View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Sway Bars: for 93 Civic Ex
- NJ Help :-X
- Civic/Integra cd player into a 92-95 civic hatch??? Anyone have pics and a write up???
- help with intake
- how much do sparco seats weigh?(used search)
- 5G Civic Si Black Floor Mats
- Del Sol springs on an Si
- del sol si?????
- where to find a manual rack?
- Flywheel question?
- Front Bumper Removal?
- Thermal Stealth & ITR sway...
- JDM front lip Vs SI front lip
- Neuspeed Race springs
- heater hose for gsr swap?
- best way to remove seized bolt?
- To hollow or not to hollow the cat......
- What Kind of Air Compressor Is Everybody Using?
- Should I rely on the gap of pre-gapped spark plugs?
- ECU question
- Is there a difference between stock EX and Si exhaust?
- which ECU for d16y7 motor...OBD2-OBD1
- AEM Pulley?
- just installed mad shit-goin to track tonight!
- What products do you use to clean your car?
- JDM D15b vtec parts? Please help.
- cf short ram question
- Wiring K20A into EG Civic Let's try to really understand how bad of a nightmare, it is.
- Bellingham, WA dyno day
- anyone here have a header tech header on thier daily driver?
- Are all 4 wire O2 sensors the same?
- d16z6 with headwork and cams, can stock bottom end handle 8k redline?
- D16Z6 to B16 conversion
- motor problem with my eg
- Ultimate EG civic Handling?????????????
- 92 Civ VX NGK spark plug stock #?
- Aftermarket steering wheel with cruise.....
- Steering rack ratios 5th Gen and 94-01 Teg
- amber corners?
- Best Swap for a 98 civic 4dr
- HOW TO MAKE B16A1 SWAP TO 92' CIVIC HATCH RUN BETTER
- Blue Magic
- If any is Vancouver I need your assistance big time. I think I'm being scammed and I need someone
- dc header question
- steering column
- Steering Wheel and Horn??
- d16y8 dizzy madness
- Is this valve chatter or and exhaust leak?
- Anyone else running d15?
- Buying body in white?
- Tenzo R Seat Bracket pictures?????
- Is there a pcv valve in a '92 CIV VX?
- 99-00 front si sway bar.
- raybrig HID kit on a civic EK
- how much do you guys think a 97 jdm gsr tranny should go for?
- Usdm vs Jdm ecu??
- type r motor in an eg?
- Ordered B18B. Any fun without turbo?
- ALL DEL SOL PICS HERE!!!
- question h22a or b16a which to choose...?
- Should I trade?
- mugen steering wheel... which momo
- question about ESoval muffler
- help deciding on a new car...
- Color codes on 98 hatch
- eRRRATE B.Cruise Delicious White Chocolate.
- Will Accord struts work on a EG?
- bolt on OBDII cat? *search* didn't help
- show me urs and ill show u mine
- anyone know the color code for this EG??
- OEM Clutch
- setting the idle in a 93 civic hatch
- hard time starting when left in the sun?
- can anyone run a check on this engine
- Will a B18b Fuel Rail fit on a b16a manifold?
- Matrix carbon fiber hoods...anyone use them?
- *** Brake upgrade Question **
- where can you get bigger rotors???
- What do you guys think about these combo's?
- will an itr lca fit on a ek civic
- is this safe???
- 0k fellas tein or eibach springs on a eg????
- what is VTEC-E??
- ATTEN: SoCal peeps do you want free access to Service Manuals??
- Speedometer problem
- If rear wheels have.......ok please help on this one
- EG Audio Console install Help
- Eibach Sportlines too stiff???
- Transmission Disassembly
- Building a D16z6???????????? i need everyones help..PLEASE!!!!
- does anyone have a pic of their cruise control plug on a 98?
- reverse makes a horrible sound...
- Swap Auto LS Motor To Auto Del Sol--What to do????
- LOOK.. FI E/M Fuse blows.....
- steering wheel swap
- FI E/M Fuse keeps blowing.......
- buildong sohc , help
- Swapped b16a2 run's /idles, tough gas motor stalls ??? Need help
- automatic to manual swap.....please help!!!!!!
- will D17A2 fit 93 Civic CX
- Working night shift...thought I would ask a question.
- automatic
- Fuel pump?
- which one would be better in your opinion(wheels)
- Rear discs optional for a 1993 EX Coupe?
- Help with a code 9??? 93 Civic si, completely stock...
- Code 22, Make It Go Away!!!
- problem with clutch pedal after clutch install *please help*
- engine in a 95 dx........what is it??
- Wrecked the civic on thurs. PICS !!! 56k....i dunno know
- 92-95 foglights..4dr fit on 3dr hatch?
- told ya they made a rear del sol lip !
- throwing code 10 or 01?? in 92 VX w/ 94 GSR using vx harness.
- Tow Package
- How much are these fallowing Civic parts? Help!!!
- Brake lines - Teg vs Civic EX
- civic with b16a not performing right
- still having problems
- botched oil changed
- The dreaded Engine question.
- D series headgaskets interchangeable?
- spoon powered mirrors
- less civic HB 95 than others?
- Anything else I should do?
- Best way to fasten Lips ????
- High idle...and knocking sound...???
- Pos engine still not starting
- help b16a1 to 92' civic hatch (eg)
- How much should i expect to pay for aJDM 96-98 ctrheadlights
- Turbo Magazine B20 Civic.......
- need help with auto to manual swap for EG with ITR motor
- b18c intake manifold ?
- Help. Maxima.org resident cant sell honda parts??
- Transmission swap: '93 DX to '97 EX
- problems trying to get warranty work through dealer
- What will the 2004 Civics look like?
- can anyone vouch for b20z??
- ANYBODY Please help me..... I'm begging
- who has a skunk 2 cat back exhaust
- looking for a pair of 97 integra rims
- ECU from critescore.com?? Anybody purchased from them?
- Better performance/Intake
- San Antonio Texas motor swap help
- How long do you think you will own your/a Civic?
- Shops in Nor Cal
- weird clicking noise
- 02 sensor wiring in 96-00 civic
- Windsheld
- lowered my car...but things starts to happen...
- del sol front end on a civic coupe?
- damn gorillas
- How far would you travel....
- What motor oil you use?
- Looking for an A/C Compressor???
- aem v2 question
- dumbass previous owner!! HELP ME DECIDE
- Need d16z6 o2 sensor
- EM2 aftermarket seats???
- What OEM mufflers are you running on your EG?
- Is this real??????
- Oil Filter Relocation Kit
- Need some info on progress suspension.
- AttN: CX64 aka Carlos
- Anyone Know How To Replace Rubber Moldings on the Windshield of an EG?
- ABS light comes on while drving, where do I find the speed sensor?
- Crane or msd ignition systems
- Does anyone know the chassis code for 1985-87 Civics?
- OBDI or OBDII?
- D16A head onto a D15B7 block?!?
- Motor swap??
- 96-00 auto cluster into a 1996 manual dx???
- Swapping out my A/C ... need advice
- Will crv trailing arms?
- what are good auto-man threads on EK
- Flywheels and pistons/rods questions
- First time posting pics of my car.
- More pics of my EK
- Will an RSX muffler fit a '99 Hatch?
- V-TEC ??????
- Exhaust
- 94 Del Sol Si Front and Rear Sway Bars
- GM SYNCHOMESH
- jdm guages help...
- Stock tach/speedo cluster wire
- What are the signs of a differential going out in a B16 tranny????
- Type R or Not???? I Need Answers Quick
- shifter question........?????
- This is a sad attempt. . . .
- INTEGRA RATED SPRINGS
- civic ek itr sway bar setup
- brake pedal goes to the floor, minimal stopping power, help!
- ICM (Ingnitor) keeps burning out
- Rear seat swap, will they fit?
- tranny vin tag question.
- D16Z6 engine beutification
- Blurred License Plates
- 1980 civic?
- rear disc disc breakes
- Upgraded ground cables (earthen grounding)
- gsr si?
- How to tell if alternator is bad or wiring is bad? (searched)
- signs of bad steering rack?!?!
- Door lock broke today(93 hatch).
- what makes a dx heavier
- what the balls.
- New Pics of the Green Meanie and a few others of Achoo and ApexiGSR's wifes car.
- asap!kumho supra 712?
- Pics of h22 turbo in a 98 dx hatch.
- PROJECT b20/vtec motor done, in car, running...but....
- model type
- d16z6 head swap
- Sway Bar Question
- Pics of my b18c1 EK hatch
- 03 civic dx looking for bolt on's
- help cant start the d16
- Testing HID......
- CIVIC LSVTECTURBO V CIVIC GSR TURBO
- EX civic exhaust in a DX civic
- stock radiators and engine swaps
- knock sensor code, how can i check this more?
- got ticket tonight.....
- 2 civics stolen from dallas
- I keep blowing a fuse!
- Please help me identify the Power Steering Pulley???
- How to: Climate Control
- AZENIS-directional or not?
- need info on axles from a 95 civic
- Help, '91 Civic won't start....
- which intake manifold for b18c1??
- brake fluid
- Pics of emissions stuff
- 1997 del sol bumper
- how to tighten crank pulley bolt on automatic SOHC?
- "Brake" it down
- Fuel Tank Size?!?!
- Clanking noise....
- is it slave cylinder or clutch
- Adding a hi-flow cat
- how do you tell if you need to change your fuel filter?
- What MPG should I get on a 92 VX?
- 93 civic fuel filter replacement
- Grinding Tranny
- anyone do a auto to manual swap in an eg hatch???
- Radiator fluid not moving in radiator..Help
- gauge needle tricks, stupid but i need some help
- GSR CAT TO EG ?
- Where to buy? where do i get the peice to put my radio behind the cupholders?
- EK k20a drop in questions???
- Question about assembling motor
- *New eg6 owner joining the boards ATTN: Bcruise
