View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Intake Manifold....BRACKET. Did you keep or ?
- Lug Nuts?
- Tokico illuminas
- Question about Civic Si's?
- 92-95 ex si gauge cluster
- car would not turnover
- DIY D-Series valve lash adjustment BIG PICTURES!
- CA Smog law? simple swap
- finally got pics of my ride
- what cat. to use? B16 in EG
- heating problems,H22 civic help!
- axle nut 32mm socket were do i get it
- bustedshocks.com EH .5 Update (56K all killa no filla)
- sedan w/ coupe bumper
- what clutch to get????
- Dumb Civic thieves
- help! engine spraying gas!
- My EG's debut to H-T (Semi 56k warn)
- Coilover or this....
- DASH BOARD
- Squeeking Noise.... Suspension?
- how much to fix this?
- integra/civic
- cheapest engine mailorder service?
- VX engine harness
- Help! Oil in Spark Plug Cylinder
- brakes locking up on me
- Searched, but had no luck finding those flared fenders for EGs.
- Real quick! Need valve lash specs for a 95 cx. It's not under my hood!
- Apexi Install on SOHC Turbo 98EX W/Intercooler?
- HELP!!!! PLEASE!!!!
- wat kinda oil..
- pic request: eg6 front end with jdm fogs..... or without fogs..
- ***QUICK HELP***GC's with AGX ?****
- damn illinois highway... !!!!
- Civic EK Mirrors Question!
- How do you wire up IAC
- question
- Whats the D seies formus???
- ITR complete rear sway set up for sale
- Tire Thread Direction
- Need advice: swapping del sol seats into my eg hatch.
- ek pillar bar
- Honda Motor Code
- differences in OBD-0 and OBD-1
- crx struts on an eg hatch
- wire keeps sliding out of ecu harness
- pic request: Carbon fiber hood on dark gray civic
- why does my shifter make this noise?
- yes/no GSR rear sway bar on EK?
- sunroof I know you konw the awsner to this Q
- where to buy custom exhaust piping??? stainless steal.... did search...
- Anyone need some Integra Cluster's ??
- Remote starter installation difficulty???
- Integra Seats Fitment?
- Timing cause my car to run like crap?
- 90 crx suspesion on a eg
- D16z6 SOHC Vetec cam gear?
- 94+ integ oe deck into an civic?
- possibilities for no vtec
- fiberglass sub inclosure
- would this hurt performance?
- need help, horrible idle and running rich
- what engine code on 93 si?
- EK Dx -> Ex swap.. PLEASE help
- question about autometer oil pressure gauges
- Detailed diagnostics help!
- I usually don't do this, but...
- interior
- brake conversion question
- post pics of HATCHS
- Electrical Problems---VERY URGENT!
- twisted metal
- not a show kinda guy but im proud of my project
- How do you keep the cam gears from moving while removing their bolts?
- 2nd gen rx-7?
- looking on ebaymotors
- DC Shoes kick ass!!! ?? (tech related)
- USDM Si seats in EK
- civic seat question
- ITR springs?
- Smog/swap questions/laws for people in Oregon.
- amber corners for del sol?
- will a b series clutch fit a d series?
- whos legit out there to buy a full swap B18C5
- help just put new clutch kit in and still no better grabbing
- ECT Sensor Question
- will b pipe fit????????
- Help!! A/C problems!!
- gsr tranny with b16?
- Del Sol Springs...which one to get with a swapped B18B ?.....
- engine bay
- Help : Civic si 92 problem
- Here are some pics I finally got developed of my CF hood from Bodykits NW.
- Will EK sides fit EG Coupe?
- Civic ZC swap questions
- Fr0nt mount intake?
- oil filter ???
- good idea or bad idea (need car buying advice)
- A/C System Install
- I have options...give opinions
- Are these bars worth to buy?
- Steering Wheel Vibrates
- Adding a EX Ecu to a DX Engine
- need some rear lca bushings where can i go???
- NA b18c5....TURBO b18c1
- will an integra exhaust, fit a civic hatch?
- brake fluid leaking out of my drums???
- ** Blown Gasket, motor swap, GO! or NO go? **
- 92-95 civic exhaust / integra????????
- which cams should i go with for my civic?
- skunk2 (and simlar) p28 ecu chip question
- Pics OF my Yellow POS....
- is Z6 alternator same as B7?
- how can i reduce the steering ratio?
- where do i buy paint?
- under dash constant power source
- Rear wiper
- CX FPR Different from EX??
- car stuttering problem, need help!
- Another VAFC Settings Question
- tails from the EG hatch fit EJ coupe?
- *** Last time I'll Buy Anything TANABE ***
- Lowering springs or coilovers on stock shocks
- traded my "hatch"
- what order?
- Front bumper plz
- help help help help help help help!!!!!!
- Disconnecting the axles.
- Primary O2 Sensor
- Suspension Problem
- JG Performer Coilovers
- Yoko ES100s FYI
- Saw Yellow EG6 Hatchback at Fall Church HS basketball court, are you in HT?
- First time at track.....worst 60ft ever?
- just sold my si
- Easy way to rid myself of the speed limiter?
- so i wieghed in the hatch Si....
- anyone know where i can buy thermal wrapping online?
- Having a lot of trouble replacing pads :( (Axxis Ultimates)
- How Do Type R Seats fit in 99 Civic??
- H&R sports on front w/ Neuspeed race on rear +koni reds
- does anybody have a jdm tray to replace passenger airbag..
- EG with BEAKS KIT: which rear-lower tie bars fit ??
- EX ECU in a DX Civic
- b18c running wrong
- what tranny should i use?
- cel code 90 please help
- finally i got ctr lights.... how to: ctr lights and Benen tow hook (56killer)
- 92-95 Greddy Turbo Kit on 99-00.............
- Sorting out the suspension/brakes in a EG with H22a?
- any1 help with a wiring diagram
- 99 bumper on 98 Civic
- opinions about a good muffler?
- 99-00 Si front LCA's required to use Si knuckles?
- Wrecked the sol, going to do a 92-95 civic conversion...
- CX engine in demand
- what the hell is this noise?
- @@ okay need advice on a nused 97 civic ex 2dr
- gsr brake conversion need help
- Best way to tune a D16Z6??
- Best color for a Eg?
- 15 or 16" Wheels. What to choose from???? Help!!
- Finally Pics Of My Car (56K go for it!!!)
- symptoms for the following please
- from ef to ek
- requesting pics of eg's with canards?
- Clicking noise once I hit Vtec...is this normal?
- big brake system
- Wierd thing with Wiring OBD1 dizzy plug to OBD2 harness
- locking up the rear wheels
- Need door panels and carpet for my EG hatch help plz
- Windshied wipers are smeary and not "clean" when it rain.
- Who wants in on a group buy of the best hood you can buy for your del Sol or Civic?
- Spinning wheels with wheel turned
- Who has seen the fake purge kits??????????????????????????????
- Somebody MUST have pics of this civic.
- N1 Exhaust rattling like hell, wtf?
- how do u reset a vafc
- FMU vs. VAFC
- AC acting up in my EK
- SRS Light
- Urethane Fix? Can it be done?
- SRS light on? suggestions?
- quick survey on performing swaps
- Semi-stripped bolt hole in head...fixable or no?
- 92-95 shocks and coilovers on a 99 civic ex
- Brake lights won't work!
- EX CX o2 sensor differences?
- FINALLY GOT A DEL SOL!
- does anyone recommend a good place on the southeast to get usdm b16a2?
- best motor for hatch
- does anyone have a purge kit video?
- need help installing Apex S-AFC
- Need A Car-Fax Please
- What is a code 48?
- what do you guys tihnk about this?
- Will taking my this out of my guage cluster effect my car?
- New JDM fad...
- Sprint seats or integra seats?????
- Is there OEM Leather seats for a Sol?
- some d15b vtec questions.
- which exhaust is best?
- I need help with my tranny
- Wuts the best paint color on a eg for that clean look
- Which cam? Skunk2 Stage 1 or ZEX 59100
- 97 GSR worth it??
- HID questions.
- Looking for pic of eibach pro-kit for EK civics.
- EK hatchs
- What ECU?
- sudden drop in gas mileage?
- Fuel Pump install question on 93 Hatch???
- Fuel Pressure Regulator...which brand to use????
- Need help with these......
- how to remove EK door handles?
- need help! threw the rod bearing, what to do?
- Help, Looking for a Link
- SOHC Cam gears
- Blowing dash light fuses everytime I try and put in Reverse????
- no a/c can i take out radiator on driver side?
- Ctr(modified)or Gsr?
- Greddy SP/Apexi WS Tech Info/ Pic Request
- install on NOS kit? directions/ instructions/ link?
- Opinion ???
- JDM SiR Cluster
- CEL after 5k RPMS?!?! Code 1
- Just how easy do vx wheels crack/break?
- LSD interchangability????
- USDM Type R seats
- Type r rad in a civic?
- CEL #6
- Check out my newly made website!!! civic stuff
- Do 95 Teg Ls Brakes on 92 Hatch Require 15" Wheels?
- Headlight trouble (already tried a search)
- part # for D16Z6 spark plugs?
- eg hatch handles funny
- z6 cam into y8?
- pics of EJ coupes on springs
- ke problemacura ls rotors fit 92 civic si ???
- Recaro seats?
- Windshield protection?
- Did B16a SIRII engines come with "block Girdles"?
- What's the best lubricant to use to quiet down squeaky AC/PS pulleys?
- s-tech or prokit
- Haynes/Helms/? Manual
- want to know what you guys think
- 99 Si Throttle position sensor major HELP!!
- EF died, thinking about an EG. Got some questions.
- i lost my power steering.. dont know whats wrong
