View Full Version : Honda Civic / Del Sol (1992 - 2000)
- suspension shops in the bay area?
- b16 swap header ?
- Si sway bar endlinks compatible with ITR?
- Couple clutch changing questions?
- D15 - D16 swap info??
- oil on spark plug, on top of cylindar
- Car making clicking noise when turning!?!
- B18 swap into a EK
- what would it happen to u if u get caught with a stole motor
- help me with firing sequence...
- Just got ARP studs and Nippon headgasket... need help
- WoOt! got my OMNI POWER camber kit! (READ IF YOU DID THE REAR WASHER CAMBER TRICK!!!)
- 93 Civic EX: ABS Problem
- D15B Swapped now sucks bad. Help
- ITR cluster install?
- help code 22
- How to mount din panel in audio console
- focuz header question
- Anyone know where I can get an OEM style REAR lip for a 99-00 Civic COUPE?
- fixing up my engine
- Driver side power window is messed up..HELP!
- *Pic request* Eg with autometer Phantom Tach & Gauges
- yall think its possible
- roll cage a pillar bars
- Converting civic to ABS
- Helms manual?
- Second O2...splice in a simulator...help! OBD2.
- VTEC lag question
- What else should I change while I'm doing suspension and brake work?
- Gauge Trim Removal
- CEL code 1457 on my 2002 Civic LX ..... need help!
- Repair a small dent, how do i go about it????
- Will This Setup Rub?
- Front Swaybar/LCA
- eg with b16a2
- shifter very sloppy
- Ode to the 92-95 Civics (Bought a Civic DX today)
- civic
- Axle Keeps Snapping...I need Help!!!!
- Fuse keeps blowing
- why does my civic fog up so bad?
- Bolt pattern help!!
- what thermostat?
- dirty ass manifold... sea foam???
- HELP! New Car or GSR Swap?
- VSS - transmission specific?
- Yet another "Car won't start" post
- 06 Civic Spy Shot
- Interior light comes on when taking hard left turns. 93 Del sol
- When to get a VAFC?
- The interior of the fron the front doors get wet!!
- Power window switch question?
- where to buy stock gsr muffler
- Vtec Controller on a d16y8
- Picture of a 5spd shifter mount to floor for ek swap
- need help on a part name?
- Motor Mount inserts / Energy Suspension / Del Sol
- For Sale!!!!!!
- 99-00 civic front end conversion on a del sol????
- Wideband / narrowband simulation
- review of fitment, jdm shit ctr style lip
- Bomex Mirrors for '92 Civic ? Where can I find them?
- brake fluid leak between MC/booster- what will fix it
- size of sway bar and spring rate, correlation.
- will this work?
- Need help locating a rear lip...
- swap out my B16 for B18C?
- experience JG soch t/b?
- What seats fit in 95 civic coupe ex?
- B16 hatch eg
- Have you passed smog with Hondata
- need help
- average Weight of Honda's
- USDM integra front end on EG.....??
- Installed Apexi WS II on hatch with S.T. sway bars. Not to friendly.
- Anyone go to University of MIAMI (White EG Hatch with Honda-Tech Sticker)
- Fan Switch compatability?
- quick question about obd2b
- 1.8L?
- engine
- weird acceleration vibration .... need help
- Fuel injector gurus?
- itr rear lca on civic
- car over heating
- Eg front suspension on an EK stripped stud
- What is this engine part???
- Is there a way to remove fuel cut off on a 99 civic?
- VAFC2 Installation problem
- How do I wire 99-00 Civic OEM Fog lights so I can turn them on without the headlights on?
- newbie question
- fun night at ATCO NJ
- quick question.
- Carsponsorships.com??
- power steering pump question.
- how much does your civic weigh thread
- New muffler - offset? center? combo?
- socal area, preferably SB county, what insurance rates?
- 91 Prelude Si disc brakes on civics??
- tein springs on ek9
- measuring how fart o lower coilovers?
- civic VX motor swap question
- 93 Civic HB rear brake conversion to 96 Integra GSR question?
- anyone know whats up with this post...
- Exhaust for Civic CX
- part numbers
- help woth feild vtec controller
- Frame repair/straightening
- Is there an Actual How To: for the Integra Brake Swap?
- civic parts?
- apexi vafc 1
- Ordering cluth and flywheel. Help before I order.
- power steering with type r in 00ek(already searched)
- Question on ECU's
- HELP QUESTION ON TRAILING ARMS?????
- broken knock sensor...
- 2003 civic 5 speed
- Wheel offset for my 92 hatch?
- h22 swap question
- G-N street Performace In littleton Colorado
- Bent brake component, replacement part?
- Headlights? Cleaning
- Adjusting Camber on '95 Civic
- Car Dies when warmed up
- Underdash wiring questions...
- Clutch suggestions
- Dropping the B16 in the 00 SI
- CEL 13 (Atmospheric Pressure) - looked at the self diagnostic...Please help me!
- will buying a b series mount kit........
- installing s2000 cluster into EK
- installing 99-00 center console climate control into 96-98
- srs lights are on & horn doesn't work.
- interior gauge cluster/climate control/buttons lights are dim
- high rev on start up?
- idling problems. HELP!
- Auto trans dipstick leak ?
- O2 Sensor Question?
- 5 lug conversion on del sol
- engine questions?
- B16a Main bearing cap
- how much for a k20a2 swap into a eg?
- help: i have searched auto harness on my manual car
- Could me overfilling the clutch master cylinder reservoir cause it leak?
- Anyone purchased civic SI rims..(the newer ones) and if so how much did you pay?
- Swapped y7 to z6 manifold...all issues fixed but...
- idle problem
- Burning Oil question with lots of detail for a detaled answer!
- Need help with loss of power/missing problem
- seized rotors??
- where to buy longblocks
- 96 Civic Coupe EX power window woes
- is there a difference between ....
- tranny clutch flywheel help???
- dent help removal...
- benen tow hook pic request on black!!!!
- oil stain
- jdm vision test pipe, where from ?
- Looking for Rear black Seats for civic Hatchback
- 95 civic with b18c1 in it not sure what to do next.
- speedometer not working(93 Ex civic)
- 93 civic si w/ integra shifter
- Type R horn Problem
- HELP...possible bad wheel bearing??
- Cat options with D16z6 motor?
- Ej1 trunk lid
- I ran out of gas once and I think that's enough
- HELP!!! My A/C and Heater control lights stay on - when the car is turned off!!!
- crashed my del sol
- Good tranny fluid...Whats your recommendation? (getting slight 3rd gear grind)
- what OBD is my 1994 Del Sol
- Oil Filter Relocation Kit
- engine swap/ecu info
- Thieves Got me
- need a reputable source for a TB pulley + spring.
- '99 Si Cluster into '96 Civic
- Anyone know the quality/fitment of the OEM EK rear lip replicas?
- Door Swap???
- HELP, installing 99 SI dash, and gauge cluster in to 95 hatch
- what honda part # is this bolt/plug? b16a2 motor very important!!
- Best swap for 92-95 hatch
- pic request. Din plate that goes where radio is that holds 3 gauges.
- 97 civic windows
- Quick Question for moldings...
- Blown fan Bearing?
- Brake Swap Questions
- official camshaft review thread
- car sways when braking on highway
- Q: Puttin in a Different Cluster!(DC5 in EK9)
- where i could find h4h hid's
- Is the backlash on the steering rack adjustable?
- 1996-2000 Mini-Me Questions
- Bad fuel pump?injectors?battery?alternator? Please help!
- clutch ???????? please help
- 195/50/16 ok for 16x7 wheel?
- Help on resetting the SRS light please
- when do you need a bigger fuel pump?
- New Apexi n1
- Mugen Twin Loop + rear bumper cover = ...
- Overheating and fan wont work!
- 2.5 inch piping too big???
- Question about o2 sensor.....
- idle fluctuates. when stopped very low- sometimes stalls. Any ideas?
- Question about adding VTEC wiring inside 95 DX wiring harness *PICS*
- Push Button ignition question
- Listen to this song!
- Intake differences
- help with swap
- anyone familiar with new civic motors?
- Considering trading 97 civic ex for 97 accord lx
- Need info on a H22 swap into my '95 civic
- WHERE IS ALL THE 4DR CIVICS OUT THERE!?!?!?
- Oil pump bad?
- Who rides with there struts cranked down??
- system too lean
- little bit crazy, modified supercharger.
- 92-95 Civic Hatch rear interior light
- EG interior light won't work. Wondering if...
- 96 si intake arm and box
- Do I need to lower to get better suspension?
- EG Seat Rail Questions
- Cofused by Helms
- EF hatch Stolen just now, WAUKESHA WISCONSIN
- Engine Swap Question
- help!!
- about engines??
- Tips on cleaning my engine bay?
- 90-93 Integra Cluster into an EG?
- Alternative to civic type r carpet
- Vafc + tuning
- Oil Sending Unit Problems, The Unit Broke Of Partially Threaded In The Block How Can I Fix This
- How Do You Tighten Rear View Mirror On A 2000 Civic??????
- NO more racing on the streets so now what?
- How Much would a used second gen jdm B16a with tranny be sold for?
- y8 Air injection..plug or not?
- Civic with front end damage
- help...no clutch pressure??
- Just thought i would share with all of you nice girls and guys
- rear bearings?
- water leaking in to trunk...help?!
- what # is on a 92-95 ex/si tranny?
- 93 civic hydro to cable conversion
- Intake pipe compatibility?
- jdm p30
- Volk centercap installation?
- Will '90-93 Integra rear strut bar fit '92-95 Civic hatchback?
- vacuum lines
- Fog in my LIGHTS!!!!
- Higher reving?
- Vacuum line diagrams anyone???
- 'Tegra Tranny...
- questions about del sol seats in an eg?
