View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Honda Part numbers What are these parts for THANKS
- Bent Valve Inspection....
- how the hell do u ighten e break
- Anyone know a good tuning shop around san jose bay area?
- what rear seats fit in EK sedan???
- how do you send a pm?
- Weird brake problem
- Civic CX shock tower wiring diagram? Have to add Map sensor.
- front EG trailing arms into EK? Will it fit?
- Have to wait for intake to turn on to idle corectly
- Clicking noise
- If I am going turbo.....
- Is there a such thing as...
- what is the difference between...
- 01 Si seats in a 93 Dx coupe
- W/B Back Yard Special Wing
- b16 into a 94 del sol
- Bought fuel pressure gauge 1/8 NPT Center back connection. Need adapter.
- auto trans
- wtf mate
- 88-89 or 90-91 crx si cluster in eg......
- d16y7 to y8
- about to dump the hatch
- Would You Guys Rebuild This Or Find A Good Used One
- civic si 93 electrical lights problem HELP PLEASE PICTURE!!
- Help, cam gear key fell!!!
- Exhaust Manifold Stud
- ADVICE: Car stolen, than recovered-- now i need some swap advice
- help on choosing new motor
- machine shop
- how do i know if my block needs decking?
- *****Passenger Airbag removal*****
- Center Console Question
- Mini Me Swap Cam Gear Question.
- few questions
- attn bay area please read stolen car
- kenji and phearable link
- Need assist, bad idle and major squealing!
- door latch help
- Was installing Endyn breather kit but... What is this on my block?
- Need Help Fast!!! (steering wheel)
- Need swap help asap!!!
- Is it fine to buy a car that was once turbo?
- dyno testing!!!
- what is the definition of a spun rod
- Walboro fuel pump install
- B18C1 into EG resistor box question
- itb's for gsr
- Installing muffler...what happens?
- fpr lean or rich
- need controler help...
- 2000 civic si is sluggish on startup
- electrical diagram
- Oil filter magnets!
- ctr steering rack??
- Carfax
- How wide of a tire can I fit on my stock steelies?
- Video / Red Civic TurboD16 - In the 12"
- y7/y8 mini me headgasket, which one?
- 98 Civic CX Tranny...Axles and Reverse Issues...SEARCHED!
- LS VTEC AND TYPE R PISTONS QUESTION???
- the anti anti cross drilled rotors.
- Im doing a D16y7 to D16y8 Head Swap ! What is the best ECU to use?
- tranny leak? from h22 EG civic?? from shaft??
- my h22hatch
- Weird voltage problem
- Cheapest motors online?
- which sounds better??
- omni power..any good?
- VX trouble.
- typical parts and labor charge...
- Can turbo manifolds be wrapped with heat wrap?
- 95 Del Sol...Timing Issues
- removing spring from strut
- handling issue.. car swerves a lot
- Black 99 SiR Stolen!
- ls/vtec
- ***POST UP PICS OF YOUR EG*** Part I (NO COMMENTS/DISCUSSION ONLY PICTURES)
- Something serious wrong d16y8
- BRAKE BOOSTER HELP!
- 93 hatch jdm b16 no power need help
- EP3 seats in the EG..
- Timing belt job question
- Head gasket question
- need help fitting apexi rsm
- JDM 2000 Yellow Foglights. How is power supply connected?????
- Crazy post I know, but what the hell... "dual stock mufflers"
- b16a2 swap problems
- gsr seats in del sol? will they bolt in?
- OEM standard alarm on a 99 civic SI
- Si radio question 99-00
- transmission vibration
- How can i tell that my car has a JDM Type R motor?
- please help me :[
- type r cams
- Help with JDM B16 swap and MAP sensor
- civic coupe side mouldings
- Anyone have this lip? Pics please.
- Please Help. Skunk 2 intake manifold
- WILWOOD BRAKE KITS?
- i'm startin to get annoyed help please
- ls boost or ls/vtec?
- need help with my EK
- PSA: Always make sure you tighten the rotor retaining screw on your distributor.
- 92 civic si power window help!
- Looking for more info on these brake calipers.
- installing EG6 double DIN console- HELP!
- Wiring Shift Light
- si lip question..
- Tanabe super hyper medalion Vs. WS2 Vs. stock
- draining a d16y8 block?
- Starting to pinpoint the problem with my vtec, but need some input from you guys.
- headlight lense painting
- I-35 Blue Eg?
- Replacing Springs
- Motor?????
- DC2 antenna on a del sol??
- 92-95 coupe exhaust on hatch
- What's that book called?
- need help over hx harness on b16a2 o2sensor
- Am i alright to run a USDM vtec solnoid on a JDM head?
- ITR shifter lever in 99 civic sir
- D-Series tranny problem...
- eg6 service maual
- EG JDM pole quiestion, need help with wiring.
- noobie with manual transmission
- a/c flush ?
- LS turbo
- New FITV, noisy intake
- tuning ?????
- cf hatch question... plz help
- trying to get new seats in del sol
- MPH doesnt work
- cold air intakes for ej8 civics
- vision mirrors
- post pic of lowered eg.
- Spoon 1.5 lsd...oil to use????
- stock exhaust... running with no muffler?
- Apexi NOIR to Test Pipe, flanges are screwy (searched)
- uberdata for jdm p30 ecu???
- engine code of stock 2000 civic ex
- ac issues
- Need help chosing a motor!!!!!
- WHAT size are the fittings on an eg power steering rack??
- 91 si with d16z6?
- quick manifold theory question?
- Pulley Size - D15B Alt Shaft Diameter NEEDED
- Timing is way off after cam install. But Cam and Crank are in sync. NEED HELP!
- a/c question
- dohc swap ac bracket
- this code = P0401
- cat converter question??????
- b16a swap 95 civic, Mounts?
- Crazy electrical problem. No clue. please help!!!
- Seat Conversion?????????????
- HAVING PROBS WITH CAR OVER HEATING help help
- passanger power window went out please help.
- torque specs
- do autos have tranny fluid filters? & what temp. fluid to use?
- did you dye ur carpet? or buy a replacement?
- Foggy, Hazy Headlamps
- Does anybody have a DIY Y7 Mani to Y8 Mani?
- i blew my h22 should i buy this
- 99 civic hatch back window same as 98 hatch?
- 2000ex Springs change question. Thanks for looking and helping
- remove steering wheel?!
- ECU Code help
- cheap Depo fog light kit help!!!
- compressor?
- does anyone else think the eg body is too weak/flimsy?
- 99 SI - Idles where it wants and Stalls?
- Oil type for honda Engines, Engine types, best swaps
- ECU
- d16 intake manifold swap?!? help
- Permission to post in the Classified section??????
- Hiding ECU?
- starting hard when engine is hot
- 8 valve cam in a 16 valve head
- TRanny removal?
- Please Help - Swapping Motor Problems
- Suspension Squeek/Squeel..
- Ohhh Maryjane...
- Struts Bars for 94 Coupe????
- Integra Front Brake Swap, Turning Is Harder?
- need help on c pillar bar installation
- what would a stock jdm b18c type r motor will run in a Ek?
- Del Sol Seats in EG?
- turbo psi set
- Common Window Problem?
- Every Civic Has This Problem?
- chrome or Hondata
- 02 sensor
- help please!
- 96 civic w/ gsr swap throwin cel 33...
- Worth Getting Aftermarket Brake Master Cylinder?
- Seats for corbeau brackets
- RPM cut off at 5500 and low idle on cold start
- ls rod
- New Guy
- Rough idle on elevated surfaces
- EG w/H22A fuel injector questions
- brake booster leak
- y21 trannyw/B20B
- Brake Master Cylinder Question
- CTR Pulley and alternator pulley?
- Throwout bearing or clutch going out?
- what is this?
- Rebuilding the block, is it worth it!?
- fog light
- how much is a b16a2 longblock worth?
- help car won't start
- Aftermarket Internals, anyone local..??
- Need help on my suspension on my 1998 civic dx..
- Running radiator fan all the time.
- is there anyway i can get the omnipower full coilovers for dc/eg to fit my EK?
- wtb 99-00 civic honda rear lip tried seraching!
- Which civic lip will fit Del Sol???
- anyone know how to wire a 99 Si cluster into an EG??
- JDM B18C 96 SPEC Problems
- tach hook-up but no wire from distributor
- What would you recommend for a base?
- Just want it to say hi! New member with Ek JDM type r Swap
- Clutch Problems...
- tranny rebuild
- Will a GReddy 4-2-1 header from a '99-00 Si fit onto a 96-98 Civic with a B16A2 swap?
- after market radiator cap
- Car just plain won't start
- help with day time running lights
- snapped a bolt, help! PLZ!
- Wiring Diagrams
- where do i buy this mugen lip??
- ECU HELP
- How does 2 S4C Tranny's differ so much?
- throwing code 21: vtec spool soleniod and code 1: o2 sensor...
- gauges
- NEED HELP!!!: Removing aftermarket steering wheel****** Pics
- stainless header performance benefit?
- p06 pinout
- Cant find one anywhere!
- I need help finding....
- keyless remote program with out stock radio?
- help please..
- anyone heard anything about SECA rims?
- 99 si
- jdm climate control
- Increase Sensitivity In My Alarm
- jdm pheen says ..
- Cruise control
- Sliver liquid like stuff on my plugs?
- another a/c question *EJ8 with swap* HELP!
