View Full Version : Honda Civic / Del Sol (1992 - 2000)
- HELP asap car was in hit and run...
- IACV Fried my ECU
- My civic sounds like a suby!
- car does not go into gear
- upper radiator hose route
- JDM red H emblems
- Cel code 21 and 23
- so confused, random codes
- CEL: Code 41.. Primary Oxygen Sensor Heater
- B20Z SETUP?
- si window wiring
- civic slicks
- b18b in ek civic 2 g rev
- NEED HELP!
- Having a problem with my 92 Civic. Need help.
- anyone know????
- jdm d15b smoking
- B18C 2.2L Stroker Build Questions!
- need help with deciding what pistons to get for turbo!
- 92 Civic eg si h2b help
- Can anyone tell me what this is????
- LS/VTEC BUILD HELP
- swap help,opinions, guidance
- Swap guidance
- Best way to remove exhaust manifold studs on '95 ex?
- 1994 Honda Civic Blowing Smoke Burning Antifreeze HELP- Video!
- Auto Trans Question
- Worn shift rod
- 93 civic driver side door panel diagram?
- Frustrated with my 96 Civic LX
- Need a dash wiring Diagram
- Type s or s2k steering wheel in ek?
- will d series linkage fit on b series trans?
- VTEC Stuck On
- 96-98 ex floor harness QUESTION!
- What's needed....
- Upgraded valvebody in 95 ex coupe?
- What auto trans fluid to use?
- Signs/time you need to change tranny fluid?
- 94 EG9 CIVIC 4 DOOR QUESTION
- D16 Injector question
- h23 block w/h22 head
- Civic Side Mirror Fitment
- Gotta a problem with the ECU fuse blowing
- Need help with my SI front end on my EK
- TECH HELP: 93 Civic SI problems starting every after visit to the gas station
- Random vaccum line?
- 92-95 auto tranny to 96-00 questions
- 98 Civic LX - no spark - replaced ICM, still no spark Help!!!
- o2 sensor question (b-swapped eg inside)
- Opinions on F20B swap!
- a lil help
- does anyone know what kind of headlights these are
- shock forks
- What spark plugs should be used when using nitrous?
- :Bored: Freshly painted valve cover
- My Project: 1999 EX Coupe B18C-R Swap
- Fit wheels on an Ek hatch???
- 92 civc hb gsr....need help
- New Struts and Springs
- my carpet is wet ... help please???
- 96 civic domani??
- vtec controller or buy a vtec ecu?
- ls/vtec serious question
- 4-point strut bar question
- Suspension..
- after vacuum test, now i got no spark
- 2000 Honda Civic CX owners with oem harness HELP!
- Honda Part number verfication 2000 Hatch wire harness
- will 98 cx exhaust bolt right up on 95 Si?
- From B series to H series EK Hatch
- 99 EX with rod knock, what bottom end?
- HELP!! HAVING SUSPENSION PROBLEM!!
- 92 civic blinkers won't work
- Fan switch not working for "1" and "2"
- 96 to 97 Civic weight difference uncovered lol
- The Saga Begins
- EK D16 Tranny Mount Question
- No pressure in brake pedal installed new MC and bled brakes
- what head is this??
- still confused b20 gsr tranny
- Si Rear Seats
- H&R Race lowering springs on Tokico HP
- problem with speedometer
- motor mount insert question. whats upper for and whats lower for?
- 94 DX Coupe steering itsself?
- From Canada with Love.
- 2000 bone stock EX,accleration ?
- Vtec help!
- h22 swap in to 94 civic sedan
- loss of power sputtering sound in eg?
- ef springs...
- can't make up my mind, boost the d or ls swap and eventually boost it...
- JUST DYNO'D THE B16 COUPE!!!
- Climate Control problems!!!
- Best looking oem wheel at stock height?? 98 ek
- OEM block plate installed EM1: gasket/leak question
- Drivers side lower than passengers side and camber question
- oil consumption?
- center consol
- 1997 Honda Civic Hatch w/S2000 Cluster
- Stock DX- Jerking & Bucking - Code 7
- 92 civic will not start.
- B16A valve question
- Drivers side sits lower than passenger...WHY?
- leak help
- ABS Civic Type R Lip 99 EK
- weird coolant leak near corner of oil pan(by the crank pulley
- 3 Wire IACV to 2 Wire IACV (96-98 Y7/Y8)
- Forza Car Pack Vote-Off Includes '97 Civic Type R
- Timing Belt / Water Pump? By Head or Block
- Paint color help
- Supertech High Performance Forged Pistons
- WARING!!!!! for people in west seattle area
- D-Series Bottom End ?s
- horrible mileage
- Engine Idle Problem
- how do you adjust the clutch on a eg?
- B17?
- Need new cam any suggestions???
- sr20det question
- WEIRD SMELL IN AC SYSTEM!
- s2k cluster in a eg ?
- I need suspension help for my sol
- 92 hatchback egr valve and sensor
- Car stalled & died out in a flood.
- Which bolts to use for mounting EK power folding mirrors??
- Fitment question about 17x9 +35
- 99-00 Civic Si ARC intake--in a 93 Civic DX?
- z6 question
- front camber kit, blox or "jdm" ebay kit...
- b-series ek exhaust
- master cylinder swap on my Del Sol
- vtec help...
- going from b18 to b20?
- Blox 76mm Throttle Body Sticking Open
- fender clearence
- unusual engine swap
- 1992 civic dx starting problem! HELP ME PLEASE!
- LS Vtech
- prothane motor mount insert...insert problem
- Help! D15Z1 Vtec-E motor in 99 Civic dx
- wtb ek coupe red and clear tail lights
- 99 Civic Brake Issues ! Please Help ASAP
- steering ?
- HOW MUCH IS A TINT TICKET IN NY
- ENGINE SWAP HELP
- Wiring gods and techies. HELP!!! Parking lights hazards dash light ALL OUT at once!
- 02 sensor problem 98 hatch
- iginition sometime sluggish
- B series into Del Sol Pwr steering pump Help
- Common reason for this...
- HELP SRS LIGHT IS ON???
- What caliper will fit on Del Sol
- cel 43 and may have a short
- Gsr leather into a Ej8?
- Rear Integra Suspension..?
- Car stalls in neutral
- Aftermarket steering wheel & retaining cruise control
- looking for some help with a part
- B18b Ecu question
- alternaotr/ speed sensor fuse keeps blowing. wiring nightmare!!!!
- Flywheel Help
- Spark Issue
- 96 has heat instantly!!! help
- Engine acting sporadically!!!
- Wtb 99-00 civic si power steering pump
- Alarm system.
- headlight painting, need help
- What cam should i get????
- Will Type R front lip fit EG Sedan? (NOOB)
- Pricing for EK Sedan Side Skirts [help]
- Serious charging issue, 93 Del Sol
- So we all know bosch plugs are terrible right...?
- Think my head gasket is blown, please help
- B18c Type R EG shift linkage guru's in here!
- wont go into first or second gear
- check engine light
- Small Cam Seal Leak
- b16a2 into eg?
- swaping from b16a3 obd1 longblock to a b16a obd0 longblock a direct swap?
- Rear Conversion For My EG
- HELP! Vtec no more!!
- My 95 boosted EH2
- How do you take off ignition switch?
- Valve stem seal leak question! please help!
- T BRACKET
- **Need help! loud squeak sound when turning the wheel**!!!
- Crank Pulley Bolt Removal Tool
- EG part questions! new to hondatech!
- JDM d15b swap NO START (SEARCHED!) electrical?
- Anyone refinish their SiR's?
- Location of hoa badges
- My New Project!
- HELP
- Throwing CEL code 67. Looking for clarification on correct catalytic converter.
- Sooo many CHOICES!!!
- heating up problem eg 1.3
- will a window from a 93 hatch fit a coupe
- ej1 w a fresh b20 no start need help
- Please Help!!! Swap nightmare
- EM1 --> D16Y8
- Suggestions for Rings?
- 93 civic, wont crank.
- 93 civic si shut off
- Need help from the HONDA masters.....Please help
- sensor plug help
- I WANT AN EG4 VTI GAUGE CLUSTER!!!
- power door conversion
- my wont pass 4000 rpms while driving i need some help
- Civic EG9 GSR problem
- need help with self adjustting screw on brake drums
- Del Sol Front Bumper US Model 97
- Weird starting problems!
- need help on my gsr swap on my eg2
- help with my s2000 antenna for my del sol
- 95 jdm h22 del sol si limp mode need help
- looking for anyone with carfax abilities.
- Blox Stage 3 Cams?
- Clutch Knocking/Grinding
- 5-lugin question
- car build thread :)
- S2000 5 lug on an EK????
- From D15 to B18C Need Guidence...
- Why is my passanger side blinker not working???
- can i replace a d16y8 with a d17a2
- help with b20 swap..
- Weird Exhaust sound...Help!!!
- air induction ideas?
- Easy way to tell if wired for vtec?
- help with removing window trim and mirror 95 coupe
- putting the clutch the wrong way.
- help wiring problem plz
- So I did it and it was a B****
- 93 del sol, Fan speed knob doesn't fit right
- k20a swap
- Del Sol interior door handles are loose
- D16zc ????'s
- shift linkage h22 problems
- Spoon N1 bolt up to HKS B-Pipe?
- Suspension problems??
- civic brake problems, help!
- Keyless entry lock and unlock doesn't work
- part # for the rear licenseplate holder
- lsvtec gsr head oil psi
- TPS issues trying to clear code 7
- burning oil after compression test it turns out good. what now???
- help a girl out picking a car and rims
- freebies
- Water Neck Help Needed ASAP
