- Rev/rpm problems
- 1998 coupe with Single cam vetch Turbo
- plug
- Rattling Noise
- ESM manual steering rack bushings question
- Proper idle learn procedure
- Del Sol weather strip
- 97 civic lx - coolant leak--- no idea
- 1999 Civic LX sedan - where are the sunroof drain holes?
- EK B16A2 Swap Throttle Cable
- I need a guide please thank u
- head bolts for a b20vtec not arp
- Need help identifying plug
- Urgent! Need help finding hard to find Civic VX manifold!
- TPS and MAP codes need help
- Speedo being weird
- Clutch line to short!? Any suggestion ?
- 2000 civic thermostat ground wires cut
- B18b1 eg hatch wont start after engine install.
- 95 civic hatch dx with a D15b7 want to swap k24?
- 3 Wire IAC Harness to 2 Wire IAC?
- 1993 Honda Civic ex coupe motor swap
- I have a 1997 Honda Civic
- LS-V Swapped Ek fuel pump/Main relay issue
- Converting engine bay to full AN honda shop and k20 forum say one thing pirtek say an
- Hard to shift into gears after replacing clutch master cylinder
- Clutch pedal too stiff
- Front fork shock absorber difference EG EK
- Acceleration issue B16 swap
- T bracket question
- Low fuel light thermistor question
- Check out this cool bracket!
- HELP! Will idle. WONT drive.
- Question? Crank sensor wiring for swap
- reverse lights not coming on
- 1992 Civic VX D15z1
- please can someone put me out of my misery regarding C419 connector
- 95 DelSol vs 95 Civic
- guide on what intake to buy for b20b
- Auto to manual swap (intake manifold) do you need to swap?
- Car popping out of 3rd, and small grind sound when going into 3rd
- 92vx b16a3 swap questions
- reliable b20vtec parts
- oil and power steering sensor wires
- distributor halllp
- Rear disc conversion 95 honda civic dx
- D16y8 manual swap intake and ecu questions
- Em1 way to low
- B16a2 burning oil...ways to help?
- 1995 civic ex d16z6 vtec fouled plugs and diluted oil
- What does this cable do on the HVAC 92-95 civic AC module
- Suspension bushing questions
- Getting rid of Hood Risers on a JDM B18C EG
- Tire and Rim Spec Recommendations 1993 Widebody EG
- Muffler Body Diameter?
- Misfires under load, weird issue
- B20b auto to manual swap no spark?
- Changed the drum hardware now no brakes?
- D16Y7 Trouble
- Wire tuck, wont start. Simple question regarding fuse box
- How To : K24Z7 swap in EG civic. Complete how to!
- I got new wheels off of Facebook marketplace. Need help finding out why they are
- Basset 15x7 wheels with 3in backspacing
- Need a trans swap in arkansas
- Y8 to y7 question
- 93 Civic Ex Coupe - Power-to-Manual Window Conversion
- Crazy TPS readings
- OBD conversion question
- Edelbrock Victor X and stock fuel rail
- Silver touch up paint for dashboard?
- 1993 Honda Civic Hatchback weird electrical problem with radio/cigarette lighter
- Vtec problems after camshafts swap
- Pinch pin
- ALOT of water from exhaust
- 1995 Delsol A/T - Key won't turn to 0 position
- Weird Tapping Noise when Accelerating
- T bracket bolt question
- B20 head need help!! Never saw this before with a honda
- Del Sol Power Lock Switch Location
- P2T immobiliser?
- Civic 99 - Where can i get Fuel Injector Air Assist Control tubes or line
- New Intake Manifold/TB for H22A Civic
- EK Project low RPM
- 99 Sedan tips/info
- Ignition timing.
- Help need tips
- Honda del Sol SiR bad compression test results?
- D14 IM swap (D16z6)
- D16A9 engine mods??
- Mystery interior plastic pieces
- Re: Honda Civic starting problem
- 5 speed crawls through all gears
- 98 civic trans problems
- 95 DelSol D15B7 Series Automatic, Which Motor Mounts
- Targa top censor
- 1999 Honda civic hood issue
- 94 Del Sol LED
- Brake help
- 1999 EX D16Y8 Rod knock or valve lash or?
- Is this from a shift linkage seal
- Gsr Swap in Auto EK
- Am I experiencing chassis flex?
- Abs pump motor relay
- Need to Fix Motor Mounts on 94 Automatic -B Series DelSol-Suggestions(?)
- 93 Civic EX Idle Surge - Fixed
- Engine Swap ej6 B16
- 2000 Civic EX engine vibrations
- EK
- 94 Civic Underhood Decals
- B20 swap in Ek HELPP!!!! PLEASE!!
- 98 ek hatch with b20 fuel pump ?
- Tire questions
- Oil Leak - 95 Del Sol - B16A2
- 93 Civic EX Idle Surge - Possible Fix
- Interior upper trim removal?
- front disk brake backing plate 94 dx hatch
- 97 Civic lx tons of codes all of a sudden
- Strreing wheel crooked while straight? And stabilization
- Will a d15b fit into a 2003 lincoln town car trunk?
- Help passing legal swap and smog
- Suspension Help
- EG radiator drain plug thread pitch
- 94 Del Sol Si speaker question
- 1998 Honda Civic lx auto
- Zc engine questions
- Installing H emblem
- Light and wiper issue
- Del Sol Speakers
- Turn signals
- proportioning valve civic hatch 1994 dx
- part number for resonator/intermediate pipe 94 civic hatch?
- Bad TPS?
- Need help
- Relay amperage under hood ABS
- 1995 Civic ex d16z6 gas diluting engine oil?
- Why does this front end look wrong?
- what gauge wire for taillight eg civic?
- 1995 ex d16z6 timing questions
- Ej6 Hatch K Swap (EK hatch)
- rebuilding an s40 and orientation for shift forks
- Front Parking Lights
- Ex To DX/HX Manual Swap
- 95 Eg hatch D series to b18b1 LS
- EGR Frequency Solenoid Not Working/ Failed SMOG
- Back firing at low rpm in high gear
- 92 Civic Hatch DX problem with fuel pump priming
- Oil in cylinders? (lots of pics + borescNope pics)
- REALLY need help 97 Civic New Stereo NO POWER
- civic front shaking, bad axle likely, need feedback
- Speedo out
- YCP Pistons What Rods?
- D16y7 swap to D15b Questions
- h22 civic problem getting the timing belt right
- Rim tolerances
- Fuel pump didn't help.... 1996 Honda Civic hasn't run in a year :(
- 97 Civic DX Coupe H22 Swap Looking For More Power
- Interior light bulb changed now it’s not working
- Did a search, still confused... B18C1 swap in OBD-2A civic
- 16Y7 1.6L Engine
- Key lock cylinder help!!!!
- Tie rod bumping while NOT turning?
- Cooling fan issue
- 97 Honda civic ex Charging issues
- 00 Civic d15b - 16Pin DLC pinout/wiring?
- red/white tail lights on 98 civic coupe
- 1994 Del Sol transmission
- JDM high comp b20b with grs head on pump e85
- 93 civic hatch Replacement hood isn't lining up correctly
- Motor
- WHAT TAIL LIGHTS WILL FIT A 98 CIVIC SEDAN LX?
- Will a d16 fit in my trunk?
- coolant bleeding help
- 2 Dr and 4 Dr differences
- Fuel Pump not Priming & no Power to ECU
- Coilover recommendations for close to stock height
- Sway bar end links - Honda Civic EK3 (1996)
- Cracked my valve train.. can I JB weld?
- No taillights
- Valve cover removal for timing belt job
- Reoccurring issues after valve adjustment
- I NEED HELP!!! (Main Relay fuse keeps blowing up!)
- Rear drum brakes bent spindle?
- Lx with a sunroof???
- HELP PLEASE intermittent stalling d16y7 in a 94 civic sedan.
- weird electrical 1994 civic hatch
- Anyone know where to buy oem eg si tail lights?
- brake upgrade: the actually difference from dx:ex spindle
- Em1 Charcol canister removal? What problems?
- Checking in before the rebuild (D15Beast7)
- What hose is this?
- Wires please help!!!
- Rear Suspension Replacements?
- Opinion on Suspension
- D16Y8 Seized Camshaft
- 1993 DX hatchback clutch pressure plate advice needed.
- Exhaust leak
- Temp gauge shoots up but my car isn’t overheating
- Tore driver side mount off the chassis
- Clock Spring issues
- Whats the + - on the back of the cluster on the temp for ?
- Integra suspension fit
- wont start, no spark, new distributor
- cheap-o ebay/amazon timing kits?
- Power steering plug to AIT
- Engine cranks but no fuel.
- Bolster wear - seat swap?
- 3500 rev limiter prob
- EM1 rear end whine; fuel pump?
- Automatic Horn
- Timing belt replacement
- Timing belt position.
- Advice please on order placed with Rock Auto
- Fuel tank question
- D15/b8 piston id
- Doors not unlocking
- 96 Civic DX Intake fit into 99 Civic Si?
- gsr swap 2000 civic
- 99 Civic EX b18b1 swap no fuel. Help!
- '00 EX coupe with B16A2 swap
- H23A1 swap into 2000 Honda Civic ex
- Inconsistent Idle
- 95 honda civic wont start
- Wiring a 99-00 Keyless Entry module for a 96-98 Civic
- Brake lights and horn doesn’t work. Please help
- 95 honda civic clutch problems
- D16Y7 Valve Chatter
- Can a Eg 4 dr hood fit an Eg coupe?
- Oil pan gasket -- any preventative maintenance while I've got the oil pan off?
- Diagnosing engine components
- 98 civic in limp mode
- Radio not working
- Would you guys be interested in these for the EGs
- Swapping over DC2 parts onto EM1
- B20b swaps from Honda Orthia have EK friendly brackets stock
- Can someone help me with the Wheel specs
- EG Civic cig lighter charges phone very slowly
- can I run power steering in a k24 swapped ek?
- B20
- What is my car and where is it from help!!
- D Series Clutches/Flywheels
- 2000 Civic -- Issues with low end hesitation
- Oil in coolant
- Radiator Fan Not Starting - 99 Civic EX
- Sunroof Help!
- Can someone explain to me the OBDII smog check in CA now?
- 93 civic VX failed smog. High CO
- 00 civic ex obd1 gsr swap evap solenoid
- Hub Bore
