoses question
- EG CX - rpms increase and decrease repeatedly
- need hose diagram!!!!!!
- 1998 Civic Ex HOW TO CHANGE HEAD GASKET???
- 92-95 Wiper Motor Self Parking Switch - Operational questions.
- 98 Civic clutch issues
- Please Clarify! 96'-00' Civic related
- mysterious coolant leak - heater core? and other questions.
- Swapped engine stuttering
- Coolant Leak Issues
- Need new engine - looking for info
- Can you switch seat parts
- 17x8 inch rims 235/40 tires on eg sedan
- My 94 samba green del sol SI
- Buying a 99 ek hatch b16a2 swap
- 95 sedan wont go in reverse after b series swap
- Trouble removing coolant switch for 92 Civic VX
- 96-98 to 99/00 dash and ac unit conversion
- 2001 Honda Civic Ex - flashing dash and turn signals?
- RHD CR-X Del Sol SIR TransTop (Problem)
- 94 civic ex need wheel/ susspension tech help
- koni yellow/gc height?
- 96 Coupe wheel well rust, replace qtr panel?!
- SOHC ZC motor in 92 honda civic.
- exhaust rattle?... help!!!
- 2000 civic dx d15b non vtec swap
- 96 b16 engine harness on 96 d16y8 engine
- Help D16z6 distributor bolts size length specs??
- Car not starting...what is this black box?
- 95 civic sputters and stalls HELP
- Wobblie shifter
- Most comfortable seats for coupe '00
- D15B Swap into 97 civic
- what's stock cc's on b16a obd1 injectors?
- window regulator swap or conversion?
- ek power folding mirror wiring
- 95 civic Solid check engine light... burning ecus up
- DIY - Replacing Del Sol heater core
- no power to fuel pump
- 93 eh3 power doors. HELP!!!
- jdm b16a sir2 - need help finding parts
- Brembo Brakes on Civic/Del Sol?
- Eg Hatch b-series all motor video
- SiR ek hatch b series turbo
- Dyno Day with Abraham Alba Rated R k-series only
- lil video i put together of a ek hatch k-series
- 2000 civic Si(R) fuel economy
- need help! 92 civic spark and fuel issue
- 98 b16 oil pressure loss.
- HOW LOWER MY CIVIC SAFELY!?
- Head gasket or something else?
- Won't start when it's humid/has been raining
- Looking To buy a engine for my 97 honda civic
- High Idle when engine is hot
- Normal stance and ride quality for Skunk2 struts & springs?
- Where can i find 2000 civic si wheels
- 93 Civic - Fan overheating issue
- Noob: how to bleed clutch '97 Civic
- Civic VX Hatchback Door Lock Actuators Binding Problem?? (solved)
- Random Stalls!
- Steering rack noise
- Acura el/isuzu gemini/honda domani trunk on 99-00 civic
- Will fuel injectors from a 96-00 Civic D-series work on a b16?
- civic 99 manual climate to automatic climate
- Tires
- Fan not working
- 93 Civic hatch - Contemplating fixing this body rust. Any advice
- Oil in spark plug wells/Replacing o-rings
- Noob question. D-B swap parts list.
- Tips for Refreshing EH9 suspension for DD'ing
- 92 civic with d16y7 swap and P28 ECU wont start
- D15b p28 auto to D16y8?
- D16Y8 Head on Y7 block
- "gin" coil springs. Where can I find info on them?
- Del Sol Tire Size?
- D16y7 stock rebuild questions
- Keep bursting Coolant Hoses, Exhaust gas?
- civic 95 sedan ceiling light wiring
- usdm oil pan gasket and usdm valve cover gasket fit 98 jdm itr pan and valve cover?
- Will any b series axles fit into 98 jdm itr?
- D16Z6
- Inputting Stereo security code?
- Y8 Head/Z6 block - No power when accelerating
- need help on wire tuck for 94 honda civic ex
- Random automatic weirdness (d16z6)
- 95-96 Civic ICM questions, seeking help.
- 93 honda civic hatchback wont start
- Stiff PCV valve hose.
- 2000 honda civic vp
- JDM B16A into 94 EJ1 Charcoal Canister
- EG brake upgrade question
- Cold air intake
- 97 ex coupe. Left turn signals come on instead of left rear running lights.
- 97 Civic Jumpy Tach (solved)
- Steering wheel two torx screws won keep stripping
- 92-00 civic ICM bench test
- need help! b18a1 in 93 si wont start
- Regular maintenance tools?
- Question about Honda Civic EG9 Mugen lip made of Fiberglass: Yes or No
- USDM Civic swap into JDM Civic help plz
- Weird tranny sound.....possibly
- DevSport Side Skirt Wind Splitters for EK... anyone?
- Del Sol Steering Wheel Off Center
- Inspire Me - to rebuild or not to rebuild
- 00 ex secondary 02 sensor harness plug location?
- non vtec jdm d15 in 00 civic - just a bolt in affair?
- honda 94 del sol what strut forks can i use
- Will 96-00 4 Door SIDE SKIRTS fit on 96-00 coupe?
- A/C compressor problem - repair or replace?
- Bled my brakes, now brake pedal sinks..
- Bad steering rack?
- 97 EX Sedan automatic mpg?
- Opinions??
- Basemap questions mini me
- P0170 & P0172 engine light keeps coming back on after three battery disconnects
- 95 delsol b16a3 questions
- Gas Tank Replacement
- Vibration & clicking sounds front only when it rains?
- Coolant leak at tee fitting on intake
- '93 Civic Randomly Dies -- Thoughts???
- D16Y8 with goodies off a tooth?
- HELP!!! b7 dizzy fits perfect on z6 head bolts ryt up
- Dim turn signal lights on cluster
- Heli-coil. I fired my assistant, the no-show scam artist.
- 1999 Honda Civic EJ8 RHD CTR Build / Progress Thread!!
- 2000 Civic Ex - Hesitation HELP
- d15b7 misfiring
- Always check fuses before...
- Suspension question EG3
- What is the strongest manual 5 speed Transmission for a d16z6
- D16Z6 - Hiccups while driving after warm, idle RPM's off.
- 00 Civic SI/B16A swap- won't rev past 3.5k RPM
- under dash diagram
- Need Help - 1993 Honda Civic LX 1.5 Hesitated Acceleration/Rough Idle
- 2000 Civic Cruise Control - One cable
- First time honda buyer
- D16 Engine Mods
- 92 civic signals and clock not working
- Leaking roof rails? Water woes.
- Highway braking - Warped OEM Rotors
- Clutch lines clogged?
- 00 Civic EX - Knock sensor Check Engine Light
- Main Relay for a 93 del sol m/t
- 95 Civic - HVAC controls sticking and popping out of dash
- Intake Gasket Leak
- My 1995 EX got stolen... [NM]
